gefri
28 October 2023 14:14
1
Problem:
Out of nowhere (i.e. no system updates since last stable)
on boot error message ‘Symbol grub_is_lockdown not found’ → grub rescue prompt
My Manjaro (no dualboot, only OS) has been installed 2017 with UEFI and been booting ever since.
secure boot & fastboot is disabled
Status:
boot via usb - supergrub2
detects grub.cfg with all entries → boot into installed Manjaro possible
EFI system partition is available and mounted as /boot/efi/
All attempts to repair/restore grub give the impression that not grub is the problem but EFI ‘got lost’ somehow:
$ sudo efibootmgr
EFI variables are not supported on this system.
/sys/firmware/efi missing
# ls /sys/firmware/efi
ls: cannot access '/sys/firmware/efi': No such file or directory
# efibootmgr -v
Following GRUB/Restore the GRUB Bootloader - Manjaro
ends with
# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
grub-install: error: efibootmgr failed to register the boot entry: No such file or directory.
Now I’m at my wits end how I can narrow down further and find a solution.
Any hints very much appreciated.
You have to disable CSM (“compatibility support module”) — also known as legacy BIOS emulation — in the UEFI firmware setup utility.
gefri
28 October 2023 14:23
3
Thank you.
But CSM is disabled - I checked
recheck options in UEFI motherboard
UEFI, create a profile and save for linux
recheck all option in your UEFI ( for linux)
SecureBoot off
Fast Boot off
No CSM
No Legacy
all disks on AHCI
you can check in terminal , before chroot
inxi -Fxza
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
sudo parted -l
If that were true, then your system would have booted in UEFI mode, but it hasn’t. It has booted in BIOS emulation mode. There’s no denying that, from the output you posted.
gefri
28 October 2023 14:36
6
Yes that has bee confusing me too
I found a previous post from @stephane and checked several times in the UEFI setup.
There
SecureBoot = off
Fast Boot = off
CSM = off
all disks on AHCI
I didn’t find an entry for ‘Legacy’
I get
$ test -d /sys/firmware/efi && echo efi || echo bios
efi
sudo inxi -Mxa
Type: Desktop Mobo: ASRock model: H170M-ITX/ac serial: M80-59017500538
UEFI: American Megatrends v: P7.00A date: 12/20/2016
$ sudo efibootmgr -v
BootCurrent: 0005
Timeout: 1 seconds
BootOrder: 0001,0005,0006
Boot0001* UEFI OS HD(1,GPT,8e5227e1-7344-4f06-aaf3-4253655b014f,0x800,0x100000)/File(\EFI\BOOT\BOOTX64.EFI)0000424f
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 10 00 00 00 00 00 e1 27 52 8e 44 73 06 4f aa f3 42 53 65 5b 01 4f 02 02 / 04 04 30 00 5c 00 45 00 46 00 49 00 5c 00 42 00 4f 00 4f 00 54 00 5c 00 42 00 4f 00 4f 00 54 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Boot0005* UEFI: SMI USB DISK 1100, Partition 2 PciRoot(0x0)/Pci(0x14,0x0)/USB(2,0)/HD(2,MBR,0x2afd93fa,0xf06800,0x10000)0000424f
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 14 / 03 05 06 00 02 00 / 04 01 2a 00 02 00 00 00 00 68 f0 00 00 00 00 00 00 00 01 00 00 00 00 00 fa 93 fd 2a 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 7f ff 04 00
data: 00 00 42 4f
Boot0006* UEFI: USB Flash Disk 1100, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(5,0)/HD(1,MBR,0xc3072e18,0x18,0x3bffe8)0000424f
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 14 / 03 05 06 00 05 00 / 04 01 2a 00 01 00 00 00 18 00 00 00 00 00 00 00 e8 ff 3b 00 00 00 00 00 18 2e 07 c3 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 7f ff 04 00
data: 00 00 42 4f
$ sudo parted -l
Modell: ATA ST500LX025-1U717 (scsi)
Festplatte /dev/sda: 500GB
Sektorgröße (logisch/physisch): 512B/4096B
Partitionstabelle: gpt
Disk-Flags:
Nummer Anfang Ende Größe Dateisystem Name Flags
1 1049kB 538MB 537MB fat16 primary boot, esp
2 538MB 9128MB 8590MB linux-swap(v1) primary swap
3 9128MB 56,3GB 47,2GB ext4 msftdata
4 56,3GB 93,0GB 36,7GB ext4 msftdata
5 93,0GB 500GB 407GB ext4 msftdata
Modell: SMI USB DISK (scsi)
Festplatte /dev/sdb: 8100MB
Sektorgröße (logisch/physisch): 512B/512B
Partitionstabelle: msdos
Disk-Flags:
Nummer Anfang Ende Größe Typ Dateisystem Flags
1 1049kB 8067MB 8066MB primary boot
2 8067MB 8100MB 33,6MB primary fat16 esp
Modell: USB Flash Disk (scsi)
Festplatte /dev/sdc: 2013MB
Disk-Flags:
1 12,3kB 2013MB 2013MB primary fat32
gefri
28 October 2023 14:39
7
inxi -Fxza
Summary
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=47991036-ac10-4bc3-8c66-497b0e5205c8 rw quiet
resume=UUID=7a129e70-9220-4db0-bcc9-f3b8fb87913b
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: H170M-ITX/ac serial: <superuser required>
Info: model: Intel Core i5-7500T bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 21607
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: ASRock driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-3
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5912
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: intel dri: iris gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-3 mapped: HDMI3 model: EIZO NANAO EV2450
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 606mm (23.9") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: Logitech Headset H340 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
chip-ID: 046d:0a38 class-ID: 0300
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: off with: 1: pipewire-media-session
status: off 2: pw-jack type: plugin tools: pw-cat,pw-cli
Server-2: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
vendor: ASRock driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Local Storage: total: 475.18 GiB used: 115.13 GiB (24.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LX025-1U717D
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SMI (STMicroelectronics)
model: USB DISK size: 7.54 GiB block-size: physical: 512 B logical: 512 B
type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
serial: <filter> fw-rev: 1100 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 model: USB Flash Disk size: 1.88 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 43.95 GiB size: 43.08 GiB (98.03%) used: 26.26 GiB (61.0%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 512 MiB size: 511.7 MiB (99.95%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 34.18 GiB size: 33.35 GiB (97.56%)
used: 2.59 GiB (7.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 42.0 C pch: 43.5 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 207 Uptime: 33m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.44 GiB used: 2.23 GiB (29.9%) Init: systemd v: 254
Packages: 1616 pm: pacman pkgs: 1593 libs: 435 tools: pamac,yay pm: flatpak
pkgs: 23 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.30
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Hi @gefri ,
Please post the output of:
sudo smartctl --all /dev/sda
as well as
lsblk
Edit:
And please fix the output for:
gefri:
inxi -Fxza
…to be as you provided previously.
gefri
28 October 2023 14:52
9
$ sudo smartctl --all /dev/sda
Summary
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.1.55-1-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate FireCuda 2.5
Device Model: ST500LX025-1U717D
Serial Number: WES3D4D1
LU WWN Device Id: 5 000c50 09e2c0693
Firmware Version: SDM1
User Capacity: 500.107.862.016 bytes [500 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Oct 28 16:50:25 2023 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 86) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 084 064 006 Pre-fail Always - 241223137
3 Spin_Up_Time 0x0003 099 099 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 094 094 020 Old_age Always - 6515
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 081 060 045 Pre-fail Always - 139807565
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 13713 (166 220 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 094 094 020 Old_age Always - 6499
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 4295032965
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 050 040 Old_age Always - 34 (Min/Max 33/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 8
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 55
193 Load_Cycle_Count 0x0032 097 097 000 Old_age Always - 6530
194 Temperature_Celsius 0x0022 034 050 000 Old_age Always - 34 (0 15 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 13708h+36m+49.085s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 9425558037
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 16206328140
254 Free_Fall_Sensor 0x0032 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
$ lsblk
Summary
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 465,8G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
├─sda2 8:2 0 8G 0 part [SWAP]
├─sda3 8:3 0 43,9G 0 part /
├─sda4 8:4 0 34,2G 0 part /home
└─sda5 8:5 0 379,1G 0 part /home/daten
sdb 8:16 1 7,5G 0 disk
├─sdb1 8:17 1 7,5G 0 part
└─sdb2 8:18 1 32M 0 part
sr0 11:0 1 1024M 0 rom
Edit: What needs fixing with the inxi output?
Please fix your output to be as you previously provided:
There
SecureBoot = off
Fast Boot = off
CSM = off
all disks on AHCI
I get
efi
sudo inxi -Mxa
BootCurrent: 0005
Timeout: 1 seco…
Please provide the output for:
cat /etc/fstab
…for your installation.
I don’t know if you’re in a live environment or a chroot environment, so I thought I’d specify.
Edit:
Please make it preformatted text, as you previously did:
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to form…
gefri
28 October 2023 15:04
11
I’m back in my live environment, having booted via usb-supergrub
So no chroot
$ cat /etc/fstab
Summary
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=3BC0-0C38 /boot/efi vfat defaults,noatime 0 2
UUID=7a129e70-9220-4db0-bcc9-f3b8fb87913b swap swap defaults,noatime 0 0
UUID=47991036-ac10-4bc3-8c66-497b0e5205c8 / ext4 defaults,noatime 0 1
UUID=d53db145-0b79-4357-a4c2-82b8cc547d6c /home ext4 defaults,noatime 0 2
#UUID=857653ed-6092-4122-8b18-88c9bcc70805 /home/daten ext4 defaults,noatime 0 2
# 14.2.2017
/dev/sda5 /home/daten ext4 auto,users,rw,nosuid,nodev,relatime,data=ordered,uhelper=udisks2 0 2
#/dev/sda5 /home/daten ext4 defaults,noatime,auto,users,rw 0 2
gefri
28 October 2023 15:06
12
So, better now
$ inxi -Fxza
Summary
desc: 1x6 MiB
disabled
class-ID: 0300
class-ID: 0403
class-ID: 0200
Local Storage: total: 473.31 GiB used: 115.09 GiB (24.3%)
ID-1: / raw-size: 43.95 GiB size: 43.08 GiB (98.03%) used: 26.26 GiB (60.9%)
used: 2.58 GiB (7.7%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 42.0 C pch: 44.5 C mobo: N/A
Processes: 200 Uptime: 9m wakeups: 0 Memory: total: 8 GiB note: est.
available: 7.44 GiB used: 1.96 GiB (26.3%) Init: systemd v: 254
This is very strange.
I don’t see anything wrong, sorry. Perhaps someone else does , but that isn’t me.
gefri
28 October 2023 15:20
14
Anyway
Thank you all for your attempts & insights!
edit: @andreas85 thanks for your intervention with formatting
When starting your live Manjaro, there may be two ways to start it.
Boot it into BIOS mode
Boot it in UEFI mode
You may need to test both as the naming is often not clear.
If you boot into BIOS mode, the EFI variables are not accessible
Is this a dualboot-system ?
Did you install another linux alongside ?
You can also use maxi -eg
to collect information about the boot process. This works,
when you are in your running system (with CTRL +ALT +F2 ).
And also in a live environment
If your manjaro installation does not boot (any more), maxi may help to find what is missing
This suggests that some files in your efi-patition or in /boot/grub/.. are missing or damaged
Summary
ls -lA /boot/grub/x86_64-efi
insgesamt 3788
-rw-r--r-- 1 root root 16800 31. Mär 2023 acpi.mod
-rw-r--r-- 1 root root 1832 31. Mär 2023 adler32.mod
-rw-r--r-- 1 root root 8912 31. Mär 2023 affs.mod
-rw-r--r-- 1 root root 9624 31. Mär 2023 afs.mod
-rw-r--r-- 1 root root 2232 31. Mär 2023 afsplitter.mod
-rw-r--r-- 1 root root 21912 31. Mär 2023 ahci.mod
-rw-r--r-- 1 root root 704 31. Mär 2023 all_video.mod
-rw-r--r-- 1 root root 1368 31. Mär 2023 aout.mod
-rw-r--r-- 1 root root 5224 31. Mär 2023 appleldr.mod
-rw-r--r-- 1 root root 4944 31. Mär 2023 archelp.mod
-rw-r--r-- 1 root root 8616 31. Mär 2023 ata.mod
-rw-r--r-- 1 root root 6408 31. Mär 2023 at_keyboard.mod
-rw-r--r-- 1 root root 2400 31. Mär 2023 backtrace.mod
-rw-r--r-- 1 root root 10864 31. Mär 2023 bfs.mod
-rw-r--r-- 1 root root 3224 31. Mär 2023 bitmap.mod
-rw-r--r-- 1 root root 5248 31. Mär 2023 bitmap_scale.mod
-rw-r--r-- 1 root root 2896 31. Mär 2023 blocklist.mod
-rw-r--r-- 1 root root 3768 31. Mär 2023 boot.mod
-rw-r--r-- 1 root root 1920 31. Mär 2023 boottime.mod
-rw-r--r-- 1 root root 51600 31. Mär 2023 bsd.mod
