A very good day to you all.
I wanted to go ahead and simply reinstall my computer etc… So, as always, I transferred the Manjaro ISO to a USB stick and booted. I recently switched to an AMD Ryzen 5700X3D, did the necessary bios update for it, so far ok. The current Manjaro KDE ISO does not seem to load the graphics card driver under AMD, so very low screen resolution etc… I had also installed the system as a test, but the installation of the AMD graphics card driver fails. On my profile you can see the necessary information, which hardware is installed in my computer. The mainboard, for example, is an Asus PRIME-X370-PRO.
Best regards and have a nice Sunday.
Translated with DeepL.com (free version)
It’s possible you might need to reconfigure the graphics hardware now that you have updated your BIOS. Perhaps the card is no longer active, or needs a graphics priority of some kind to be set before appropriate drivers can be installed.
This is only a guess, and probably only one of many scenarios possible. I suggest providing enough information for others to at least make an educated guess.
As an infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Hello, thank you very much for the quick reply.
What I can say in any case, the Manjaro KDE ISO, Xahea 24.1.2 (2024-11-04) boots for example with the correct monitor resolution and the graphics card driver in this case AMD. What I can do, I boot from the new KDE ISO and submit system information. The bios is set up correctly etc… However, other distributions boot correctly.
Well, let’s start with some system information as per the command previously given, and then see what others might have to say.
Perhaps someone with a similar system can offer some advice.
Freshly booted from the ISO, here is some information:
Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de
tz=Europe/Berlin misobasedir=manjaro misolabel=MANJARO_KDE_2420 quiet
systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
UEFI: American Megatrends v: 6232 date: 09/29/2024
System RAM: total: 16 GiB available: 15.53 GiB used: 2.34 GiB (15.1%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KHX2666C16/8G serial: <filter>
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3472 min/max: 550/4149 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3472 2: 3472 3: 3472
4: 3472 5: 3472 6: 3472 7: 3472 8: 3472 9: 3472 10: 3472 11: 3472 12: 3472
13: 3472 14: 3472 15: 3472 16: 3472 bogomips: 95851
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 XL/XT [Radeon RX 56/64]
vendor: ASUSTeK driver: N/A alternate: amdgpu arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0b:00.0 chip-ID: 1002:687f class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting unloaded: radeon
alternate: fbdev,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
s-diag: 338mm (13.3")
Monitor-1: Unknown-1 mapped: None-1 res: 1024x768 hz: 60 size: N/A
modes: 1024x768
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
x11: drv: swrast inactive: gbm,wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.2.8-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 18.1.8 256 bits)
device-ID: ffffffff:ffffffff memory: 15.17 GiB unified: yes
Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Vega 10 HDMI Audio [Radeon
56/64] driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0b:00.1 chip-ID: 1002:aaf8 class-ID: 0403
API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 706.11 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 model: USB DISK 2.0 size: 7.46 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 1024 MiB fs: vfat label: N/A
uuid: 9621-0BF4
ID-2: /dev/sda2 maj-min: 8:2 size: 231.88 GiB fs: ext4 label: N/A
uuid: 96ccf560-fbe0-425a-8ba7-7e0854ff564a
ID-3: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ext4 label: Daten
uuid: e31aeb3d-ac1b-4423-9f4d-baa46a12e8e4
ID-4: /dev/sdc1 maj-min: 8:33 size: 3.71 GiB fs: iso9660
ID-5: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 2983-4F90
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-3:2 info: Phison flash drive (4GB EMTEC) type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 13fe:3600 class-ID: 0806
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-2:2 info: Valve Wireless Steam Controller type: keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 28de:1142 class-ID: 0300
Device-2: 5-3:3 info: USB Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Device-3: 5-4:4 info: INSTANT USB Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:2031 class-ID: 0300
Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 42.6 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1245 libs: 326 tools: pamac pm: flatpak pkgs: 0
1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
3: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
4: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
5: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
6: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
7: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
8: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
9: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
10: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
11: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
12: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
13: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
14: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
15: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
16: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
17: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
18: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
20: https://mirror.funami.tech/manjaro/stable/$repo/$arch
21: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
22: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
23: http://mirror.fcix.net/manjaro/stable/$repo/$arch
24: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
25: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
26: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
27: https://repos.silknet.com/manjaro/stable/$repo/$arch
28: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
29: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
30: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
31: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
32: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
33: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
34: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
35: http://manjaro.mirror.ac.za/stable/$repo/$arch
36: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
37: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
