A couple months ago I changed from intel to amd(Ryzen 5 7640U), no GPU only integrated, and I have been experiencing an issue where, randomly, my screen flickers white, sometimes dark spots on the screen become pixilated, and the flickering gets faster until my whole screen is white, sometimes if I start a wayland session in a new tty (I use x11), the wayland session is also completly white, but sometimes it’s unaffected. I have to reboot to fix, starting a new x11 session after closing the first one doesn’t help. it’s been happening for awhile but until recently it doesn’t happen often. I don’t know why it has been happening more often. because of the switch from intel to amd, I am guessing I need to fix my graphics drivers. I am on 6.6.16-2-MANJARO.
Here’s my inxi -Fazy output
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f6898bf0-f23e-4f8c-8f59-2b16eaa17936 rw
resume=UUID=f6898bf0-f23e-4f8c-8f59-2b16eaa17936 resume_offset=11597824
quiet splash usbcore.autosuspend=-1 apparmor=1 security=apparmor
udev.log_priority=3 ibt=off nvme.noacpi=1
Desktop: i3 v: 4.23 with: polybar tools: avail: i3lock vt: 2 dm: SDDM
Type: Laptop System: Framework product: Laptop 13 (AMD Ryzen 7040Series)
v: A5 serial: <superuser required>
Mobo: Framework model: FRANMDCP05 v: A5 serial: <superuser required>
part-nu: FRANMDCP05 uuid: <superuser required> UEFI: INSYDE v: 03.03
date: 10/17/2023
ID-1: BAT1 charge: 42.9 Wh (94.5%) condition: 45.4/55.0 Wh (82.6%)
volts: 16.5 min: 15.4 model: type: Unknown serial: <filter>
status: discharging cycles: 18
Info: model: AMD Ryzen 5 7640U w/ Radeon 760M Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x74 (116) stepping: 1 microcode: 0xA704103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 623 high: 2110 min/max: 400/4971:5121:5275:5425:5579
scaling: driver: amd-pstate-epp governor: powersave cores: 1: 1368 2: 400
3: 400 4: 400 5: 400 6: 400 7: 2110 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 83886
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Phoenix1 vendor: Framework driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, DP-6, DP-7, DP-8 bus-ID: c1:00.0 chip-ID: 1002:15bf
class-ID: 0300 temp: 42.0 C
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: Picom v: git-fc1d1 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting alternate: vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
s-diag: 716mm (28.19")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x095f built: 2019
res: 2256x1504 hz: 60 dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48")
diag: 343mm (13.5") ratio: 3:2 modes: max: 2256x1504 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.5-manjaro1.1
gfx1103_r1 LLVM 16.0.6 DRM 3.54 6.6.16-2-MANJARO) device-ID: 1002:15bf
memory: 500 MiB unified: no
API: Vulkan v: 1.3.276 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV GFX1103_R1) driver: mesa radv v: 23.3.5-manjaro1.1
device-ID: 1002:15bf surfaces: xcb,xlib
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Framework
bus-ID: c1:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Framework
driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c1:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Framework
bus-ID: c1:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 14c3:0616 class-ID: 0280
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0e8d:e616
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.82 TiB used: 782.41 GiB (42.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR402 temp: 36.9 C
scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 782.41 GiB (42.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 20 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 43.8 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 14.82 GiB used: 3.9 GiB (26.3%)
Processes: 297 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
image: 5.92 GiB services: upowerd Init: systemd v: 255 default: graphical
tool: systemctl
Packages: 2772 pm: pacman pkgs: 2754 libs: 591 tools: octopi, pacseek,
pamac, trizen, yay pm: flatpak pkgs: 9 pm: snap pkgs: 9 Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: kitty inxi: 3.3.33
Please let me know what more information I should give, I am not sure what is needed.
