When trying to boot from USB to install, i got a grub error “grub_disk_native_sector not found” how would i fix this?
i used rufus 3.5 to write the ISO, etcher always fails for some reason
rufus did give me an error saying that i needed to download grub 2.04 because it only had 2.02, not sure if that may be helpful
im able to use the ISO in virtualbox successfully
Wollie
2
Have you verified the checksum after burning the stick?
Maybe the USB stick is defective.
Which OS are you using ?
Manajro KDE plasma latest version
i dont know how to do that
Then you should use Imagewriter to flash the USB stick.
i downloaded it, but it only uses .img files, not .iso, and i dont know where to get the img file for manjaro
You need the *.iso file from here:
and flash your USB stick.
Then install and start Suse Studio Imagewriter, select the ISO image, USB stick, you want to write and flash it.
ok i did that, is there supposed to only be a 4MB partition with a folder called efi?
Windows 10, i ran chkdsk on it and it came out with no errors
I had a look at my Manjaro 20.1.2 USB stick and there are the following visible contents on the stick:
boot
efi
manjaro
boot.catalog
efi.img
I am using my Manjaro installation.
Or you can use Ventoy: Ventoy
thats what im trying to use rn, but its been stuck like this for the past 12 hours
system
Closed
16
