There is no rush:
#! /bin/sh set -e # grub-mkconfig helper script. # Copyright (C) 2006,2007,2008,2009,2010 Free Software Foundation, Inc. # # GRUB is free software: you can redistribute it and/or modify # it under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # GRUB is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details. # # You should have received a copy of the GNU General Public License # along with GRUB. If not, see <http://www.gnu.org/licenses/>. prefix="/usr" exec_prefix="/usr" datarootdir="/usr/share" quiet_boot="1" . "$pkgdatadir/grub-mkconfig_lib" export TEXTDOMAIN=grub export TEXTDOMAINDIR="${datarootdir}/locale" CLASS="--class gnu-linux --class gnu --class os"
if [ "x${GRUB_DISTRIBUTOR}" = "x" ] ; then
OS=Linux
else
OS="${GRUB_DISTRIBUTOR} Linux"
CLASS="--class $(echo ${GRUB_DISTRIBUTOR} | tr 'A-Z' 'a-z' | cut -d' ' -f1|LC_ALL=C sed 's,[^[:alnum:]_],_,g') ${CLASS}"
fi
# loop-AES arranges things so that /dev/loop/X can be our root device, but# the initrds that Linux uses don't like that.
case ${GRUB_DEVICE} in
/dev/loop/*|/dev/loop[0-9])
GRUB_DEVICE=`losetup ${GRUB_DEVICE} | sed -e "s/^[^(]*(\([^)]\+\)).*/\1/"`
esac
if [ "x${GRUB_CMDLINE_LINUX_RECOVERY}" = "x" ] ; then
GRUB_CMDLINE_LINUX_RECOVERY=single
fi
# Default to disabling partition uuid support to maintian compatibility with
# older kernels.
GRUB_DISABLE_LINUX_PARTUUID=${GRUB_DISABLE_LINUX_PARTUUID-true}
# btrfs may reside on multiple devices. We cannot pass them as value of root= parameter
# and mounting btrfs requires user space scanning, so force UUID in this case.
if ( [ "x${GRUB_DEVICE_UUID}" = "x" ] && [ "x${GRUB_DEVICE_PARTUUID}" = "x" ] ) \
|| ( [ "x${GRUB_DISABLE_LINUX_UUID}" = "xtrue" ] \
&& [ "x${GRUB_DISABLE_LINUX_PARTUUID}" = "xtrue" ] ) \
|| ( ! test -e "/dev/disk/by-uuid/${GRUB_DEVICE_UUID}" \
&& ! test -e "/dev/disk/by-partuuid/${GRUB_DEVICE_PARTUUID}" ) \
|| ( test -e "${GRUB_DEVICE}" && uses_abstraction "${GRUB_DEVICE}" lvm ); then
LINUX_ROOT_DEVICE=${GRUB_DEVICE}
elif [ "x${GRUB_DEVICE_UUID}" = "x" ] \
|| [ "x${GRUB_DISABLE_LINUX_UUID}" = "xtrue" ]; then
LINUX_ROOT_DEVICE=PARTUUID=${GRUB_DEVICE_PARTUUID}
else
LINUX_ROOT_DEVICE=UUID=${GRUB_DEVICE_UUID}
fi
case x"$GRUB_FS" in
xbtrfs)
rootsubvol="`make_system_path_relative_to_its_root /`"
rootsubvol="${rootsubvol#/}"
if [ "x${rootsubvol}" != x ]; then
GRUB_CMDLINE_LINUX="rootflags=subvol=${rootsubvol} ${GRUB_CMDLINE_LINUX}"
fi;;
xzfs)
rpool=`${grub_probe} --device ${GRUB_DEVICE} --target=fs_label 2>/dev/null || true`
bootfs="`make_system_path_relative_to_its_root / | sed -e "s,@$,,"`"
LINUX_ROOT_DEVICE="ZFS=${rpool}${bootfs%/}"
esac
title_correction_code=
linux_entry ()
os="$1"
version="$2"
type="$3"
args="$4"
if [ -z "$boot_device_id" ]; then
boot_device_id="$(grub_get_device_id "${GRUB_DEVICE}")"
fi
if [ x$type != xsimple ] ; then
case $type in
recovery)
title="$(gettext_printf "%s (Kernel: %s - recovery mode)" "${os}" "${version}")" ;;
