Story:
I was using Windows, decided to install manjaro and not to delete windows for some time in case of emergency(I have dual boot now). Now, I want to delete windows and use its partition in manjaro.
I made bootable usb(I tried to use imagewriter and dd for that, and also tried rufus) and I want to boot via it and join partitions. But I have a problem, my laptop HP ProBook 455 probook doesn’t use my usb for boot. I changed boot order in BIOS, turned off fast boot and secure boot, nothing helps
So I tried to use that command
sudo update-grub
And I get this output
Generating grub configuration file …
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings …
Root filesystem isn’t btrfs
If you think an error has occurred, please file a bug report at “GitHub - Antynea/grub-btrfs: Include btrfs snapshots at boot options. (Grub menu)”
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
As I understand, all my problems because of this line
but funny thing is, that I don’t have /dev/sda1 partition, I only have /dev/sda which file system is ISO 9660
What am I doing wrong? When I was installing manjaro, I had only windows installed, and it was fine. But now its not working(
I tried to delete partition with my windows, but it didn’t help(but for some reason windows boot is still exists in grub menu)
I tried that too sudo grub-install /dev/sda, output is
Installing for x86_64-efi platform.
Installation finished. No error reported.
it didn’t help
I also tried to use another usb drive, didnt help
Nope that does not compute. If you target a drive like /dev/sda, you always write a MBR and not an EFI file on a EFI partition. Now you messed grub up. Remove /boot/grub and run grub-install correctly again. Take a look here: GRUB/Restore the GRUB Bootloader - Manjaro
I didn’t find something about removing /boot/grub in url you provided, and I just deleted that folder
After that I followed steps that described there
After that command sudo grub-install --force --target=i386-pc --recheck --boot-directory=/boot /dev/sda I get this output
Installing for i386-pc platform.
grub-install: warning: Attempting to install GRUB to a disk with multiple partition labels. This is not supported yet..
grub-install: error: embedding is not possible, but this is required for cross-disk install.
I think it didn’t go well, so after update-grub I get the same error
That’s laptop I got from work.
Windows was installed already
For manjaro installation I used rufus, and I didn’t choose between EFI and MBR, it’s just worked
Now I tried to do the same, it didn’t work.
I tried to create bootable usb from manjaro(using dd, imagewriter) and it didn’t work either
Actually, may be we misunderstood each other? /dev/sda is my usb drive, that I want to use just once, to join partitions
By target you meant drive that system should be installed on or you meant the same thing I described earlier?
Just to make it clear here is output of command lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/loop0
/dev/loop1
/dev/loop2
/dev/loop3
/dev/loop4
/dev/loop5
/dev/loop6
/dev/loop7
/dev/sda dos iso9660
/dev/sda1 dos 0x0 iso9660 Empty
/dev/sda2 dos 0xef EFI (FAT-12/16/32)
/dev/nvme0n1 gpt
/dev/nvme0n1p1 gpt c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat EFI System
/dev/nvme0n1p2 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/nvme0n1p4 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment
/dev/nvme0n1p5 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
It is very obvious that this is not a BIOS installation because A) GPT and B) there is an EFI partition, Manjaro shares this with Windows.
You need to change the root directory (chroot) to the local installation and then install grub. Otherwise you will install grub on the live session. There are tonnes of examples on the forum about that.
The message may be confusing but it is not fatal - unless your system is bricked.
The message will most certainly display if you have a bootable USB device attached to the system while generating a new grub configuration.
First step is to remove that USB device - of course - if you are in live chroot, you cannot do that - then you know the reference it to your boot media - thus - simply ignore the message.