38: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
39: https://linorg.usp.br/manjaro/stable/$repo/$arch
40: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
41: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
42: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
43: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
44: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
45: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
46: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
47: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
48: https://mirror.seahost.de/manjaro/stable/$repo/$arch
49: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
50: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
51: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
52: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
53: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
54: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
55: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
56: https://mirror.dc.uz/manjaro/stable/$repo/$arch
57: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
58: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
59: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
60: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
61: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
62: https://mirror.easyname.at/manjaro/stable/$repo/$arch
63: https://mirror.23m.com/manjaro/stable/$repo/$arch
64: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
65: https://mirrors.manjaro.org/repo/stable/$repo/$arch
66: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
67: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
68: https://mirrors2.manjaro.org/stable/$repo/$arch
69: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
70: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
71: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
72: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
73: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
74: https://manjaro.kurdy.org/stable/$repo/$arch
75: http://manjaro.grena.ge/stable/$repo/$arch
76: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
77: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
78: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
79: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
80: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
81: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
82: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
83: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
84: https://mirror.init7.net/manjaro/stable/$repo/$arch
85: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
86: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
87: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
88: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
89: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
90: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
91: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
92: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
93: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
94: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
95: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
96: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
98: https://mirrors.netix.net/manjaro/stable/$repo/$arch
99: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
100: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
101: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
102: https://muug.ca/mirror/manjaro/stable/$repo/$arch
103: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
104: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
105: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
106: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
107: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
108: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
109: https://manjaro.ynh.ovh/stable/$repo/$arch
110: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
111: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
112: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
113: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
114: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
115: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
116: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
117: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
118: https://mirror.koddos.net/manjaro/stable/$repo/$arch
119: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
120: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
121: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
122: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
123: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
124: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
125: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
126: https://mirror.zetup.net/manjaro/stable/$repo/$arch
127: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
128: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
129: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
130: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
131: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
132: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 308
1: cpu: 27.9% command: kwin_x11 pid: 1421 mem: 263.9 MiB (1.6%)
2: cpu: 13.4% command: zsh pid: 3839 mem: 7.97 MiB (0.0%)
3: cpu: 11.8% command: plasmashell pid: 1527 mem: 386.8 MiB (2.4%)
4: cpu: 11.7% command: firefox pid: 3374 mem: 497.7 MiB (3.1%)
5: cpu: 5.9% command: firefox pid: 3495 mem: 251.2 MiB (1.5%)
Memory top: 5 of 308
1: mem: 497.7 MiB (3.1%) command: firefox pid: 3374 cpu: 11.7%
2: mem: 386.8 MiB (2.4%) command: plasmashell pid: 1527 cpu: 11.8%
3: mem: 263.9 MiB (1.6%) command: kwin_x11 pid: 1421 cpu: 27.9%
4: mem: 251.2 MiB (1.5%) command: firefox pid: 3495 cpu: 5.9%
5: mem: 235.2 MiB (1.4%) command: firefox pid: 3544 cpu: 4.5%
Processes: 308 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
I had also installed the new ISO normally on the computer as a test. The command:
sudo mhwd -a pci free 0300
In this case, this message appears in the console:
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> Using config 'video-linux' for device: 0000:0b:00.0 (0300:1002:687f) Display controller ATI Technologies Inc Vega 10 XL/XT [Radeon RX Vega 56/64]
> Installing video-linux...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/video-linux/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0380
Processing classid: 0302
core downloading...
extra downloading...
multilib downloading...
