Hello
I’m wondering if anyone can give me guidance before i reboot. I’m unsure if I just broke my windoze or linux installation or if I need to do anything. Generally WARN/WARNING seems pretty safe to reboot, and ERROR usually means i broke something though…
So Just an hour or so ago (after searching the forums and typing this I ammend this to 2+ hours ago.. haha) I attempted to update my system as I was unexpectedly logged out of my session while I was sleeping. Figured I might as well just update since all my tasks and windows were terminated anyway and maybe an update would solve whatever happened.
I got an ERROR during the grub bootmenu update.
Part of update where error happened: (full at the bottom of this post)
(20/36) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.18-x86_64.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
ERROR: unsupported sector size 4096 on /dev/dm-2.
ERROR: pdc: reading /dev/sdc[Input/output error]
ERROR: sil: reading /dev/sdc[Input/output error]
Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
This system is a dual boot system with two separate 2TB nvme drives. I have windoze on one drive as ive been unable to solve some graphical errors on linux and been unable to properly colour grade with 10bit until recently. I only bring up the graphical errors in case it’s important for trouble shooting.
$ sudo inxi -Fz
[sudo] password for resove:
Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 50.1 Distro: Manjaro Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: ProArt X570-CREATOR WIFI v: Rev X.0x serial: <filter>
Firmware: UEFI vendor: American Megatrends v: 1505 date: 03/18/2024
Info: 8-core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 2393 min/max: 422/4674 cores: 1: 2393 2: 2393 3: 2393
4: 2393 5: 2393 6: 2393 7: 2393 8: 2393 9: 2393 10: 2393 11: 2393 12: 2393
13: 2393 14: 2393 15: 2393 16: 2393
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti 16GB] driver: nvidia
v: 590.48.01
Device-2: Blackmagic Design DeckLink 4K Extreme 12G driver: blackmagic-io
v: N/A
Device-3: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] driver: amdgpu v: kernel
Display: unspecified server: X.org v: 1.21.1.22 with: Xwayland v: 24.1.11
driver: X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon
dri: radeonsi gpu: amdgpu resolution: 3840x2160~30Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.64
6.18.18-1-MANJARO)
API: Vulkan v: 1.4.341 drivers: radv surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Device-1: NVIDIA AD106M High Definition Audio driver: snd_hda_intel
Device-3: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
Device-4: Advanced Micro Devices [AMD] Ryzen HD Audio
API: ALSA v: k6.18.18-1-MANJARO status: kernel-api
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
IF: wlp57s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V driver: igc
IF: enp58s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb type: USB
Local Storage: total: 40.02 TiB used: 30.49 TiB (76.2%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN850P for PS5
2000GB size: 1.82 TiB
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
ID-3: /dev/sda vendor: Seagate model: Expansion Desk size: 7.28 TiB
type: USB
ID-4: /dev/sdb vendor: Seagate model: ST18000NM014J-2WS103 size: 16.37 TiB
type: USB
ID-5: /dev/sdc vendor: Western Digital model: WD4001FAEX-00MJRA0
size: 3.64 TiB type: USB
ID-6: /dev/sdd vendor: Seagate model: ST10000DM005-3AW101 size: 9.1 TiB
type: USB
ID-1: / size: 1.81 TiB used: 901.67 GiB (48.7%) fs: xfs dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 696 KiB (0.2%) fs: vfat
dev: /dev/nvme1n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 7.4 MiB (0.1%)
dev: /dev/dm-1
System Temperatures: cpu: 30.0 C mobo: 37.0 C gpu: amdgpu temp: 27.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 128 GiB note: est. available: 123.61 GiB
used: 15.99 GiB (12.9%)
Processes: 475 Uptime: 16d 12h 51m Shell: Sudo inxi: 3.3.40
I often mount the NTFS 2TB drive, just the main file partition, to syncronize a password database and make some backups of important files on external luks volumes.
$ sudo lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS FSTYPE
sda 8:0 0 7.3T 0 disk
├─sda1 8:1 0 5.5T 0 part /run/media/resove/29 ext4
├─sda2 8:2 0 931.3G 0 part /run/media/resove/PS4 exfat
└─sda3 8:3 0 931.3G 0 part /run/media/resove/PS3 vfat
sdb 8:16 0 16.4T 0 disk crypto_LUKS 2
└─luks-35 253:3 0 16.4T 0 crypt /run/media/resove/18_1_RAID1 xfs
sdc 8:32 0 3.6T 0 disk
└─sdc1 8:33 0 3.6T 0 part /run/media/resove/PRIVATE_NTFS ntfs
sdd 8:48 0 9.1T 0 disk
└─sdd1 8:49 0 9.1T 0 part crypto_LUKS 2
└─luks-ef 253:2 0 9.1T 0 crypt /run/media/resove/storage-backup ext4
sde 8:64 1 0B 0 disk
nvme1n1 259:0 0 1.8T 0 disk
├─nvme1n1p1 259:1 0 300M 0 part /boot/efi vfat
├─nvme1n1p2 259:2 0 1.8T 0 part crypto_LUKS 1
│ └─luks-19 253:0 0 1.8T 0 crypt / xfs
└─nvme1n1p3 259:3 0 8.8G 0 part crypto_LUKS 1
└─luks-1c 253:1 0 8.8G 0 crypt [SWAP] swap
nvme0n1 259:4 0 1.8T 0 disk
├─nvme0n1p1 259:5 0 100M 0 part vfat
├─nvme0n1p2 259:6 0 16M 0 part
├─nvme0n1p3 259:7 0 1.8T 0 part /run/media/resove/64 ntfs
└─nvme0n1p4 259:8 0 708M 0 part ntfs
My last boot which was probably around 17 days ago, when I last asked questions on the forum when I think I removed a bunch of orphans, updated to a more recent kernel for rt support with my new piano, and changed a bunch of sound stuff and as well removed a few conflicting versions of compilers as some kind community support member(s) suggested. This is update history from after/during my last forum post:
[2026-04-26T02:12:50-0700] [ALPM] installed python-evdev (1.9.3-1)
[2026-04-26T02:12:50-0700] [ALPM] installed gamemode (1.8.2-1)
[2026-04-26T02:12:50-0700] [ALPM] installed winetricks (20260125-1)
[2026-04-26T02:12:50-0700] [ALPM] installed gamescope (3.16.22-1)
[2026-04-26T02:12:50-0700] [ALPM] installed xcb-util-errors (1.0.1-2)
[2026-04-26T02:12:50-0700] [ALPM] installed seatd (0.9.3-1)
[2026-04-26T02:12:50-0700] [ALPM] installed vkd3d (1.19-1)
[2026-04-26T02:12:50-0700] [ALPM] installed lib32-gamemode (1.8.2-1)
[2026-04-26T02:12:50-0700] [ALPM] installed lib32-vkd3d (1.19-1)
[2026-04-26T02:12:50-0700] [ALPM] installed python-protobuf (33.1-4)
[2026-04-26T02:12:50-0700] [ALPM] installed perl-json (4.10-2)
[2026-04-26T02:12:50-0700] [ALPM] installed lutris (0.5.22-1)
[2026-04-26T02:12:50-0700] [ALPM] installed cabextract (1.11-2)
[2026-04-26T02:12:50-0700] [ALPM] installed python-pefile (2024.8.26-2)
[2026-04-26T02:12:50-0700] [ALPM] installed libayatana-appindicator (0.5.94-1)
[2026-04-26T02:12:50-0700] [ALPM] installed mangohud (0.8.2-3)
[2026-04-26T02:12:50-0700] [ALPM] installed glfw (1:3.4-1)
[2026-04-26T02:12:50-0700] [ALPM] installed lib32-mangohud (0.8.2-1)
[2026-04-26T02:12:50-0700] [ALPM] installed lib32-glew (2.3.0-2)
[2026-04-26T02:12:50-0700] [ALPM] installed lib32-libxkbcommon (1.13.1-1)
[2026-04-26T02:12:50-0700] [ALPM] installed python-matplotlib (3.10.8-5)
[2026-04-26T02:12:50-0700] [ALPM] installed qhull (2020.2-5)
[2026-04-26T02:12:50-0700] [ALPM] installed python-pyparsing (3.3.2-1)
[2026-04-26T02:12:50-0700] [ALPM] installed python-kiwisolver (1.4.8-1)
[2026-04-26T02:12:50-0700] [ALPM] installed python-fonttools (4.62.1-1)
[2026-04-26T02:12:50-0700] [ALPM] installed python-dateutil (2.9.0-8)
[2026-04-26T02:12:50-0700] [ALPM] installed python-cycler (0.12.1-4)
[2026-04-26T02:12:50-0700] [ALPM] installed python-contourpy (1.3.3-3)
[2026-04-26T02:12:50-0700] [ALPM] installed python-moddb (0.14.0-2.0)
[2026-04-26T02:12:50-0700] [ALPM] installed python-curl-adapter (1.2.0-1)
[2026-04-26T02:12:50-0700] [ALPM] installed python-curl_cffi (0.14.0-6)
[2026-04-26T02:12:50-0700] [ALPM] installed python-gevent (25.9.1-2)
[2026-04-26T02:12:50-0700] [ALPM] installed python-zope-event (6.1-2)
[2026-04-26T02:12:50-0700] [ALPM] installed python-eventlet (0.40.4-2)
[2026-04-26T02:12:50-0700] [ALPM] installed python-greenlet (3.3.2-1)
[2026-04-26T02:12:50-0700] [ALPM] installed python-dnspython (1:2.8.0-3)
[2026-04-26T02:12:49-0700] [ALPM] installed python-certifi (2026.02.25-1)
[2026-04-26T02:12:49-0700] [ALPM] installed curl-impersonate (1.5.1-1)
[2026-04-26T02:12:49-0700] [ALPM] installed python-brotli (1.2.0-1)
[2026-04-26T02:12:49-0700] [ALPM] installed python-zope-interface (8.2-1)
[2026-04-26T02:12:49-0700] [ALPM] installed libxres (1.2.3-1)
[2026-04-26T02:12:49-0700] [ALPM] installed umu-launcher (1.3.0-2)
[2026-04-26T02:12:49-0700] [ALPM] installed python-cbor2 (5.8.0-2)
[2026-04-26T02:12:49-0700] [ALPM] installed python-pyzstd (0.19.1-3)
[2026-04-26T02:12:49-0700] [ALPM] installed python-xxhash (3.6.0-2)
[2026-04-26T02:12:49-0700] [ALPM] installed python-xlib (0.33-6)
[2026-04-26T02:12:49-0700] [ALPM] installed python-cffi (2.0.0-2)
[2026-04-26T02:12:49-0700] [ALPM] installed python-pycparser (2.23-2)
[2026-04-26T02:12:49-0700] [ALPM] installed python-pycurl (7.45.7-3)
[2026-04-26T02:12:49-0700] [ALPM] installed python-distro (1.9.0-4)
[2026-04-26T02:12:49-0700] [ALPM] installed wine (11.4-1)
[2026-04-24T11:58:09-0700] [ALPM] installed realtime-privileges (5-1)
[2026-04-24T11:58:09-0700] [ALPM] installed easyeffects (8.1.4-1)
[2026-04-24T11:58:09-0700] [ALPM] installed gsl (2.8-1)
[2026-04-24T11:58:09-0700] [ALPM] installed qt6-graphs (6.10.2-1)
[2026-04-24T11:58:09-0700] [ALPM] installed calf (0.90.8-6)
[2026-04-24T11:58:08-0700] [ALPM] installed qt6-quick3d (6.10.2-1)
[2026-04-24T11:58:08-0700] [ALPM] installed qt6-quicktimeline (6.10.2-1)
[2026-04-24T11:58:08-0700] [ALPM] installed webrtc-audio-processing (2.1-5)
[2026-04-24T11:58:08-0700] [ALPM] installed zita-convolver (4.0.3-5)
[2026-04-24T11:58:08-0700] [ALPM] installed openxr (1.1.57-1)
[2026-04-24T11:58:08-0700] [ALPM] installed nlohmann-json (3.12.0-2)
[2026-04-24T11:58:08-0700] [ALPM] installed lsp-plugins-lv2 (1.2.26-1)
[2026-04-24T00:14:33-0700] [ALPM] reinstalled decklink (16.0-1)
[2026-04-24T00:12:55-0700] [ALPM] installed linux618-headers (6.18.18-1)
[2026-04-24T00:12:54-0700] [ALPM] installed linux612-headers (6.12.77-1)
[2026-04-24T00:12:53-0700] [ALPM] installed pahole (1:1.31-2)
[2026-04-23T20:00:39-0700] [ALPM] reinstalled decklink (16.0-1)
[2026-04-23T18:49:39-0700] [ALPM] removed linux66 (6.6.128-1)
[2026-04-23T18:49:39-0700] [ALPM] removed linux66-nvidia-open (590.48.01-11)
[2026-04-23T18:44:30-0700] [ALPM] installed linux618-nvidia-open (590.48.01-19)
[2026-04-23T18:44:30-0700] [ALPM] installed linux618 (6.18.18-1)
[2026-04-22T21:22:13-0700] [ALPM] installed qpwgraph (0.9.9-1)
[2026-04-22T19:58:51-0700] [ALPM] installed lib32-pipewire-jack (1:1.6.2-1)
[2026-04-22T19:57:41-0700] [ALPM] installed pipewire-jack (1:1.6.2-1)
[2026-04-22T19:57:41-0700] [ALPM] removed jack2 (1.9.22-2)
[2026-04-22T19:07:45-0700] [ALPM] installed grilo-plugins (1:0.3.18-1)
[2026-04-22T19:07:45-0700] [ALPM] installed dleyna (0.8.3-4)
[2026-04-22T19:06:22-0700] [ALPM] removed grilo-plugins (1:0.3.18-1)
[2026-04-22T19:05:25-0700] [ALPM] removed audacity (1:3.7.7-1)
[2026-04-22T19:05:25-0700] [ALPM] removed audacity-docs (1:3.7.7-1)
[2026-04-22T19:02:44-0700] [ALPM] removed musescore (4.6.5-1)
[2026-04-22T19:02:26-0700] [ALPM] removed lmms (1.2.2-27)
[2026-04-22T19:01:28-0700] [ALPM] removed lib32-jack2 (1.9.22-2)
[2026-04-22T19:01:28-0700] [ALPM] removed jack2-dbus (1.9.22-2)
[2026-04-22T19:01:28-0700] [ALPM] removed jack2-docs (1.9.22-2)
[2026-04-22T19:01:28-0700] [ALPM] removed qtractor (1.5.11-2)
[2026-04-22T19:01:28-0700] [ALPM] removed alsa-tools (1.2.15-3)
[2026-04-22T19:01:28-0700] [ALPM] removed xjadeo (0.8.15-1)
[2026-04-22T19:01:28-0700] [ALPM] removed new-session-manager (1.6.1-3)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-pipewire (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed appstream-glib (0.8.3-3)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-qxl (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-spice (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-alsa (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed libgnome-games-support (1.8.2-4)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-system-x86 (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed libgnome-games-support-2 (2.0.2-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-block-nfs (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed libmatroska (1.7.1-2)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-sdl2_mixer (2.8.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-ui-spice-app (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-libcanberra (1:0.30+r2+gc0620e4-4)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-usb-host (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-sdl2_ttf (2.24.0-2)
[2026-04-22T19:00:25-0700] [ALPM] removed cantarell-fonts (1:0.311-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-vga-rutabaga (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed vcdimager (2.0.1-7)
[2026-04-22T19:00:25-0700] [ALPM] removed sdl2_ttf (2.24.0-2)
[2026-04-22T19:00:25-0700] [ALPM] removed sdl2_net (1:2.2.0-2)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-gpu-pci (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-vga (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-usb-redirect (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-sdl2_image (2.8.4-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-ui-gtk (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed virtiofsd (1.13.3-1)
[2026-04-22T19:00:25-0700] [ALPM] removed live-media (2025.05.24-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-gpu-rutabaga (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-gpu-pci-gl (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-usb-smartcard (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-sdl_mixer (1.2.12-6)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-uefi-vars (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-sdl_ttf (2.0.11-9)
[2026-04-22T19:00:25-0700] [ALPM] removed aribb24 (1.0.3-4)
[2026-04-22T19:00:25-0700] [ALPM] removed lirc (1:0.10.2-6)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-jack (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-gpu-gl (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-block-ssh (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-gpu-pci-rutabaga (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-openal (1.25.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-block-curl (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed aribb25 (0.2.7-3)
[2026-04-22T19:00:25-0700] [ALPM] removed lib32-sdl_image (1.2.12-9)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-dbus (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-vhost-user-gpu (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed dynamic-wallpaper (0.1.0-3)
[2026-04-22T19:00:25-0700] [ALPM] removed libvisual (0.4.2-2)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-ui-curses (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-gpu (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-block-dmg (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-sdl (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-oss (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-ui-egl-headless (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-audio-pa (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-img (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-ui-dbus (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-hw-display-virtio-vga-gl (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed aubio (0.4.9-24)
[2026-04-22T19:00:25-0700] [ALPM] removed qemu-ui-sdl (10.2.1-1)
[2026-04-22T19:00:25-0700] [ALPM] removed libinstpatch (1.1.7-2)
[2026-04-22T18:51:50-0700] [ALPM] removed adobe-source-code-pro-fonts (2.042u+1.062i+1.026vf-2)
[2026-04-22T18:50:20-0700] [ALPM] removed reiserfsprogs (3.6.27-7)
[2026-04-22T18:49:15-0700] [ALPM] removed libvirt (1:12.1.0-1)
[2026-04-22T18:49:15-0700] [ALPM] removed libvirt-glib (5.0.0-3)
[2026-04-22T18:48:48-0700] [ALPM] removed qemu-base (10.2.1-1)
[2026-04-22T18:48:22-0700] [ALPM] removed qemu-desktop (10.2.1-1)
[2026-04-22T18:45:03-0700] [ALPM] removed ardour (9.2-2)
[2026-04-22T18:42:42-0700] [ALPM] removed libvlc (3.0.21-32)
[2026-04-22T15:22:32-0700] [ALPM] removed a2jmidid (9-6)
[2026-04-22T15:22:32-0700] [ALPM] removed jacksettings (0.1.0-1)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-journal (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-dav1d (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-vorbis (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-jpeg (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-png (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-opus (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-speex (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-vpx (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-tag (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-inflate (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-xml (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-archive (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-twolame (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-gnutls (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-theora (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-alsa (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-dbus (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-flac (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-mpg123 (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-a52dec (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-shout (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-dbus-screensaver (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-faad2 (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-ogg (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugins-base (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-live555 (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-freetype (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-dvd (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-jack (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-notify (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-soxr (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-quicksync (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-sdl (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-svg (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-mdns (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-lirc (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-modplug (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-gstreamer (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-mtp (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-zvbi (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-gme (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-matroska (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-dca (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-lua (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-libsecret (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-pulse (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-musepack (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-sftp (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-mpeg2 (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-x264 (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-x265 (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-firewire (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-kate (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-srt (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-nfs (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-samplerate (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-dvb (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-kwallet (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-udev (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-fluidsynth (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-mad (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-upnp (3.0.21-32)
[2026-04-22T15:21:26-0700] [ALPM] removed vlc-plugin-smb (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-ass (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-aribb24 (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-aom (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-caca (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-cddb (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-avahi (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-bluray (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-aalib (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-aribb25 (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-chromecast (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugins-extra (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugins-video-output (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugin-ffmpeg (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugins-visualization (3.0.21-32)
[2026-04-22T15:19:26-0700] [ALPM] removed vlc-plugins-all (3.0.21-32)
[2026-04-22T15:15:04-0700] [ALPM] removed vlc-cli (3.0.21-32)
[2026-04-22T15:15:04-0700] [ALPM] removed vlc-gui-qt (3.0.21-32)
[2026-04-22T15:14:45-0700] [ALPM] removed vlc (3.0.21-32)
[2026-04-22T14:28:55-0700] [ALPM] installed jacksettings (0.1.0-1)
[2026-04-22T14:28:40-0700] [ALPM] installed a2jmidid (9-6)
[2026-04-22T14:13:00-0700] [ALPM] installed helvum (0.5.1-1)
[2026-04-22T14:12:16-0700] [ALPM] installed apulse (0.1.14-1)
[2026-04-22T14:06:47-0700] [ALPM] upgraded firefox (149.0.2-1 -> 150.0-1)
[2026-04-22T14:00:55-0700] [ALPM] installed lib32-jack2 (1.9.22-2)
[2026-04-22T14:00:55-0700] [ALPM] installed lib32-libsamplerate (0.2.2-3)
[2026-04-22T14:00:55-0700] [ALPM] installed jack2-docs (1.9.22-2)
[2026-04-22T14:00:55-0700] [ALPM] installed jack2-dbus (1.9.22-2)
[2026-04-22T13:50:12-0700] [ALPM] installed python-pyalsa (1.2.14-2)
[2026-04-22T13:50:12-0700] [ALPM] installed alsa-tools (1.2.15-3)
[2026-04-22T13:50:12-0700] [ALPM] installed pulseaudio-alsa (1:1.2.12-5)
[2026-04-22T13:50:12-0700] [ALPM] installed fltk1.3 (1.3.11-3)
[2026-04-22T13:34:48-0700] [ALPM] installed qastools (1.4.0-2)
[2026-04-22T13:34:48-0700] [ALPM] removed jack_mixer (19-3)
[2026-04-22T13:17:23-0700] [ALPM] installed jack_mixer (19-3)
[2026-04-21T09:45:44-0700] [ALPM] installed nvtop (3.3.2-1)
[2026-04-21T02:00:09-0700] [ALPM] installed linux66-nvidia-open (590.48.01-11)
[2026-04-21T02:00:09-0700] [ALPM] installed linux612-nvidia-open (590.48.01-15)
[2026-04-21T02:00:09-0700] [ALPM] installed lib32-nvidia-utils (590.48.01-1)
[2026-04-21T01:58:45-0700] [ALPM] installed nvidia-prime (1.0-5)
[2026-04-20T22:34:51-0700] [ALPM] installed nvidia-settings (590.48.01-3)
[2026-04-20T22:34:51-0700] [ALPM] installed nvidia-utils (590.48.01-3)
[2026-04-20T22:34:50-0700] [ALPM] installed egl-x11 (1.0.5-1)
[2026-04-20T22:34:50-0700] [ALPM] installed egl-gbm (1.1.3-1)
[2026-04-20T22:34:50-0700] [ALPM] installed egl-wayland2 (1.0.1-1)
[2026-04-20T22:29:55-0700] [ALPM] installed vulkan-tools (1.4.341.0-2)
[2026-04-20T14:40:04-0700] [ALPM] installed qtractor (1.5.11-2)
[2026-04-20T14:40:04-0700] [ALPM] installed lmms (1.2.2-27)
[2026-04-20T14:40:03-0700] [ALPM] installed stk (5.0.1-3)
[2026-04-20T14:40:03-0700] [ALPM] installed libgig (4.5.2-1)
[2026-04-20T14:35:54-0700] [ALPM] installed musescore (4.6.5-1)
[2026-04-20T14:35:54-0700] [ALPM] installed qt6-scxml (6.10.2-1)
[2026-04-20T14:35:54-0700] [ALPM] installed qt6-networkauth (6.10.2-1)
[2026-04-20T14:35:54-0700] [ALPM] installed libopusenc (0.3-1)
[2026-04-20T14:35:54-0700] [ALPM] installed tinyxml2 (11.0.0-2)
[2026-04-20T13:17:54-0700] [ALPM] removed quadrapassel (49.3-1)
[2026-04-20T13:17:54-0700] [ALPM] removed iagno (3.38.1+r137+g0d01085-1)
[2026-04-20T13:17:54-0700] [ALPM] removed plasmatube (25.12.3-1)
[2026-04-20T13:17:54-0700] [ALPM] removed gnome-boxes (49.1-2)
[2026-04-20T13:17:54-0700] [ALPM] removed simple-scan (49.1-1)
[2026-04-20T13:13:40-0700] [ALPM] removed electron38 (38.8.0-1)
[2026-04-20T13:13:20-0700] [ALPM] removed electron35 (35.7.5-1)
[2026-04-20T13:13:20-0700] [ALPM] removed electron37 (37.5.1-1)
[2026-04-20T13:13:20-0700] [ALPM] removed electron34 (34.5.8-1)
[2026-04-20T13:13:20-0700] [ALPM] removed electron36 (36.9.3-1)
[2026-04-20T12:14:45-0700] [ALPM] removed gnome-shell-extension-x11gestures (25-1)
[2026-04-20T12:14:19-0700] [ALPM] removed gstreamer0.10 (0.10.36-20)
[2026-04-20T12:14:19-0700] [ALPM] removed gstreamer0.10-base (0.10.36-13)
[2026-04-20T12:13:49-0700] [ALPM] removed gcc13-libs (13.4.1+r80+gd6ebfe4-1)
[2026-04-20T12:13:49-0700] [ALPM] removed gcc13 (13.4.1+r80+gd6ebfe4-1)
[2026-04-20T12:13:49-0700] [ALPM] removed gcc14-libs (14.3.1+r516+g5998566829ee-1)
[2026-04-20T12:13:49-0700] [ALPM] removed gcc14 (14.3.1+r516+g5998566829ee-1)
[2026-04-20T12:12:38-0700] [ALPM] removed steam-native-runtime (1.0.0.75-8)
[2026-04-18T11:54:33-0700] [ALPM] upgraded lib32-openssl-1.1 (1.1.1.w-2 -> 1.1.1.w-3)
[2026-04-18T11:50:03-0700] [ALPM] upgraded chromium (147.0.7727.55-1 -> 147.0.7727.101-1)
[2026-04-18T03:50:39-0700] [ALPM] installed pacutils (0.15.0-2)
[2026-04-18T02:22:15-0700] [ALPM] upgraded botan2 (2.19.5-2 -> 2.19.5-4)
[2026-04-18T02:21:51-0700] [ALPM] upgraded ncurses5-compat-libs (6.5-2 -> 6.6-1)
[2026-04-18T02:21:04-0700] [ALPM] upgraded reiserfsprogs (3.6.27-5 -> 3.6.27-7)
[2026-04-18T02:19:47-0700] [ALPM] upgraded gcc14 (14.3.1+r420+g039a62bd2e0c-1 -> 14.3.1+r516+g5998566829ee-1)
[2026-04-18T02:16:15-0700] [ALPM] upgraded stremio (4.4.169-1 -> 4.4.183-1)
[2026-04-18T02:09:20-0700] [ALPM] upgraded decklink (15.3.1-1 -> 16.0-1)
[2026-04-18T02:03:05-0700] [ALPM] upgraded qt5-websockets (5.15.17+kde+r2-1 -> 5.15.18+kde+r2-1)
[2026-04-18T02:00:33-0700] [ALPM] upgraded clutter-gtk (1.8.4-4 -> 1.8.4-5)
[2026-04-18T01:57:17-0700] [ALPM] upgraded libtiff4 (3.9.7-7 -> 3.9.7-8)
[2026-04-18T01:56:31-0700] [ALPM] upgraded openssl-1.1 (1.1.1.w-7 -> 1.1.1.w-9)
[2026-04-18T01:55:52-0700] [ALPM] upgraded gcc14-libs (14.3.1+r420+g039a62bd2e0c-1 -> 14.3.1+r516+g5998566829ee-1)
[2026-04-18T01:55:04-0700] [ALPM] upgraded clutter (1.26.4-3 -> 1.26.4-4)
[2026-04-18T01:53:56-0700] [ALPM] upgraded qt5-webengine (5.15.19-2 -> 5.15.19-4)
[2026-04-17T14:35:15-0700] [ALPM] upgraded cogl (1.22.8-3 -> 1.22.8-5)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinx (9.1.0-1)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinxcontrib-serializinghtml (2.0.0-5)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinxcontrib-qthelp (2.0.0-5)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinxcontrib-jsmath (1.0.1-21)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinxcontrib-htmlhelp (2.1.0-5)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinxcontrib-devhelp (2.0.0-6)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinxcontrib-applehelp (2.0.0-5)
[2026-04-17T14:23:57-0700] [ALPM] installed python-sphinx-alabaster-theme (1.0.0-6)
[2026-04-17T14:23:57-0700] [ALPM] installed python-snowballstemmer (3.0.0.1-1)
[2026-04-17T14:23:57-0700] [ALPM] installed python-roman-numerals-py (3.1.0-2)
[2026-04-17T14:23:57-0700] [ALPM] installed python-jinja (1:3.1.6-3)
[2026-04-17T14:23:57-0700] [ALPM] installed python-imagesize (1.4.1-7)
[2026-04-17T14:23:57-0700] [ALPM] installed python-docutils (1:0.22.4-1)
[2026-04-17T14:23:57-0700] [ALPM] installed python-babel (2.17.0-3)
[2026-04-17T14:23:57-0700] [ALPM] installed boost (1.89.0-4)
[2026-04-17T14:23:56-0700] [ALPM] installed meson (1.10.2-1)
[2026-04-17T14:23:56-0700] [ALPM] installed python-tqdm (4.67.3-1)
[2026-04-17T14:18:15-0700] [ALPM] upgraded zsh-completions (0.35.0-3 -> 0.36.0-1)
[2026-04-17T14:18:15-0700] [ALPM] upgraded xapp-symbolic-icons (1.0.9-0.1 -> 1.0.9-1)
[2026-04-17T14:18:15-0700] [ALPM] upgraded wxwidgets-gtk3 (3.2.9-4 -> 3.2.10-1)
[2026-04-17T14:18:15-0700] [ALPM] upgraded wxwidgets-common (3.2.9-4 -> 3.2.10-1)
[2026-04-17T14:18:15-0700] [ALPM] upgraded webkit2gtk (2.50.5-1 -> 2.50.6-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded vim (9.2.0010-1 -> 9.2.0081-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded vim-runtime (9.2.0010-1 -> 9.2.0081-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded transmission-gtk (4.1.0-1 -> 4.1.1-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded transmission-cli (4.1.0-1 -> 4.1.1-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded systemd-sysvcompat (259.1-1 -> 259.5-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded suil (0.10.24-1 -> 0.10.26-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded steam (1.0.0.85-4 -> 1.0.0.85-6)
[2026-04-17T14:18:14-0700] [ALPM] upgraded steam-devices (1.0.0.85-4 -> 1.0.0.85-6)
[2026-04-17T14:18:14-0700] [ALPM] upgraded sstp-client (1:1.0.19-5 -> 1:1.0.20-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded squashfs-tools (4.7.4-1 -> 4.7.5-1)
[2026-04-17T14:18:14-0700] [ALPM] upgraded signal-desktop (8.0.0-1 -> 8.7.0-1)
[2026-04-17T14:18:13-0700] [ALPM] upgraded sane (1.4.0-3 -> 1.4.0-4)