-rw-r--r-- 1 root root 3080 31. Mär 2023 bswap_test.mod
-rw-r--r-- 1 root root 30280 31. Mär 2023 btrfs.mod
-rw-r--r-- 1 root root 2872 31. Mär 2023 bufio.mod
-rw-r--r-- 1 root root 2128 31. Mär 2023 cacheinfo.mod
-rw-r--r-- 1 root root 4248 31. Mär 2023 cat.mod
-rw-r--r-- 1 root root 5952 31. Mär 2023 cbfs.mod
-rw-r--r-- 1 root root 5552 31. Mär 2023 cbls.mod
-rw-r--r-- 1 root root 3752 31. Mär 2023 cbmemc.mod
-rw-r--r-- 1 root root 1504 31. Mär 2023 cbtable.mod
-rw-r--r-- 1 root root 4384 31. Mär 2023 cbtime.mod
-rw-r--r-- 1 root root 9104 31. Mär 2023 chain.mod
-rw-r--r-- 1 root root 4496 31. Mär 2023 cmdline_cat_test.mod
-rw-r--r-- 1 root root 3488 31. Mär 2023 cmp.mod
-rw-r--r-- 1 root root 6232 31. Mär 2023 cmp_test.mod
-rw-r--r-- 1 root root 3731 31. Mär 2023 command.lst
-rw-r--r-- 1 root root 3160 31. Mär 2023 configfile.mod
-rw-r--r-- 1 root root 303104 31. Mär 2023 core.efi
-rw-r--r-- 1 root root 4592 31. Mär 2023 cpio_be.mod
-rw-r--r-- 1 root root 4592 31. Mär 2023 cpio.mod
-rw-r--r-- 1 root root 2480 31. Mär 2023 cpuid.mod
-rw-r--r-- 1 root root 2032 31. Mär 2023 crc64.mod
-rw-r--r-- 1 root root 22928 31. Mär 2023 cryptodisk.mod
-rw-r--r-- 1 root root 936 31. Mär 2023 crypto.lst
-rw-r--r-- 1 root root 7416 31. Mär 2023 crypto.mod
-rw-r--r-- 1 root root 3848 31. Mär 2023 cs5536.mod
-rw-r--r-- 1 root root 2528 31. Mär 2023 ctz_test.mod
-rw-r--r-- 1 root root 2912 31. Mär 2023 datehook.mod
-rw-r--r-- 1 root root 3104 31. Mär 2023 date.mod
-rw-r--r-- 1 root root 2928 31. Mär 2023 datetime.mod
-rw-r--r-- 1 root root 13952 31. Mär 2023 diskfilter.mod
-rw-r--r-- 1 root root 3152 31. Mär 2023 disk.mod
-rw-r--r-- 1 root root 1240 31. Mär 2023 div.mod
-rw-r--r-- 1 root root 7808 31. Mär 2023 div_test.mod
-rw-r--r-- 1 root root 2776 31. Mär 2023 dm_nv.mod
-rw-r--r-- 1 root root 3048 31. Mär 2023 echo.mod
-rw-r--r-- 1 root root 2696 31. Mär 2023 efifwsetup.mod
-rw-r--r-- 1 root root 12792 31. Mär 2023 efi_gop.mod
-rw-r--r-- 1 root root 7216 31. Mär 2023 efinet.mod
-rw-r--r-- 1 root root 3832 31. Mär 2023 efitextmode.mod
-rw-r--r-- 1 root root 7032 31. Mär 2023 efi_uga.mod
-rw-r--r-- 1 root root 25824 31. Mär 2023 ehci.mod
-rw-r--r-- 1 root root 8952 31. Mär 2023 elf.mod
-rw-r--r-- 1 root root 2168 31. Mär 2023 eval.mod
-rw-r--r-- 1 root root 9016 31. Mär 2023 exfat.mod
-rw-r--r-- 1 root root 2048 31. Mär 2023 exfctest.mod
-rw-r--r-- 1 root root 9392 31. Mär 2023 ext2.mod
-rw-r--r-- 1 root root 7808 31. Mär 2023 extcmd.mod
-rw-r--r-- 1 root root 10976 31. Mär 2023 f2fs.mod
-rw-r--r-- 1 root root 9048 31. Mär 2023 fat.mod
-rw-r--r-- 1 root root 27400 31. Mär 2023 file.mod
-rw-r--r-- 1 root root 2768 31. Mär 2023 fixvideo.mod
-rw-r--r-- 1 root root 19920 31. Mär 2023 font.mod
-rw-r--r-- 1 root root 4576 31. Mär 2023 fshelp.mod
-rw-r--r-- 1 root root 219 31. Mär 2023 fs.lst
-rw-r--r-- 1 root root 46984 31. Mär 2023 functional_test.mod
-rw-r--r-- 1 root root 2280 31. Mär 2023 gcry_arcfour.mod
-rw-r--r-- 1 root root 9264 31. Mär 2023 gcry_blowfish.mod
-rw-r--r-- 1 root root 28176 31. Mär 2023 gcry_camellia.mod
-rw-r--r-- 1 root root 14712 31. Mär 2023 gcry_cast5.mod
-rw-r--r-- 1 root root 11744 31. Mär 2023 gcry_crc.mod
-rw-r--r-- 1 root root 16320 31. Mär 2023 gcry_des.mod
-rw-r--r-- 1 root root 3288 31. Mär 2023 gcry_dsa.mod
-rw-r--r-- 1 root root 3864 31. Mär 2023 gcry_idea.mod
