Hello all, I’ve been using Manjaro for quite awhile but there’s one problem that I cant seem to fix for a long while. Everytime I update I get an error like this:
[main@main-manjaro ~]$ sudo update-grub
[sudo] password for main:
Generating grub configuration file …
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
error: syntax error.
error: Incorrect command.
Syntax error at line 246
Syntax errors are detected in generated GRUB config file.
Ensure that there are no errors in /etc/default/grub
and /etc/grub.d/* files or please file a bug report with
/boot/grub/grub.cfg.new file attached.
No matter how many times I try to reinstall grub, this keep happening.