[2026-04-17T14:18:13-0700] [ALPM] upgraded samba (2:4.23.5-1 -> 2:4.23.6-1)
[2026-04-17T14:18:13-0700] [ALPM] upgraded quadrapassel (49.2.3-1 -> 49.3-1)
[2026-04-17T14:18:13-0700] [ALPM] upgraded qt6-tools (6.10.2-1 -> 6.10.2-3)
[2026-04-17T14:18:13-0700] [ALPM] upgraded qt5-tools (5.15.18+kde+r3-1 -> 5.15.18+kde+r3-2)
[2026-04-17T14:18:13-0700] [ALPM] upgraded python-setuptools (1:82.0.0-1 -> 1:82.0.1-1)
[2026-04-17T14:18:13-0700] [ALPM] upgraded python-platformdirs (4.9.2-1 -> 4.9.4-1)
[2026-04-17T14:18:13-0700] [ALPM] upgraded python-numpy (2.4.2-1 -> 2.4.3-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded python-markupsafe (3.0.2-2 -> 3.0.3-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded python-iniconfig (2.1.0-3 -> 2.2.0-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded python-click (8.3.1-1 -> 8.3.1-3)
[2026-04-17T14:18:12-0700] [ALPM] upgraded plasmatube (25.12.2-1 -> 25.12.3-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded qqc2-desktop-style (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded purpose (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded pipewire-alsa (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded ostree (2025.7-2 -> 2025.7-3)
[2026-04-17T14:18:12-0700] [ALPM] upgraded os-prober (1.83-1 -> 1.84-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded openmp (21.1.8-1 -> 22.1.1-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded opencl-mesa (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded spirv-llvm-translator (21.1.4-3 -> 22.1.0-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded obs-studio (32.0.4-1 -> 32.1.0-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded noto-fonts-extra (1:2026.02.01-1 -> 1:2026.03.01-1)
[2026-04-17T14:18:12-0700] [ALPM] upgraded nodejs (25.6.1-1 -> 25.8.1-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded simdjson (1:4.2.4-1 -> 1:4.4.0-1)
[2026-04-17T14:18:11-0700] [ALPM] installed ada (3.4.3-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded nftables (1:1.1.6-2 -> 1:1.1.6-3)
[2026-04-17T14:18:11-0700] [ALPM] upgraded nfs-utils (2.8.5-2 -> 2.8.7-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded nfsidmap (2.8.5-2 -> 2.8.7-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded networkmanager (1.54.3-1 -> 1.56.0-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded mujs (1.3.8-1 -> 1.3.9-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded mhwd-nvidia-390xx (390.157-21 -> 390.157-23)
[2026-04-17T14:18:11-0700] [ALPM] upgraded manjaro-release (26.0.3-1 -> 26.0.4-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded lsof (4.99.5-2 -> 4.99.6-1)
[2026-04-17T14:18:11-0700] [ALPM] upgraded linux66 (6.6.126-1 -> 6.6.128-1)
[2026-04-17T14:18:10-0700] [ALPM] upgraded linux612 (6.12.73-1 -> 6.12.77-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-meta (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-realtek (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-radeon (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-other (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-nvidia (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-mediatek (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-intel (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-cirrus (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-broadcom (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-atheros (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-amdgpu (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded linux-firmware-whence (20260110-1 -> 20260309-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded libvncserver (0.9.14-4 -> 0.9.15-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded libsynctex (2025.2-3 -> 2026.0-1)
[2026-04-17T14:18:09-0700] [ALPM] upgraded libreoffice-still (25.8.4-3 -> 25.8.5-3)
[2026-04-17T14:18:07-0700] [ALPM] upgraded lpsolve (5.5.2.11-3 -> 5.5.2.14-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded libphonenumber (1:9.0.24-1 -> 1:9.0.26-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded libid3tag (0.16.3-2 -> 0.16.4-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded libclc (21.1.8-1 -> 22.1.1-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded libc++ (21.1.8-1 -> 22.1.1-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded libc++abi (21.1.8-1 -> 22.1.1-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded lib32-vulkan-radeon (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded vulkan-radeon (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded lib32-vulkan-nouveau (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded vulkan-nouveau (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded lib32-vulkan-intel (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded vulkan-intel (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded lib32-vulkan-mesa-implicit-layers (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:07-0700] [ALPM] upgraded vulkan-mesa-implicit-layers (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-sdl2_mixer (2.8.0-1 -> 2.8.1-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded libxmp (4.6.3-1 -> 4.7.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-sdl3 (3.4.0-1 -> 3.4.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-pipewire (1:1.4.10-1 -> 1:1.6.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-mesa (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-llvm-libs (1:21.1.8-1 -> 1:22.1.1-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libxml2 (2.15.1-4 -> 2.15.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libpipewire (1:1.4.10-1 -> 1:1.6.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libnm (1.54.3-1 -> 1.56.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-nss (3.120.1-1 -> 3.121-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-sqlite (3.51.2-1 -> 3.52.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libcurl-gnutls (8.18.0-4 -> 8.19.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded libcurl-gnutls (8.18.0-3 -> 8.19.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libcurl-compat (8.18.0-4 -> 8.19.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded libcurl-compat (8.18.0-3 -> 8.19.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-harfbuzz (12.3.2-1 -> 13.1.1-2)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-freetype2 (2.14.1-1 -> 2.14.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-curl (8.18.0-4 -> 8.19.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libldap (2.6.12-1 -> 2.6.13-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-e2fsprogs (1.47.3-2 -> 1.47.4-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libngtcp2 (1.20.0-1 -> 1.21.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-audit (4.1.2-1 -> 4.1.3-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-at-spi2-core (2.58.3-1 -> 2.58.4-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-zlib (1.3.1-2 -> 1.3.2-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-systemd (259.1-1 -> 259.5-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libgcrypt (1.12.0-1 -> 1.12.1-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded lib32-libgpg-error (1.58-1 -> 1.59-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kirigami-addons (1.11.0-1 -> 1.12.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded sonnet (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded ksvg (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kitemmodels (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded keepassxc (2.7.11-1 -> 2.7.12-2)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kdeclarative (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kauth (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kaccounts-integration (25.12.2-1 -> 25.12.3-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded signon-kwallet-extension (25.12.2-1 -> 25.12.3-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kcmutils (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kxmlgui (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kglobalaccel (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kirigami (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kio (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded solid (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kwallet (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded qca-qt6 (2.3.10-4 -> 2.3.10-5)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kwindowsystem (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kservice (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kjobwidgets (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded knotifications (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kitemviews (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kiconthemes (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kdbusaddons (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kcrash (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kcompletion (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kbookmarks (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded karchive (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kconfigwidgets (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:06-0700] [ALPM] upgraded kwidgetsaddons (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded kcoreaddons (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded kcolorscheme (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded ki18n (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded kguiaddons (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded kcodecs (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded kconfig (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded iproute2 (6.18.0-1 -> 6.19.0-2)
[2026-04-17T14:18:05-0700] [ALPM] upgraded intel-ucode (20260210-1 -> 20260227-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded intel-media-driver (25.3.4-2 -> 25.4.6-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded hwinfo (25.0-2 -> 25.2-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded perl-clone (0.47-2 -> 0.48-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded perl-timedate (2.33-9 -> 2.34-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded handbrake (1.10.2-4 -> 1.11.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-wsdd (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-smb (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-onedrive (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-nfs (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-mtp (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-gphoto2 (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-google (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded libgdata (0.18.1-4 -> 0.18.1-5)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-goa (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-dnssd (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gvfs-afc (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gtk-doc (1.35.1-1 -> 1.36.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-plugins-ugly (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-plugins-bad (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded imagemagick (7.1.2.13-2 -> 7.1.2.17-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded zxing-cpp (3.0.1-1 -> 3.0.2-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded libsrtp (1:2.7.0-1 -> 1:2.8.0-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-plugin-pipewire (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-plugin-gtk4 (0.14.4-1 -> 0.15.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-plugin-gtk (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-libav (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-editing-services (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-python (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gst-devtools-libs (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded groff (1.23.0-8 -> 1.24.1-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded graphviz (14.1.2-1 -> 14.1.3-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded gom (0.5.5-2 -> 0.5.6-1)
[2026-04-17T14:18:05-0700] [ALPM] upgraded go (2:1.25.7-1 -> 2:1.26.1-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-shell-extension-gtk4-desktop-icons-ng (1:100.17-1 -> 1:100.22-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-shell-extension-dash-to-panel (72-1 -> 73-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-shell-extension-dash-to-dock (103-2 -> 105-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-shell-extension-arc-menu (68.0-1 -> 69.0-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-shell-extension-appindicator (1:63-1 -> 1:64-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-maps (49.4-1 -> 49.5-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-control-center (49.4-2 -> 49.6-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-keybindings (49.4-2 -> 49.6-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded smbclient (2:4.23.5-1 -> 2:4.23.6-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded ldb (2:4.23.5-1 -> 2:4.23.6-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-online-accounts (3.56.4-1 -> 3.56.5-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded libgoa (3.56.4-1 -> 3.56.5-1)
[2026-04-17T14:18:03-0700] [ALPM] upgraded gnome-boxes (49.1-1 -> 49.1-2)
