I have windows on one SSD and Manjaor on another, plus some additional SSDs for storage.
Initially everything was fine, I had installed Ubuntu and I was able to dual boot just fine. Then i decided I didnt want that and went for Manjaro. And still everything was fine. At some point , trying to debug graphics card issues, I did a clean install of Manjaro and forgot to set the bootloader location and it just chose one of my SSDs.
Then no more grub. I tried a lot of steps but it just was not recognizing windows being anywhere and kept assigning some random drive as having windows .
So i clean installed both windows and Manjaro and no grub anymore, i just tried this refind bootloader and nothing, system just boots into linux. Yes windows is there and it works fine. I have done the grub-update among other commands that do not return anything or have no effect. I have played with boot order in my bios to see if maybe it was on another drive and the only thing that happens is I either boot into linux or windows or nothing…but never a grub menu.
here is some info:
Model: ATA Samsung SSD 870 (scsi)
Disk /dev/sda: 2000GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 106MB 105MB fat32 EFI system partition boot, esp
2 106MB 123MB 16.8MB Microsoft reserved partition msftres
3 123MB 2000GB 2000GB ntfs Basic data partition msftdata
Model: ATA SanDisk SDSSDH3 (scsi)
Disk /dev/sdb: 512GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 512GB 512GB primary ext4 boot
Model: ATA SanDisk SDSSDA12 (scsi)
Disk /dev/sdc: 120GB
Disk Flags:
1 1049kB 120GB 120GB primary ntfs
Model: ATA SAMSUNG SSD 830 (scsi)
Disk /dev/sdd: 128GB
Disk Flags:
1 17.4kB 16.8MB 16.8MB Microsoft reserved partition msftres
2 16.8MB 128GB 128GB ntfs Basic data partition msftdata
Model: ATA WDC WD5000AAKX-7 (scsi)
Disk /dev/sde: 500GB
Disk Flags:
Model: Samsung SSD 970 EVO Plus 2TB (nvme)
Disk /dev/nvme0n1: 2000GB
Disk Flags:
2 16.8MB 2000GB 2000GB ntfs Basic data partition msftdata
EFI variables are not supported on this system.
