I’m running the latest version of manjaro that I installed on an SSD where windows had installed its bootloader despite installing the rest of the system on my other HHD (I ******** hate windows so much). I thought this would be ok because I always get a Grub menu at boot any time I install a new distro, but it just boots directly into Manjaro.
I’ve tried updating grub and changing “hidden” to “menu” in the grub config file, but to no avail. Out of ideas here. ty
Welcome to the forum!
You have to run…
sudo update-grub
… after modifying /etc/default/grub
thank you for the welcome!
i cant believe i didn’t try updating grub lol, my bad.
so grub shows up now except it hasn’t detected my windows install so I cant boot into it. Any ideas?
Can you post the output of…
inxi -F
… please?
Note: Type two lines of three bacticks (`) each with an empty line in between them, and paste the output on the empty line. It makes the output more readable for us.
$ inxi -F
Host: acab Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 2347A79 v: ThinkPad T430
serial: <superuser required>
Mobo: LENOVO model: 2347A79 serial: <superuser required> UEFI: LENOVO
v: G1ETC2WW (2.82 ) date: 08/07/2019
ID-1: BAT0 charge: 53.0 Wh condition: 65.3/93.6 Wh (70%)
Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP
L2 cache: 3 MiB
Speed: 1197 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1196
Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Device-2: NVIDIA GF108M [NVS 5400M] driver: N/A
Device-3: Acer Integrated Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.3.4
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel 82579LM Gigabit Network driver: e1000e
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: 28:d2:44:44:09:9d
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi
IF: wlp3s0 state: up mac: 3c:a9:f4:7e:24:bc
Local Storage: total: 585 GiB used: 48.12 GiB (8.2%)
ID-1: /dev/sda vendor: Seagate model: ST9500423AS size: 465.76 GiB
ID-2: /dev/sdb vendor: LITE-ON IT model: LMT-128L9M-11 MSATA 128GB
ID-1: / size: 116.58 GiB used: 48.12 GiB (41.3%) fs: ext4 dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 480 KiB (0.2%) fs: vfat
dev: /dev/sdb1
System Temperatures: cpu: 47.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3768
Processes: 212 Uptime: 26m Memory: 7.6 GiB used: 1.66 GiB (21.8%)
Shell: Bash inxi: 3.3.01
Have you tried…
sudo grub-install && sudo update-grub
Also, this is perhaps an interesting read for you, depending on your situation…
Difficulty: ★★☆☆☆
Dual boot - Step by Step
Target systems
Firmware
Checklist
Windows preparation
Manjaro installation
Revisions
Target systems UEFI
Computers with preinstalled Windows (Windows 10) is computers using UEFI firmware. This guide is a generic guide targeted at UEFI installations.
However some of the guide does apply even if you are using a BIOS/MBR setup.
If you are using a BIOS/MBR (DOS) partition schema watch out for this Skip if using BIOS/MBR
To ensure a …
You can make grub appear holding either Esc , Shift or F8 during boot.
Edit /etc/default/grub
and change to
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=menu
Rebuild your grub.cfg
sudo grub-mkconfig -o /boot/grub/grub.cfg
Reboot
Please, I had to register for this, remove the mac address info from your post(s); I mean, do yourself a favor.