[2026-04-17T14:18:02-0700] [ALPM] upgraded gst-plugins-good (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded libvirt (1:12.0.0-2 -> 1:12.1.0-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded libnbd (1.24.0-2 -> 1.24.2-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded webkit2gtk-4.1 (2.50.5-1 -> 2.50.6-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-desktop (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-vhost-user-gpu (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-spice-app (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-sdl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-gtk (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-egl-headless (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-dbus (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-curses (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-usb-smartcard (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-usb-redirect (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-usb-host (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-uefi-vars (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-vga-rutabaga (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-vga-gl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-vga (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-rutabaga (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-gl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-gpu-rutabaga (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-gpu-gl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-virtio-gpu (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-hw-display-qxl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-chardev-spice (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-block-ssh (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-block-nfs (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-block-dmg (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-block-curl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-spice (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-spice-core (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-ui-opengl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-sdl (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-pipewire (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-pa (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-oss (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-jack (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-dbus (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-audio-alsa (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-base (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-system-x86 (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-system-x86-firmware (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded rdma-core (61.0-1 -> 62.0-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded ndctl (79-1 -> 82-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded libtraceevent (1:1.8.7-1 -> 1:1.9.0-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded libxdp (1.6.1-1 -> 1.6.2-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-img (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded qemu-common (10.2.0-2 -> 10.2.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded gmic (3.7.0-1 -> 3.7.3-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded gst-plugins-base (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded gegl (0.4.66-2 -> 0.4.68-1)
[2026-04-17T14:18:02-0700] [ALPM] upgraded openexr (3.4.4-1 -> 3.4.7-1)
[2026-04-17T14:18:02-0700] [ALPM] installed openjph (0.26.3-3)
[2026-04-17T14:18:02-0700] [ALPM] upgraded luajit (2.1.1767980792+707c12b-2 -> 2.1.1772619647+659a616-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded gdm (49.2-2 -> 49.2-3)
[2026-04-17T14:18:01-0700] [ALPM] upgraded gnome-shell (1:49.4-3 -> 1:49.5-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded nautilus (49.4-1 -> 49.5-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded poppler-glib (26.01.0-1 -> 26.03.0-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded poppler (26.01.0-1 -> 26.03.0-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded libinih (61-1 -> 62-2)
[2026-04-17T14:18:01-0700] [ALPM] upgraded libfyaml (0.9.4-1 -> 0.9.6-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded libnautilus-extension (49.4-1 -> 49.5-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded gvfs (1.58.1-1 -> 1.58.3-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded udisks2 (2.11.0-1 -> 2.11.1-2)
[2026-04-17T14:18:01-0700] [ALPM] upgraded mdadm (4.4-2 -> 4.5-2)
[2026-04-17T14:18:01-0700] [ALPM] upgraded webkitgtk-6.0 (2.50.5-1 -> 2.50.6-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded libavif (1.3.0-5 -> 1.4.0-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded harfbuzz-icu (12.3.2-1 -> 13.1.1-2)
[2026-04-17T14:18:01-0700] [ALPM] upgraded mutter (49.4-1 -> 49.5-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded pipewire-pulse (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded pipewire-session-manager (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded pipewire-audio (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded spandsp (0.0.6-6 -> 0.0.6-7)
[2026-04-17T14:18:01-0700] [ALPM] upgraded libldac (2.0.2.3-2 -> 2.0.2.3-3)
[2026-04-17T14:18:01-0700] [ALPM] upgraded gst-plugins-bad-libs (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded gst-plugins-base-libs (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:01-0700] [ALPM] upgraded gstreamer (1.28.0-2 -> 1.28.1-1)
[2026-04-17T14:18:00-0700] [ALPM] upgraded pipewire (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:18:00-0700] [ALPM] upgraded iio-sensor-proxy (3.8-1 -> 3.9-1)
[2026-04-17T14:18:00-0700] [ALPM] installed libssc (0.4.1-1)
[2026-04-17T14:18:00-0700] [ALPM] upgraded libnm (1.54.3-1 -> 1.56.0-1)
[2026-04-17T14:18:00-0700] [ALPM] upgraded libgdm (49.2-2 -> 49.2-3)
[2026-04-17T14:18:00-0700] [ALPM] upgraded gjs (2:1.86.0-1 -> 2:1.86.0-2)
[2026-04-17T14:18:00-0700] [ALPM] upgraded js140 (140.7.1-1 -> 140.8.0-1)
[2026-04-17T14:18:00-0700] [ALPM] upgraded fwupd (2.0.19-1 -> 2.1.1-1)
[2026-04-17T14:18:00-0700] [ALPM] upgraded protobuf (33.1-3 -> 33.1-4)
[2026-04-17T14:18:00-0700] [ALPM] upgraded freerdp (2:3.22.0-2 -> 2:3.23.0-1)
[2026-04-17T14:18:00-0700] [ALPM] upgraded foomatic-db-ppds (3:20251122-1 -> 3:20260209-1)
[2026-04-17T14:17:59-0700] [ALPM] upgraded foomatic-db-nonfree-ppds (3:20251122-1 -> 3:20260209-1)
[2026-04-17T14:17:59-0700] [ALPM] upgraded foomatic-db-nonfree (3:20251122-1 -> 3:20260209-1)
[2026-04-17T14:17:59-0700] [ALPM] upgraded foomatic-db (3:20251122-1 -> 3:20260209-1)
[2026-04-17T14:17:59-0700] [ALPM] upgraded flashrom (1.6.0-2 -> 1.7.0-1)
[2026-04-17T14:17:59-0700] [ALPM] upgraded firefox (148.0-1 -> 149.0.2-1)
[2026-04-17T14:17:58-0700] [ALPM] upgraded noto-fonts (1:2026.02.01-1 -> 1:2026.03.01-1)
[2026-04-17T14:17:58-0700] [ALPM] upgraded enchant (2.8.14-1 -> 2.8.15-1)
[2026-04-17T14:17:58-0700] [ALPM] upgraded element-desktop (1.12.9-0.1 -> 1.12.9-1)
[2026-04-17T14:17:58-0700] [ALPM] upgraded element-web (1.12.9-0.1 -> 1.12.9-1)
[2026-04-17T14:17:58-0700] [ALPM] upgraded doxygen (1.16.1-2 -> 1.16.1-3)
[2026-04-17T14:17:58-0700] [ALPM] upgraded fmt (12.1.0-1 -> 12.1.0-2)
[2026-04-17T14:17:58-0700] [ALPM] upgraded debuginfod (0.194-1 -> 0.194-2)
[2026-04-17T14:17:58-0700] [ALPM] upgraded cpupower (6.19-2 -> 6.19.7-1)
[2026-04-17T14:17:58-0700] [ALPM] upgraded clonezilla (5.14.5-1 -> 5.15.7-1)
[2026-04-17T14:17:57-0700] [ALPM] installed jq (1.8.1-1)
[2026-04-17T14:17:57-0700] [ALPM] installed oniguruma (6.9.10-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded sshfs (3.7.3-3 -> 3.7.5-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded partclone (0.3.45-1 -> 0.3.47-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded liburcu (0.15.5-1 -> 0.15.6-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded drbl (5.7.12-1 -> 5.8.2-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded clang (21.1.8-1 -> 22.1.1-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded compiler-rt (21.1.8-1 -> 22.1.1-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded ckbcomp (1.227-2 -> 1.245-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded cifs-utils (7.4-1 -> 7.5-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded libwbclient (2:4.23.5-1 -> 2:4.23.6-1)
[2026-04-17T14:17:57-0700] [ALPM] upgraded chromium (145.0.7632.116-1 -> 147.0.7727.55-1)
[2026-04-17T14:17:56-0700] [ALPM] upgraded libsoup3 (3.6.6-1 -> 3.6.6-2)
[2026-04-17T14:17:56-0700] [ALPM] upgraded minizip (1:1.3.1-2 -> 1:1.3.2-3)
[2026-04-17T14:17:56-0700] [ALPM] upgraded nss (3.120.1-1 -> 3.121-1)
[2026-04-17T14:17:56-0700] [ALPM] upgraded breeze-icons (6.23.0-1 -> 6.24.0-1)
[2026-04-17T14:17:53-0700] [ALPM] upgraded xkeyboard-config (2.46-1 -> 2.47-1)
[2026-04-17T14:17:53-0700] [ALPM] upgraded botan (3.10.0-2 -> 3.11.0-1.0)
[2026-04-17T14:17:53-0700] [ALPM] upgraded bluez-obex (5.86-2 -> 5.86-4)
[2026-04-17T14:17:53-0700] [ALPM] upgraded bluez-libs (5.86-2 -> 5.86-4)
[2026-04-17T14:17:53-0700] [ALPM] upgraded bluez (5.86-2 -> 5.86-4)
[2026-04-17T14:17:53-0700] [ALPM] upgraded babl (0.1.122-1 -> 0.1.124-1)
[2026-04-17T14:17:53-0700] [ALPM] upgraded at-spi2-core (2.58.3-1 -> 2.58.4-1)
[2026-04-17T14:17:53-0700] [ALPM] upgraded ardour (8.12-4 -> 9.2-2)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libsodium (1.0.20-1 -> 1.0.21-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded bubblewrap (0.11.0-1 -> 0.11.0-2)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libplacebo (7.360.0-1 -> 7.360.1-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded shaderc (2026.1-1 -> 2026.1-2)
[2026-04-17T14:17:51-0700] [ALPM] upgraded gsm (1.0.23-1 -> 1.0.24-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libbluray (1.4.0-2 -> 1.4.1-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded v4l-utils (1.32.0-1 -> 1.32.0-2)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libvpx (1.15.2-2 -> 1.15.2-3)
[2026-04-17T14:17:51-0700] [ALPM] upgraded glslang (1:1.4.341.0-1 -> 1:1.4.341.0-2)
[2026-04-17T14:17:51-0700] [ALPM] upgraded harfbuzz (12.3.2-1 -> 13.1.1-2)
[2026-04-17T14:17:51-0700] [ALPM] upgraded freetype2 (2.14.1-2 -> 2.14.2-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libva (2.22.0-1 -> 2.23.0-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded lilv (0.26.2-3 -> 0.26.4-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded sratom (0.6.20-1 -> 0.6.22-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded sord (0.16.20-1 -> 0.16.22-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded serd (0.32.6-1 -> 0.32.8-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libwebsockets (4.4.1-1 -> 4.4.2-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libuv (1.52.0-1 -> 1.52.1-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded fluidsynth (2.5.2-1 -> 2.5.3-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libpipewire (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded sdl3 (3.4.0-4 -> 3.4.2-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded mesa (1:25.3.5-1 -> 1:26.0.2-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded spirv-tools (1:1.4.341.0-1 -> 1:1.4.341.0-2)
[2026-04-17T14:17:51-0700] [ALPM] upgraded llvm-libs (21.1.8-1 -> 22.1.1-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded libedit (20250104_3.1-1 -> 20251016_3.1-1)
[2026-04-17T14:17:51-0700] [ALPM] upgraded taglib (2.1.1-1 -> 2.2.1-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded archlinux-keyring (20260206-1 -> 20260301-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded python-requests (2.32.5-3 -> 2.32.5-4)
[2026-04-17T14:17:49-0700] [ALPM] upgraded python-charset-normalizer (3.4.4-2 -> 3.4.6-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded gpgme (2.0.1-1 -> 2.0.1-3)
[2026-04-17T14:17:49-0700] [ALPM] upgraded libksba (1.6.7-2 -> 1.6.8-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded gawk (5.3.2-1 -> 5.4.0-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded libarchive (3.8.5-1 -> 3.8.6-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded libxml2 (2.15.1-5 -> 2.15.2-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded apparmor (4.1.6-1 -> 4.1.7-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded amd-ucode (20260110-1 -> 20260309-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded alsa-card-profiles (1:1.4.10-2 -> 1:1.6.2-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded adwaita-fonts (49.0-2 -> 50.0-1)
[2026-04-17T14:17:49-0700] [ALPM] upgraded accountsservice (23.13.9-3 -> 25.34.76-2)
[2026-04-17T14:17:47-0700] [ALPM] upgraded systemd (259.1-1 -> 259.5-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded file (5.46-5 -> 5.47-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded libelf (0.194-1 -> 0.194-2)
[2026-04-17T14:17:47-0700] [ALPM] upgraded curl (8.18.0-3 -> 8.19.0-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded ca-certificates-mozilla (3.120.1-1 -> 3.121-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded audit (4.1.2-2 -> 4.1.3-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded libldap (2.6.12-1 -> 2.6.13-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded lmdb (0.9.33-1 -> 0.9.35-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded e2fsprogs (1.47.3-2 -> 1.47.4-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded sqlite (3.51.2-1 -> 3.52.0-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded libcap-ng (0.9-1 -> 0.9.1-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded libngtcp2 (1.20.0-1 -> 1.21.0-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded gmp (6.3.0-2 -> 6.3.0-3)
[2026-04-17T14:17:47-0700] [ALPM] upgraded hwdata (0.404-1 -> 0.405-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded systemd-libs (259.1-1 -> 259.5-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded zlib (1:1.3.1-2 -> 1:1.3.2-3)
[2026-04-17T14:17:47-0700] [ALPM] upgraded libgcrypt (1.12.0-1 -> 1.12.1-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded libgpg-error (1.58-1 -> 1.59-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded iana-etc (20260203-1 -> 20260306-1)
[2026-04-17T14:17:47-0700] [ALPM] upgraded tzdata (2025c-1 -> 2026a-1)
[2026-04-17T14:15:51-0700] [ALPM] installed yay (12.5.7-1)
[2026-03-03T21:38:26-0800] [ALPM] upgraded wireless-regdb (2025.10.07-1 -> 2026.02.04-1)
This is my primary machine, and it’s on Manjaro. While I’m somewhat familure with the cli, I really dislike chrooting into my system and fixing grub and it’s never any fun trying to understand and fix grub/boot things for me, even though I’ve successfully recovered a broken luks partition in the past.
Thanks so much for any help! lmk if you need any other info (o:
$ sudo pacman -Syyu
core 153.6 KiB 381 KiB/s 00:00 [######################] 100%
extra 8.8 MiB 13.4 MiB/s 00:01 [######################] 100%
multilib 142.2 KiB 390 KiB/s 00:00 [######################] 100%
warning: btrfsmaintenance: local (1:0.5.2-1) is newer than extra (0.5.2-3)
:: Replace geocode-glib-2 with extra/geocode-glib? [Y/n] y
:: Replace gvfs-google with extra/gvfs? [Y/n] y
resolving dependencies...
:: geocode-glib-3.26.4-6 and geocode-glib-common-3.26.4-5 are in conflict. Remove geocode-glib-common? [y/N] y
Packages (681) 7zip-26.01-1 a52dec-0.8.0-3 abseil-cpp-20260107.1-1
accounts-qml-module-0.7-7 accountsservice-26.13.3-1
acl-2.3.2-2 ada-3.4.4-1 addwater-1.3-1 adw-gtk-theme-6.5-1
adwaita-cursors-50.0-1 adwaita-icon-theme-50.0-1
alsa-card-profiles-1:1.6.4-1 amd-ucode-20260410-1
android-tools-35.0.2-25 android-udev-20260423-1 aom-3.13.3-1
apache-2.4.66-2 archlinux-appstream-data-20260421-1
archlinux-keyring-20260420-1 at-spi2-core-2.60.2-1
atkmm-2.28.4-2 attr-2.5.2-2 audit-4.1.4-2 autoconf-2.73-1
avahi-1:0.9rc4-1 babl-0.1.126-1 baobab-50.0-1
blas-openblas-0.3.33-1 bluez-5.86-5 bluez-libs-5.86-5
bluez-obex-5.86-5 bolt-0.9.11-1 boost-1.91.0-1
boost-libs-1.91.0-1 botan-3.11.1-1 breeze-icons-6.25.0-1
btrfs-progs-6.19.1-1 bubblewrap-0.11.2-1
ca-certificates-mozilla-3.123.1-1 cairomm-1.14.5-3
calf-0.90.9-2 cef-147.0.10-1 chromaprint-1.6.0-3
chromium-148.0.7778.96-1 clang-22.1.3-1 clonezilla-5.15.16-1
cmake-4.3.2-1 collision-3.14.0-1 compiler-rt-22.1.3-1
confuse-3.3-5 coreutils-9.11-1 cppdap-1.58.0-3
cpupower-7.0.2-1 cryptsetup-2.8.6-1 cuda-13.2.1-1
cups-2:2.4.19-1 curl-impersonate-1.5.5-1 darktable-2:5.4.1-2
deja-dup-50.0-1 device-mapper-2.03.40-1 ding-libs-0.7.0-1
djvulibre-3.5.29-2 dkms-3.4.0-1 dleyna-0.8.3-5 drbl-5.8.6-1
easyeffects-8.2.1-1 editorconfig-core-c-0.12.11-1
edk2-ovmf-202602-3 electron39-39.8.9-1 electron41-41.3.0-1
element-desktop-1.12.15-0.2 element-web-1.12.15-0.2
enchant-2.8.15-2 endeavour-43.0-7 evince-1:48.1-2
evolution-data-server-3.60.1-1 exempi-2.6.6-3 exiv2-0.28.8-2
expat-2.8.0-1 faac-1.50-1 ffmpeg-2:8.1-3 ffmpeg4.4-4.4.6-5
fftw-3.3.11-1 file-5.47-3 file-roller-44.6-2
firefox-150.0.1-1 flatpak-1:1.16.6-1 flex-2.6.4-6
fltk1.3-1.3.11-4 fluidsynth-2.5.4-1 folks-0.15.12-1
fprintd-1.94.5-2 fragments-3.0.1-4 freerdp-2:3.25.0-1
freetype2-2.14.3-1 fuse-common-3.18.2-1 fuse3-3.18.2-1
fwupd-2.1.2-1 fwupd-efi-1.8-2 gamemode-1.8.2-2
gamescope-3.16.23-1 gdb-17.1-5 gdb-common-17.1-5
gdk-pixbuf2-2.44.6-2 gdm-50.0-2 gegl-0.4.70-2 geoclue-2.8.1-1
geocode-glib-3.26.4-6 geocode-glib-2-3.26.4-5 [removal]
geocode-glib-common-3.26.4-5 [removal] gexiv2-0.16.0-2
ghostscript-10.07.0-1 giflib-6.1.3-1 gimp-3.2.4-1
git-2.54.0-1 gjs-2:1.88.0-1 glib2-2.88.0-1
glib2-devel-2.88.0-1 glib2-docs-2.88.0-1
glibc-2.43+r22+g8362e8ce10b2-1
glibc-locales-2.43+r22+g8362e8ce10b2-1 glibmm-2.68-2.88.0-1
glycin-2.1.1-1 glycin-gtk4-2.1.1-1 gmic-3.7.5-1
gnome-backgrounds-50.0-1 gnome-bluetooth-3.0-47.2-1
gnome-calculator-50.0-1 gnome-calendar-50.0-1
gnome-characters-50.0-1 gnome-chess-50.0-1 gnome-clocks-50.0-2
gnome-connections-50.0-1 gnome-console-50.0-1
gnome-contacts-50.0-1 gnome-control-center-50.1-1
gnome-font-viewer-50.0-1 gnome-keybindings-50.1-1
gnome-keyring-1:50.0-1 gnome-layout-switcher-0.8.39-6
gnome-logs-50.0-1 gnome-maps-50.1-1 gnome-mines-50.0-1
gnome-online-accounts-3.58.1-1 gnome-remote-desktop-50.1-1
gnome-session-50.0-1 gnome-settings-daemon-50.1-1
gnome-shell-1:50.1-1
gnome-shell-extension-forge-89+8+ge5e1705-1
gnome-shell-extension-gnome-ui-tune-1.11.0-2
gnome-shell-extension-gsconnect-72-1
gnome-shell-extension-gtk4-desktop-icons-ng-1:100.23-1
gnome-shell-extension-legacy-theme-auto-switcher-r29.e82edbe-1
gnome-shell-extension-space-bar-37-1
gnome-shell-extensions-50.1-1 gnome-system-monitor-50.0-1
gnome-terminal-3.60.0-1 gnome-text-editor-50.0-1
gnome-tour-50.0-1 gnome-user-docs-50.0-1 gnome-weather-50.0-1
gnuplot-6.0.4-3 go-2:1.26.2-1 gpart-0.3-6 gparted-1.8.1-1
gperftools-2.18.1-1 graphviz-14.1.5-1 grilo-0.3.19-2
grilo-plugins-1:0.3.18-3 gsettings-desktop-schemas-50.1-1
gsettings-system-schemas-50.1-1 gsound-1.0.3-4 gspell-1.14.3-1
gssproxy-0.9.2-3 gst-devtools-libs-1.28.2-1
gst-editing-services-1.28.2-1 gst-libav-1.28.2-1
gst-plugin-gtk-1.28.2-1 gst-plugin-pipewire-1:1.6.4-1
gst-plugins-bad-1.28.2-1 gst-plugins-bad-libs-1.28.2-1
gst-plugins-base-1.28.2-1 gst-plugins-base-libs-1.28.2-1
gst-plugins-good-1.28.2-1 gst-plugins-ugly-1.28.2-1
gst-python-1.28.2-1 gstreamer-1.28.2-1 gthumb-3.12.10-3
gtk-doc-1.36.1-1 gtk-update-icon-cache-1:4.22.4-1
gtk3-1:3.24.52-1 gtk4-1:4.22.4-1 gtkmm-4.0-4.22.0-1
gtksourceview5-5.20.0-1 gvfs-1.60.0-2 gvfs-afc-1.60.0-2
gvfs-dnssd-1.60.0-2 gvfs-goa-1.60.0-2
gvfs-google-1.58.3-1 [removal] gvfs-gphoto2-1.60.0-2
gvfs-mtp-1.60.0-2 gvfs-nfs-1.60.0-2 gvfs-onedrive-1.60.0-2
gvfs-smb-1.60.0-2 gvfs-wsdd-1.60.0-2
gweather-locations-2026.2-1 handbrake-1.11.1-1
harfbuzz-14.2.0-1 harfbuzz-icu-14.2.0-1 highway-1.4.0-1
htop-3.5.1-1 hwdata-0.406-1 iana-etc-20260425-1 icu-78.3-1
ijs-0.35-7 imagemagick-7.1.2.21-1 imath-3.2.2-5
intel-media-driver-26.1.5-1 iproute2-7.0.0-1
iptables-1:1.8.13-1 jasper-4.2.9-1 jbig2dec-0.20-2
jdk-openjdk-26.0.1.u8-1 jq-1.8.1-3 jre8-openjdk-8.492.u09-1
jre8-openjdk-headless-8.492.u09-1 js140-140.10.1-1
kaccounts-integration-26.04.0-1 karchive-6.25.0-1
kauth-6.25.0-1 kbookmarks-6.25.0-1 kcmutils-6.25.0-1
kcodecs-6.25.0-1 kcolorscheme-6.25.0-1 kcompletion-6.25.0-1
kconfig-6.25.0-1 kconfigwidgets-6.25.0-1 kcoreaddons-6.25.0-1
kcrash-6.25.0-1 kdbusaddons-6.25.0-1 kdeclarative-6.25.0-1
keyutils-1.6.3-4 kglobalaccel-6.25.0-1 kguiaddons-6.25.0-1
ki18n-6.25.0-1 kiconthemes-6.25.0-1 kio-6.25.0-1
kirigami-6.25.0-1 kitemmodels-6.25.0-1 kitemviews-6.25.0-1
kjobwidgets-6.25.0-1 knotifications-6.25.0-1 kservice-6.25.0-1
ksvg-6.25.0-1 kwallet-6.25.0-1 kwidgetsaddons-6.25.0-1
kwindowsystem-6.25.0-1 kxmlgui-6.25.0-1 lcms2-2.19-1
ldb-2:4.24.1-1 leancrypto-1.7.2-1 lib32-at-spi2-core-2.60.2-1
lib32-audit-4.1.4-1 lib32-expat-2.8.0-1
lib32-freetype2-2.14.3-1 lib32-gdk-pixbuf2-2.44.6-2
lib32-glib2-2.88.0-1 lib32-glibc-2.43+r22+g8362e8ce10b2-1
lib32-harfbuzz-14.2.0-1 lib32-icu-78.3-1
lib32-keyutils-1.6.3-4 lib32-libcap-2.78-1
lib32-libcups-2.4.19-1 lib32-libgcrypt-1.12.2-1
lib32-libgpg-error-1.60-1 lib32-libjpeg-turbo-3.1.4.1-1
lib32-libnghttp2-1.69.0-1 lib32-libngtcp2-1.22.1-1
lib32-libpciaccess-0.19-1 lib32-libpipewire-1:1.6.4-1
lib32-libpng-1.6.58-1 lib32-librsvg-2:2.62.1-1
lib32-libxft-2.3.9-1 lib32-libxml2-2.15.3-1
lib32-llvm-libs-1:22.1.3-1 lib32-mesa-1:26.0.6-1
lib32-mpg123-1.33.5-1 lib32-ncurses-6.6-2 lib32-nss-3.123.1-1
lib32-nvidia-utils-595.71.05-1 lib32-opencl-nvidia-595.71.05-1
lib32-openssl-1:3.6.2-1 lib32-pango-1:1.57.1-1
lib32-pipewire-1:1.6.4-1 lib32-pipewire-jack-1:1.6.4-1
lib32-sdl2-compat-2.32.66-1 lib32-sdl3-3.4.4-1
lib32-sqlite-3.53.0-2 lib32-systemd-260.1-1
lib32-util-linux-2.42-1 lib32-vulkan-intel-1:26.0.6-1
lib32-vulkan-mesa-implicit-layers-1:26.0.6-1
lib32-vulkan-nouveau-1:26.0.6-1 lib32-vulkan-radeon-1:26.0.6-1
lib32-wayland-1.25.0-1 lib32-xz-5.8.3-1 libaccounts-qt-1.17-2
libadwaita-1:1.9.0-1 libarchive-3.8.7-1 libass-0.17.4-2
libatasmart-0.19-8 libavif-1.4.1-1
libayatana-indicator-0.9.4-2 libblockdev-3.5.0-1
libblockdev-crypto-3.5.0-1 libblockdev-fs-3.5.0-1
libblockdev-loop-3.5.0-1 libblockdev-mdraid-3.5.0-1
libblockdev-nvme-3.5.0-1 libblockdev-part-3.5.0-1
libblockdev-smart-3.5.0-1 libblockdev-swap-3.5.0-1
libbpf-1.7.0-1 libc++-22.1.3-1 libc++abi-22.1.3-1
libcaca-0.99.beta20-7 libcap-2.78-1 libcap-ng-0.9.3-1
libcbor-0.14.0-1 libcdio-paranoia-10.2+2.0.2-2 libclc-22.1.3-1
libcmis-0.6.2-9 libcue-2.3.0-2 libcups-2:2.4.19-1
libdatachannel-0.24.2-2 libdc1394-2.2.7-2 libdca-0.0.7-3
libde265-1.0.18-1 libdv-1.0.0-12 libdvbpsi-1:1.3.3-4
libebml-1.4.5-2 libedataserverui4-3.60.1-1 libexif-0.6.26-1
libexttextcat-3.4.7-2 libfdk-aac-2.0.3-2 libfyaml-0.9.6-2
libgcrypt-1.12.2-1 libgdm-50.0-2 libgme-0.6.4-2
libgoa-3.58.1-1 libgpg-error-1.60-1 libgsf-1.14.58-1
libgsystemservice-0.3.0-2 libgweather-4-4.6.0-1
libimagequant-4.4.1-2 libinput-1.31.1-1 libixion-0.20.0-7
libjcat-0.2.6-1 libjpeg-turbo-3.1.4.1-1 libjuice-1.7.1-1
libmalcontent-0.14.0-4 libmanette-0.2.13-2 libmediaart-1.9.7-2
libmicrohttpd-1.0.5-1 libmodplug-0.8.9.0-7 libmpc-1.4.1-1
libmspack-1:1.11-2 libmysofa-1.3.4-1
libnautilus-extension-50.1-1 libnbd-1.24.2-2
libnetfilter_conntrack-1.1.1-1 libnghttp2-1.69.0-1
libngtcp2-1.22.1-1 libopenmpt-0.8.6-1 liborcus-0.21.0-6
libosinfo-1.12.0-3 libpciaccess-0.19-1 libpeas-1.38.1-1
libpgm-5.3.128-4 libphonenumber-1:9.0.29-1
libpipewire-1:1.6.4-1 libpng-1.6.58-1 libportal-0.9.1-3
libportal-gtk3-0.9.1-3 libportal-gtk4-0.9.1-3 libraqm-0.10.5-1
libraw-0.22.1-1 libreoffice-still-25.8.6-5 librsvg-2:2.62.1-1
libsbsms-2.3.0-6 libshumate-1.6.1-1 libsodium-1.0.22-1
libssc-0.4.2-1 libsysprof-capture-50.0-1 libtar-1.2.20-8
libtiff-4.7.1-2 libunibreak-7.0-1 libupnp-1.14.26-1
libverto-0.3.2-6 libvpx-1.16.0-3 libwbclient-2:4.24.1-1
libwebsockets-4.5.8-1 libwireplumber-0.5.14-1 libwmf-0.2.15-1
libxdmcp-1.1.5-2 libxdp-1.6.3-1 libxml2-2.15.3-1
libxmlb-0.3.26-1 libxpm-3.5.19-1 libzip-1.11.4-1
linux-firmware-amdgpu-20260410-1
linux-firmware-atheros-20260410-1
linux-firmware-broadcom-20260410-1
linux-firmware-cirrus-20260410-1
linux-firmware-intel-20260410-1
linux-firmware-mediatek-20260410-1
linux-firmware-meta-20260410-1 linux-firmware-nvidia-20260410-1
linux-firmware-other-20260410-1
linux-firmware-radeon-20260410-1
linux-firmware-realtek-20260410-1
linux-firmware-whence-20260410-1 linux612-6.12.85-1
linux612-headers-6.12.85-1 linux612-nvidia-open-595.71.05-2
linux618-6.18.26-1 linux618-headers-6.18.26-1
linux618-nvidia-open-595.71.05-2 llvm-libs-22.1.3-1
localsearch-3.11.1-1 lrzip-0.660-1 lsp-plugins-lv2-1.2.29-1
lua-5.5.0-2 lua-socket-1:3.1.0-2 lua54-5.4.8-6
luajit-2.1.1774896198+18b087c-1 lvm2-2.03.40-1 m4-1.4.21-2
make-4.4.1-3 malcontent-0.14.0-4 man-pages-6.18-1
manjaro-gnome-settings-20260221-2 manjaro-hello-0.8.1-5
manjaro-release-26.1.0pre-1 md4c-0.5.3-1 mdadm-4.6-2
mesa-1:26.0.6-1 meson-1.11.1-1 mhwd-db-20260305-1
mhwd-nvidia-595.71.05-1 mhwd-nvidia-390xx-390.157-24
mhwd-nvidia-580xx-580.159.03-1 mjpegtools-2.2.1-4
mod_dnssd-0.6-10 mpdecimal-4.0.1-3 mpg123-1.33.5-1
mpvqt-1.1.1-2 mutter-50.1-1 mypaint-brushes-2.0.2-2
nano-9.0-1 nautilus-50.1-1 nautilus-python-4.1.0-3
ncurses-6.6-2 ndctl-84-1 neon-0.37.1-1 netpbm-10.86.49-2
network-manager-sstp-1.3.2-5
networkmanager-vpn-plugin-sstp-1.3.2-5 nfs-utils-2.9.1-1
nfsidmap-2.9.1-1 nilfs-utils-2.3.0-1 nodejs-25.9.0-1
noto-fonts-1:2026.04.01-1 noto-fonts-extra-1:2026.04.01-1
nss-3.123.1-1 nvidia-settings-595.71.05-1
nvidia-utils-595.71.05-2 oath-toolkit-2.6.14-3
obs-studio-32.1.2-1 openblas-0.3.33-1 openbsd-netcat-1.234_2-1
opencl-mesa-1:26.0.6-1 opencl-nvidia-595.71.05-1
opencv-4.13.0-6 openexr-3.4.11-1 openjph-0.27.0-1
openmp-22.1.3-1 openssh-10.3p1-1 openssl-3.6.2-2
openvpn-2.7.3-1 openxr-1.1.58-2
pamac-gnome-integration-11.7.5-1 pamac-gtk-11.7.5-1
pango-1:1.57.1-1 pangomm-2.46.4-2 parted-3.7-1
passim-0.1.11-1 pciutils-3.15.0-1 perl-5.42.2-1
perl-class-inspector-1.36-10 perl-clone-0.50-1
perl-file-sharedir-1.118-8 perl-image-exiftool-13.55-1
perl-json-4.11-1 perl-libwww-6.82-1 perl-timedate-2.35-1
perl-xml-parser-2.58-1 pipewire-1:1.6.4-1
pipewire-alsa-1:1.6.4-1 pipewire-audio-1:1.6.4-1
pipewire-jack-1:1.6.4-1 pipewire-pulse-1:1.6.4-1
pipewire-session-manager-1:1.6.4-1 polkit-qt5-0.201.1-1
polkit-qt6-0.201.1-1 poppler-26.04.0-1 poppler-glib-26.04.0-1
portaudio-1:19.7.0-4 protobuf-34.1-1 protobuf-c-1.5.2-9
psmisc-23.7-2 purpose-6.25.0-1 python-3.14.4-1
python-argcomplete-3.6.3-1 python-cbor2-5.9.0-1
python-certifi-2026.04.22-1 python-charset-normalizer-3.4.7-1
python-click-8.3.3-1 python-curl-adapter-1.2.1-1
python-curl_cffi-0.15.0-2 python-dulwich-1.1.0-1
python-eventlet-0.41.0-1 python-fastbencode-0.3.10-1
python-filelock-3.29.0-1 python-gevent-26.4.0-1
python-gobject-3.56.2-1 python-greenlet-3.5.0-1
python-idna-3.13-1 python-imagesize-2.0.0-1
python-iniconfig-2.3.0-1 python-jaraco.context-6.1.2-1
python-kiwisolver-1.5.0-1 python-lxml-6.1.0-1
python-mako-1.3.11-1 python-markdown-it-py-4.0.0-2
python-matplotlib-3.10.9-1 python-mdurl-0.1.2-9
python-more-itertools-11.0.2-1 python-numpy-2.4.4-1
python-packaging-26.2-1 python-pillow-12.2.0-1
python-platformdirs-4.9.6-1 python-protobuf-34.1-1
python-pycparser-3.00-1 python-pycurl-7.46.0-1
python-pygments-2.20.0-1 python-pytest-1:9.0.3-1
python-pytz-2026.1-1 python-requests-2.33.1-1
python-rich-15.0.0-1 python-six-1.17.0-3
python-snowballstemmer-3.0.1-1 python-wheel-0.47.0-1
python-wxpython-1:4.2.5-1 python-xxhash-3.7.0-1
python-zope-event-6.2-1 python-zope-interface-8.4-1
qemu-chardev-spice-11.0.0-1 qemu-common-11.0.0-1
qemu-system-x86-firmware-11.0.0-1 qemu-ui-opengl-11.0.0-1
qemu-ui-spice-core-11.0.0-1 qpwgraph-1.0.1-1
qqc2-desktop-style-6.25.0-1 qt6-5compat-6.11.0-1
qt6-base-6.11.0-2 qt6-declarative-6.11.0-4 qt6-graphs-6.11.0-1
qt6-multimedia-6.11.0-1 qt6-multimedia-ffmpeg-6.11.0-1
qt6-networkauth-6.11.0-1 qt6-positioning-6.11.0-1
qt6-quick3d-6.11.0-1 qt6-quicktimeline-6.11.0-1
qt6-scxml-6.11.0-1 qt6-shadertools-6.11.0-1 qt6-svg-6.11.0-2
qt6-tools-6.11.0-3 qt6-translations-6.11.0-1
qt6-wayland-6.11.0-1 qt6-webchannel-6.11.0-1
qt6-webengine-6.11.0-5 qt6ct-0.11-5 qtkeychain-qt6-0.16.0-1
rasqal-1:0.9.33-8 re2-2:2025.11.05-3 redland-1:1.0.17-10
rsync-3.4.2-1 rubberband-4.0.0-2 samba-2:4.24.1-1
sdl2-compat-2.32.66-1 sdl2_image-2.8.10-1 sdl3-3.4.4-1
sed-4.10-1 signal-desktop-8.9.1-2
signon-kwallet-extension-26.04.0-1 signon-plugin-oauth2-0.25-4
signond-8.61-4 simdjson-1:4.6.3-1 smbclient-2:4.24.1-1
snapshot-50.0-1 solid-6.25.0-1 sonnet-6.25.0-1
source-highlight-3.1.9-18 spirv-llvm-translator-22.1.1-1
sqlite-3.53.0-2 stk-5.0.1-4 strongswan-6.0.6-1 sushi-50.0-1
svt-av1-4.1.0-1 svt-hevc-1.5.1-4 systemd-260.1-2
systemd-libs-260.1-2 systemd-sysvcompat-260.1-2 tecla-50.0-1
texinfo-7.3-1 thin-provisioning-tools-1.3.2-1
tinysparql-3.11.1-1 totem-43.2-5 totem-pl-parser-3.26.7-1
ttf-dejavu-2.37+18+g9b5d1b2f-8 tzdata-2026b-1 uchardet-0.0.8-4
udftools-2.3-3 umu-launcher-1.4.0-1 unrar-1:7.2.6-1
upower-1.91.2-1 uthash-2.3.0-3 util-linux-2.42-1
util-linux-libs-2.42-1 vala-0.56.19-1 verdict-1.4.5-2
vim-9.2.0388-1 vim-runtime-9.2.0388-1 vmaf-3.1.0-1
vpnc-1:0.5.3.r557.r241-1 vte-common-0.84.0-1 vte3-0.84.0-1
vte4-0.84.0-1 vulkan-intel-1:26.0.6-1
vulkan-nouveau-1:26.0.6-1 vulkan-radeon-1:26.0.6-1
wayland-1.25.0-1 webapp-manager-1.4.6-2
webkit2gtk-4.1-2.52.3-1 webkitgtk-6.0-2.52.3-1
webrtc-audio-processing-2.1-6 wine-11.7-1
wireless-regdb-2026.03.18-1 wireplumber-0.5.14-1
wl-clipboard-1:2.3.0-1 wolfssl-5.9.1-1 xdg-dbus-proxy-0.1.7-1
xdg-desktop-portal-1.20.4-1 xdg-desktop-portal-gnome-50.0-1
xdg-user-dirs-0.20-1 xf86-input-elographics-1.4.4-2
xf86-video-ati-1:22.0.0-3 xfsprogs-6.19.0-1 xmlsec-1.3.11-1
xorg-fonts-encodings-1.1.0-2 xorg-server-21.1.22-1
xorg-server-common-21.1.22-1 xorg-setxkbmap-1.3.5-1
xorg-xrandr-1.5.4-1 xorg-xwayland-24.1.11-1 xz-5.8.3-1
zenity-4.2.2-1 zsh-5.9-6 zsh-syntax-highlighting-0.8.0-2
Total Download Size: 6160.30 MiB
Total Installed Size: 17353.55 MiB
Net Upgrade Size: 814.94 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
Total (678/678) 6.0 GiB 35.3 MiB/s 02:55 [######################] 100%
(678/678) checking keys in keyring [######################] 100%
downloading required keys...
:: Import PGP key 8DFDB575B0538C5D, "Jonathan Grotelüschen <tippfehlr@archlinux.org>"? [Y/n] y
(678/678) checking package integrity [######################] 100%
(678/678) loading package files [######################] 100%
(678/678) checking for file conflicts [######################] 100%
(681/681) checking available disk space [######################] 100%
(1/4) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/4) Removing linux initcpios...
(3/4) Remove DKMS modules
==> dkms remove --no-depmod blackmagic/16.0a14 -k 6.18.18-1-MANJARO
==> dkms remove --no-depmod blackmagic-io/16.0a14 -k 6.18.18-1-MANJARO
==> dkms remove --no-depmod v4l2loopback/0.15.3 -k 6.18.18-1-MANJARO
==> dkms remove --no-depmod blackmagic/16.0a14 -k 6.12.77-1-MANJARO
==> dkms remove --no-depmod blackmagic-io/16.0a14 -k 6.12.77-1-MANJARO
==> dkms remove --no-depmod v4l2loopback/0.15.3 -k 6.12.77-1-MANJARO
==> depmod 6.18.18-1-MANJARO
==> depmod 6.12.77-1-MANJARO
(4/4) Remove Firefox Distribution Settings
(1/3) removing geocode-glib-2 [######################] 100%
(2/3) removing geocode-glib-common [######################] 100%
(3/3) removing gvfs-google [######################] 100%
( 1/678) upgrading tzdata [######################] 100%
( 2/678) upgrading iana-etc [######################] 100%
( 3/678) upgrading glibc [######################] 100%
Generating locales...
en_CA.UTF-8... done
en_US.UTF-8... done
Generation complete.
( 4/678) upgrading ncurses [######################] 100%
( 5/678) upgrading 7zip [######################] 100%
( 6/678) upgrading a52dec [######################] 100%
( 7/678) upgrading abseil-cpp [######################] 100%
( 8/678) upgrading libsysprof-capture [######################] 100%
( 9/678) upgrading sqlite [######################] 100%
( 10/678) upgrading util-linux-libs [######################] 100%
( 11/678) upgrading glib2 [######################] 100%
( 12/678) upgrading libpng [######################] 100%
( 13/678) upgrading freetype2 [######################] 100%
( 14/678) upgrading harfbuzz [######################] 100%
( 15/678) upgrading icu [######################] 100%
( 16/678) upgrading expat [######################] 100%
( 17/678) upgrading libgpg-error [######################] 100%
( 18/678) upgrading libgcrypt [######################] 100%
( 19/678) upgrading xz [######################] 100%
( 20/678) upgrading systemd-libs [######################] 100%
( 21/678) upgrading libcap-ng [######################] 100%
( 22/678) upgrading openssl [######################] 100%
( 23/678) upgrading keyutils [######################] 100%
( 24/678) upgrading libverto [######################] 100%
( 25/678) upgrading audit [######################] 100%
( 26/678) upgrading libcap [######################] 100%
( 27/678) upgrading avahi [######################] 100%
( 28/678) upgrading leancrypto [######################] 100%
( 29/678) upgrading libcups [######################] 100%
( 30/678) installing lua54 [######################] 100%
( 31/678) upgrading libinput [######################] 100%
( 32/678) upgrading libjpeg-turbo [######################] 100%
( 33/678) upgrading md4c [######################] 100%
( 34/678) upgrading libxml2 [######################] 100%
( 35/678) upgrading llvm-libs [######################] 100%
( 36/678) upgrading wayland [######################] 100%
( 37/678) upgrading libpciaccess [######################] 100%
( 38/678) upgrading libxdmcp [######################] 100%
( 39/678) upgrading nvidia-utils [######################] 100%
xorg configuration symlink valid...
New optional dependencies for nvidia-utils
opencl-nvidia=595.71.05: OpenCL support [pending]
( 40/678) upgrading libnghttp2 [######################] 100%
( 41/678) upgrading libngtcp2 [######################] 100%
( 42/678) upgrading acl [######################] 100%
( 43/678) upgrading attr [######################] 100%
( 44/678) upgrading coreutils [######################] 100%
( 45/678) upgrading ca-certificates-mozilla [######################] 100%
( 46/678) upgrading mesa [######################] 100%
( 47/678) upgrading qt6-translations [######################] 100%
( 48/678) upgrading file [######################] 100%
( 49/678) upgrading qt6-base [######################] 100%
( 50/678) upgrading libaccounts-qt [######################] 100%
( 51/678) upgrading qt6-declarative [######################] 100%
( 52/678) upgrading signond [######################] 100%
( 53/678) upgrading accounts-qml-module [######################] 100%
( 54/678) upgrading device-mapper [######################] 100%
( 55/678) upgrading cryptsetup [######################] 100%
( 56/678) upgrading hwdata [######################] 100%
( 57/678) upgrading util-linux [######################] 100%
( 58/678) upgrading sed [######################] 100%
( 59/678) upgrading systemd [######################] 100%
:: This is a systemd feature update. You may want to have a look at
NEWS for what changed, or if you observe unexpected behavior:
/usr/share/doc/systemd/NEWS
Created symlink '/etc/systemd/system/autovt@.service' → '/usr/lib/systemd/system/getty@.service'.
( 60/678) upgrading accountsservice [######################] 100%
( 61/678) upgrading ada [######################] 100%
( 62/678) upgrading adwaita-cursors [######################] 100%
( 63/678) upgrading adwaita-icon-theme [######################] 100%
( 64/678) upgrading gsettings-system-schemas [######################] 100%
( 65/678) upgrading gsettings-desktop-schemas [######################] 100%
( 66/678) upgrading at-spi2-core [######################] 100%
( 67/678) upgrading bubblewrap [######################] 100%
( 68/678) upgrading libtiff [######################] 100%
( 69/678) upgrading lcms2 [######################] 100%
( 70/678) upgrading pango [######################] 100%
( 71/678) upgrading librsvg [######################] 100%
( 72/678) upgrading giflib [######################] 100%
( 73/678) upgrading gperftools [######################] 100%
( 74/678) upgrading highway [######################] 100%
( 75/678) upgrading glycin [######################] 100%
( 76/678) upgrading gdk-pixbuf2 [######################] 100%
( 77/678) upgrading gstreamer [######################] 100%
( 78/678) upgrading gst-plugins-base-libs [######################] 100%
( 79/678) upgrading vmaf [######################] 100%
( 80/678) upgrading gst-plugins-bad-libs [######################] 100%
( 81/678) upgrading gtk-update-icon-cache [######################] 100%
( 82/678) upgrading tinysparql [######################] 100%
( 83/678) upgrading gtk3 [######################] 100%
( 84/678) upgrading libpipewire [######################] 100%
( 85/678) upgrading pipewire [######################] 100%
( 86/678) upgrading fuse-common [######################] 100%
( 87/678) upgrading fuse3 [######################] 100%
( 88/678) upgrading xdg-desktop-portal [######################] 100%
( 89/678) upgrading gtk4 [######################] 100%
( 90/678) upgrading libxmlb [######################] 100%
( 91/678) upgrading libfyaml [######################] 100%
( 92/678) upgrading libadwaita [######################] 100%
( 93/678) upgrading libportal [######################] 100%
( 94/678) upgrading libportal-gtk4 [######################] 100%
( 95/678) upgrading mpdecimal [######################] 100%
( 96/678) upgrading python [######################] 100%
( 97/678) upgrading python-gobject [######################] 100%
( 98/678) upgrading python-packaging [######################] 100%
( 99/678) upgrading python-charset-normalizer [######################] 100%
(100/678) upgrading python-idna [######################] 100%
(101/678) upgrading python-certifi [######################] 100%
(102/678) upgrading python-requests [######################] 100%
(103/678) upgrading addwater [######################] 100%
(104/678) upgrading adw-gtk-theme [######################] 100%
(105/678) upgrading alsa-card-profiles [######################] 100%
(106/678) upgrading amd-ucode [######################] 100%
(107/678) upgrading protobuf [######################] 100%
(108/678) upgrading android-tools [######################] 100%
(109/678) upgrading android-udev [######################] 100%
(110/678) upgrading aom [######################] 100%
(111/678) upgrading apache [######################] 100%
(112/678) upgrading archlinux-appstream-data [######################] 100%
(113/678) upgrading libarchive [######################] 100%
(114/678) upgrading python-pytz [######################] 100%
(115/678) upgrading archlinux-keyring [######################] 100%
==> Appending keys from archlinux.gpg...
==> Disabling revoked keys in keyring...
-> Disabled 2 keys.
==> Updating trust database...
gpg: Note: third-party key signatures using the SHA1 algorithm are rejected
gpg: (use option "--allow-weak-key-signatures" to override)
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 22 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 22 signed: 86 trust: 0-, 0q, 0n, 22m, 0f, 0u
gpg: depth: 2 valid: 74 signed: 18 trust: 74-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2026-08-21
(116/678) upgrading perl [######################] 100%
(117/678) upgrading atkmm [######################] 100%
(118/678) upgrading m4 [######################] 100%
(119/678) upgrading autoconf [######################] 100%
(120/678) upgrading babl [######################] 100%
(121/678) upgrading baobab [######################] 100%
(122/678) upgrading openblas [######################] 100%
(123/678) upgrading blas-openblas [######################] 100%
(124/678) upgrading bluez [######################] 100%
(125/678) upgrading bluez-libs [######################] 100%
(126/678) upgrading bluez-obex [######################] 100%
(127/678) upgrading bolt [######################] 100%
(128/678) upgrading boost [######################] 100%
(129/678) upgrading boost-libs [######################] 100%
(130/678) upgrading botan [######################] 100%
(131/678) upgrading breeze-icons [######################] 100%
(132/678) upgrading btrfs-progs [######################] 100%
(133/678) upgrading cairomm [######################] 100%
(134/678) upgrading sdl3 [######################] 100%
(135/678) upgrading fftw [######################] 100%
(136/678) upgrading libfdk-aac [######################] 100%
(137/678) upgrading libmysofa [######################] 100%
(138/678) upgrading mpg123 [######################] 100%
(139/678) upgrading pipewire-audio [######################] 100%
(140/678) upgrading libwireplumber [######################] 100%
(141/678) upgrading lua [######################] 100%
(142/678) upgrading wireplumber [######################] 100%
(143/678) upgrading pipewire-session-manager [######################] 100%
(144/678) upgrading pipewire-jack [######################] 100%
(145/678) upgrading portaudio [######################] 100%
(146/678) upgrading fluidsynth [######################] 100%
(147/678) upgrading calf [######################] 100%
(148/678) upgrading libunibreak [######################] 100%
(149/678) upgrading libass [######################] 100%
(150/678) upgrading libmodplug [######################] 100%
(151/678) upgrading libopenmpt [######################] 100%
(152/678) upgrading libvpx [######################] 100%
(153/678) upgrading rubberband [######################] 100%
(154/678) upgrading sdl2-compat [######################] 100%
(155/678) upgrading svt-av1 [######################] 100%
(156/678) upgrading libbpf [######################] 100%
(157/678) upgrading libpgm [######################] 100%
(158/678) upgrading libsodium [######################] 100%
(159/678) upgrading ffmpeg [######################] 100%
(160/678) upgrading chromaprint [######################] 100%
(161/678) upgrading nss [######################] 100%
(162/678) upgrading pciutils [######################] 100%
(163/678) upgrading chromium [######################] 100%
(164/678) upgrading compiler-rt [######################] 100%
(165/678) upgrading libmpc [######################] 100%
(166/678) upgrading clang [######################] 100%
(167/678) upgrading drbl [######################] 100%
(168/678) upgrading parted [######################] 100%
(169/678) upgrading lrzip [######################] 100%
(170/678) upgrading jq [######################] 100%
(171/678) upgrading libwbclient [######################] 100%
(172/678) upgrading nilfs-utils [######################] 100%
(173/678) upgrading openssh [######################] 100%
(174/678) upgrading clonezilla [######################] 100%
(175/678) upgrading cppdap [######################] 100%
(176/678) upgrading cmake [######################] 100%
(177/678) upgrading collision [######################] 100%
(178/678) upgrading confuse [######################] 100%
(179/678) upgrading cpupower [######################] 100%
(180/678) upgrading opencl-nvidia [######################] 100%
(181/678) upgrading cuda [######################] 100%
- When you uninstall an old, unrequired version of GCC that was previously
required by cuda for the default host compiler ($NVCC_CCBIN), you may need
to source /etc/profile or restart your session. Additionally, you may need
to clear the build cache of your projects where the old path may be still
recorded.
(182/678) upgrading poppler [######################] 100%
(183/678) upgrading libexif [######################] 100%
(184/678) upgrading cups [######################] 100%
(185/678) upgrading curl-impersonate [######################] 100%
(186/678) upgrading exiv2 [######################] 100%
(187/678) upgrading imath [######################] 100%
(188/678) upgrading gst-plugins-base [######################] 100%
(189/678) upgrading libdc1394 [######################] 100%
(190/678) upgrading openjph [######################] 100%
(191/678) upgrading openexr [######################] 100%
New optional dependencies for openexr
python: for python bindings [installed]
(192/678) upgrading verdict [######################] 100%
(193/678) upgrading opencv [######################] 100%
(194/678) upgrading gmic [######################] 100%
(195/678) upgrading jasper [######################] 100%
(196/678) upgrading libavif [######################] 100%
(197/678) upgrading openmp [######################] 100%
(198/678) upgrading libxpm [######################] 100%
(199/678) upgrading libde265 [######################] 100%
New optional dependencies for libde265
sdl2-compat: for the decoder tool [installed]
(200/678) upgrading darktable [######################] 100%
(201/678) upgrading libcdio-paranoia [######################] 100%
(202/678) upgrading libblockdev [######################] 100%
(203/678) upgrading libblockdev-crypto [######################] 100%
(204/678) upgrading libblockdev-fs [######################] 100%
(205/678) upgrading libblockdev-loop [######################] 100%
(206/678) upgrading mdadm [######################] 100%
(207/678) upgrading libblockdev-mdraid [######################] 100%
(208/678) upgrading libblockdev-nvme [######################] 100%
(209/678) upgrading libblockdev-part [######################] 100%
(210/678) upgrading libatasmart [######################] 100%
(211/678) upgrading libblockdev-smart [######################] 100%
(212/678) upgrading libblockdev-swap [######################] 100%
(213/678) upgrading gvfs [######################] 100%
(214/678) upgrading deja-dup [######################] 100%
(215/678) upgrading ding-libs [######################] 100%
(216/678) upgrading djvulibre [######################] 100%
(217/678) upgrading make [######################] 100%
(218/678) upgrading dkms [######################] 100%
(219/678) upgrading dleyna [######################] 100%
(220/678) upgrading qt6-svg [######################] 100%
(221/678) upgrading kirigami [######################] 100%
(222/678) upgrading karchive [######################] 100%
(223/678) upgrading kconfig [######################] 100%
(224/678) upgrading kguiaddons [######################] 100%
(225/678) upgrading ki18n [######################] 100%
(226/678) upgrading kcolorscheme [######################] 100%
(227/678) upgrading kwidgetsaddons [######################] 100%
(228/678) upgrading kiconthemes [######################] 100%
(229/678) upgrading kcodecs [######################] 100%
(230/678) upgrading kcoreaddons [######################] 100%
(231/678) upgrading kconfigwidgets [######################] 100%
(232/678) upgrading sonnet [######################] 100%
(233/678) upgrading qqc2-desktop-style [######################] 100%
(234/678) upgrading openxr [######################] 100%
(235/678) upgrading qt6-quicktimeline [######################] 100%
(236/678) upgrading qt6-shadertools [######################] 100%
(237/678) upgrading qt6-quick3d [######################] 100%
(238/678) upgrading qt6-graphs [######################] 100%
(239/678) upgrading pipewire-pulse [######################] 100%
(240/678) upgrading webrtc-audio-processing [######################] 100%
(241/678) upgrading kcrash [######################] 100%
(242/678) upgrading kglobalaccel [######################] 100%
(243/678) upgrading kitemmodels [######################] 100%
(244/678) upgrading ksvg [######################] 100%
(245/678) upgrading qt6-multimedia-ffmpeg [######################] 100%
(246/678) upgrading qt6-multimedia [######################] 100%
(247/678) upgrading easyeffects [######################] 100%
(248/678) upgrading editorconfig-core-c [######################] 100%
(249/678) upgrading edk2-ovmf [######################] 100%
(250/678) upgrading electron39 [######################] 100%
(251/678) upgrading element-web [######################] 100%
(252/678) installing electron41 [######################] 100%
Optional dependencies for electron41
kde-cli-tools: file deletion support (kioclient5)
pipewire: WebRTC desktop sharing under Wayland [installed]
qt5-base: enable Qt5 with --enable-features=AllowQt [installed]
gtk4: for --gtk-version=4 (GTK4 IME might work better on Wayland)
[installed]
trash-cli: file deletion support (trash-put)
xdg-utils: open URLs with desktop’s default (xdg-email, xdg-open)
[installed]
(253/678) upgrading element-desktop [######################] 100%
(254/678) upgrading enchant [######################] 100%
(255/678) upgrading libgoa [######################] 100%
(256/678) installing geocode-glib [######################] 100%
(257/678) installing gweather-locations [######################] 100%
(258/678) upgrading libgweather-4 [######################] 100%
(259/678) upgrading libphonenumber [######################] 100%
(260/678) upgrading harfbuzz-icu [######################] 100%
(261/678) upgrading libmanette [######################] 100%
(262/678) upgrading xdg-dbus-proxy [######################] 100%
(263/678) upgrading noto-fonts [######################] 100%
(264/678) upgrading ttf-dejavu [######################] 100%
(265/678) upgrading webkit2gtk-4.1 [######################] 100%
(266/678) upgrading evolution-data-server [######################] 100%
(267/678) upgrading libpeas [######################] 100%
(268/678) upgrading endeavour [######################] 100%
(269/678) upgrading exempi [######################] 100%
(270/678) upgrading gspell [######################] 100%
(271/678) upgrading poppler-glib [######################] 100%
(272/678) upgrading jbig2dec [######################] 100%
(273/678) upgrading ijs [######################] 100%
(274/678) upgrading ghostscript [######################] 100%
(275/678) upgrading evince [######################] 100%
(276/678) upgrading faac [######################] 100%
(277/678) upgrading ffmpeg4.4 [######################] 100%
(278/678) upgrading libnautilus-extension [######################] 100%
(279/678) upgrading file-roller [######################] 100%
(280/678) upgrading firefox [######################] 100%
(281/678) upgrading libmalcontent [######################] 100%
(282/678) upgrading flatpak [######################] 100%
(283/678) upgrading flex [######################] 100%
(284/678) upgrading fltk1.3 [######################] 100%
(285/678) upgrading folks [######################] 100%
(286/678) upgrading fprintd [######################] 100%
(287/678) upgrading fragments [######################] 100%
(288/678) upgrading freerdp [######################] 100%
(289/678) upgrading fwupd-efi [######################] 100%
(290/678) upgrading libcbor [######################] 100%
(291/678) upgrading libjcat [######################] 100%
(292/678) upgrading passim [######################] 100%
(293/678) upgrading protobuf-c [######################] 100%
(294/678) upgrading fwupd [######################] 100%
(295/678) upgrading gamemode [######################] 100%
(296/678) upgrading luajit [######################] 100%
(297/678) upgrading xorg-setxkbmap [######################] 100%
(298/678) upgrading xorg-server-common [######################] 100%
(299/678) upgrading xorg-fonts-encodings [######################] 100%
(300/678) upgrading xorg-xwayland [######################] 100%
(301/678) upgrading gamescope [######################] 100%
(302/678) upgrading gdb-common [######################] 100%
(303/678) upgrading source-highlight [######################] 100%
(304/678) upgrading gdb [######################] 100%
(305/678) upgrading gexiv2 [######################] 100%
(306/678) installing glycin-gtk4 [######################] 100%
(307/678) upgrading libcue [######################] 100%
(308/678) upgrading libgsf [######################] 100%
(309/678) upgrading libosinfo [######################] 100%
(310/678) installing libzip [######################] 100%
(311/678) upgrading uchardet [######################] 100%
(312/678) upgrading totem-pl-parser [######################] 100%
(313/678) upgrading upower [######################] 100%
(314/678) upgrading localsearch [######################] 100%
(315/678) upgrading xdg-user-dirs [######################] 100%
(316/678) upgrading nautilus [######################] 100%
(317/678) upgrading xdg-desktop-portal-gnome [######################] 100%
(318/678) upgrading gnome-session [######################] 100%
New optional dependencies for gnome-session
gnome-keyring: Secrets service backend [installed]
(319/678) upgrading js140 [######################] 100%
(320/678) upgrading gjs [######################] 100%
(321/678) upgrading geoclue [######################] 100%
(322/678) upgrading gnome-settings-daemon [######################] 100%
(323/678) upgrading libgdm [######################] 100%
(324/678) upgrading python-argcomplete [######################] 100%
(325/678) upgrading libssc [######################] 100%
(326/678) upgrading mutter [######################] 100%
(327/678) upgrading webkitgtk-6.0 [######################] 100%
(328/678) upgrading gnome-shell [######################] 100%
(329/678) upgrading gdm [######################] 100%
warning: /etc/gdm/custom.conf installed as /etc/gdm/custom.conf.pacnew
(330/678) upgrading libraw [######################] 100%
(331/678) upgrading gegl [######################] 100%
(332/678) upgrading libwmf [######################] 100%
(333/678) installing mypaint-brushes [######################] 100%
(334/678) upgrading gimp [######################] 100%
(335/678) upgrading perl-timedate [######################] 100%
(336/678) upgrading git [######################] 100%
(337/678) upgrading glib2-devel [######################] 100%
(338/678) upgrading glib2-docs [######################] 100%
(339/678) upgrading glibc-locales [######################] 100%
(340/678) upgrading glibmm-2.68 [######################] 100%
(341/678) upgrading gnome-backgrounds [######################] 100%
(342/678) upgrading gsound [######################] 100%
(343/678) upgrading gnome-bluetooth-3.0 [######################] 100%
(344/678) upgrading gtksourceview5 [######################] 100%
(345/678) upgrading gnome-calculator [######################] 100%
(346/678) upgrading libedataserverui4 [######################] 100%
(347/678) upgrading gnome-calendar [######################] 100%
(348/678) upgrading gnome-characters [######################] 100%
(349/678) upgrading gnome-chess [######################] 100%
(350/678) upgrading gnome-clocks [######################] 100%
(351/678) upgrading libcaca [######################] 100%
(352/678) upgrading libdv [######################] 100%
(353/678) upgrading gst-plugins-good [######################] 100%
(354/678) upgrading gnome-connections [######################] 100%
(355/678) upgrading vte-common [######################] 100%
(356/678) upgrading vte4 [######################] 100%
(357/678) upgrading gnome-console [######################] 100%
(358/678) upgrading gnome-online-accounts [######################] 100%
(359/678) upgrading gst-plugin-pipewire [######################] 100%
(360/678) upgrading gnome-contacts [######################] 100%
(361/678) upgrading ldb [######################] 100%
(362/678) upgrading smbclient [######################] 100%
(363/678) upgrading tecla [######################] 100%
(364/678) upgrading gnome-keybindings [######################] 100%
(365/678) upgrading gnome-control-center [######################] 100%
(366/678) upgrading gnome-font-viewer [######################] 100%
(367/678) upgrading gnome-keyring [######################] 100%
(368/678) upgrading gnome-shell-extension-forge [######################] 100%
(369/678) upgrading gnome-shell-extension-gnom... [######################] 100%
(370/678) upgrading gnome-shell-extension-gtk4... [######################] 100%
(371/678) upgrading gnome-shell-extension-spac... [######################] 100%
(372/678) upgrading pamac-gtk [######################] 100%
(373/678) upgrading python-click [######################] 100%
(374/678) upgrading gnome-layout-switcher [######################] 100%
(375/678) upgrading gnome-logs [######################] 100%
(376/678) upgrading libshumate [######################] 100%
(377/678) upgrading gnome-maps [######################] 100%
(378/678) upgrading gnome-mines [######################] 100%
(379/678) upgrading gnome-remote-desktop [######################] 100%
(380/678) upgrading gnome-shell-extension-gsco... [######################] 100%
(381/678) upgrading gnome-shell-extension-lega... [######################] 100%
(382/678) upgrading gnome-shell-extensions [######################] 100%
(383/678) upgrading gtkmm-4.0 [######################] 100%
(384/678) upgrading gnome-system-monitor [######################] 100%
(385/678) upgrading vte3 [######################] 100%
(386/678) upgrading gnome-terminal [######################] 100%
(387/678) upgrading gnome-text-editor [######################] 100%
(388/678) upgrading gnome-tour [######################] 100%
(389/678) upgrading gnome-user-docs [######################] 100%
(390/678) upgrading gnome-weather [######################] 100%
(391/678) upgrading qt6-5compat [######################] 100%
(392/678) upgrading libmspack [######################] 100%
(393/678) upgrading gnuplot [######################] 100%
(394/678) upgrading go [######################] 100%
(395/678) upgrading gpart [######################] 100%
(396/678) upgrading pangomm [######################] 100%
(397/678) upgrading gparted [######################] 100%
(398/678) upgrading netpbm [######################] 100%
(399/678) upgrading graphviz [######################] 100%
(400/678) upgrading grilo [######################] 100%
(401/678) upgrading libdca [######################] 100%
(402/678) upgrading libgme [######################] 100%
(403/678) upgrading mjpegtools [######################] 100%
(404/678) upgrading neon [######################] 100%
(405/678) upgrading svt-hevc [######################] 100%
(406/678) upgrading libraqm [######################] 100%
(407/678) upgrading imagemagick [######################] 100%
(408/678) upgrading gst-plugins-bad [######################] 100%
(409/678) upgrading libmediaart [######################] 100%
(410/678) upgrading grilo-plugins [######################] 100%
(411/678) upgrading gssproxy [######################] 100%
(412/678) upgrading gst-devtools-libs [######################] 100%
(413/678) upgrading gst-python [######################] 100%
(414/678) upgrading gst-editing-services [######################] 100%
(415/678) upgrading gst-libav [######################] 100%
(416/678) upgrading gst-plugin-gtk [######################] 100%
(417/678) upgrading gst-plugins-ugly [######################] 100%
(418/678) upgrading gthumb [######################] 100%
(419/678) upgrading python-lxml [######################] 100%
(420/678) upgrading python-pygments [######################] 100%
(421/678) upgrading gtk-doc [######################] 100%
(422/678) upgrading gvfs-afc [######################] 100%
(423/678) upgrading gvfs-dnssd [######################] 100%
(424/678) upgrading gvfs-goa [######################] 100%
(425/678) upgrading gvfs-gphoto2 [######################] 100%
(426/678) upgrading gvfs-mtp [######################] 100%
(427/678) upgrading gvfs-nfs [######################] 100%
(428/678) upgrading gvfs-onedrive [######################] 100%
(429/678) upgrading gvfs-smb [######################] 100%
(430/678) upgrading gvfs-wsdd [######################] 100%
(431/678) upgrading handbrake [######################] 100%
(432/678) upgrading htop [######################] 100%
(433/678) upgrading intel-media-driver [######################] 100%
(434/678) upgrading libnetfilter_conntrack [######################] 100%
(435/678) upgrading iptables [######################] 100%
(436/678) upgrading iproute2 [######################] 100%
(437/678) upgrading jdk-openjdk [######################] 100%
(438/678) upgrading jre8-openjdk-headless [######################] 100%
(439/678) upgrading jre8-openjdk [######################] 100%
(440/678) upgrading kbookmarks [######################] 100%
(441/678) upgrading kcompletion [######################] 100%
(442/678) upgrading kdbusaddons [######################] 100%
(443/678) upgrading kitemviews [######################] 100%
(444/678) upgrading knotifications [######################] 100%
(445/678) upgrading kjobwidgets [######################] 100%
(446/678) upgrading kservice [######################] 100%
(447/678) upgrading kwindowsystem [######################] 100%
(448/678) upgrading kwallet [######################] 100%
(449/678) upgrading solid [######################] 100%
(450/678) upgrading kio [######################] 100%
(451/678) upgrading kxmlgui [######################] 100%
(452/678) upgrading kcmutils [######################] 100%
(453/678) upgrading signon-kwallet-extension [######################] 100%
(454/678) upgrading signon-plugin-oauth2 [######################] 100%
(455/678) upgrading qt6-positioning [######################] 100%
(456/678) upgrading qt6-webchannel [######################] 100%
(457/678) upgrading re2 [######################] 100%
(458/678) upgrading qt6-webengine [######################] 100%
(459/678) upgrading kaccounts-integration [######################] 100%
(460/678) upgrading polkit-qt6 [######################] 100%
(461/678) upgrading kauth [######################] 100%
(462/678) upgrading kdeclarative [######################] 100%
(463/678) upgrading lib32-glibc [######################] 100%
(464/678) upgrading lib32-util-linux [######################] 100%
(465/678) upgrading lib32-glib2 [######################] 100%
(466/678) upgrading lib32-libgpg-error [######################] 100%
(467/678) upgrading lib32-libgcrypt [######################] 100%
(468/678) upgrading lib32-xz [######################] 100%
(469/678) upgrading lib32-systemd [######################] 100%
(470/678) upgrading lib32-at-spi2-core [######################] 100%
(471/678) upgrading lib32-audit [######################] 100%
(472/678) upgrading lib32-expat [######################] 100%
(473/678) upgrading lib32-libpng [######################] 100%
(474/678) upgrading lib32-freetype2 [######################] 100%
(475/678) upgrading lib32-libjpeg-turbo [######################] 100%
(476/678) upgrading lib32-gdk-pixbuf2 [######################] 100%
(477/678) upgrading lib32-harfbuzz [######################] 100%
(478/678) upgrading lib32-icu [######################] 100%
(479/678) upgrading lib32-openssl [######################] 100%
(480/678) upgrading lib32-keyutils [######################] 100%
(481/678) upgrading lib32-libcap [######################] 100%
(482/678) upgrading lib32-libcups [######################] 100%
(483/678) upgrading lib32-libnghttp2 [######################] 100%
(484/678) upgrading lib32-libngtcp2 [######################] 100%
(485/678) upgrading lib32-libpciaccess [######################] 100%
(486/678) upgrading lib32-libpipewire [######################] 100%
(487/678) upgrading lib32-libxml2 [######################] 100%
(488/678) upgrading lib32-libxft [######################] 100%
(489/678) upgrading lib32-pango [######################] 100%
(490/678) upgrading lib32-librsvg [######################] 100%
(491/678) upgrading lib32-ncurses [######################] 100%
(492/678) upgrading lib32-llvm-libs [######################] 100%
(493/678) upgrading lib32-wayland [######################] 100%
(494/678) upgrading lib32-nvidia-utils [######################] 100%
(495/678) upgrading lib32-mesa [######################] 100%
(496/678) upgrading lib32-mpg123 [######################] 100%
(497/678) upgrading lib32-sqlite [######################] 100%
(498/678) upgrading lib32-nss [######################] 100%
(499/678) upgrading lib32-opencl-nvidia [######################] 100%
(500/678) upgrading lib32-pipewire [######################] 100%
(501/678) upgrading lib32-pipewire-jack [######################] 100%
(502/678) upgrading lib32-sdl3 [######################] 100%
(503/678) upgrading lib32-sdl2-compat [######################] 100%
(504/678) upgrading vulkan-mesa-implicit-layers [######################] 100%
(505/678) upgrading lib32-vulkan-mesa-implicit... [######################] 100%
(506/678) upgrading vulkan-intel [######################] 100%
(507/678) upgrading lib32-vulkan-intel [######################] 100%
(508/678) upgrading vulkan-nouveau [######################] 100%
(509/678) upgrading lib32-vulkan-nouveau [######################] 100%
(510/678) upgrading vulkan-radeon [######################] 100%
(511/678) upgrading lib32-vulkan-radeon [######################] 100%
(512/678) upgrading libayatana-indicator [######################] 100%
(513/678) upgrading libc++abi [######################] 100%
(514/678) upgrading libc++ [######################] 100%
(515/678) upgrading libclc [######################] 100%
(516/678) upgrading libcmis [######################] 100%
(517/678) upgrading libjuice [######################] 100%
(518/678) upgrading libdatachannel [######################] 100%
(519/678) upgrading libdvbpsi [######################] 100%
(520/678) upgrading libebml [######################] 100%
(521/678) upgrading libexttextcat [######################] 100%
(522/678) upgrading libimagequant [######################] 100%
(523/678) upgrading libixion [######################] 100%
(524/678) upgrading libmicrohttpd [######################] 100%
(525/678) upgrading libnbd [######################] 100%
(526/678) upgrading liborcus [######################] 100%
(527/678) upgrading libportal-gtk3 [######################] 100%
(528/678) upgrading rasqal [######################] 100%
(529/678) upgrading redland [######################] 100%
(530/678) upgrading xmlsec [######################] 100%
(531/678) upgrading libreoffice-still [######################] 100%
(532/678) upgrading libsbsms [######################] 100%
(533/678) upgrading libtar [######################] 100%
(534/678) upgrading libupnp [######################] 100%
(535/678) upgrading libwebsockets [######################] 100%
(536/678) upgrading libxdp [######################] 100%
(537/678) upgrading linux-firmware-whence [######################] 100%
(538/678) upgrading linux-firmware-amdgpu [######################] 100%
(539/678) upgrading linux-firmware-atheros [######################] 100%
(540/678) upgrading linux-firmware-broadcom [######################] 100%
(541/678) upgrading linux-firmware-cirrus [######################] 100%
(542/678) upgrading linux-firmware-intel [######################] 100%
(543/678) upgrading linux-firmware-mediatek [######################] 100%
(544/678) upgrading linux-firmware-nvidia [######################] 100%
(545/678) upgrading linux-firmware-other [######################] 100%
(546/678) upgrading linux-firmware-radeon [######################] 100%
(547/678) upgrading linux-firmware-realtek [######################] 100%
(548/678) upgrading linux-firmware-meta [######################] 100%
(549/678) upgrading linux612 [######################] 100%
(550/678) upgrading linux612-headers [######################] 100%
(551/678) upgrading linux612-nvidia-open [######################] 100%
(552/678) upgrading linux618 [######################] 100%
(553/678) upgrading linux618-headers [######################] 100%
(554/678) upgrading linux618-nvidia-open [######################] 100%
(555/678) upgrading lsp-plugins-lv2 [######################] 100%
(556/678) upgrading lua-socket [######################] 100%
(557/678) upgrading thin-provisioning-tools [######################] 100%
(558/678) upgrading lvm2 [######################] 100%
(559/678) installing libgsystemservice [######################] 100%
(560/678) upgrading malcontent [######################] 100%
(561/678) upgrading man-pages [######################] 100%
(562/678) upgrading manjaro-gnome-settings [######################] 100%
==> To apply your preferred accent color to Gtk3 / Gtk4 applications
to match the system Libadwaita theme, run the following script from your terminal:
-> accent-color-change'
(563/678) upgrading manjaro-hello [######################] 100%
(564/678) upgrading manjaro-release [######################] 100%
(565/678) upgrading meson [######################] 100%
(566/678) upgrading perl-clone [######################] 100%
(567/678) upgrading perl-libwww [######################] 100%
(568/678) installing perl-class-inspector [######################] 100%
(569/678) installing perl-file-sharedir [######################] 100%
(570/678) upgrading perl-xml-parser [######################] 100%
(571/678) upgrading mhwd-nvidia [######################] 100%
(572/678) upgrading mhwd-nvidia-390xx [######################] 100%
(573/678) installing mhwd-nvidia-580xx [######################] 100%
(574/678) upgrading mhwd-db [######################] 100%
==> Updating Config: '/var/lib/mhwd/local/pci/video-hybrid-amd-nvidia-prime'
(575/678) upgrading mod_dnssd [######################] 100%
(576/678) upgrading mpvqt [######################] 100%
(577/678) upgrading nano [######################] 100%
(578/678) upgrading nautilus-python [######################] 100%
(579/678) upgrading ndctl [######################] 100%
(580/678) upgrading networkmanager-vpn-plugin-sstp [######################] 100%
(581/678) upgrading network-manager-sstp [######################] 100%
(582/678) upgrading nfsidmap [######################] 100%
(583/678) upgrading nfs-utils [######################] 100%
(584/678) upgrading simdjson [######################] 100%
(585/678) upgrading nodejs [######################] 100%
(586/678) upgrading noto-fonts-extra [######################] 100%
(587/678) upgrading nvidia-settings [######################] 100%
(588/678) upgrading oath-toolkit [######################] 100%
(589/678) upgrading uthash [######################] 100%
(590/678) installing cef [######################] 100%
(591/678) upgrading obs-studio [######################] 100%
(592/678) upgrading openbsd-netcat [######################] 100%
(593/678) upgrading spirv-llvm-translator [######################] 100%
(594/678) upgrading opencl-mesa [######################] 100%
(595/678) upgrading openvpn [######################] 100%
(596/678) upgrading pamac-gnome-integration [######################] 100%
(597/678) upgrading perl-image-exiftool [######################] 100%
(598/678) upgrading perl-json [######################] 100%
(599/678) upgrading pipewire-alsa [######################] 100%
(600/678) upgrading polkit-qt5 [######################] 100%
(601/678) upgrading psmisc [######################] 100%
(602/678) upgrading purpose [######################] 100%
(603/678) upgrading python-cbor2 [######################] 100%
(604/678) upgrading python-greenlet [######################] 100%
(605/678) upgrading python-eventlet [######################] 100%
(606/678) upgrading python-zope-event [######################] 100%
(607/678) upgrading python-zope-interface [######################] 100%
(608/678) upgrading python-more-itertools [######################] 100%
(609/678) upgrading python-platformdirs [######################] 100%
(610/678) upgrading python-wheel [######################] 100%
(611/678) upgrading python-jaraco.context [######################] 100%
(612/678) upgrading python-gevent [######################] 100%
(613/678) installing python-mdurl [######################] 100%
(614/678) installing python-markdown-it-py [######################] 100%
Optional dependencies for python-markdown-it-py
python-mdit_py_plugins: core plugins
python-linkify-it-py: linkify extension
(615/678) installing python-rich [######################] 100%
(616/678) upgrading python-pycparser [######################] 100%
(617/678) upgrading python-curl_cffi [######################] 100%
(618/678) upgrading python-pycurl [######################] 100%
(619/678) upgrading python-curl-adapter [######################] 100%
(620/678) upgrading python-dulwich [######################] 100%
(621/678) upgrading python-fastbencode [######################] 100%
(622/678) upgrading python-filelock [######################] 100%
(623/678) upgrading python-imagesize [######################] 100%
(624/678) upgrading python-iniconfig [######################] 100%
(625/678) upgrading python-kiwisolver [######################] 100%
(626/678) upgrading python-mako [######################] 100%
(627/678) upgrading python-numpy [######################] 100%
(628/678) upgrading python-pillow [######################] 100%
(629/678) upgrading python-six [######################] 100%
(630/678) upgrading python-matplotlib [######################] 100%
(631/678) upgrading python-protobuf [######################] 100%
(632/678) upgrading python-pytest [######################] 100%
(633/678) upgrading python-snowballstemmer [######################] 100%
(634/678) upgrading python-wxpython [######################] 100%
(635/678) upgrading python-xxhash [######################] 100%
(636/678) upgrading qemu-common [######################] 100%
(637/678) upgrading qemu-ui-opengl [######################] 100%
(638/678) upgrading qemu-ui-spice-core [######################] 100%
(639/678) upgrading qemu-chardev-spice [######################] 100%
(640/678) upgrading qemu-system-x86-firmware [######################] 100%
(641/678) upgrading qpwgraph [######################] 100%
(642/678) upgrading qt6-networkauth [######################] 100%
(643/678) upgrading qt6-scxml [######################] 100%
(644/678) upgrading qt6-tools [######################] 100%
(645/678) upgrading qt6-wayland [######################] 100%
(646/678) upgrading qt6ct [######################] 100%
(647/678) upgrading qtkeychain-qt6 [######################] 100%
(648/678) upgrading rsync [######################] 100%
(649/678) upgrading samba [######################] 100%
(650/678) upgrading sdl2_image [######################] 100%
(651/678) upgrading signal-desktop [######################] 100%
==> NOTE: Custom flags should be put directly in: ~/.config/signal-desktop-flags.conf
(652/678) upgrading snapshot [######################] 100%
(653/678) upgrading stk [######################] 100%
(654/678) upgrading strongswan [######################] 100%
(655/678) upgrading sushi [######################] 100%
(656/678) upgrading systemd-sysvcompat [######################] 100%
(657/678) upgrading texinfo [######################] 100%
(658/678) upgrading totem [######################] 100%
(659/678) upgrading udftools [######################] 100%
(660/678) upgrading zenity [######################] 100%
(661/678) upgrading xorg-xrandr [######################] 100%
(662/678) upgrading umu-launcher [######################] 100%
(663/678) upgrading unrar [######################] 100%
(664/678) upgrading vala [######################] 100%
(665/678) upgrading vim-runtime [######################] 100%
(666/678) upgrading vim [######################] 100%
(667/678) upgrading vpnc [######################] 100%
(668/678) upgrading webapp-manager [######################] 100%
(669/678) upgrading wine [######################] 100%
New optional dependencies for wine
gstreamer [installed]
libusb [installed]
perl [installed]
(670/678) upgrading wireless-regdb [######################] 100%
(671/678) upgrading wl-clipboard [######################] 100%
(672/678) upgrading wolfssl [######################] 100%
(673/678) upgrading xf86-input-elographics [######################] 100%
(674/678) upgrading xf86-video-ati [######################] 100%
(675/678) upgrading xfsprogs [######################] 100%
(676/678) upgrading xorg-server [######################] 100%
(677/678) upgrading zsh [######################] 100%
New optional dependencies for zsh
grml-zsh-config: grml's zsh setup
zsh-autosuggestions: Fish-like autosuggestions for zsh [installed]
zsh-completions: Additional completion definitions for Zsh [installed]
zsh-doc: Info, HTML and PDF format of the ZSH documentation
zsh-history-substring-search: ZSH port of Fish history search (up arrow)
[installed]
zsh-lovers: A collection of tips, tricks and examples for the Z shell.
zsh-syntax-highlighting: Fish shell like syntax highlighting for Zsh
[installed]
zshdb: A debugger for zsh scripts
(678/678) upgrading zsh-syntax-highlighting [######################] 100%
( 1/36) Creating system user accounts...
Creating group 'malcontent-timer-ext-agent' with GID 946.
Creating user 'malcontent-timer-ext-agent' (Malcontent (Parental Controls) Timer Extension Agent) with UID 946 and GID 946.
Creating group 'malcontent-timerd' with GID 945.
Creating user 'malcontent-timerd' (Malcontent (Parental Controls) Timer Daemon) with UID 945 and GID 945.
Creating group 'malcontent-webd' with GID 944.
Creating user 'malcontent-webd' (Malcontent (Parental Controls) Web Filtering Daemon) with UID 944 and GID 944.
( 2/36) Creating temporary files...
( 3/36) Registering binary formats...
( 4/36) Updating journal message catalog...
( 5/36) Updating udev hardware database...
( 6/36) Applying kernel sysctl settings...
( 7/36) Reloading system manager configuration...
( 8/36) Reloading user manager configuration...
( 9/36) Updating the MIME type database...
(10/36) Enqueuing marked services...
(11/36) Reloading device manager configuration...
(12/36) Arming ConditionNeedsUpdate...
(13/36) Rebuilding certificate stores...
(14/36) Updating module dependencies...
(15/36) Install DKMS modules
==> dkms install --no-depmod blackmagic-io/16.0a14 -k 6.12.85-1-MANJARO
==> dkms install --no-depmod v4l2loopback/0.15.3 -k 6.18.26-1-MANJARO
==> dkms install --no-depmod blackmagic-io/16.0a14 -k 6.18.26-1-MANJARO
==> dkms install --no-depmod v4l2loopback/0.15.3 -k 6.12.85-1-MANJARO
==> dkms install --no-depmod blackmagic/16.0a14 -k 6.18.26-1-MANJARO
==> dkms install --no-depmod blackmagic/16.0a14 -k 6.12.85-1-MANJARO
==> depmod 6.12.85-1-MANJARO
==> depmod 6.18.26-1-MANJARO
(16/36) Restart a running sshd.service
(17/36) Restarting cronie for libc upgrade...
(18/36) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.85-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [microcode]
-> Running build hook: [kms]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [encrypt]
-> Running build hook: [openswap]
==> WARNING: you are using potentially dangerous unlock_method keyfile, please make sure you know what you are doing
==> WARNING: https://docs.kernel.org/power/swsusp.html
==> WARNING: https://wiki.archlinux.org/title/Dm-crypt/Swap_encryption#busybox-based_initramfs
==> WARNING: keyfile_device_mount_options variable is not set and unlock_method is set to keyfile
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux618.preset: 'default'
-> -k /boot/vmlinuz-6.18-x86_64 -g /boot/initramfs-6.18-x86_64.img
==> Starting build: '6.18.26-1-MANJARO'
==> WARNING: Possibly missing firmware for module: 'qat_6xxx'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.18-x86_64.img'
(19/36) Updating the appstream cache...
✔ Metadata cache was updated successfully.
(20/36) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.18-x86_64.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
ERROR: unsupported sector size 4096 on /dev/dm-2.
ERROR: pdc: reading /dev/sdc[Input/output error]
ERROR: sil: reading /dev/sdc[Input/output error]
Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(21/36) Restarting accounts-daemon...
(22/36) Reloading system bus configuration...
(23/36) Updating system dconf databases...
(24/36) Checking for old perl modules...
(25/36) Copy Firefox Distribution Settings
(26/36) Updating fontconfig cache...
(27/36) Updating 32-bit fontconfig cache...
(28/36) Probing GDK-Pixbuf loader modules...
(29/36) Probing 32-bit GDK-Pixbuf loader modules...
(30/36) Updating GIO module cache...
(31/36) Compiling GSettings XML schema files...
(32/36) Probing GTK3 input method modules...
(33/36) Updating icon theme caches...
(34/36) Reloading GVFS config...
(35/36) Updating the info directory file...
(36/36) Updating the desktop file MIME type cache...
