I have my computer connected (via ethernet cable) and my phone (via WIFI) to the same router but I can’t get it to work.
I have done:
sudo ufw allow 1714:1764/udp
sudo ufw allow 1714:1764/tcp
sudo ufw reload
but then noticed an issue with touchegg
So I made sure to systemctl enable --now touchegg That seemed to have been fixed but I generated a support log and noticed some missing libraries so I did sudo pacman-mirrors -f5 && sudo pacman -Syyu libvoikko hspell nuspell hunspell aspell
But it still doesn’t see any devices. I am now stuck.
GSConnect: 50 (system)
GJS:       17001
Session:   x11
OS:        Manjaro Linux
Apr 03 09:55:23 gnome-shell[1289]: cr_parser_new_from_buf: assertion 'a_buf && a_len' failed
Apr 03 09:55:23 gnome-shell[1289]: cr_declaration_parse_list_from_buf: assertion 'parser' failed
Apr 03 09:55:23 gjs[25481]: JS ERROR: Gio.IOErrorEnum: Could not connect to 192.168.1.10: Connection timed out
                            _onIdentity/connection</<@/usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io/service/backends/lan.js:370:40
                            @/usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io/service/daemon.js:727:17
Apr 03 09:55:25 dbus-daemon[1221]: [session uid=1000 pid=1221] Activating service name='org.gnome.ControlCenter.SearchProvider' requested by ':1.21' (uid=1000 pid=1289 comm="/usr/bin/gnome-shell")
Apr 03 09:55:25 dbus-daemon[1221]: [session uid=1000 pid=1221] Activating service name='org.gnome.Nautilus' requested by ':1.21' (uid=1000 pid=1289 comm="/usr/bin/gnome-shell")
Apr 03 09:55:25 dbus-daemon[1221]: [session uid=1000 pid=1221] Activating service name='org.manjaro.pamac.manager' requested by ':1.21' (uid=1000 pid=1289 comm="/usr/bin/gnome-shell")
Apr 03 09:55:25 dbus-daemon[1221]: [session uid=1000 pid=1221] Activating service name='org.gnome.Calculator.SearchProvider' requested by ':1.21' (uid=1000 pid=1289 comm="/usr/bin/gnome-shell")
Apr 03 09:55:25 dbus-daemon[1221]: [session uid=1000 pid=1221] Activating service name='org.gnome.FontManager' requested by ':1.21' (uid=1000 pid=1289 comm="/usr/bin/gnome-shell")
Apr 03 09:55:26 dbus-daemon[1221]: [session uid=1000 pid=1221] Successfully activated service 'org.gnome.ControlCenter.SearchProvider'
Apr 03 09:55:26 dbus-daemon[1221]: [session uid=1000 pid=1221] Successfully activated service 'org.gnome.Nautilus'
Apr 03 09:55:26 dbus-daemon[1221]: [session uid=1000 pid=1221] Successfully activated service 'org.gnome.Calculator.SearchProvider'
Apr 03 09:55:26 nautilus[25527]: Connecting to org.freedesktop.Tracker3.Miner.Files
Apr 03 09:55:26 dbus-daemon[1221]: [session uid=1000 pid=1221] Successfully activated service 'org.gnome.FontManager'
Apr 03 09:55:26 dbus-daemon[1221]: [session uid=1000 pid=1221] Successfully activated service 'org.manjaro.pamac.manager'
Apr 03 09:55:27 /usr/lib/gdm-x-session[1210]: (II) modeset(0): EDID vendor "AUO", prod id 25069
Apr 03 09:55:27 /usr/lib/gdm-x-session[1210]: (II) modeset(0): Printing DDC gathered Modelines:
Apr 03 09:55:27 /usr/lib/gdm-x-session[1210]: (II) modeset(0): Modeline "1920x1080"x0.0  142.00  1920 2028 2076 2100  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
Apr 03 09:55:27 bluetoothd[807]: Failed to set mode: Blocked through rfkill (0x12)
Apr 03 09:55:29 bluetoothd[807]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Apr 03 09:55:30 bluetoothd[807]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Apr 03 09:55:31 bluetoothd[807]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Apr 03 09:55:32 bluetoothd[807]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Apr 03 09:55:33 bluetoothd[807]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Apr 03 09:55:33 rtkit-daemon[941]: Supervising 11 threads of 8 processes of 1 users.
Apr 03 09:55:33 rtkit-daemon[941]: Supervising 11 threads of 8 processes of 1 users.```
