Graphics related issues after update - AMD Radeon RS-235
Since I updated on 2026-07-24 there are some errors in the journal which seems to be coming from when various applications are run. Or is all this just an indicator of that my graphics card is about to become too old for new drivers?
System update went find, no issues while it ran. Only when I run certain applications (it seems to me), the errors occur.
Graphics related inxi report:
$ inxi -G
  Device-1: Advanced Micro Devices [AMD/ATI] Caicos XT [Radeon HD 7470/8470 /
    R5 235/310 OEM] driver: radeon v: kernel
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: radeon unloaded: modesetting
    dri: r600 gpu: radeon resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,r600,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 26.1.5-arch1.1
    renderer: AMD CAICOS (DRM 2.50.0 / 6.12.96-1-MANJARO)
    x11: xdpyinfo, xprop, xrandr
Related log entries (for Geany, never mind the missing spelling libraries, those are expected and have been there for years):
jul 25 10:01:15 majtaytre systemd[1302]: app-geany@d053c2fb781b423ab7b101271c8b0681.service: Consumed 1.506s CPU time over 15.043s wall clock time, 136M memory peak.
jul 25 10:01:12 majtaytre kernel: [drm:radeon_cs_ioctl [radeon]] *ERROR* Invalid command stream !
jul 25 10:01:12 majtaytre kernel: radeon 0000:01:00.0: evergreen_cs_track_validate_texture:831 texture invalid 0x007c00c1 0x1000001f 0x060a0000 0x00000000 0x00000000 0x8002001a
jul 25 10:01:12 majtaytre kernel: radeon 0000:01:00.0: evergreen_surface_check_linear_aligned:216 texture pitch 32 invalid must be aligned with 64
jul 25 10:01:12 majtaytre kwin_wayland_wrapper[1371]: radeon: The kernel rejected CS, see dmesg for more information (-22).
jul 25 10:01:08 majtaytre kernel: [drm:radeon_cs_ioctl [radeon]] *ERROR* Invalid command stream !
jul 25 10:01:08 majtaytre kernel: radeon 0000:01:00.0: evergreen_cs_track_validate_texture:831 texture invalid 0x007c00c1 0x1000001f 0x060a0000 0x00000000 0x00000000 0x8002001a
jul 25 10:01:08 majtaytre kernel: radeon 0000:01:00.0: evergreen_surface_check_linear_aligned:216 texture pitch 32 invalid must be aligned with 64
jul 25 10:01:08 majtaytre kwin_wayland_wrapper[1371]: radeon: The kernel rejected CS, see dmesg for more information (-22).
jul 25 10:01:02 majtaytre kernel: [drm:radeon_cs_ioctl [radeon]] *ERROR* Invalid command stream !
jul 25 10:01:02 majtaytre kernel: radeon 0000:01:00.0: evergreen_cs_track_validate_texture:831 texture invalid 0x007c00c1 0x1000001f 0x060a0000 0x00000000 0x00000000 0x8002001a
jul 25 10:01:02 majtaytre kernel: radeon 0000:01:00.0: evergreen_surface_check_linear_aligned:216 texture pitch 32 invalid must be aligned with 64
jul 25 10:01:02 majtaytre kwin_wayland_wrapper[1371]: radeon: The kernel rejected CS, see dmesg for more information (-22).
jul 25 10:01:01 majtaytre kernel: [drm:radeon_cs_ioctl [radeon]] *ERROR* Invalid command stream !
jul 25 10:01:01 majtaytre kernel: radeon 0000:01:00.0: evergreen_cs_track_validate_texture:831 texture invalid 0x007c00c1 0x1000001f 0x060a0000 0x00000000 0x00000000 0x8002001a
jul 25 10:01:01 majtaytre kernel: radeon 0000:01:00.0: evergreen_surface_check_linear_aligned:216 texture pitch 32 invalid must be aligned with 64
jul 25 10:01:01 majtaytre kwin_wayland_wrapper[1371]: radeon: The kernel rejected CS, see dmesg for more information (-22).
jul 25 10:01:01 majtaytre rtkit-daemon[1407]: Successfully made thread 66262 of process 66032 owned by '1000' RT at priority 5.
jul 25 10:01:01 majtaytre systemd[1302]: Started VTE child process 66259 launched by geany process 66032.
jul 25 10:01:01 majtaytre rtkit-daemon[1407]: Successfully made thread 66173 of process 66068 owned by '1000' RT at priority 5.
jul 25 10:01:01 majtaytre rtkit-daemon[1407]: Successfully made thread 66171 of process 66032 owned by '1000' RT at priority 5.
jul 25 10:01:01 majtaytre geany[66032]: broker.vala:156: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
jul 25 10:01:01 majtaytre geany[66032]: broker.vala:156: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
jul 25 10:01:01 majtaytre geany[66032]: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
Mod edit: Topic title edited for brevity.
No, not the graphics card but new graphic drivers might not play well with an old kernel. Notice there is (normally) no reason to run an old kernel if you have an older system. I would update the kernel to at least 6.18 (or 7.1.4 if 6.18 shows the same issues as you get now using 6.12). One of the good things about Manjaro is that managing different kernels is easy (and for the folks with nvidia gpus there are lots of drivers, too :wink:).
I remember seeing similar errors on my laptop some time ago. Unfortunately I can’t remember much more than that, but I think @jofi might be right and that linux618 fixed it.
I don’t have my laptop with me atm, I left it at a relative’s house, so I can’t check anything.
Okay, I switched to 618. I seem to recall there was another issue before, one with dialogs in the wrong order or whatever it was. Perhaps this has been corrected as well.
I have to test this and run a few things to see if it behaves. So far MyPaint doesn’t cause any problems, I’ll test Geany and a few others as well. VLC was also misbehaving.
I’ll mark the first reply as the solution.
Thanks for the suggestion. 8)
