I have installed in my desktop PC dual boot Windows first Manjaro Linux. After update my grub disappears and boot only from windows. After boot with Manjaro linux Usb live and chroot reinstalled and update grub and i got symbol grub_memcpy not found. I can’t boot anymore neither Manjaro or Linux.
Any help is welcome..
For better understanding of your system please boot into a live ISO, open a terminal and enter
$ sudo blkid
What command did you use to restore the bootloader?
I must say that my desktop PC is dual boot separate SSD Disks with Windows first Manjaro Linux second install and boots with Manjaro grub.
The real problem began after update and grub menu had some Kernels that couldn’t boot my system. Anyway my windows boot were ok! After boot with Manjaro linux Usb live and chroot reinstalled and update grub and with some bad terminal codes i lost Manjaro from grub menu first and Windows boot second and then got
Verifying DMI Pool Data
error: symbol grub_memcpy not found
Entering rescure mode
grub rescue> _
My system is in BIOS/GPT
and my
Partition Table MS DOS
Flags
/dev/sda1 ntfs Δεσμευμένο boot σύστημα boot 50ΜΒ
/dev/sda2 ntfs 232.34GB
/dev/sda3 ntfs 500 MB msftres
unallocated 2.15 MB
/dev/sdb1 ext4 224.43 GB boot
/dev/sdb2 Linux-swap 8.45 GB swap
Unallocated - -
In my second attempt i tried with Manjaro live USB to chroot reinstalled and update grub with
sudo grub-install --force --recheck --no-rs-codes --modules=“part_msdos part_gpt” --target=“i386-pc” /dev/sdb
sudo update-grub
and this detects windows on grub menu but not manjaro but got this error.
ERROR: mkdir /var/lock/dmraid
and when in chroot usb live in terminal give mhwd-kernel -li
return
[manjaro /]# mhwd-kernel -li
Currently running: 6.18.18-1-MANJARO (linux618)
- linux61
- linux612
- linux618
- linux71
[manjaro /]# sudo blkid
/dev/loop1: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/sdb2: UUID="1304d3e6-aa39-46c5-896e-96e26f1f5e56" TYPE="swap" PARTUUID="05afb015-02"
/dev/sdb1: UUID="0a29ac31-78fd-456d-a198-0b9b91b65a28" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="05afb015-01"
/dev/loop2: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/loop0: BLOCK_SIZE="262144" TYPE="squashfs"
/dev/sdc2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="2F81-443B" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdc1: BLOCK_SIZE="2048" UUID="2026-03-27-22-38-48-00" LABEL="MANJARO_XFCE_2604" TYPE="iso9660"
/dev/sda2: BLOCK_SIZE="512" UUID="EE98AC3298ABF76D" TYPE="ntfs" PARTUUID="803c29ab-02"
/dev/sda3: BLOCK_SIZE="512" UUID="CC9AE7AD9AE7926E" TYPE="ntfs" PARTUUID="803c29ab-03"
/dev/sda1: LABEL="M-NM-^TM-NM-5M-OM-^CM-NM-<M-NM-5M-OM-^EM-NM-<M-NM--M-NM-=M-NM-? M-NM-1M-OM-^@M-OM-^L M-OM-^DM-NM-? M-OM-^CM-OM-^MM-OM-^CM-OM-^DM-NM-7M-NM-<M-NM-1" BLOCK_SIZE="512" UUID="BE929C11929BCC71" TYPE="ntfs" PARTUUID="803c29ab-01"
/dev/loop3: BLOCK_SIZE="262144" TYPE="squashfs"
After all i can’t understand why i can’t see manjaro on my grub menu. I suspect maybe is a kernel Conflict with my system, or an ERROR: mkdir /var/lock/dmraid.
I would appreciate your opinion on this!
Please notice we enclose output of commands with three ``` (backticks). I edited this part of your post for demonstration. Please edit the rest of your post accordingly.
This label looks corrupted.
Sorry my bad. Hope this is right
# sudo blkid:
Flags
unallocated 2.15 MB
Unallocated - -
# mhwd-kernel -li
* linux61
* linux612
* linux618
* linux71
Mod edit:- Please avoid consecutive posts. If there are no comments made since your previous post, edit that post instead to include additional content. To respond other members within the same post use the forum @mention feature, or insert a horizontal line (
---) to delineate subtopics in the same post.
Remedied for you. No charge.
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
My idea was that you add missing backticks to your post, not that you create a single post for each output. Actually, we avoid creating consecutive posts, these should be merged to one post. Please read the tutorial of how to post. So, please delete your last 4 posts and instead edit the existing post Grub problem after update can't boot and get this message symbol grub_memcpy not found - #4 by anton74
Notice that you used block quotes (>) that is a single bigger sign and not 3 backticks ```. I edited your post such that you could see how it works ![]()
You say your system is BIOS/GPT. Means not UEFI/GPT, right?
