Green vertical bars on system startup
It seems like I’m the only one with this issue, and it’s one of the only reasons I switched back to Windows
When I boot up my linux system (Arch-based KDE system) I see these green vertical overlays, and they (very) slowly fade with time
When I sampled the colors they were identical so a screenshot won’t show it, here’s a photo from my phone to demonstrate the issue:
I’m using proprietary NVIDIA drivers, and an AMD cpu, thanks in advance for your help, I really want to see this community grow.
you dont see these lines in non arch distros?
post full system info:
inxi -Fazv7
mhwd -l -li
and logs:
journalctl -b-1 -p4 --no-pager
Thanks for replying!
  Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=d95f11ed-65e9-425d-8fc0-f172de8c4c67 rw quiet splash
    udev.log_priority=3 amd_iommu=on iommu=pt video=efifb:off
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2513 high: 3600 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3084
    3: 2200 4: 2200 5: 2200 6: 2800 7: 2200 8: 3298 9: 2200 10: 2200 11: 2200
    12: 2200 13: 2211 14: 2393 15: 2728 16: 2877 17: 2246 18: 2200 19: 2879
    20: 2200 21: 3600 22: 2200 23: 3599 24: 2200 bogomips: 177692
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: ASUSTeK
    driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2022-12) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 08:00.0 chip-ID: 10de:1e07 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
    compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1080 s-dpi: 81 s-size: 803x343mm (31.61x13.50")
    s-diag: 873mm (34.38")
  Monitor-1: DP-4 res: 2560x1080 dpi: 81 size: 798x335mm (31.42x13.19")
    diag: 865mm (34.07") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX 2080
    Ti/PCIe/SSE2 direct render: Yes
Installed PCI configs:
          video-nvidia            2021.11.04               false            PCI
No installed USB configs!
0000:08:00.0 (0300:10de:1e07) Display controller nVidia Corporation:
    video-nvidia-470xx            2021.11.04               false            PCI
           video-linux            2018.05.04                true            PCI
The logs file was too long to send in this reply, I hope this data is enough
post output from this:
inxi -M
maybe there will be an entry in the arch wiki for your machine…
and for the logs, just reboot and post them:
journalctl -b0 -p4 --no-pager
Here’s what I got:
Jan 09 08:40:21 liam-pc kernel:  #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23
Jan 09 08:40:21 liam-pc kernel: ldm_parse_tocblock(): Cannot find TOCBLOCK, database may be corrupt.
Jan 09 08:40:21 liam-pc kernel: usb 3-1: config 1 has an invalid interface number: 5 but max is 4
Jan 09 08:40:21 liam-pc kernel: usb 3-1: config 1 has no interface number 4
Jan 09 08:40:21 liam-pc kernel: usb 3-6: config 1 has an invalid interface number: 2 but max is 1
Jan 09 08:40:21 liam-pc kernel: usb 3-6: config 1 has no interface number 1
Jan 09 08:40:21 liam-pc systemd-modules-load[443]: Failed to find module 'v4l2loopback'
Jan 09 08:40:21 liam-pc kernel: usb 3-1: Warning! Unlikely big volume range (=4608), cval->res is probably wrong.
Jan 09 08:40:21 liam-pc kernel: usb 3-1: [2] FU [Mic Capture Volume] ch = 1, val = -4608/0/1
Jan 09 08:40:21 liam-pc kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -61
Jan 09 08:40:21 liam-pc kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -61
Jan 09 08:40:21 liam-pc kernel: usb 3-1: Warning! Unlikely big volume range (=5632), cval->res is probably wrong.
Jan 09 08:40:21 liam-pc kernel: usb 3-1: [9] FU [Main Configuration Playback Volume] ch = 1, val = -2560/3072/1
Jan 09 08:40:21 liam-pc kernel: usb 3-1: Warning! Unlikely big volume range (=18432), cval->res is probably wrong.
Jan 09 08:40:21 liam-pc kernel: usb 3-1: [6] FU [Speaker Playback Volume] ch = 1, val = -18432/0/1
Jan 09 08:40:22 liam-pc kernel: nvidia: loading out-of-tree module taints kernel.
