Grub hidden menu still visible
Hi,
Looking for advice to get Grub hidden menu working.
After applying dec. 30th Manjaro update, I had to replace grub-vanilla with regular grub, but I could not get either GRUB hidden menu working again nor the bootsplash manjaro theme.
I’ve found this solution:
How to hide GRUB menu ? when - #11 by GokuSan
But I find rather risky to modify /etc/grub.d/30_os-prober
Digging in the archived forum, the official announce message from 2018-10-28 give details how to get hidden grub (i.e.: Changes made to grub package):
Maybe some packages have changed since 2018, and I wonder if this method it is still valid in 2021 ?
Any advices are welcome
Here is my actual grub
 GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 quiet i915.fastboot=1     bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash resume=UUID=a355129c-bb09-4c91-ba94-ca2672911212"
GRUB_CMDLINE_LINUX=
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT="true"
You don’t have the entry:
in your grub, under the GRUB_TIMEOUT … you will have to run
sudo update-grub
after you add it, but if you have other installations detected then the menu will be shown anyway.
Thank you for your reply
Well, but it is present a bit lower in the grub text file
And I already try many times, always show each boot.
But it is true that I have another Ubuntu partition on my SSD, maybe it block the hidden function. Nevertheless, it was working fine with vanilla-grub
¯\__(ツ)_/¯
Impossible to bypass the grub menu, even if I apply all the command lines from Oct. 28th 2018 message above.
I wonder if I should keep quiet in GRUB_CMDLINE_LINUX_DEFAULT line of /etc/default/grub ?
Instructions to get Grub hidden menu say to keep it, but Bootsplash needs to remove it.
I managed to make bootsplash working as describe in the archived forum here:
Anyway, with and without quiet, result is the same: grub is always present.
Edit: I finally edit the file here /etc/grub.d/30_os-prober and change menu in hidden
set timeout_style=hidden
And grub is hidden now!
Perhaps it could be managed with os-prober?
Edit#2: had to modify again /etc/grub.d/30_os-prober after last february update. this is not very convenient
