Grub Rescue: No such device Unknown Filesystem
A linux beginner here.
I have a Dell Vostro 3559 with two HDD with Win10, Pop OS and Ubuntu Installed.
I recently Installed Manjaro but after the installation It always boots up to,
error: no such device:
error: unknown filesystem.
Entering rescue mode…
grub rescue>
Here is the output from
sudo parted -l
Model: ATA TOSHIBA MQ01ABD1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 525MB 524MB fat32 EFI system partition boot, esp
2 525MB 660MB 134MB Microsoft reserved partition msftres
3 660MB 305GB 304GB ntfs Basic data partition msftdata
4 305GB 619GB 315GB ntfs Basic data partition msftdata
5 619GB 809GB 190GB ntfs Basic data partition msftdata
6 809GB 901GB 91.4GB ext4 Basic data partition msftdata
9 901GB 963GB 62.9GB ext4
7 986GB 987GB 472MB ntfs hidden, diag
8 987GB 1000GB 13.3GB ntfs hidden, diag
Model: ATA WDC WD5000LPVX-2 (scsi)
Disk /dev/sdb: 500GB
Disk Flags:
1 1049kB 630MB 629MB fat32 boot, esp
2 630MB 68.8GB 68.2GB ext4
3 68.8GB 226GB 157GB ext4
4 226GB 268GB 41.9GB ext4
7 268GB 373GB 105GB ext4
8 373GB 383GB 10.5GB linux-swap(v1) swap, hidden
5 383GB 400GB 16.8GB linux-swap(v1) swap
6 400GB 500GB 100GB ntfs Basic data partition msftdata
Model: TOSHIBA TransMemory (scsi)
Disk /dev/sdc: 7759MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2932MB 2937MB 4194kB primary esp
Manjaro root(/) is installed on the second HDD on 4.
/home on 7.
