Hey guys,
I’ve installed Manjaro XFCE and it worked fine. After restarting my PC, I cannot boot it anymore. Of course I already googled and found out that my grub installation is messed up but I’m too noobish to fix it myself.
Solution from another thread:
mount -t ext4 /dev/sda6 /manjaro
mount -t vfat /dev/sda1 /manjaro/boot/efi
mount --bind /dev /manjaro/dev
mount -t proc proc /manjaro/proc
mount -t sysfs sys /manjaro/sys
[ -d /manjaro/sys/firmware/efi/efivarfs ] || mkdir -p /manjaro/sys/firmware/efi/efivarfs
mount -t efivarfs efivarfs /manjaro/sys/firmware/efi/efivarfs
chroot /manjaro /usr/bin/bash
grub-install --recheck --no-rs-codes --modules="part_gpt part_msdos" --efi-directory="/boot/efi" --target="x86_64-efi"
update-grub
exit
umount -R /manjaro
Can I just apply the solution posted?
Some more info:
[manjaro ~]# lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda
└─sda1 ntfs HDD 66F63393F633630B
sdb iso9660 Joliet Extension MANJARO_XFCE_2122 2022-01-23-13-29-58-00 0 100% /run/miso/bootmnt
├─sdb1 iso9660 Joliet Extension MANJARO_XFCE_2122 2022-01-23-13-29-58-00
└─sdb2 vfat FAT12 MISO_EFI 01C9-8517
sr0
nvme0n1
├─nvme0n1p1 ntfs Wiederherstellung 94FA2D60FA2D403A
├─nvme0n1p2 vfat FAT32 BA30-7E34
├─nvme0n1p3
├─nvme0n1p4 ntfs System 1674442574440A47
├─nvme0n1p5 ext4 1.0 308f23b4-27f4-4027-9d52-539174dddbaf
└─nvme0n1p6 ntfs 3E6EB3C26EB3716F
[manjaro ~]# test -d /sys/firmware/efi && echo efi || echo bios
efi
Thanks in advance!