If you boot Windows in BIOS mode which is quite strange as UEFI is Windows standard for quiet a while then I don’t understand why you have an ESP on /dev/sdc2. Maybe I read your system wrong but I don’t see an ESP on the Windows disk.
Mixing to boot in UEFI and BIOS mode is possible as long as you do this from your firmware. If Manjaro is booted in UEFI mode, I woud bet it’s impossible to boot Wndows and vice versa, if Windows is installed in BIOS mode. Grub is pretty fail proof, so maybe it worked somehow in the past. Anyway, it’s not a good approach to mix if you wish to boot both OS via Manjaro’s grub menu. In this case better use one boot mode, only. If you agree, you have to decide what system should be changed. Probably easier is to change Manjaro to BIOS mode, you only need to restore the system AFTER booting the live ISO in BIOS mode, chroot into your system and then restore the boot loader for BIOS mode as given in the wiki.
There also is (or at least was) a “convert GPT” command one can/could use from within Windows, but beware that doing this will likely destroy anything else you have on the disk which isn’t Windows-related. So in that case one would need to reinstall Manjaro (also in (U)EFI mode).
No i was wrong. I boot from Manjaro Usb live and check gparted and my partition table for both SSD drives is Partition Table MS DOS (MBR) same both in Windows and for the Manjaro. Τherefore my system is a BIOS/MBR.
When i boot my pc on startup my Manjaro grub menu appears but detects only Windows and i can boot windows without a problem, but can’t detects Manjaro that’s the problem.
Mod edit: Consecutive posts merged and @mention added.
If there are no intervening replies, please edit your previous post instead to add further information. Cheers! ![]()
I reinstalled grub and got
❯ sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sdb1]
--> mount: [/mnt]
[manjaro /]#
[manjaro /]# grub-install --force --target=i386-pc --recheck --boot-directory=/boot /dev/sdb
Installing for i386-pc platform.
Installation finished. No error reported.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found Windows 10 on /dev/sda1
done
I can’t understand :
first this error with the dmraid and
second the UEFI Firmware Settings.
My system has no UEFI. Νot make sense.
And I can’t see my files on SSD that Manjaro is installed. I see the drive on PC BIOS and on Gparted but not in file manager in Manjaro Live Usb.
Strange!
I think this is the wrong device. You should use the disk where Manjaro is installed, this looks to be /dev/sdc.
Deleted, see post of @dmt.
According to the above sdc is the live USB (that’s why it has an EFI partition) and sdb is the Manjaro SSD.
It’s been a long time since I had a BIOS install, but IIRC (which I might not) grub doesn’t seem to be picking up anything from sdb.
Try reinstalling a kernel from chroot.
pacman -Syu linux71
Are you sure?
inxi -zcv8
Doesn’t let me reinstalled kernel linux71
❯ manjaro-chroot -a
--> mount: [/mnt]
[manjaro /]# pacman -Syu linux71
core is up to date
extra is up to date
multilib is up to date
:: Replace python-py-cpuinfo with extra/python-py-cpuinfo2? [Y/n] y
resolving dependencies...
:: installing audit (4.2.1-1) breaks dependency 'audit=4.1.4' required by lib32-audit
[manjaro /]#
and
[manjaro /]# inxi -zcv8
tty: ttyname error: No such device
Duplicate specification "debug-width|debug-y|debug-zy:i" for option "debug-zy"
Kernel: 7.1.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_XFCE_2610 quiet systemd.show_status=1 splash apparmor=1 security=apparmor
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Console: N/A wm: xfwm Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: EP43-DS3 v: x.x serial: N/A BIOS: Award v: F5
date: 06/19/2008
RAM: total: 3.81 GiB used: 1.55 GiB (40.7%)
Array-1: capacity: 8 GiB note: est. slots: 4 EC: None max-module-size: 2 GiB note: est.
