Grub menu not showing UEFI
Hi,
Just installed manjaro with windows dual booting in UEFI and GPT. I can boot from the BIOS menu but when Manjaro is booted, the grub menu is not showing. I don’t think the dual boot is in the way here, just manjaro is concerned. In /etc/default/grub:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
and I did a grub-update.
I list below the /etc/default/grub, /boot/grub/grub.cfg, and the inxi output. What could be the reason ? Thanks.
/etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
set root='hd0,gpt5'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt5 --hint-efi=hd0,gpt5 --hint-baremetal=ahci0,gpt5  d9fd46f8-98cd-49f1-904b-9fbc8ed843e3
else
  search --no-floppy --fs-uuid --set=root d9fd46f8-98cd-49f1-904b-9fbc8ed843e3
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_GB
  insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod ext2
set root='hd0,gpt5'
else
fi
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=menu
  set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
  set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-d9fd46f8-98cd-49f1-904b-9fbc8ed843e3' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt5'
	else
	fi
	linux	/boot/vmlinuz-6.1-x86_64 root=UUID=d9fd46f8-98cd-49f1-904b-9fbc8ed843e3 rw  quiet splash apparmor=1 security=apparmor udev.log_priority=3
	initrd	/boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-d9fd46f8-98cd-49f1-904b-9fbc8ed843e3' {
	menuentry 'Manjaro Linux (Kernel: 6.1.19-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.1.19-1-MANJARO x64-advanced-d9fd46f8-98cd-49f1-904b-9fbc8ed843e3' {
	savedefault
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt5'
		else
		fi
	menuentry 'Manjaro Linux (Kernel: 6.1.19-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.1.19-1-MANJARO x64-fallback-d9fd46f8-98cd-49f1-904b-9fbc8ed843e3' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt5'
		else
		fi
		initrd	/boot/initramfs-6.1-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Boot Manager (on /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-efi-0839-D413' {
	savedefault
	insmod part_gpt
	insmod fat
	set root='hd0,gpt1'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt1 --hint-efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1  0839-D413
	else
	  search --no-floppy --fs-uuid --set=root 0839-D413
	fi
	chainloader /efi/Microsoft/Boot/bootmgfw.efi
if [ "${timeout}" = 0 ]; then
  set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
	fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/41_snapshots-btrfs ###
### END /etc/grub.d/41_snapshots-btrfs ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
    menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
        search --fs-uuid --no-floppy --set=root --hint-bios=hd0,gpt5 --hint-efi=hd0,gpt5 --hint-baremetal=ahci0,gpt5  d9fd46f8-98cd-49f1-904b-9fbc8ed843e3
        linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
### BEGIN /etc/grub.d/60_memtest86+-efi ###
if [ "${grub_platform}" == "efi" ]; then
        if loadfont unicode ; then
            set gfxmode=1024x768,800x600,auto
            set gfxpayload=800x600,1024x768
        fi
        linux /boot/memtest86+/memtest.efi
fi
### END /etc/grub.d/60_memtest86+-efi ###
and inxi output:
  Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 2479AV7 v: ThinkPad L530
  Mobo: LENOVO model: 2479AV7 serial: <superuser required> UEFI: LENOVO
    v: G3ETB5WW(2.75) date: 06/10/2019
  ID-1: BAT0 charge: 5.6 Wh (100.0%) condition: 5.6/56.2 Wh (10.0%) volts: 12.4
    min: 10.8 model: SANYO 45N1001 type: Li-ion serial: <filter> status: full
  RAM: total: 7.59 GiB used: 2.37 GiB (31.3%)
  Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1201 high: 1210 min/max: 1200/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1210 2: 1197 3: 1200
    4: 1197 bogomips: 20760
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
    active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: LVDS-1 model: Seiko Epson 0x3152 built: 2010 res: 1366x768
    hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1366x768
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Centrino Wireless-N 2200 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:0891
    class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp12s0 state: down mac: <filter>
  Local Storage: total: 476.94 GiB used: 130.56 GiB (27.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN512HCHP-000L1
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 5L0Q scheme: GPT
  Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DS8A9SH rev: EL3B
    dev-links: cdrom
  ID-1: / raw-size: 57.62 GiB size: 56.41 GiB (97.91%) used: 10.34 GiB (18.3%)
    fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: d9fd46f8-98cd-49f1-904b-9fbc8ed843e3
  ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
    used: 312 KiB (0.0%) fs: vfat dev: /dev/sda9 maj-min: 8:9 label: N/A
    uuid: 2195-67A5
  ID-3: /home raw-size: 273.44 GiB size: 268.08 GiB (98.04%)
    used: 120.22 GiB (44.8%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: home
    uuid: 4fc1734e-7576-405e-ae09-2e2127ddc05d
  ID-1: swap-1 type: partition size: 7.55 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda8 maj-min: 8:8 label: N/A
    uuid: fec44397-cddc-4e08-9393-8c6d68b3ea04
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 0839-D413
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 39.06 GiB fs: ntfs label: N/A
    uuid: FE3610A6361061C7
  ID-4: /dev/sda4 maj-min: 8:4 size: 537 MiB fs: ntfs label: N/A
    uuid: 2C0AA4060AA3CAE2
  ID-5: /dev/sda6 maj-min: 8:6 size: 97.66 GiB fs: ext4 label: wwwFrench
    uuid: 9f46c562-a877-4fe1-9fb5-4b42d578917a
  Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 3-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 2109:0812 class-ID: 0900
  Device-1: 3-2.2:3 info: IBM NetVista Full Width Keyboard type: Keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 70mA
    chip-ID: 04b3:3025 class-ID: 0301
  Device-2: 3-2.4:4 info: Logitech Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 206 Uptime: 1h 57m wakeups: 1 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1065 pm: pacman pkgs: 1062 libs: 316 tools: pamac pm: flatpak
  pkgs: 0 pm: snap pkgs: 3 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.25
:mag: grub in arch-wiki and forum :artist:
You did change /etc/default/grub, and you also recreated grub.cfg , so it can take effect at next boot. If the grub-menu does not show please try to hit ESC while booting.
You can also use maxi -eg
to collect information about the boot process. This works,
  • when you are in your running system (with CTRL+ALT+F2).
  • And also in a live environment
Try to mount all other partitions, and look if there is another grub.cfg
Actually it is sudo update-grub which is a shortcut for sudo grub-mkconfig /boot/grub/grub.cfg
And actually the entry is there:
Did you type ESC on boot, so that it is viewable?
Thanks for the suggestions. Actually, I reexecuted update-grub and now it works fine so pb solved.
