gscan2pdf is starting, but won’t do any scanning for me. The only message I see in the app is “gscan2pdf: must open device before starting scan”.
The scanner IS connected and switched on, but probably not found by the system ?
On the commandline there are these messages:
given is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 179.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 180.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 184.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 189.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 200.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 204.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 208.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 216.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 237.
given is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 615.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 616.
when is deprecated at /usr/share/perl5/vendor_perl/Gtk3/ImageView.pm line 619.
File Info:
gscan2pdf 2.13.4-1 extra
A GUI with OCR capability to produce PDFs or DjVus from scanned documents
what follows is speculation, but not totally out of thin air:
if you have a camera and a scanner, you effectively have two capable devices
and from that it would follow that you’d have to select which one you’d like to use.
In your output, there is no scanner device
(probably USB connected, but I don’t know, of course)
present.
No USB info at all.
Perhaps install a “regular” scanner program to test the basic functionality.
</>gscan2pdf
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 241.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 242.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 249.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 252.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 256.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 257.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 260.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 263.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 389.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 390.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 394.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 398.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 403.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 536.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 537.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 540.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 543.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 546.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 549.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Options.pm line 552.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 123.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 124.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 132.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 133.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 137.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 140.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 143.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 146.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 149.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 152.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 155.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 207.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 213.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 445.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 446.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 492.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 498.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 586.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 587.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 590.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Bboxtree.pm line 594.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 816.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 817.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 827.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 844.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 854.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 860.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2185.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2186.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2189.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2192.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2539.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2540.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2545.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2556.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2568.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2581.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2592.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2603.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2613.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2618.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2631.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2638.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2642.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2646.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2653.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2666.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2672.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2683.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2696.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2702.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2714.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2725.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2730.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2737.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2748.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2761.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2819.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2820.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2831.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2843.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2919.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 2961.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3059.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3060.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3167.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3170.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3270.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3729.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3730.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3733.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3736.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3739.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Document.pm line 3742.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Save.pm line 670.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Save.pm line 671.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Save.pm line 689.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Save.pm line 697.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Save.pm line 710.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Save.pm line 718.
Smartmatch is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Save.pm line 743.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 187.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 188.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 191.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 194.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 202.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 229.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 230.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 233.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 236.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 244.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 294.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Scanner/Profile.pm line 295.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 903.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 904.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 907.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 910.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 914.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 919.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 924.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 934.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 938.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 941.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 945.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 949.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 952.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 964.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 994.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 999.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1013.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1242.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1243.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1246.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1249.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1252.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1255.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1258.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1547.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1550.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1565.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 1583.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 2498.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 2499.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 2509.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 2514.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Dialog/Scan.pm line 2521.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 169.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 173.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 178.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 185.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 191.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 214.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 219.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 230.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 242.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 245.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 248.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 255.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 426.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 427.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 433.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 460.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 463.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 466.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/CLI.pm line 472.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 444.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 445.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 446.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 449.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 453.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 463.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 466.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 470.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Frontend/Image_Sane.pm line 473.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 432.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 433.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 460.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 466.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 479.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 496.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 526.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 527.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 535.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 538.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 541.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 551.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 586.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 587.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 594.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 598.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 610.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Unpaper.pm line 614.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 315.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 316.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 321.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 326.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 331.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 336.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 557.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 558.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 561.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas/Bbox.pm line 565.
given is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas.pm line 152.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas.pm line 153.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas.pm line 164.
when is deprecated at /usr/share/perl5/vendor_perl/Gscan2pdf/Canvas.pm line 168.
given is deprecated at /usr/bin/gscan2pdf line 3051.
when is deprecated at /usr/bin/gscan2pdf line 3052.
when is deprecated at /usr/bin/gscan2pdf line 3117.
when is deprecated at /usr/bin/gscan2pdf line 3162.
when is deprecated at /usr/bin/gscan2pdf line 3190.
when is deprecated at /usr/bin/gscan2pdf line 3215.
when is deprecated at /usr/bin/gscan2pdf line 3240.
when is deprecated at /usr/bin/gscan2pdf line 3267.
when is deprecated at /usr/bin/gscan2pdf line 3292.
given is deprecated at /usr/bin/gscan2pdf line 3330.
when is deprecated at /usr/bin/gscan2pdf line 3331.
when is deprecated at /usr/bin/gscan2pdf line 3334.
when is deprecated at /usr/bin/gscan2pdf line 3337.
when is deprecated at /usr/bin/gscan2pdf line 3340.
when is deprecated at /usr/bin/gscan2pdf line 3343.
when is deprecated at /usr/bin/gscan2pdf line 3346.
when is deprecated at /usr/bin/gscan2pdf line 3356.
libv4l2: error v4l2_set_control called with invalid fd: 15
As I have a great deal of difficulty reading instructions, cutting and pasting seems to be my way of repairing problems with Linux, and has for the 25 years I’ve used Linux. As a 72 year old with ADHD, and PTSD from my Vietnam experience, I do not find it easy.
