Hello, Since I installed manjaro I’ve had an input lag in the grub menu that I don’t know how to fix. I’ve seen on multiple forums including this one that the input lag could be due to the resolution being to large for whatever reason. I’ve lowered it to what helped others(1024x768x8) and I’m still having issues. I am dual booting in case that might affect anything. Any recommendations would be greatly appreciated, Thank you!
Here is my grub config file.
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=1024x768x8
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
And Grub Brtfs config file
#!/usr/bin/env bash
GRUB_BTRFS_VERSION=4.12-master-2023-04-28T16:26:00+00:00
# Disable grub-btrfs.
# Default: "false"
#GRUB_BTRFS_DISABLE="true"
# Name appearing in the Grub menu.
# Default: "Use distribution information from /etc/os-release."
#GRUB_BTRFS_SUBMENUNAME="Arch Linux snapshots"
# Custom title.
# Shows/Hides "date" "snapshot" "type" "description" in the Grub menu, custom order available.
# Default: ("date" "snapshot" "type" "description")
#GRUB_BTRFS_TITLE_FORMAT=("date" "snapshot" "type" "description")
# Limit the number of snapshots populated in the GRUB menu.
# Default: "50"
#GRUB_BTRFS_LIMIT="50"
# Sort the found subvolumes by "ogeneration" or "generation" or "path" or "rootid".
# # See Sorting section to https://btrfs.wiki.kernel.org/index.php/Manpage/btrfs-subvolume#SUBCOMMAND
# "-rootid" means list snapshot by new ones first.
# Default: "-rootid"
#GRUB_BTRFS_SUBVOLUME_SORT="+ogen,-gen,path,rootid"
# Show snapshots found during run "grub-mkconfig"
# Default: "true"
#GRUB_BTRFS_SHOW_SNAPSHOTS_FOUND="false"
# Show Total of snapshots found during run "grub-mkconfig"
# Default: "true"
#GRUB_BTRFS_SHOW_TOTAL_SNAPSHOTS_FOUND="true"
# By default, "grub-btrfs" automatically detects most existing kernels.
# If you have one or more custom kernels, you can add them here.
# Default: ("")
#GRUB_BTRFS_NKERNEL=("kernel-custom" "vmlinux-custom")
# By default, "grub-btrfs" automatically detects most existing initramfs.
# If you have one or more custom initramfs, you can add them here.
# Default: ("")
#GRUB_BTRFS_NINIT=("initramfs-custom.img" "initrd-custom.img" "otherinit-custom.gz")
# By default, "grub-btrfs" automatically detects most existing microcodes.
# If you have one or more custom microcodes, you can add them here.
# Default: ("")
#GRUB_BTRFS_CUSTOM_MICROCODE=("custom-ucode.img" "custom-uc.img "custom_ucode.cpio")
# Additonal kernel command line parameters that should be passed to the kernel
# when booting a snapshot.
# For dracut based distros this could be useful to pass "rd.live.overlay.overlayfs=1"
# or "rd.live.overlay.readonly=1" to the Kernel for booting snapshots read only.
# Default: ""
#GRUB_BTRFS_SNAPSHOT_KERNEL_PARAMETERS="rd.live.overlay.overlayfs=1"
# Comma seperated mount options to be used when booting a snapshot.
# They can be defined here as well as in the "/" line inside the respective snapshots'
# "/etc/fstab" files. Mount options found in both places are combined, and this variable
# takes priority over `fstab` entries.
# NB: Do NOT include "subvol=..." or "subvolid=..." here.
# Default: ""
#GRUB_BTRFS_ROOTFLAGS="space_cache,commit=10,norecovery"
# Ignore specific path during run "grub-mkconfig".
# Only exact paths are ignored.
# e.g : if `specific path` = @, only `@` snapshot will be ignored.
# Default: ("@")
GRUB_BTRFS_IGNORE_SPECIFIC_PATH=("@")
