Hi. There are three systems on the disk. Windows stood for a long time, now I installed arch on sda5 and immediately Manjaro on sda6. Both are encrypted. Grub sees Manjaro and Windows, but not Arch. All systems boot normally via uefi. What should I do in this situation? I’ve already tried it
Since the systems are encrypted, they can’t be accessed without the decryption key. That is why your 1 grub can’t access the other Linux, so according to it, there’s nothing boot-able there.
I suspect you’ll have to add the other distribution manually in /etc/grub.d/40_custom. No, I don’t know how.
Edit:
More here:
Edit #2:
Either that or, and here I again don’t know if, or how to do it, but either that, or the boot partitions for both distributions need to be on an un-encrypted partition.
Personally, I’d say this is the best option if you have to have encryption. Leave the OS un-encrypted and encrypt just your data.
For grub to be able to identify other systems it needs access to the system’s root filesystem.
Logically - this is not possible when the root filesystem is encrypted.
So no matter what you do - os-prober will never be able to identify what is inside a luks encrypted block device.
The only way you can have a dual system using encryption is to use a unified kernel image stored as an efi image - then you can boot it using your systems boot override.
Could you please explain in a little more detail what it is so I can figure out for myself if it’s worth it
