after update grub menu is disappear. load only linux. i can’t load other OS ((
“sudo update-grub” not fix problem
From the Known issues and solutions
Manualy add the line
GRUB_DISABLE_OS_PROBER=falseto/etc/default/grub
Runsudo update-grub
To fix the grub to find other OS
Thank you kindly
Thank you!!! it works!!)))
This solution also worked for me. Thanks a million.
Mate, you’re a legend I just registered to the forum looking for that solution