-rw-r--r-- 1 root root 4008 31. Mär 2023 gcry_md4.mod
-rw-r--r-- 1 root root 4464 31. Mär 2023 gcry_md5.mod
-rw-r--r-- 1 root root 3000 31. Mär 2023 gcry_rfc2268.mod
-rw-r--r-- 1 root root 20464 31. Mär 2023 gcry_rijndael.mod
-rw-r--r-- 1 root root 7824 31. Mär 2023 gcry_rmd160.mod
-rw-r--r-- 1 root root 3216 31. Mär 2023 gcry_rsa.mod
-rw-r--r-- 1 root root 12504 31. Mär 2023 gcry_seed.mod
-rw-r--r-- 1 root root 16344 31. Mär 2023 gcry_serpent.mod
-rw-r--r-- 1 root root 8064 31. Mär 2023 gcry_sha1.mod
-rw-r--r-- 1 root root 5104 31. Mär 2023 gcry_sha256.mod
-rw-r--r-- 1 root root 5976 31. Mär 2023 gcry_sha512.mod
-rw-r--r-- 1 root root 13152 31. Mär 2023 gcry_tiger.mod
-rw-r--r-- 1 root root 33664 31. Mär 2023 gcry_twofish.mod
-rw-r--r-- 1 root root 22720 31. Mär 2023 gcry_whirlpool.mod
-rw-r--r-- 1 root root 8744 31. Mär 2023 geli.mod
-rw-r--r-- 1 root root 8528 31. Mär 2023 gettext.mod
-rw-r--r-- 1 root root 64064 31. Mär 2023 gfxmenu.mod
-rw-r--r-- 1 root root 4304 31. Mär 2023 gfxterm_background.mod
-rw-r--r-- 1 root root 7616 31. Mär 2023 gfxterm_menu.mod
-rw-r--r-- 1 root root 16752 31. Mär 2023 gfxterm.mod
-rw-r--r-- 1 root root 5296 31. Mär 2023 gptsync.mod
-rw-r--r-- 1 root root 303104 31. Mär 2023 grub.efi
-rw-r--r-- 1 root root 12736 31. Mär 2023 gzio.mod
-rw-r--r-- 1 root root 7544 31. Mär 2023 halt.mod
-rw-r--r-- 1 root root 8688 31. Mär 2023 hashsum.mod
-rw-r--r-- 1 root root 10248 31. Mär 2023 hdparm.mod
-rw-r--r-- 1 root root 1760 31. Mär 2023 hello.mod
-rw-r--r-- 1 root root 4048 31. Mär 2023 help.mod
-rw-r--r-- 1 root root 4392 31. Mär 2023 hexdump.mod
-rw-r--r-- 1 root root 10696 31. Mär 2023 hfs.mod
-rw-r--r-- 1 root root 4432 31. Mär 2023 hfspluscomp.mod
-rw-r--r-- 1 root root 12816 31. Mär 2023 hfsplus.mod
-rw-r--r-- 1 root root 9792 31. Mär 2023 http.mod
-rw-r--r-- 1 root root 4240 31. Mär 2023 iorw.mod
-rw-r--r-- 1 root root 14568 31. Mär 2023 iso9660.mod
-rw-r--r-- 1 root root 9336 31. Mär 2023 jfs.mod
-rw-r--r-- 1 root root 10880 31. Mär 2023 jpeg.mod
-rw-r--r-- 1 root root 5968 31. Mär 2023 json.mod
-rw-r--r-- 1 root root 6408 31. Mär 2023 keylayouts.mod
-rw-r--r-- 1 root root 2872 31. Mär 2023 keystatus.mod
-rw-r--r-- 1 root root 11000 31. Mär 2023 ldm.mod
-rw-r--r-- 1 root root 46968 31. Mär 2023 legacycfg.mod
-rw-r--r-- 1 root root 15816 31. Mär 2023 legacy_password_test.mod
-rw-r--r-- 1 root root 8480 31. Mär 2023 linux16.mod
-rw-r--r-- 1 root root 19960 31. Mär 2023 linux.mod
-rw-r--r-- 1 root root 4544 31. Mär 2023 loadbios.mod
-rw-r--r-- 1 root root 9496 31. Mär 2023 loadenv.mod
-rw-r--r-- 1 root root 4960 31. Mär 2023 loopback.mod
-rw-r--r-- 1 root root 7008 31. Mär 2023 lsacpi.mod
-rw-r--r-- 1 root root 3688 31. Mär 2023 lsefimmap.mod
-rw-r--r-- 1 root root 5200 31. Mär 2023 lsefi.mod
-rw-r--r-- 1 root root 4544 31. Mär 2023 lsefisystab.mod
-rw-r--r-- 1 root root 2832 31. Mär 2023 lsmmap.mod
-rw-r--r-- 1 root root 6488 31. Mär 2023 ls.mod
-rw-r--r-- 1 root root 7120 31. Mär 2023 lspci.mod
-rw-r--r-- 1 root root 3704 31. Mär 2023 lssal.mod
-rw-r--r-- 1 root root 21264 31. Mär 2023 luks2.mod
-rw-r--r-- 1 root root 6184 31. Mär 2023 luks.mod
-rw-r--r-- 1 root root 13352 31. Mär 2023 lvm.mod
-rw-r--r-- 1 root root 7352 31. Mär 2023 lzopio.mod
-rw-r--r-- 1 root root 4872 31. Mär 2023 macbless.mod
-rw-r--r-- 1 root root 11512 31. Mär 2023 macho.mod
