Graphical Artifacts
Hey Mate,
Do you have found a Solution yet? I have the same GPU as well and i have the same Graphical Artifacts.
I hope you have found an Solution.
Your post has been moved to a dedicated topic.
Please edit the first post and describe fully the issue you are experiencing, so that others who might wish to help have somewhere to start.
Your system information is expected, as described (below), and any other detail you can add will no doubt be helpful.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