Jan 09 08:40:22 liam-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 09 08:40:22 liam-pc kernel: Disabling lock debugging due to kernel taint
Jan 09 08:40:22 liam-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  525.60.11  Wed Nov 23 23:04:03 UTC 2022
Jan 09 08:40:23 liam-pc kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Jan 09 08:40:23 liam-pc kernel: kauditd_printk_skb: 3 callbacks suppressed
Jan 09 08:40:23 liam-pc systemd[1]: nordvpnd.socket: TCP_NODELAY failed: Operation not supported
Jan 09 08:40:25 liam-pc systemd[899]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jan 09 08:40:25 liam-pc systemd[899]: Failed to start Update XDG user dir configuration.
Jan 09 08:40:25 liam-pc sddm-greeter[909]: QFont::fromString: Invalid description '(empty)'
Jan 09 08:40:26 liam-pc sddm-greeter[909]: QObject: Cannot create children for a parent that is in a different thread.
                                           (Parent is QGuiApplication(0x7ffc4c558bd0), parent's thread is QThread(0x5633deab3680), current thread is QThread(0x5633deb87900)
Jan 09 08:40:26 liam-pc sddm-greeter[909]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jan 09 08:40:26 liam-pc sddm-greeter[909]: Failed to find a Kirigami platform plugin
Jan 09 08:40:26 liam-pc sddm-greeter[909]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:12:1: Type InputPanel unavailable
Jan 09 08:40:26 liam-pc sddm-greeter[909]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jan 09 08:40:26 liam-pc sddm-greeter[909]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jan 09 08:40:26 liam-pc sddm-greeter[909]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Jan 09 08:40:30 liam-pc kernel: kauditd_printk_skb: 183 callbacks suppressed
Jan 09 08:40:31 liam-pc sddm-greeter[909]: failed to create compose table
Jan 09 08:40:32 liam-pc systemd-xdg-autostart-generator[999]: /home/liam/.config/autostart/org.kde.latte-dock.desktop:7: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Jan 09 08:40:32 liam-pc systemd-xdg-autostart-generator[999]: /home/liam/.config/autostart/Yakuake.desktop:15: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Jan 09 08:40:32 liam-pc systemd-xdg-autostart-generator[1034]: /home/liam/.config/autostart/org.kde.latte-dock.desktop:7: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Jan 09 08:40:32 liam-pc systemd-xdg-autostart-generator[1034]: /home/liam/.config/autostart/Yakuake.desktop:15: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Jan 09 08:40:33 liam-pc systemd[993]: /run/user/1000/systemd/generator.late/app-Yakuake@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Jan 09 08:40:33 liam-pc ksmserver[1071]: Qt: Session management error: networkIdsList argument is NULL
Jan 09 08:40:33 liam-pc ksmserver[1071]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:39:34: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:40:29: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:41:29: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:42:29: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:43:29: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:44:27: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:45:27: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:46:27: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:47:27: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:48:29: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:49:29: string literal is not a valid UTF-8 string
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:49:29: too many errors
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: /usr/share/X11/locale/iso8859-1/Compose:49:29: failed to parse file
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jan 09 08:40:33 liam-pc kwin_x11[1074]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jan 09 08:40:33 liam-pc kded5[1073]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Jan 09 08:40:34 liam-pc kded5[1073]: kscreen.kded: PowerDevil SuspendSession action not available!
