Grub not showing up in new dualboot system
Hi all,
Not sure if this is the right place to ask this but here goes nothing. I just installed manjaro to my HP laptop alongside windows 10. I’ve tried changing the boot order using both bcdedit and efibootmgr yet to no avail. I was wondering if there were any other methods to try and get my laptop to boot up and recognise manjaro first before windows? thanks in advance :slight_smile:
so open this file lecated here:
sudo nano /etc/default/grub
and edit this line to look like this:
GRUB_TIMEOUT_STYLE=menu
(its the third line from top)
save the file with ctrl+x, update grub:
sudo update-grub
reboot, and the grub menu will be shown, and in there you boot with manjaro
Hi @projec3t, and welcome!
While @brahma’s advice will unhide and make the grub menu visible on boot, I suspect you’ll find this handy as well:
Hope it helps!
