I have 2 modules that are failing during updates and I do not find that they are needed by any application…lib32-gstreamer0.10-base and lib32.gstreamer0.10. … Can I safely delete these 2 items?
They are not needed by anything basic for running the system. In this way, you can safely remove them.
Check first what cascading effect their removal will have first.
How should I check the cascading problems that might occur?
Look what will be removed.
