I’ve been having graphical bugs in Emacs and GIMP recently. They look like the green pixels in the image below. In Emacs they mainly appear in my dashboard’s banner and in the modeline. In GIMP they appear when I’m saving or opening an image. If I highlight the area affected the pixels sometimes disappear. What could this be caused by and how could I fix it?
System information:
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bc0a07fc-17dc-4ec8-8cac-7c24849df69e rw quiet apparmor=1
security=apparmor amd_iommu=on
resume=UUID=e9d39b3a-cde0-445c-a571-aff94958acde udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B450 Steel Legend
serial: <superuser required> UEFI: American Megatrends v: P3.40
date: 06/04/2020
RAM: total: 15.55 GiB used: 5.77 GiB (37.1%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L1: 384 KiB L2: 3 MiB L3: 32 MiB bogomips: 86276
Speed: 3623 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 4190 2: 3894 3: 2186 4: 2159 5: 3871 6: 2129 7: 2378 8: 2219 9: 4027
10: 3937 11: 4014 12: 1983
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 0c:00.0 chip-ID: 1002:731f
class-ID: 0300
Device-2: Microdia USB Live camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-4:2 chip-ID: 0c45:6536 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 952x285mm (37.5x11.2")
s-diag: 994mm (39.1")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: HDMI-A-0 res: 1680x1050 hz: 60 dpi: 99
size: 430x270mm (16.9x10.6") diag: 508mm (20")
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.42.0 5.15.2-2-MANJARO
LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0c:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Microdia USB Live camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
vendor: ASRock driver: r8169 v: kernel port: d000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: zt5u4zhvi6 state: unknown speed: 10 Mbps duplex: full mac: <filter>
IP v6: <filter> scope: link
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-3:4 chip-ID: 0a5c:21ec class-ID: fe01 serial: <filter>
Local Storage: total: 4.55 TiB used: 3.09 TiB (67.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR021 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: MBR
ID-1: / raw-size: 914.09 GiB size: 898.75 GiB (98.32%)
used: 645.43 GiB (71.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: bc0a07fc-17dc-4ec8-8cac-7c24849df69e
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D741-AF70
ID-3: /mnt/4TB raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 2.45 TiB (68.6%) fs: ext4 dev: /dev/sda maj-min: 8:0 label: 4TB
uuid: ab5b97f0-18a3-4d41-9fd4-a8eacf3c28be
ID-1: swap-1 type: partition size: 17.12 GiB used: 117.5 MiB (0.7%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:3 label: N/A
uuid: e9d39b3a-cde0-445c-a571-aff94958acde
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:4 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21ec
Device-2: 1-7:2 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Device-3: 1-10:3 info: Holtek Gaming Mouse [Redragon M711]
type: Mouse,Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:fc30 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Microdia USB Live camera type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0c45:6536 class-ID: 0102 serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Message: No sensor data found. Is lm-sensors configured?
Processes: 383 Uptime: 2h 33m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 13.0.0 Packages:
pacman: 2636 lib: 571 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.09