-rw-r--r-- 1 root root 2880 31. Mär 2023 mdraid09_be.mod
-rw-r--r-- 1 root root 2848 31. Mär 2023 mdraid09.mod
-rw-r--r-- 1 root root 2624 31. Mär 2023 mdraid1x.mod
-rw-r--r-- 1 root root 3104 31. Mär 2023 memdisk.mod
-rw-r--r-- 1 root root 4200 31. Mär 2023 memrw.mod
-rw-r--r-- 1 root root 5736 31. Mär 2023 minicmd.mod
-rw-r--r-- 1 root root 6024 31. Mär 2023 minix2_be.mod
-rw-r--r-- 1 root root 5920 31. Mär 2023 minix2.mod
-rw-r--r-- 1 root root 6056 31. Mär 2023 minix3_be.mod
-rw-r--r-- 1 root root 5952 31. Mär 2023 minix3.mod
-rw-r--r-- 1 root root 5896 31. Mär 2023 minix_be.mod
-rw-r--r-- 1 root root 5800 31. Mär 2023 minix.mod
-rw-r--r-- 1 root root 9952 31. Mär 2023 mmap.mod
-rw-r--r-- 1 root root 5309 31. Mär 2023 moddep.lst
-rw-r--r-- 1 root root 2511 31. Mär 2023 modinfo.sh
-rw-r--r-- 1 root root 3152 31. Mär 2023 morse.mod
-rw-r--r-- 1 root root 44056 31. Mär 2023 mpi.mod
-rw-r--r-- 1 root root 3592 31. Mär 2023 msdospart.mod
-rw-r--r-- 1 root root 2312 31. Mär 2023 mul_test.mod
-rw-r--r-- 1 root root 25368 31. Mär 2023 multiboot2.mod
-rw-r--r-- 1 root root 22192 31. Mär 2023 multiboot.mod
-rw-r--r-- 1 root root 7208 31. Mär 2023 nativedisk.mod
-rw-r--r-- 1 root root 83616 31. Mär 2023 net.mod
-rw-r--r-- 1 root root 4744 31. Mär 2023 newc.mod
-rw-r--r-- 1 root root 10432 31. Mär 2023 nilfs2.mod
-rw-r--r-- 1 root root 186168 31. Mär 2023 normal.mod
-rw-r--r-- 1 root root 5688 31. Mär 2023 ntfscomp.mod
-rw-r--r-- 1 root root 16288 31. Mär 2023 ntfs.mod
-rw-r--r-- 1 root root 4592 31. Mär 2023 odc.mod
-rw-r--r-- 1 root root 2328 31. Mär 2023 offsetio.mod
-rw-r--r-- 1 root root 15504 31. Mär 2023 ohci.mod
-rw-r--r-- 1 root root 2208 31. Mär 2023 part_acorn.mod
-rw-r--r-- 1 root root 2520 31. Mär 2023 part_amiga.mod
-rw-r--r-- 1 root root 2888 31. Mär 2023 part_apple.mod
-rw-r--r-- 1 root root 4064 31. Mär 2023 part_bsd.mod
-rw-r--r-- 1 root root 2568 31. Mär 2023 part_dfly.mod
-rw-r--r-- 1 root root 2096 31. Mär 2023 part_dvh.mod
-rw-r--r-- 1 root root 3152 31. Mär 2023 part_gpt.mod
-rw-r--r-- 1 root root 111 31. Mär 2023 partmap.lst
-rw-r--r-- 1 root root 2912 31. Mär 2023 part_msdos.mod
-rw-r--r-- 1 root root 2416 31. Mär 2023 part_plan.mod
-rw-r--r-- 1 root root 2160 31. Mär 2023 part_sun.mod
-rw-r--r-- 1 root root 2616 31. Mär 2023 part_sunpc.mod
-rw-r--r-- 1 root root 17 31. Mär 2023 parttool.lst
-rw-r--r-- 1 root root 7792 31. Mär 2023 parttool.mod
-rw-r--r-- 1 root root 2928 31. Mär 2023 password.mod
-rw-r--r-- 1 root root 4936 31. Mär 2023 password_pbkdf2.mod
-rw-r--r-- 1 root root 7360 31. Mär 2023 pata.mod
-rw-r--r-- 1 root root 2040 31. Mär 2023 pbkdf2.mod
-rw-r--r-- 1 root root 3352 31. Mär 2023 pbkdf2_test.mod
-rw-r--r-- 1 root root 3424 31. Mär 2023 pcidump.mod
-rw-r--r-- 1 root root 19640 31. Mär 2023 pgp.mod
-rw-r--r-- 1 root root 11512 31. Mär 2023 plainmount.mod
-rw-r--r-- 1 root root 3848 31. Mär 2023 play.mod
-rw-r--r-- 1 root root 11096 31. Mär 2023 png.mod
-rw-r--r-- 1 root root 2464 31. Mär 2023 priority_queue.mod
-rw-r--r-- 1 root root 5864 31. Mär 2023 probe.mod
-rw-r--r-- 1 root root 3744 31. Mär 2023 procfs.mod
-rw-r--r-- 1 root root 3072 31. Mär 2023 progress.mod
-rw-r--r-- 1 root root 2120 31. Mär 2023 raid5rec.mod
-rw-r--r-- 1 root root 3576 31. Mär 2023 raid6rec.mod
-rw-r--r-- 1 root root 3632 31. Mär 2023 random.mod
-rw-r--r-- 1 root root 3008 31. Mär 2023 rdmsr.mod