fallback)
title="$(gettext_printf "%s (Kernel: %s - fallback initramfs)" "${os}" "${version}")" ;;
title="$(gettext_printf "%s (Kernel: %s)" "${os}" "${version}")" ;;
esac
if [ x"$title" = x"$GRUB_ACTUAL_DEFAULT" ] || [ x"Previous Linux versions>$title" = x"$GRUB_ACTUAL_DEFAULT" ]; then
replacement_title="$(echo "Advanced options for ${OS}" | sed 's,>,>>,g')>$(echo "$title" | sed 's,>,>>,g')"
quoted="$(echo "$GRUB_ACTUAL_DEFAULT" | grub_quote)"
title_correction_code="${title_correction_code}if [ \"x\$default\" = '$quoted' ]; then default='$(echo "$replacement_title" | grub_quote)'; fi;"
grub_warn "$(gettext_printf "Please don't use old title \`%s' for GRUB_DEFAULT, use \`%s' (for versions before 2.00) or \`%s' (for 2.00 or later)" "$GRUB_ACTUAL_DEFAULT" "$replacement_title" "gnulinux-advanced-$boot_device_id>gnulinux-$version-$type-$boot_device_id")"
fi
echo "menuentry '$(echo "$title" | grub_quote)' ${CLASS} \$menuentry_id_option 'gnulinux-$version-$type-$boot_device_id' {" | sed "s/^/$submenu_indentation/"
else
echo "menuentry '$(echo "$os" | grub_quote)' ${CLASS} \$menuentry_id_option 'gnulinux-simple-$boot_device_id' {" | sed "s/^/$submenu_indentation/"
fi
if [ x$type != xrecovery ] && [ x$type != xfallback ] ; then
save_default_entry | grub_add_tab
fi
# Use ELILO's generic "efifb" when it's known to be available.
# FIXME: We need an interface to select vesafb in case efifb can't be used.
if [ "x$GRUB_GFXPAYLOAD_LINUX" = x ]; then
echo "load_video" | sed "s/^/$submenu_indentation/"
if grep -qx "CONFIG_FB_EFI=y" "${config}" 2> /dev/null \
&& grep -qx "CONFIG_VT_HW_CONSOLE_BINDING=y" "${config}" 2> /dev/null; then
echo "set gfxpayload=keep" | sed "s/^/$submenu_indentation/"
fi
else
if [ "x$GRUB_GFXPAYLOAD_LINUX" != xtext ]; then
fi
echo "set gfxpayload=$GRUB_GFXPAYLOAD_LINUX" | sed "s/^/$submenu_indentation/"
fi
echo "insmod gzio" | sed "s/^/$submenu_indentation/"
if [ x$dirname = x/ ]; then
if [ -z "${prepare_root_cache}" ]; then
prepare_root_cache="$(prepare_grub_to_access_device ${GRUB_DEVICE} | grub_add_tab)"
fi
printf '%s\n' "${prepare_root_cache}" | sed "s/^/$submenu_indentation/"
else
if [ -z "${prepare_boot_cache}" ]; then
prepare_boot_cache="$(prepare_grub_to_access_device ${GRUB_DEVICE_BOOT} | grub_add_tab)"
fi
printf '%s\n' "${prepare_boot_cache}" | sed "s/^/$submenu_indentation/"
fi
if [ "x${GRUB_ROOT_FS_RO}" = "xtrue" ]; then
grub_root_fs_mode=ro
else
grub_root_fs_mode=rw
fi
if [ x"$quiet_boot" = x0 ]; then
message="$(gettext_printf "Loading Linux %s ..." "${version}")"
sed "s/^/$submenu_indentation/" << EOF
echo'$(echo "$message" | grub_quote)'
EOF
fi
linux${rel_dirname}/${basename} root=${linux_root_device_thisversion} ${grub_root_fs_mode} ${args}
EOF
if test -n "${initrd}" ; then
# TRANSLATORS: ramdisk isn't identifier. Should be translated.
message="$(gettext_printf "Loading initial ramdisk ...")"
