Grub requiring downgrade but fails
Im running on testing branch.
Recently I checked for updates in Pamac and it trying to downgrade grub but fails.
Is this a known thing. I couldn’t find anything on the forums.
  Kernel: 6.4.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.4-x86_64
    root=UUID=0d74b82b-d7a6-4487-9b9e-dac090d9210c rw rootflags=subvol=@ quiet
    splash resume=UUID=33dc68e0-8455-4b80-98bc-228b7a4640f5
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
    BIOS: American Megatrends LLC. v: F38e date: 07/18/2023
  Device-1: sony_controller_battery_38:c0:96:9a:d2:51 model: N/A serial: N/A
    charge: N/A status: charging
  System RAM: total: 32 GiB available: 31.26 GiB used: 4.38 GiB (14.0%)
  Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB
    desc: 1x96 MiB
  Speed (MHz): avg: 2258 high: 2800 min/max: 2200/4549 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2267 4: 2200 5: 2307 6: 2209 7: 2361 8: 2200 9: 2200 10: 2207 11: 2200
    12: 2800 13: 2200 14: 2192 15: 2200 16: 2200 bogomips: 108844
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 1002:73bf
    class-ID: 0300
  Device-2: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4:6
    chip-ID: 046d:0826 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
    model: LG (GoldStar) 27GL650F serial: <filter> built: 2019 res: 1920x1080
    hz: 144 dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 609mm (24")
    ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: DP-3 mapped: DisplayPort-2 pos: right
  API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon RX 6800 XT (navi21
    LLVM 15.0.7 DRM 3.52 6.4.7-1-MANJARO) direct-render: Yes
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
  Device-4: Focusrite-Novation Scarlett 2i4 driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4.3:8
    chip-ID: 1235:800a class-ID: fe01
  API: ALSA v: k6.4.7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.4.4:9
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 20.28 TiB used: 3.35 TiB (16.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Sabrent
    model: SB-ROCKET-NVMe4-2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: RKT4B5.1 temp: 33.9 C scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: N/A size: 1.86 TiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 26.9 C scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
  ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> scheme: MBR
  ID-7: /dev/sde maj-min: 8:64 vendor: Western Digital
  ID-8: /dev/sdg maj-min: 8:96 vendor: SanDisk model: USB 3.2Gen1
    size: 232.88 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 434.52 GiB (23.4%)
    fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:3 label: MANJARO
    uuid: 0d74b82b-d7a6-4487-9b9e-dac090d9210c
  ID-2: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
    used: 434.52 GiB (23.4%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:3
    label: MANJARO uuid: 0d74b82b-d7a6-4487-9b9e-dac090d9210c
  ID-3: /run/media/thedatabug/DOCUMENTS raw-size: 5.46 TiB
    size: 5.41 TiB (99.19%) used: 1.25 TiB (23.1%) fs: ext4 dev: /dev/sdc1
    maj-min: 8:33 label: DOCUMENTS uuid: 19263c53-23f2-49ad-99eb-d57e1269cc6b
  ID-4: /run/media/thedatabug/ENTERTAINMENT raw-size: 5.46 TiB
    size: 5.41 TiB (99.19%) used: 1.17 TiB (21.7%) fs: ext4 dev: /dev/sdb1
    maj-min: 8:17 label: ENTERTAINMENT
    uuid: a6d7961b-52de-4738-b12e-a3ef209f61c5
  ID-5: /run/media/thedatabug/GAMING raw-size: 1.86 TiB
    size: 1.83 TiB (98.37%) used: 521.04 GiB (27.8%) fs: ext4 dev: /dev/nvme1n1p1
    maj-min: 259:2 label: GAMING uuid: 8ef8bd2f-dbe6-42b6-aa88-f0cfc3745de6
  ID-6: /var/cache raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
  ID-7: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 5.5 MiB (0.1%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:4 label: swap
    uuid: 33dc68e0-8455-4b80-98bc-228b7a4640f5
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: GARUDA
    uuid: 540a54c6-f85c-4888-ba19-b884f0f92ad4
  ID-2: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: ext4 label: EXTERNAL_HD
    uuid: ff9dd446-ceac-428a-bc4d-89f7199a1a58
  ID-3: /dev/sde1 maj-min: 8:65 size: 1.82 TiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sdg1 maj-min: 8:97 size: 232.87 GiB fs: vfat label: APP STICK
    uuid: 1D57-6408
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-3: 1-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-3.1:5 info: Razer USA Naga Trinity type: mouse,keyboard
    driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0067 class-ID: 0300
    serial: <filter>
  Device-2: 1-3.2:6 info: Microdia Backlit Gaming Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
    chip-ID: 0c45:652f class-ID: 0301
  Device-3: 1-3.3:7 info: HP Photosmart 6520 series
    type: printer,mass storage driver: usb-storage,usblp interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 03f0:af11 class-ID: 0806 serial: <filter>
  Hub-4: 1-3.4:8 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
  Device-1: 1-3.4.4:9 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 1-4:4 info: Integrated Express IT8297 RGB LED Controller
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8297 class-ID: 0301
  Hub-5: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 2-2:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Device-1: 2-2.1:3 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E
    ASM1153 3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1
    rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
  Hub-7: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-3:2 info: Google Nexus/Pixel Device (MTP) type: still imaging
    driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 18d1:4ee1 class-ID: 0601 serial: <filter>
  Device-2: 3-4:6 info: Sony Batoh Device / PlayStation 3 Controller
    type: HID driver: sony,usbhid interfaces: 1 rev: 2.0
    chip-ID: 054c:0268 class-ID: 0300
  Hub-8: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-9: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-11: 5-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 5-2.3:4 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
    vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
  Device-2: 5-2.4:6 info: Logitech HD Webcam C525 type: audio,video
  Hub-12: 5-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-13: 5-4:5 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 5-4.2:7 info: Holtek USB Gaming Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a0f8 class-ID: 0300
  Device-2: 5-4.3:8 info: Focusrite-Novation Scarlett 2i4 type: audio
    driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1235:800a class-ID: fe01
  Hub-14: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-15: 6-2:2 info: Genesys Logic Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-16: 6-3:3 info: Genesys Logic Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
  Device-1: 6-3.2:5 info: SanDisk Ultra Flair type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
    serial: <filter>
  Hub-17: 6-4:4 info: Genesys Logic Hub ports: 4 rev: 3.0
  System Temperatures: cpu: 34.9 C mobo: 27.0 C gpu: amdgpu temp: 31.0 C
    mem: 38.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 426 Uptime: 40m wakeups: 3 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1597 pm: dpkg
  pkgs: 0 pm: pacman pkgs: 1548 libs: 422 tools: pamac,paru,yay pm: flatpak
  pkgs: 49 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.28
…maybe this?
Thank you that did it.
Why was Grub downgraded though?
I really dont know … didnt occur in Unstable. (Or i missed it I guess)
Maybe this explains it?