# Ignore prefix path during run "grub-mkconfig".
# Any path starting with the specified string will be ignored.
# e.g : if `prefix path` = @, all snapshots beginning with "@/..." will be ignored.
# Default: ("var/lib/docker" "@var/lib/docker" "@/var/lib/docker")
GRUB_BTRFS_IGNORE_PREFIX_PATH=("var/lib/docker" "@var/lib/docker" "@/var/lib/docker")
# Ignore specific type/tag of snapshot during run "grub-mkconfig".
# For snapper:
# Type = single, pre, post.
# For Timeshift:
# Tag = boot, ondemand, hourly, daily, weekly, monthly.
# Default: ("")
#GRUB_BTRFS_IGNORE_SNAPSHOT_TYPE=("")
# Ignore specific description of snapshot during run "grub-mkconfig".
# e.g: timeline
# Default: ("")
#GRUB_BTRFS_IGNORE_SNAPSHOT_DESCRIPTION=("")
# By default "grub-btrfs" automatically detects your boot partition,
# either located at the system root or on a separate partition or in a subvolume,
# Change to "true" if your boot partition isn't detected as separate.
# Default: "false"
#GRUB_BTRFS_OVERRIDE_BOOT_PARTITION_DETECTION="true"
# Location of the folder containing the "grub.cfg" file.
# Might be grub2 on some systems.
# Default: "/boot/grub"
#GRUB_BTRFS_GRUB_DIRNAME="/boot/grub2"
# Location of kernels/initramfs/microcode.
# Use by "grub-btrfs" to detect the boot partition and the location of kernels/initrafms/microcodes.
# Default: "/boot"
#GRUB_BTRFS_BOOT_DIRNAME="/boot"
# Location where grub-btrfs.cfg should be saved.
# Some distributions (like OpenSuSE) store those files at the snapshot directory
# instead of boot. Be aware that this direcory must be available for grub during
# startup of the system.
# Default: $GRUB_BTRFS_GRUB_DIRNAME
#GRUB_BTRFS_GBTRFS_DIRNAME="/boot/grub"
# Location of the directory where Grub searches for the grub-btrfs.cfg file.
# Some distributions (like OpenSuSE) store those file at the snapshot directory
# Default: "\${prefix}" # This is a grub variable that resolves to where grub is
# installed. (like /boot/grub, /boot/efi/grub)
# NOTE: If variables of grub are used here (like ${prefix}) they need to be escaped
# with `\` before the `$`
#GRUB_BTRFS_GBTRFS_SEARCH_DIRNAME="\${prefix}"
# Name/path of grub-mkconfig command, use by "grub-btrfs.service"
# Might be 'grub2-mkconfig' on some systems (Fedora ...)
# Default paths are /sbin:/bin:/usr/sbin:/usr/bin,
# if your path is missing, report it on the upstream project.
# For example, on Fedora : "/sbin/grub2-mkconfig"
# You can use only name or full path.
# Default: grub-mkconfig
#GRUB_BTRFS_MKCONFIG=/usr/bin/grub2-mkconfig
# Name of grub-script-check command, use by "grub-btrfs"
# Might be 'grub2-script-check' on some systems (Fedora ...)
# For example, on Fedora : "grub2-script-check"
# Default: grub-script-check
#GRUB_BTRFS_SCRIPT_CHECK=grub2-script-check
# Path of grub-mkconfig_lib file, use by "grub-btrfs"
# Might be '/usr/share/grub2/grub-mkconfig_lib' on some systems (Opensuse ...)
# Default: /usr/share/grub/grub-mkconfig_lib
#GRUB_BTRFS_MKCONFIG_LIB=/usr/share/grub2/grub-mkconfig_lib
# Password protection management for submenu,snapshots
# Refer to the Grub documentation https://www.gnu.org/software/grub/manual/grub/grub.html#Authentication-and-authorisation
# and this comment https://github.com/Antynea/grub-btrfs/issues/95#issuecomment-682295660
# Add authorized usernames separate by comma (foo,bar)
# When Grub's password protection is enabled, the superuser is authorized by default, it isn't necessary to add it
# Default: ""
#GRUB_BTRFS_PROTECTION_AUTHORIZED_USERS="foo,bar"
# Disable authentication support for submenu of Grub-btrfs only (--unrestricted)
# doesn't work if GRUB_BTRFS_PROTECTION_AUTHORIZED_USERS isn't empty
# Default: "false"
#GRUB_BTRFS_DISABLE_PROTECTION_SUBMENU="true"