-rw-r--r-- 1 root root 2832 31. Mär 2023 read.mod
-rw-r--r-- 1 root root 1520 31. Mär 2023 reboot.mod
-rw-r--r-- 1 root root 79392 31. Mär 2023 regexp.mod
-rw-r--r-- 1 root root 14480 31. Mär 2023 reiserfs.mod
-rw-r--r-- 1 root root 27384 31. Mär 2023 relocator.mod
-rw-r--r-- 1 root root 6056 31. Mär 2023 romfs.mod
-rw-r--r-- 1 root root 7416 31. Mär 2023 scsi.mod
-rw-r--r-- 1 root root 5016 31. Mär 2023 search_fs_file.mod
-rw-r--r-- 1 root root 5200 31. Mär 2023 search_fs_uuid.mod
-rw-r--r-- 1 root root 5136 31. Mär 2023 search_label.mod
-rw-r--r-- 1 root root 5576 31. Mär 2023 search.mod
-rw-r--r-- 1 root root 17728 31. Mär 2023 serial.mod
-rw-r--r-- 1 root root 912 31. Mär 2023 setjmp.mod
-rw-r--r-- 1 root root 2520 31. Mär 2023 setjmp_test.mod
-rw-r--r-- 1 root root 8160 31. Mär 2023 setpci.mod
-rw-r--r-- 1 root root 9208 31. Mär 2023 sfs.mod
-rw-r--r-- 1 root root 2992 31. Mär 2023 shift_test.mod
-rw-r--r-- 1 root root 8304 31. Mär 2023 signature_test.mod
-rw-r--r-- 1 root root 3272 31. Mär 2023 sleep.mod
-rw-r--r-- 1 root root 3008 31. Mär 2023 sleep_test.mod
-rw-r--r-- 1 root root 8400 31. Mär 2023 smbios.mod
-rw-r--r-- 1 root root 2968 31. Mär 2023 spkmodem.mod
-rw-r--r-- 1 root root 11288 31. Mär 2023 squash4.mod
-rw-r--r-- 1 root root 3160 31. Mär 2023 strtoull_test.mod
-rw-r--r-- 1 root root 30920 31. Mär 2023 syslinuxcfg.mod
-rw-r--r-- 1 root root 5200 31. Mär 2023 tar.mod
-rw-r--r-- 1 root root 162 31. Mär 2023 terminal.lst
-rw-r--r-- 1 root root 6584 31. Mär 2023 terminal.mod
-rw-r--r-- 1 root root 19248 31. Mär 2023 terminfo.mod
-rw-r--r-- 1 root root 1952 31. Mär 2023 test_blockarg.mod
-rw-r--r-- 1 root root 3880 31. Mär 2023 testload.mod
-rw-r--r-- 1 root root 7512 31. Mär 2023 test.mod
-rw-r--r-- 1 root root 3536 31. Mär 2023 testspeed.mod
-rw-r--r-- 1 root root 7568 31. Mär 2023 tftp.mod
-rw-r--r-- 1 root root 6304 31. Mär 2023 tga.mod
-rw-r--r-- 1 root root 2272 31. Mär 2023 time.mod
-rw-r--r-- 1 root root 7760 31. Mär 2023 tpm.mod
-rw-r--r-- 1 root root 1936 31. Mär 2023 trig.mod
-rw-r--r-- 1 root root 3672 31. Mär 2023 tr.mod
-rw-r--r-- 1 root root 1792 31. Mär 2023 true.mod
-rw-r--r-- 1 root root 13704 31. Mär 2023 udf.mod
-rw-r--r-- 1 root root 8528 31. Mär 2023 ufs1_be.mod
-rw-r--r-- 1 root root 8344 31. Mär 2023 ufs1.mod
-rw-r--r-- 1 root root 8344 31. Mär 2023 ufs2.mod
-rw-r--r-- 1 root root 9992 31. Mär 2023 uhci.mod
-rw-r--r-- 1 root root 5816 31. Mär 2023 usb_keyboard.mod
-rw-r--r-- 1 root root 18744 31. Mär 2023 usb.mod
-rw-r--r-- 1 root root 11416 31. Mär 2023 usbms.mod
-rw-r--r-- 1 root root 2968 31. Mär 2023 usbserial_common.mod
-rw-r--r-- 1 root root 3328 31. Mär 2023 usbserial_ftdi.mod
-rw-r--r-- 1 root root 3656 31. Mär 2023 usbserial_pl2303.mod
-rw-r--r-- 1 root root 2240 31. Mär 2023 usbserial_usbdebug.mod
-rw-r--r-- 1 root root 5776 31. Mär 2023 usbtest.mod
-rw-r--r-- 1 root root 8456 31. Mär 2023 video_bochs.mod
-rw-r--r-- 1 root root 8840 31. Mär 2023 video_cirrus.mod
-rw-r--r-- 1 root root 9920 31. Mär 2023 video_colors.mod
-rw-r--r-- 1 root root 28632 31. Mär 2023 video_fb.mod
-rw-r--r-- 1 root root 5208 31. Mär 2023 videoinfo.mod
-rw-r--r-- 1 root root 41 31. Mär 2023 video.lst
-rw-r--r-- 1 root root 8856 31. Mär 2023 video.mod
-rw-r--r-- 1 root root 3584 31. Mär 2023 videotest_checksum.mod
-rw-r--r-- 1 root root 5304 31. Mär 2023 videotest.mod