Jan 09 08:40:34 liam-pc kwin_x11[1074]: kwin_scripting: /home/liam/.local/share/kwin/scripts/sticky-window-snapping/contents/code/main.js:36: error: enabledCurrently is not defined
Jan 09 08:40:34 liam-pc plasmashell[1120]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jan 09 08:40:34 liam-pc plasmashell[1120]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jan 09 08:40:34 liam-pc ksystemstats[1192]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Jan 09 08:40:34 liam-pc backlighthelper[1212]: org.kde.powerdevil: no kernel backlight interface found
Jan 09 08:40:34 liam-pc org_kde_powerdevil[1173]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 09 08:40:34 liam-pc org_kde_powerdevil[1173]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jan 09 08:40:34 liam-pc org_kde_powerdevil[1173]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jan 09 08:40:34 liam-pc org_kde_powerdevil[1173]: org.kde.powerdevil: The profile  "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Jan 09 08:40:34 liam-pc plasmashell[1120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Jan 09 08:40:34 liam-pc plasmashell[1120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:41: TypeError: Cannot read property 'length' of undefined
Jan 09 08:40:34 liam-pc plasmashell[1120]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jan 09 08:40:34 liam-pc pipewire[1276]: mod.rt: Can't find xdg-portal: (null)
Jan 09 08:40:34 liam-pc pipewire[1276]: mod.rt: found session bus but no portal
Jan 09 08:40:34 liam-pc pipewire-media-session[1279]: mod.rt: Can't find xdg-portal: (null)
Jan 09 08:40:34 liam-pc pipewire-media-session[1279]: mod.rt: found session bus but no portal
Jan 09 08:40:35 liam-pc plasmashell[1120]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 09 08:40:35 liam-pc plasmashell[1120]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/FullRepresentation.qml:22:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
Jan 09 08:40:35 liam-pc plasmashell[1120]: file:///usr/lib/qt/qml/org/kde/plasma/private/containmentlayoutmanager/BasicAppletContainer.qml:144: TypeError: Cannot read property 'width' of null
Jan 09 08:40:35 liam-pc plasmashell[1120]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/FullRepresentation.qml:28:9: Unable to assign [undefined] to double
Jan 09 08:40:35 liam-pc plasmashell[1120]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
Jan 09 08:40:35 liam-pc plasmashell[1120]: kf.quickcharts.deprecated: LegendDelegate::colorVisible is deprecated (since 5.82): Use an empty indicator instead
Jan 09 08:40:35 liam-pc plasmashell[1120]: kf.quickcharts.deprecated: LegendDelegate::layoutWidth is deprecated (since 5.82): Unused
Jan 09 08:40:35 liam-pc plasmashell[1120]: kf.quickcharts.deprecated: LegendDelegate::valueWidth is deprecated (since 5.82): Use maximumValueWidth instead
Jan 09 08:40:35 liam-pc kwin_x11[1074]: kwin_core: XCB error: 152 (BadDamage), sequence: 1876, resource id: 16777245, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jan 09 08:40:36 liam-pc kernel: usb 3-1: 3:1: cannot get freq at ep 0x82
Jan 09 08:40:36 liam-pc kernel: usb 3-1: 2:1: cannot get freq at ep 0x2
Jan 09 08:40:37 liam-pc pulseaudio[1351]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 09 08:40:39 liam-pc plasmashell[1120]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 09 08:40:40 liam-pc kernel: kauditd_printk_skb: 17 callbacks suppressed
Jan 09 08:40:55 liam-pc kwin_x11[1074]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Jan 09 08:40:55 liam-pc kwin_x11[1074]: qt.svg: link #g1000 is undefined!
Jan 09 08:40:56 liam-pc kwalletd5[1575]: kf.wallet.kwalletd: Lacking a socket, pipe: 0 env: 0
Jan 09 08:40:56 liam-pc kwalletd5[1580]: kf.wallet.kwalletd: Lacking a socket, pipe: 0 env: 0
Jan 09 08:40:58 liam-pc kded5[1073]: kf.bluezqt: PendingCall Error: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Jan 09 08:40:58 liam-pc pulseaudio[1351]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
theres nothing in the logs, so what remains:
and why did you add these parameters:
to trying to fix the screen? is the issue present also without them?
This sort of graphics failure is caused by the video card.
Yes sir, even with a clean fresh install of Linux it happens
That can’t be possible as this only happens sometimes, and in Windows I’ve never had this issue
Do you think I should switch to open-source drivers for the time being?
Hey, this problem still persists even after a reset, and the open-source drivers are stuttery like a virtual-machine, does anyone else have this issue? I’d be grateful for help
Hey, just a little update:
with video-linux drivers my screen looks sharper than I can remember (I’ve been using the other driver for a month), but it’s extremely stuttery, is there anything I can do for the computer to feel… smoother?
