Hi. I’m having an issue where my graphics card will not output any video until after I login. Currently I have 1 monitor plugged into my motherboard so I can login. After I login, my graphics card works normally.
How would I go about troubleshooting something like this?
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e65275a8-3076-4e7b-8907-e73a538d2a0d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: STRIX Z270I GAMING v: Rev X.0x
UEFI: American Megatrends v: 0704 date: 04/05/2017
Device-1: nintendo_switch_controller_battery_0003:057E:2009.0003 model: N/A
serial: N/A charge: Full status: full
System RAM: total: 16 GiB available: 15.49 GiB used: 2.47 GiB (16.0%)
Device-1: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: G-Skill part-no: F4-2400C15-8GRR serial: N/A
Device-2: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 67224
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-2
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0300
Device-2: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-3,DP-4,HDMI-A-3 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
unloaded: radeon alternate: fbdev,vesa dri: iris,radeonsi gpu: i915,amdgpu
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-2 pos: right res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:5912 memory: 15.13 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: Intel HD Graphics 630 (KBL GT2)
driver: mesa intel v: 24.0.2-manjaro1.1 device-ID: 8086:5912
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 60.0 C
IF: wlp5s0 state: up mac: <filter>
Device-1: ASUSTek Qualcomm Bluetooth 4.1 driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:6 chip-ID: 0b05:1825
class-ID: e001
Local Storage: total: 4.09 TiB used: 195.84 GiB (4.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G1B0A-00H9H0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM005-2DP166
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5980 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 195.84 GiB (42.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: e65275a8-3076-4e7b-8907-e73a538d2a0d
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F55B-5068
ID-1: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ext4 label: N/A
uuid: 6b9f7af0-b0f1-433f-ba3d-769f3f6f8162
Device-1: 1-1:2 info: CX 2.4G Receiver type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3554:fc03 class-ID: 0301
Device-2: 1-8:3 info: Nintendo Switch Pro Controller type: HID
driver: nintendo,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 057e:2009 class-ID: 0300
serial: <filter>
Device-3: 1-9:4 info: Corsair Gaming K55 RGB Keyboard type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:1b3d class-ID: 0300
serial: <filter>
Device-4: 1-10:5 info: Logitech M500s Optical Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c093 class-ID: 0300
serial: <filter>
Device-5: 1-11:6 info: ASUSTek Qualcomm Bluetooth 4.1 type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 0b05:1825 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 1525 pm: pacman pkgs: 1509 libs: 486 tools: pamac,yay pm: flatpak
pkgs: 16
1: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
2: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
3: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 276
1: cpu: 21.9% command: chromium pid: 3532 mem: 262.3 MiB (1.6%)
2: cpu: 10.2% command: chromium pid: 3327 mem: 213.3 MiB (1.3%)
3: cpu: 9.6% command: chromium pid: 3285 mem: 416.4 MiB (2.6%)
4: cpu: 4.9% command: kwin_wayland pid: 2618 mem: 232.8 MiB (1.4%)
5: cpu: 3.1% command: zsh pid: 3600 mem: 8.47 MiB (0.0%)
Memory top: 5 of 276
1: mem: 416.4 MiB (2.6%) command: chromium pid: 3285 cpu: 9.6%
2: mem: 365.3 MiB (2.3%) command: plasmashell pid: 2789 cpu: 2.2%
3: mem: 262.3 MiB (1.6%) command: chromium pid: 3532 cpu: 21.9%
4: mem: 232.8 MiB (1.4%) command: kwin_wayland pid: 2618 cpu: 4.9%
5: mem: 213.3 MiB (1.3%) command: chromium pid: 3327 cpu: 10.2%
Processes: 276 Power: uptime: 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: yakuake inxi: 3.3.33
