Hello everyone
I have posted on the Archlabs forum, but I am trying a two-pronged attack
I currently have Win 10, Manjaro XFCE, EOS-i3 and have just installed Archlabs Openbox on my ASUS laptop after some shenanigans and steep learning curves because my efi partition was full (I ended up having to physically copy its contents to another partition, delete it and then make a bigger one and then copy back the contents since gparted couldn’t sim+ply fill an enlarged efi partition with its contents, no idea why)
I could boot to archlabs but then had to do the following to get Manjaro to boot (I’m really used to having to do this after updating other OS’s, but not exactly sure why I have to do it):
boot up and press ‘c’ at the menu to get to the grub prompt (grub>).
grub> search.file /etc/manjaro-release root grub> configfile /boot/grub/grub.cfg
Then, when booted:
sudo grub-install /dev/sda sudo update-grub
[I think the obove should be posted somewhere predominant as it is invaluable for dualbooting with Manjaro]
However, now everything except Archlabs boots
But I can boot it from the UEFI / BIOS options by selecting it as the first boot option which switches to the Archlabs grub
However, if I access the Archlabs Grub via the UEFI firmware option then only Archlabs and windows boot - not EOS or Manjaro …
Could it be something to do with where efi is mounted?
I noticed for Manjaro it was /boot/efi and for Archlabs it is /boot
I’m stabbing in the dark tho
When I am booted into EOS I have this:
[root@Endeavour boot]# ls
efi initramfs-linux-fallback.img initramfs-linux-lts-fallback.img intel-ucode.img vmlinuz-linux-lts
grub initramfs-linux.img initramfs-linux-lts.img vmlinuz-linux
[root@Endeavour boot]# ls efi
boot-repair BOOTSECT.BAK grub initramfs-linux.img initramfs-linux-lts.img vmlinuz-linux
boot-sav EFI initramfs-linux-fallback.img initramfs-linux-lts-fallback.img intel-ucode.img vmlinuz-linux-lts
[root@Endeavour boot]# ls efi/grub
fonts grub.cfg grubenv locale themes x86_64-efi
[root@Endeavour boot]# ls grub
When I am in Manjaro I have:
[manjaro boot]# ls
efi initramfs-5.15-x86_64-fallback.img linux515-x86_64.kver
grub initramfs-5.15-x86_64.img memtest86+
initramfs-5.10-x86_64-fallback.img intel-ucode.img vmlinuz-5.10-x86_64
initramfs-5.10-x86_64.img linux510-x86_64.kver vmlinuz-5.15-x86_64
[manjaro boot]# ls efi
boot-repair EFI initramfs-linux.img intel-ucode.img
boot-sav grub initramfs-linux-lts-fallback.img vmlinuz-linux
BOOTSECT.BAK initramfs-linux-fallback.img initramfs-linux-lts.img vmlinuz-linux-lts
[manjaro boot]# ls efi/grub
[manjaro boot]# ls grub
fonts grub.cfg.example grub.cfg.pacsave.1 locale unicode.pf2
grub.cfg grub.cfg.pacsave grubenv themes x86_64-efi
When I boot into Archlabs (via setting it as 1st in boot sequence in UEFI / BIOS on laptop) I have:
[root@archlabs boot]# ls
boot-repair grub initramfs-linux-lts.img
boot-sav initramfs-linux-fallback.img intel-ucode.img
BOOTSECT.BAK initramfs-linux.img vmlinuz-linux
EFI initramfs-linux-lts-fallback.img vmlinuz-linux-lts
[root@archlabs boot]# ls grub
by opening the two instances of grub.cfg I can see that:
- The grub folder at /boot/grub is the Manjaro one
- The grub folder at /boot/efi/grub is the Archlabs one
Does this help to explain anything?
As you can see I dont really know what is going on and the Archwiki Efi page hasnt helped me
Could someone explain what the problem could be please?
Thanks
