Linux noob,
I dual booted Manjaro 20.1 on my MSI Modern 14 and it was installed perfectly and running fine but after I restarted it, grub didn’t show up and I booted right into windows , I tried booting up with live disk and running chroot also tried installing and updating grub as a root user and referred to GRUB/RESTORE in the wiki but I suppose I must be doing something wrong.
It’s not that I can’t boot into Manjaro I have to go into the BIOS and then into boot options and change preference to Manjaro but then I can’t boot into windows and am forced to change preferences in boot options every time I have to use the other OS, My laptop is running in UEFI mode but there is an option of UEFI + CSM should I switch to that or is there any other way I could make grub working.
P.S. :- I didn’t do any manual partitions while installing and chose the install alongside windows option, also fast boot is disabled, also as a root user installed grub on nvme/01 which is same as dev/sda in ssd’s but that didn’t work too.
