I installed Xenlism-Manjaro - Grub2 Theme
on www.gnome-look.org.
When I run sudo bash install.sh
in the folder it says:
* Xenlism-Manjaro - Grub2 Theme *
Checking for root access...
Checking for the existence of themes directory...
Installing Xenlism-Manjaro theme...
Setting Xenlism-Manjaro as default...
Updating grub config...
Initializing grub config files ...
Found theme:/usr/share/grub/themes/Xenlism-Manjaro/theme.txt
Found Linux image:/boot/vmlinuz-linux-surface
Found initrd image:/boot/intel-ucode.img /boot/initramfs-linux-surface.img
Found initrd fallback image: /boot/initramfs-linux-surface-fallback.img
Found Linux image:/boot/vmlinuz-5.8-x86_64
Found initrd image:/boot/intel-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found Windows Boot Manager at /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
/usr/bin/grub-probe:Warning: Unknown device nvme0n1.
Done
* All done! *
But when I reboot it says error and goes into the black and white grub theme.
