Hi there! well first of all I’ve always used GSConnect on Pop OS, or Zorin OS to share my files from my phone to my PC and there is a option call “Mount” that doesn’t work on Manjaro
Someone have a solution for that??
See:
Thanks for the info!! It seems that there is a solution I’m gonna try
Well, let us know what works, I probably need to take a look myself.
It works!!! thanks for the info
you have to put this
Host 192.168..
HostKeyAlgorithms +ssh-rsa
in:
/etc/ssh/ssh_config
and it works when I reboot my PC :3 really thanks so much
