Graphical rendering issues when attempting to use ckb-next
I am having an issue in the GUI where it lags by one frame when switching between tabs, similar to this user on the main Arch forum, whose solutions I have also tried but to no avail:
https://bbs.archlinux.org/viewtopic.php?id=289605
My GPU is currently the AMD Radeon Vega 11 as I use a Ryzen 5 2400G as my APU.
I am using the XFCE version 4.18 desktop environment with X11 as well as GTK version 3.24.38.
My Linux kernel version is 6.6.7-1.
I am now wondering what I should do to mitigate this issue.
Any help will be appreciated. Thanks in advance.
Hi @monotheisticmortal, and welcome!
I have and use ckb-next myself, and I just checked again. I have no such issues with it and never had for the ±2 years I’ve been using it.
So I don’t know what it could be, but I can provide you with information as to what I have installed, and you can possibly see a difference:
$ pamac info ckb-next
Version               : 0.6.0-1
Description           : Corsair Keyboard and Mouse Input Driver, release version
URL                   : https://github.com/ckb-next/ckb-next
Licences              : GPL2
Repository            : AUR
Installed Size        : 3.5 MB
Groups                : --
Depends On            : qt5-base hicolor-icon-theme quazip-qt5 qt5-tools libxcb xcb-util-wm qt5-x11extras libdbusmenu-qt5 python3 python-pyqt5
Optional Dependencies : libpulse [Installed]
Make Dependencies     : git cmake
Check Dependencies    : --
Required By           : --
Optional For          : --
Provides              : ckb-next
Replaces              : --
Conflicts With        : ckb-git ckb-git-latest ckb-next-git
Packager              : Unknown Packager
Maintainer            : tatokis
First Submitted       : Sat 29 Dec 2018 18:24:44
Last Modified         : Thu 22 Jun 2023 23:36:32
Votes                 : 54
Out of Date           : --
Build Date            : Wed 12 Jul 2023 09:03:41
Install Date          : Wed 12 Jul 2023 09:06:33
Install Reason        : Explicitly installed
Validated By          : None
Backup files          : --
Hope this helps!
Edit:
Another thing to do to help troubleshoot this is to open the GUI from the terminal:
ckb-next
…and seeing if there are any errors when using it.
Hi, thanks for the reply. I wasn’t expecting to hear back this quickly!
mahmud@16DT-MR-LON-XEN /o/d/resources> pamac info ckb-next
Version               : 0.6.0-1
Licences              : GPL2
Repository            : AUR
Groups                : --
Required By           : --
Optional For          : --
Provides              : ckb-next
Replaces              : --
First Submitted       : Sat 29 Dec 2018 16:24:44 GMT
Last Modified         : Thu 22 Jun 2023 22:36:32 BST
Votes                 : 54
Out of Date           : --
Build Date            : Wed 15 Nov 2023 15:27:00 GMT
Install Date          : Wed 15 Nov 2023 15:29:53 GMT
Validated By          : None
Backup files          : --
So, as you can see, I appear to be having the same exact output as you and am not sure what to do.
Just one more thing: my keyboard is the Corsair K70 Rapidfire non-RGB, although I’m not sure if it makes a difference in this case as it’s to do with the GUI.
Edit: I am running into this issue yet again when running it from terminal. It also seems to be adding a delay to my typing, making it incredibly difficult to type out this reply, so I have had to kill it from the background.
I’m afraid I have absolutely NO idea where to go and what to do. Sorry.
:sob:
