Hi I installed Manjaro Cinnamon x64. Everything are great but one thing is not working. I can’t see GRUB bootloader OS selection screen. What happened i don’t know. Can you help me ?
Have a nice day
EDIT: I cannot upload images, links.
Have look at /etc/default/grub
Change there:
GRUB_TIMEOUT_STYLE=menu #OR countdown
https://www.gnu.org/software/grub/manual/grub/html_node/Simple-configuration.html
and
sudo update-grub
Thanks i will try
Problem solved by itself. That was weird but probably kernel upgrades can solve this problem
