Is there a way to change the look of the grub menu on KDE build?
Iām currently using this to customize grub
try grub-customizer
Not recommendable, this caused a lot of borked systems in the past - unless you are experienced user and know exactly what you are doing with that tool.
If you think about background image and theming have a look into the arch wiki and change your /etc/default/grub file accordingly:
I did not know that ! I use the grub-customizer on ubuntu-Mint-Debian without any problem! Just to relocate or rename options .
@joeboris
about grub-customizer
this is Grub for ubuntu & cie ,
version Grub is not the same we use 2.04 serie
and they CANT LEARN HOW to boot kernel img and microcode
we use grub ( manjaro ) or grub -vanilla ( from archlinux )
never propose an another solution without any support in case it goes bad
that means you will accept to help on grub rescue ?