initrd_path=
for i in ${initrd}; do
initrd_path="${initrd_path} ${rel_dirname}/${i}"
done
EOF
fi
initrd$(echo $initrd_path)
EOF
fi
EOF
machine=`uname -m`
case "x$machine" in
xi?86 | xx86_64)
list=
for i in /boot/vmlinuz-* /vmlinuz-* /boot/kernel-* ; do
if grub_file_is_not_garbage "$i" ; then list="$list $i" ; fi
done ;;
list=
for i in /boot/vmlinuz-* /boot/vmlinux-* /vmlinuz-* /vmlinux-* /boot/kernel-* ; do
done ;;
esac
case "x$machine" in
aarch64)
list=
for i in /boot/vmlinuz-* /vmlinuz-* /boot/kernel-* /boot/Image ; do
done ;;
list=
for i in /boot/vmlinuz-* /boot/vmlinux-* /vmlinuz-* /vmlinux-* /boot/kernel-* /boot/Image ; do
done ;;
esac
case "$machine" in
i?86) GENKERNEL_ARCH="x86" ;;
mips|mips64) GENKERNEL_ARCH="mips" ;;
mipsel|mips64el) GENKERNEL_ARCH="mipsel" ;;
arm*) GENKERNEL_ARCH="arm" ;;
*) GENKERNEL_ARCH="$machine" ;;
esac
prepare_boot_cache=
prepare_root_cache=
boot_device_id=
# Extra indentation to add to menu entries in a submenu. We're not in a submenu
# yet, so it's empty. In a submenu it will be equal to '\t' (one tab).
submenu_indentation=""
is_top_level=true
while [ "x$list" != "x" ] ; do
linux=`version_find_latest $list`
gettext_printf "Found linux image: %s\n" "$linux" >&2
basename=`basename $linux`
dirname=`dirname $linux`
rel_dirname=`make_system_path_relative_to_its_root $dirname`
version=`echo $basename | sed -e "s,^[^0-9]*-,,g"`
alt_version=`echo $version | sed -e "s,\.old$,,g"`
linux_root_device_thisversion="${LINUX_ROOT_DEVICE}"
if test -e "/etc/manjaro-release" ; then
kbasename="`echo "${basename}" | sed -e 's,vmlinuz-,linux,g'`"
if test -e "${dirname}/${kbasename}.kver" ; then
version="$(cat ${dirname}/${kbasename}.kver)"
fi
kbasename2="`echo "${basename}" | sed -e 's,vmlinuz-,linux-,g'`"
if test -e "${dirname}/${kbasename2}.kver" ; then
version="$(cat ${dirname}/${kbasename2}.kver)"
fi
kbasename3="`echo "${basename}" | sed -e 's,vmlinuz-,linux,g' | sed -e 's,\.,,g'`"
if test -e "${dirname}/${kbasename3}.kver" ; then
version="$(cat ${dirname}/${kbasename3}.kver)"
fi
kbasename4="`echo "${basename}" | sed -e 's,vmlinuz-,linux-,g' | sed -e 's,\.,,g'`"
if test -e "${dirname}/${kbasename4}.kver" ; then
version="$(cat ${dirname}/${kbasename4}.kver)"
fi
fi
initrd_early=
for i in ${GRUB_EARLY_INITRD_LINUX_STOCK} \
${GRUB_EARLY_INITRD_LINUX_CUSTOM}; do
if test -e "${dirname}/${i}" ; then
initrd_early="${initrd_early} ${i}"
fi
done
initrd_real=
initramfs_manjaro="`echo "${basename}" | sed -e 's,vmlinuz,initramfs,g'`"
for i in "initrd.img-${version}" "initrd-${version}.img" \
"initrd-${alt_version}.img.old" "initrd-${version}.gz" \
"initrd-${alt_version}.gz.old" "initrd-${version}" \
"initramfs-${version}.img" "initramfs-${alt_version}.img.old" \ "initrd.img-${alt_version}" "initrd-${alt_version}.img" \
"initrd-${alt_version}" "initramfs-${alt_version}.img" \
