Hello, I installed Fedora 34 (Gnome) in a dual-boot setup of Manjaro KDE and Windows 10. After installation of Fedora, running sudo update-grub in Manjaro gives:
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found Fedora 34 (Workstation Edition) on /dev/sda10
Found Windows Boot Manager on /dev/sda2@/efi/Microsoft/Boot/bootmgfw.efi
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-09-16 20:26:01 | timeshift-btrfs/snapshots/2021-09-16_20-26-01/@
Found snapshot: 2021-09-16 20:09:04 | timeshift-btrfs/snapshots/2021-09-16_20-09-04/@
Found snapshot: 2021-09-16 20:00:02 | timeshift-btrfs/snapshots/2021-09-16_20-00-02/@
Found snapshot: 2021-09-16 05:53:59 | timeshift-btrfs/snapshots/2021-09-16_05-53-59/@
Found snapshot: 2021-09-16 05:27:56 | timeshift-btrfs/snapshots/2021-09-16_05-27-56/@
Found 5 snapshot(s)
done
which is as usual. But after reboot, no Fedora entry in grub!
What is the issue here?