-rw-r--r-- 1 root root 2328 31. Mär 2023 wrmsr.mod
-rw-r--r-- 1 root root 11192 31. Mär 2023 xfs.mod
-rw-r--r-- 1 root root 44664 31. Mär 2023 xnu.mod
-rw-r--r-- 1 root root 3264 31. Mär 2023 xnu_uuid.mod
-rw-r--r-- 1 root root 3024 31. Mär 2023 xnu_uuid_test.mod
-rw-r--r-- 1 root root 20264 31. Mär 2023 xzio.mod
-rw-r--r-- 1 root root 8504 31. Mär 2023 zfscrypt.mod
-rw-r--r-- 1 root root 11144 31. Mär 2023 zfsinfo.mod
-rw-r--r-- 1 root root 60664 31. Mär 2023 zfs.mod
-rw-r--r-- 1 root root 79120 31. Mär 2023 zstd.mod
That doesn’t seem to be the case:
gefri
28 October 2023 15:56
17
Sorry if I have been causing confusion.
I’m not in a live medium e.g. a manjaro*.iso with chroot
I’m in my installed Manjaro environment (booted into via usb-supergrub)
And all my output comes from my manjaro installed on sda3
@andreas85 : no dualboot, no other linux
Thanks for the hint with maxi and the possibly missing grub files, I’ll check it out.
Just rebooted again, re-checked all UEFI setings on my motherboard (as @stephane suggested)
no change - end up in grub rescue.
Though whats strange: for the first time in days efibootmgr doesn’t give me ‘EFI variables are not supported on this system’ but output as expected.
No idea what changed.
I’ll spend some more time with further reading and investigating.
If I find anything interesting I’ll post again.
So far, thanks again to all posters!
try to get USB iso manjaro, if possible by dd command or ventoy
on boot USB , you will see 2 entries , select < USB vendor name > < partition 1 > ( boot in UEFI )
redo a grub install from USb iso manjaro
inxi -Mxa ( check for UEFI only )
manjaro-chroot -a
grub-mkconfig -o /boot/grub/grub.cfg
mkinitcpio -P
sync
exit
gefri
28 October 2023 20:13
20
Following @stefane 's last instruction reinstalling grub let my system boot properly again.
One more final THANKS to all who contributed here.
To sum up & retracing my steps
Similar instructions in GRUB/Restore the GRUB Bootloader - Manjaro failed during my previous atemps always with
The most likely culprit is the CSM setting
Though every time when checked previously, it has been set to ‘disabled’
On @Aragorn 's suspicion: I ‘enabled’ rebooted ‘disabled’ this option again.
So the credit goes to @Aragorn for pointing it out again
Nevertheless the question remains how a UEFI setting can be sort of ‘unstable’.
As stated in my first post the system has been booting with those, same settings since 2017 and it has not been for years that I entered the UEFI as all.
Can this be a hint on failing of the motherboard?
gefri
29 October 2023 16:24
24
Final remark
After yesterdays grub repair (incl. several reboots) everything was fine.
Today I was back booting into ‘rescue mode’…
UEFI setting CSM was back to ‘enabled’
And now I have a good guess:
Hardware from 2017 = old buffer battery plus on shutdown I separate my system from electricity via a physical on/off switch on the plug socket. i.e. after I shutdown it’s completely off the power grid.
Seems that the buffer battery on the motherboard became too weak, hence some UEFI settings go back to default values after some time in total powerless state.
Explains also inconsistent UEFI settings - depending on the availability of power supply during reboots.
PS: a quick search shows that this problem seems to be known to occur with certain ASRock boards
