Grub menu not showing , I have to trigger it manually every time
I have a duel boot [win10-manjaro] i reinstalled manjaro and now grub menu not showing
i have to type this command every time i open my laptop
grub> configfile (hd1,gpt4)/boot/grub/grub.cfg
it gets the job done and takes me to the grub menu but it’s tedious , i guess there is a way not to do this every time.
Note: i get this error thou but it boots up “Error: grub/grubenv not found”
$ sudo fdisk -l
Disk /dev/nvme0n1: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: KBG40ZNS256G NVMe KIOXIA 256GB
Disklabel type: gpt
Disk identifier: ACF42D46-2F57-409E-9B22-AA7856AD65BD
Device             Start       End   Sectors   Size Type
/dev/nvme0n1p1      2048 266691103 266689056 127.2G Microsoft basic data
/dev/nvme0n1p2 266692608 268148735   1456128   711M Windows recovery environment
/dev/nvme0n1p3 268148736 268353535    204800   100M EFI System
/dev/nvme0n1p4 268353536 467591167 199237632    95G Linux filesystem
/dev/nvme0n1p5 467591168 468615167   1024000   500M Microsoft basic data
/dev/nvme0n1p6 468615168 500118158  31502991    15G Linux swap
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10SPZX-75Z
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xcd615b1c
Device     Boot Start        End    Sectors   Size Id Type
/dev/sda1        2048 1953523711 1953521664 931.5G  7 HPFS/NTFS/exFAT
Disk /dev/loop0: 32.09 MiB, 33644544 bytes, 65712 sectors
Disk /dev/loop1: 55.42 MiB, 58114048 bytes, 113504 sectors
Disk /dev/loop2: 65.1 MiB, 68259840 bytes, 133320 sectors
Disk /dev/loop3: 156.04 MiB, 163618816 bytes, 319568 sectors
Disk /dev/loop4: 156.04 MiB, 163614720 bytes, 319560 sectors
Disk /dev/loop5: 32.1 MiB, 33660928 bytes, 65744 sectors
Disk /dev/loop6: 128.29 MiB, 134524928 bytes, 262744 sectors
Disk /dev/loop7: 162.87 MiB, 170778624 bytes, 333552 sectors
$ sudo update-grub
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
It's output will be used to detect bootable binaries on them and create new boot entries.
Found Windows Boot Manager on /dev/nvme0n1p3@/efi/Microsoft/Boot/bootmgfw.efi
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
I’ve red a couple of previous posts and implemented the solutions but i got no where
