[grep] finding a single Ampersand within a nested directory
Hi,
I feel slightly stupid, but I need a bit of help. I have to find Ampersands (&) within a filetree (there are multiple nested folders with different depths) in actual text files.
For example there could be any character before or after the ampersand. I want to find ALL occurrences of it. Even those where they are in double (&&) or surrounded by whitespace.
I did try a lot of weird stuff with grep but nothing had me delivered sufficient results.
I know it’s probably some nice regex magic that’s needed, but I don’t get it.
Thanks in advance
Hi,
If you install ripgrep, you can do:
rg \& or rg '&'
With grep, you may try: grep -rs -F '&'
Do you want to find all file names that contain an &, or all files which contain &?
# Find all file names that contain an &
find -iregex '.*&+.*'
# Find all files that contain &. If you just want the name use `--files-with-matches`
grep --extended-regexp --recursive --regexp='.*&+.*'
Any character zero or more times
& one or more times
https://www.gnu.org/software/findutils/manual/html_mono/find.html
Awesome site for regexs: http://www.regular-expressions.info/
grep --extended-regexp --recursive --regexp= '.*&+.*'
grep: .&+.: No such file or directory
@stargazer sadly I do get an error with this command. Do you know why?
grep -rs -F '&'
contrary to the short grep above, which does result in an output. Thanks @cjean
Oooppss, remove the space after the = on --regexp.
hmm, somehow this still doesn’t give any results back compared to the 42 results of the other command.
only weird output, refering to pdf files and exe files
binary file matches
@cjean do you know a way to constrain this grep command to a certain assortment of file endings? (e.g. .c .h .cpp .hpp AND no fileending, the bare unix file)
Did it myself…just added
--include "*.cpp"
Thanks to everyone :slight_smile:
