i am in live manjaro environment (i was using manjaro in dual boot with windows 10).
my laptop is not showing the grub menu , it directly boots into the windows 10 OS,
earlier i used below commands to fix the grub and it always worked.
sudo su
mount /dev/sda10 /mnt
mount /dev/sda11 /mnt/boot/efi
cd /mnt
mount -t proc proc /mnt/proc
mount -t sysfs sys /mnt/sys
mount -o bind /dev /mnt/dev
mount -t devpts pts /mnt/dev/pts
chroot /mnt
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
update-grub
exit
exit
reboot
But today , i am stuck in an error ,
after this command grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
its saying
grub-install: unknown filesystem
please let me know if need any more information, please help as soon as possible i am searching the solution for two hours nothing seems to be working…
thanks
While in the live system, did you try force-checking the root file-system? I’m guessing that sda10 is your Manjaro root, ext4?
Out of curiosity, what happens if you pause/interrupt the laptop’s boot screen? How many EFI boot menu entries does it detect and allow you to choose from?
sda10 is my manjaro root directory,
i dont know how to interupt the boot screen,
i have two efi menu entries, windows 10 and manjaro
but it directly boots into the windows OS without showing me the grub menu
Okay, to clarify you mean that if you select the “manjaro” option under your laptop’s EFI boot entries, it immediately boots into Windows 10 without a Grub menu delay?
Interrupt the boot process as in holding down a particular key to override the boot options. (Different for each computer. It could be F1, F2, F9, F10, F12, ESC, DEL, etc.)
So manually overriding the boot selection and specifically choosing “manjaro” instead of “Windows”, it seems to just skip the Grub menu? or do you mean recently there is no longer a “manjaro” entry for your EFI boot options?
I noticed you didn’t specify the device in your grub-install command. I’m going to try something out on my own Manjaro box.
So the EFI entry is missing. Can you try again, this time specifying the device in your grub-install command? I’m not entirely sure of your layout or system, but what if you manually specify /dev/sda at the end of the command?
can you please provide the complete command , i am new in linux…i may destroy it…
and i want to ask should i start from the start or just enter this command provided by you.
You append /dev/sda to the end of the command, assuming this is your HDD/SSD drive.
But I need to test this to be safe. There was a recent change to Grub’s defaults that removes the OS-prober, which will remove the Grub entry for Windows 10.
Next, rather than manually chroot in a clean live session (with all those commands), use the built-in “manjaro-chroot -a” command:
manjaro-chroot -a
Once inside, retry grub-install /dev/sda with the -v flag for a verbose output, that might hint to the problem:
grub-install -v /dev/sda
And finally update the menu:
update-grub
Now exit and reboot.
When I tested this on my own dual-boot setup, it worked fine, and I didn’t need to supply any extra options. The above command, grub-install is able to automatically detect the proper directories and files within a chroot environment.
[manjaro-gnome /]# grub-install -v /dev/sda
grub-install: info: executing modprobe efivarfs 2>/dev/null.
grub-install: info: Looking for /sys/firmware/efi ...
grub-install: info: ...found.
Installing for x86_64-efi platform.
grub-install: info: cannot open `/boot/grub/device.map': No such file or directory.
grub-install: info: /dev/sda11 is not present.
grub-install: info: Looking for /dev/sda11.
grub-install: info: /dev/sda is a parent of /dev/sda11.
grub-install: info: /dev/sda11 starts from 313321472.
grub-install: info: opening the device hostdisk//dev/sda.
grub-install: info: drive = 0.
grub-install: info: the size of hostdisk//dev/sda is 1953525168.
grub-install: info: Scanning for DISKFILTER devices on disk hostdisk//dev/sda.
grub-install: info: Scanning for mdraid1x devices on disk hostdisk//dev/sda.
grub-install: info: Scanning for mdraid09_be devices on disk hostdisk//dev/sda.
grub-install: info: Scanning for mdraid09 devices on disk hostdisk//dev/sda.
grub-install: info: Scanning for dmraid_nv devices on disk hostdisk//dev/sda.
grub-install: info: Scanning for ldm devices on disk hostdisk//dev/sda.
grub-install: info: scanning hostdisk//dev/sda for LDM.
grub-install: info: no LDM signature found.
grub-install: info: Scanning for lvm devices on disk hostdisk//dev/sda.
grub-install: info: no LVM signature found.
grub-install: info: Partition 0 starts from 2048.
grub-install: info: Partition 1 starts from 923648.
grub-install: info: Partition 2 starts from 1128448.
grub-install: info: Partition 3 starts from 1411072.
grub-install: info: Partition 4 starts from 311629824.
grub-install: info: Partition 5 starts from 315121664.
grub-install: info: Partition 6 starts from 1134321664.
grub-install: info: Partition 7 starts from 1827694592.
grub-install: info: Partition 8 starts from 1023320064.
grub-install: info: Partition 9 starts from 1029611520.
grub-install: info: Partition 10 starts from 313321472.
grub-install: info: /dev/sda11 is present.
grub-install: error: unknown filesystem.
