hi, after update i find my GRUB menu is freezing and i cant change kernel - if i use keyboard to navigate its freeze and i need reboot PC. If i let to start PC normal - not using GRUB menu - it loads normal Linux and its all working. i try to use live Manjaro iso and fix from it - then i use : sudo manjaro-chroot -a , its say no Manjaro os installed, but i can normal navigate to hard disk, folder where is Manjaro installed. sorry bad English.
Kernel: 6.17.0-rc3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
root=UUID=01888cf6-db0d-44d0-a8e1-138428041e0d rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <filter>
uuid: 57006b9c-66b8-0000-0000-000000000000 BIOS: American Megatrends
v: P10.10 date: 01/24/2024
System RAM: total: 16 GiB available: 15.49 GiB used: 2.24 GiB (14.5%)
Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
(unregistered) size: 8 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-2666C19-8GNT serial: N/A
Slot: 17 type: PCIe gen: 1 status: in use length: short volts: 3.3
bus-ID: 00:00.0
Slot: 18 type: PCIe gen: 2 status: in use length: long volts: 3.3
bus-ID: 00:00.0
Slot: 19 type: PCIe gen: 3 status: in use length: short volts: 3.3
bus-ID: 00:00.0
Info: model: AMD Ryzen 5 5500 socket: AM4 bits: 64 type: MT MCP arch: Zen 3
gen: 3 level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA500012
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2391 min/max: 411/4269 boost: enabled
base/boost: 3600/4250 scaling: driver: amd-pstate-epp governor: performance
volts: 1.4 V ext-clock: 100 MHz cores: 1: 2391 2: 2391 3: 2391 4: 2391
5: 2391 6: 2391 7: 2391 8: 2391 9: 2391 10: 2391 11: 2391 12: 2391
bogomips: 86397
xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
Display: unspecified server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-1 mapped: DisplayPort-0 model: AOC 27G2WG3- serial: <filter>
built: 2023 res: N/A dpi: 82 gamma: 1.2 chroma: red: x: 0.675 y: 0.310
green: x: 0.278 y: 0.655 blue: x: 0.153 y: 0.071 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 20.1.8 DRM 3.64 6.17.0-rc3-2-MANJARO) device-ID: 1002:73ff
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.321 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.2.1-arch1.2
device-ID: 1002:73ff surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
bus-ID: 0c:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0c:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: JBL Quantum 360 Wireless
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 0ecb:2115 class-ID: 0300
API: ALSA v: k6.17.0-rc3-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: n/a (root, process) with:
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp10s0 state: down mac: <filter>
Local Storage: total: 700.51 GiB used: 276.01 GiB (39.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 700
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFMG2.0 temp: 27.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31240GNTD
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 61.3 scheme: GPT
ID-1: / raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
used: 276.01 GiB (57.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 01888cf6-db0d-44d0-a8e1-138428041e0d
ID-2: /home raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-3: /var/cache raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-4: /var/log raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
ID-1: /dev/sda1 maj-min: 8:1 size: 223.57 GiB fs: btrfs label: N/A
uuid: a3d76a1e-1012-475d-a8fe-a4e2f1d25366
Device-1: 1-7:2 info: JBL Quantum 360 Wireless type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
Device-1: 3-1:2 info: SteelSeries ApS Aerox 3 type: mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:1836 class-ID: 0300
Device-2: 3-2:3 info: Turtle Beach Impact 100 Gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 10f5:0652 class-ID: 0300
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 33.0 C mobo: 30.0 C gpu: amdgpu temp: 42.0 C
mem: 44.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 1401 pm: pacman pkgs: 1395 libs: 450 tools: pamac pm: flatpak
pkgs: 6
1: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 335
1: cpu: 100% command: ps pid: 2346 mem: 3.98 MiB (0.0%)
2: cpu: 5.7% command: brave pid: 2129 mem: 253.7 MiB (1.5%)
3: cpu: 5.2% command: brave pid: 1340 mem: 382.3 MiB (2.4%)
4: cpu: 3.4% command: Xorg pid: 728 mem: 91.2 MiB (0.5%)
5: cpu: 2.5% command: brave pid: 1394 mem: 317.7 MiB (2.0%)
Memory top: 5 of 335
1: mem: 439.9 MiB (2.7%) command: plasmashell pid: 900 cpu: 0.5%
2: mem: 382.3 MiB (2.4%) command: brave pid: 1340 cpu: 5.2%
3: mem: 317.7 MiB (2.0%) command: brave pid: 1394 cpu: 2.5%
4: mem: 253.7 MiB (1.5%) command: brave pid: 2129 cpu: 5.7%
5: mem: 238.2 MiB (1.5%) command: konsole pid: 2152 cpu: 0.2%
Processes: 335 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p1 default: Bash
v: 5.3.3 running-in: konsole inxi: 3.3.38
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/sda gpt
/dev/sda1 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 btrfs Linux filesystem
/dev/nvme0n1 dos
/dev/nvme0n1p1 dos 0x83 btrfs Linux