"initramfs-genkernel-${version}" \
"initramfs-genkernel-${alt_version}" \
"initramfs-genkernel-${GENKERNEL_ARCH}-${version}" \
"initramfs-genkernel-${GENKERNEL_ARCH}-${alt_version}" \
"${initramfs_manjaro}.img" \
"initramfs-linux.img" ; do
initrd_real="${i}"
break
fi
done
initrd=
if test -n "${initrd_early}" || test -n "${initrd_real}"; then
initrd="${initrd_early} ${initrd_real}"
initrd_display=
initrd_display="${initrd_display} ${dirname}/${i}"
done
gettext_printf "Found initrd image: %s\n" "$(echo $initrd_display)" >&2
fi
config=
for i in "${dirname}/config-${version}" "${dirname}/config-${alt_version}" "/etc/kernels/kernel-config-${version}" ; do
if test -e "${i}" ; then
config="${i}"
break
fi
done
initramfs=
if test -n "${config}" ; then
initramfs=`grep CONFIG_INITRAMFS_SOURCE= "${config}" | cut -f2 -d= | tr -d \"`
fi
if test -z "${initramfs}" && test -z "${initrd_real}" ; then
# "UUID=" and "ZFS=" magic is parsed by initrd or initramfs. Since there's
# no initrd or builtin initramfs, it can't work here.
if [ "x${GRUB_DEVICE_PARTUUID}" = "x" ] \
|| [ "x${GRUB_DISABLE_LINUX_PARTUUID}" = "xtrue" ]; then
linux_root_device_thisversion=${GRUB_DEVICE}
else
linux_root_device_thisversion=PARTUUID=${GRUB_DEVICE_PARTUUID}
fi
fi
# The GRUB_DISABLE_SUBMENU option used to be different than others since it was
# mentioned in the documentation that has to be set to 'y' instead of 'true' to
# enable it. This caused a lot of confusion to users that set the option to 'y',
# 'yes' or 'true'. This was fixed but all of these values must be supported now.
if [ "x${GRUB_DISABLE_SUBMENU}" = xyes ] || [ "x${GRUB_DISABLE_SUBMENU}" = xy ]; then
GRUB_DISABLE_SUBMENU="true"
fi
if [ "x$is_top_level" = xtrue ] && [ "x${GRUB_DISABLE_SUBMENU}" != xtrue ]; then
linux_entry "${OS}" "${version}" simple \
"${GRUB_CMDLINE_LINUX} ${GRUB_CMDLINE_LINUX_DEFAULT}"
submenu_indentation="$grub_tab"
fi
# TRANSLATORS: %s is replaced with an OS name
echo "submenu '$(gettext_printf "Advanced options for %s" "${OS}" | grub_quote)' \$menuentry_id_option 'gnulinux-advanced-$boot_device_id' {"
is_top_level=false
fi
linux_entry "${OS}" "${version}" advanced \
for i in "${initramfs_manjaro}-fallback.img" "initramfs-${version}-fallback.img" ; do
initrd="${i}"
gettext_printf "Found initrd fallback image: %s\n" "${dirname}/${initrd}" >&2
linux_entry "${OS}" "${version}" fallback \
break
fi
done
if [ "x${GRUB_DISABLE_RECOVERY}" != "xtrue" ]; then
linux_entry "${OS}" "${version}" recovery \
"${GRUB_CMDLINE_LINUX_RECOVERY} ${GRUB_CMDLINE_LINUX}"
fi
list=`echo $list | tr ' ' '\n' | fgrep -vx "$linux" | tr '\n' ' '`
done
# If at least one kernel was found, then we need to
# add a closing '}' for the submenu command.
if [ x"$is_top_level" != xtrue ]; then
echo '}'
fi
echo "$title_correction_code"