warning: xf86-video-ati-1:22.0.0-2 is up to date -- skipping
warning: xf86-video-amdgpu-23.0.0-2 is up to date -- skipping
warning: xf86-video-intel-1:2.99.917+923+gb74b67f0-2 is up to date -- skipping
warning: xf86-video-nouveau-1.0.18-1 is up to date -- skipping
warning: vulkan-intel-1:24.2.8-1 is up to date -- skipping
warning: vulkan-nouveau-1:24.2.8-1 is up to date -- skipping
warning: vulkan-radeon-1:24.2.8-1 is up to date -- skipping
warning: mesa-1:24.2.8-1 is up to date -- skipping
warning: lib32-vulkan-intel-1:24.2.8-1 is up to date -- skipping
warning: lib32-vulkan-nouveau-1:24.2.8-1 is up to date -- skipping
warning: lib32-vulkan-radeon-1:24.2.8-1 is up to date -- skipping
there is nothing to do
error: could not set install reason for package libva-mesa-driver (could not find or read package)
xf86-video-ati: install reason has been set to 'explicitly installed'
xf86-video-amdgpu: install reason has been set to 'explicitly installed'
xf86-video-intel: install reason has been set to 'explicitly installed'
xf86-video-nouveau: install reason has been set to 'explicitly installed'
vulkan-intel: install reason has been set to 'explicitly installed'
vulkan-nouveau: install reason has been set to 'explicitly installed'
vulkan-radeon: install reason has been set to 'explicitly installed'
lib32-vulkan-intel: install reason has been set to 'explicitly installed'
lib32-vulkan-nouveau: install reason has been set to 'explicitly installed'
lib32-vulkan-radeon: install reason has been set to 'explicitly installed'
Error: pacman failed!
Error: script failed!
I can confirm this: Xahea ISO everything correct, new ISO (Yonada) without AMD driver. No changes made to the system. Graphics card RX 580.
This might be related to Graphical interface might not start due to missing libpixbufloader-svg.so listed under Known Issues and Solutions in the 2024-11-30 Update announcement;
If that’s the case, this might help solve it;
sudo gdk-pixbuf-query-loaders --update-cache
Otherwise, if it is actually an issue with the ISO, or something else entirely, let’s see if @philm can shed any light on it.
Did I understand the following sequence of events correct?
you installed the system - this worked?
you could boot the system and everything worked?
then you tried to install or update a graphics driver - even though everything did work?
The first thing after a working fresh install should be to refresh the list of mirrors and then run a full system update.
using pacman this would be:
sudo pacman-mirrors -c Germany
or
sudo pacman-mirrors -f
and then
sudo pacman -Syu
Then you can reboot and turn your attention to the driver you want to change.
But why would you want to - if everything works?
Hello, I’ll try to express myself more clearly. I apologize if I am expressing myself incorrectly or unclearly or something…
So the current Manjaro KDE ISO does not seem to load the free AMD driver correctly. In the GRUB menu you can select the free and non-free driver, in this case the free driver. Then comes the boot process, where the correct monitor resolution is already set because the driver has been loaded, etc… With the ISO, you end up on the desktop, but with a monitor resolution of 1024x768. So the graphics card seems to be in Vesa mode? Then I simply installed Manjaro on the computer anyway in the hope that the driver would then be loaded. Exactly the same result, this time the full resolution of the monitor is set correctly. But the graphics card still seems to be without function, i.e. virtually non-existent. I always do these steps to configure the mirrors out of habit anyway. @anon29113220 also confirms that the free graphics card driver is not loaded.
refresh mirrors and full system update?
or just the mirror refresh?
How do you determine that?
You could do an
inxi -zv8
from the now installed system - it would show which driver is used
mhwd could also show you what is currently installed, no?
In your previous inxi (from the live system) I saw a modesetting driver.
I have no real hardware system to check this on - only Manjaro VM’s.
I’ll just install Manjaro quickly on my computer, then I’ll get back to you.
Best regards.
I was under the impression that you had it installed already and where looking for the solution to a problem.
But yes - without actual data from a current actual system all would remain speculation.
cscs
8 December 2024 22:52
14
Lack of linux-firmware in the images …
So …
We have the previous manjaro-firmware becoming deprecated and removed.
We also have kernels like linux66 directly depending on linux-firmware.
But kernels like linux612 do not.
Its in there lies the issue methinks.
( Yonada probably needs to be re-released. )
The command:
pamac install linux-firmware
Solves the problem, restarted the computer and the graphics card works properly again. Thank you very much!
When will the repaired ISO be available? I want to do a fresh installation on a second computer soon.
pamac install linux-firmware will not be possible in the live system because you would have to reboot.
I have of course installed the firmware on an installed system.
Kind regards.
@anon29113220 @SchulzX777
I imagine you won’t have too long to wait.
Keep an eye on the following thread;
I will re-release 6.12 ISOs by adding linux-firmware to it. Have to check why those got not installed and check why they are now optional in newer kernels.
system
Closed
12 December 2024 07:49
20