voltage: 5.0
Device-1: A0 size: 2 GiB info: 2048 mib (single-bank speed: 667 MT/s type: Unknown
detail: none bus-width: 64 bits total: 64 bits manufacturer: N/A part-no: N/A serial: N/A
Device-2: A1 size: No Module Installed
Device-3: A2 size: 2 GiB info: 2048 mib (single-bank speed: 667 MT/s type: Unknown
Device-4: A3 size: No Module Installed
Slot: 0 type: PCI PCI status: Available length: Long
Slot: 1 type: PCI PCI status: Available length: Long
Slot: 2 type: PCI PCI status: Available length: Long
Slot: 3 type: PCI PCI status: Available length: Long
Info: model: Intel Core2 Duo E8400 socket: 478 (775) note: check bits: 64 type: MCP
arch: Core Yorkfield family: 6 model-id: 0x17 (23) stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB
L2: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2000 min/max: 2000/3000 base/boost: 3000/4000 scaling: driver: acpi-cpufreq
governor: schedutil volts: 1.0 V ext-clock: 333 MHz cores: 1: 2000 2: 2000 bogomips: 11999
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid cx16 cx8 de
ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht lahf_lm lm mca mce mmx monitor msr mtrr
nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3
syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling; PBRSB-eIBRS: Not
affected; BHI: Not affected
Type: vmscape status: Not affected
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nouveau v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s ports: active: DVI-I-1 empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
Display: server: X.org v: 1.21.1.24 compositor: xfwm driver: X: loaded: nouveau
unloaded: modesetting failed: nvidia alternate: fbdev,nv,vesa gpu: nouveau display-ID: :0.0
Monitor-1: DVI-I-1 model: Samsung SyncMaster serial: <filter> built: 2008 res: 1680x1050
dpi: 90 gamma: 1.2 size: 474x296mm (18.7x11.7") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
Message: GL data unavailable for root.
Device-1: Intel 82801JI HD Audio vendor: Gigabyte GA-EP45-UD3R driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k7.1.8-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.22 running: no
Sound Server-4: PulseAudio v: 17.0-98-gb096 running: no
Sound Server-5: PipeWire v: 1.6.7 running: yes
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 03:00.0
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Local Storage: total: 473.1 GiB used: 197.99 GiB (41.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.88 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 1B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston model: DataTraveler 2.0 size: 7.33 GiB
block-size: physical: 512 B logical: 512 B speed: <unknown> type: N/A serial: <filter> rev: PMAP
Floppy-1: /dev/fd0
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7200A rev: 1.05 dev-links: cdrom
Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
state: running
ID-1: / raw-size: 224.43 GiB size: 219.85 GiB (97.96%) used: 197.99 GiB (90.1%) fs: ext4
block-size: 4096 B dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 0a29ac31-78fd-456d-a198-0b9b91b65a28
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs
label: Δεσμευμένο από το σύστημα uuid: BE929C11929BCC71
ID-2: /dev/sda2 maj-min: 8:2 size: 232.34 GiB fs: ntfs label: N/A uuid: EE98AC3298ABF76D
ID-3: /dev/sda3 maj-min: 8:3 size: 500 MiB fs: ntfs label: N/A uuid: CC9AE7AD9AE7926E
ID-4: /dev/sdb2 maj-min: 8:18 size: 8.45 GiB fs: swap label: N/A
uuid: 1304d3e6-aa39-46c5-896e-96e26f1f5e56
ID-5: /dev/sdc1 maj-min: 8:33 size: 4.79 GiB fs: N/A label: MANJARO_XFCE_2610
uuid: 2026-08-12-08-01-29-00
ID-6: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: N/A label: MISO_EFI uuid: 564B-9737
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Hub-2: 2-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
Hub-3: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
Device-1: 3-1:2 info: Logitech Logi Bolt Receiver type: Keyboard,Mouse,HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c548 class-ID: 0300
Hub-4: 4-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Device-1: 4-4:2 info: Kingston Digital DataTraveler SE9 type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 0951:1665 class-ID: 0806
serial: <filter>
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
Device-1: 5-1:2 info: Keychron Receiver type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 3434:d027 class-ID: 0301
serial: <filter>
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
Hub-7: 7-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
Hub-8: 8-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s chip-ID: 1d6b:0001
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nouveau temp: 39.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 3510
Packages: 2069 pacman: 2050 lib: 497 flatpak: 19
1: https: //mirror.alwyzon.net/manjaro/stable/$repo/$arch
2: https: //mirror.netcologne.de/manjaro/stable/$repo/$arch
3: https: //mirror.vinehost.net/manjaro/stable/$repo/$arch
4: https: //mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
5: https: //mirrors.ft.uam.es/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 226
1: cpu: 100% command: ps pid: 5038 mem: 4.01 MiB (0.1%)
2: cpu: 3.4% command: code3 started by: mousepad pid: 4973 mem: 64.5 MiB (1.6%)
3: cpu: 2.4% command: [kworker/u8:0-events_unbound] pid: 2493 mem: 0.00 MiB (0.0%)
4: cpu: 1.4% command: xorg pid: 1302 mem: 96.5 MiB (2.4%)
5: cpu: 1.1% command: [kworker/u8:6-events_power_efficient] pid: 147 mem: 0.00 MiB (0.0%)
Memory top: 5 of 226
1: mem: 103.9 MiB (2.6%) command: xfwm4 pid: 1493 cpu: 0.8%
2: mem: 96.5 MiB (2.4%) command: xorg pid: 1302 cpu: 1.4%
3: mem: 78.9 MiB (2.0%) command: xfce4-session pid: 1407 cpu: 0.4%
4: mem: 76.3 MiB (1.9%) command: xfdesktop pid: 1586 cpu: 0.3%
5: mem: 67.2 MiB (1.7%) command: blueman-applet started by: python pid: 1777 cpu: 0.1%
Processes: 226 Uptime: 19m wakeups: 0 Init: systemd v: 261 tool: systemctl Compilers:
gcc: 16.1.1 alt: 15 clang: 22.1.6 Client: Unknown Client: systemd inxi: 3.3.13
[manjaro /]#
Windows installed on /dev/sda and Manjaro Linux on /dev/sdb and my system is BIOS/MBR for all two. My grub is installed and update on /dev/sdb.
I’d get rid of that first. It can be reinstalled if anything needs it.
For confirmation:
pacman -Qi lib32-audit
… You may also need to remove lib32-pam and lib32-libcap.
In my case, the latter has nothing depending on it, but check to make sure.
I 've done all you said
[manjaro /]# pacman -Qi lib32-audit
Version : 4.1.4-1
Description : Userspace components of the audit framework
Architecture : x86_64
URL : https://github.com/linux-audit/audit-userspace
Licenses : GPL-2.0-or-later LGPL-2.0-or-later
Groups : None
Provides : libaudit.so=1-32
Depends On : audit=4.1.4 lib32-glibc
Optional Deps : None
Required By : lib32-pam
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 125.60 KiB
Packager : David Runge <dvzrv@archlinux.org>
Build Date : Mon Mar 23 19:09:40 2026
Install Date : Sun Jun 14 23:14:11 2026
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
[manjaro /]# pacman -Qi lib32-pam
Version : 1.7.2-1
Description : Pluggable Authentication Modules
URL : http://linux-pam.org
Licenses : GPL2
Groups : None
Provides : None
Depends On : lib32-audit lib32-libnsl lib32-libtirpc lib32-libxcrypt
lib32-systemd pam
Required By : lib32-libcap
Optional For : None
Replaces : None
Installed Size : 790.88 KiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Sun Jul 5 11:32:26 2026
Install Date : Mon Jul 20 12:13:31 2026
Install Script : No
[manjaro /]# pacman -Qi lib32-libcap
Version : 2.78-1
Description : POSIX 1003.1e capabilities (32-bit)
URL : https://sites.google.com/site/fullycapable/
Licenses : BSD-3-Clause OR GPL-2.0-only
Groups : None
Provides : libcap.so=2-32 libpsx.so=2-32
Depends On : lib32-glibc lib32-pam libcap=2.78
Required By : None
Optional For : None
Replaces : None
Installed Size : 94.52 KiB
Packager : Felix Yan <felixonmars@archlinux.org>
Build Date : Mon Apr 6 20:09:27 2026
Install Date : Sun Jun 14 23:14:16 2026
Install Script : No
[manjaro /]#
and unfortunately the same result
core is up to date
extra is up to date
[manjaro /]#
I would try removing those packages in the reverse order i.e. starting with
pacman -Rns lib32-libcap
.. and doing the same with the others.
I removed those packages with your code and done all of them with once.
[manjaro /]# pacman -Rns lib32-libcap
checking dependencies...
Packages (5) lib32-audit-4.1.4-1 lib32-libnsl-2.0.1-2 lib32-libtirpc-1.3.7-1
lib32-pam-1.7.2-1 lib32-libcap-2.78-1
Total Removed Size: 1.19 MiB
:: Do you want to remove these packages? [Y/n] y
(1/5) removing lib32-libcap [######################] 100%
(2/5) removing lib32-pam [######################] 100%
(3/5) removing lib32-libnsl [######################] 100%
(4/5) removing lib32-libtirpc [######################] 100%
(5/5) removing lib32-audit [######################] 100%
(1/1) Arming ConditionNeedsUpdate...
[manjaro /]#
This let me update the system and install kernel linux71. And then update grub
Found linux image: /boot/vmlinuz-7.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-7.1-x86_64.img
Found linux image: /boot/vmlinuz-6.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.18-x86_64.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.12-x86_64.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
done
[manjaro /]#
Restart. And Voila! That’s it i boot from Manjaro!
Many thanks for all of you! You are all magnificent !
Linux71 is EOL, linux618 is LTS and linux72 is latest stable.
I think to install linux618 kernel because is LTS, but I’m afraid maybe this cause problems. What’s your opinion?
I usually have both - latest LTS and latest stable - installed.
