Hello all! I recently bought a new laptop, and upon booting from the live USB I created, I noticed that it has some graphical artifacting that occurs whenever I move my mouse around. It almost seems to be at specific positions as the artifacting will remain in place until I shift my cursor away from that position, and so I was hoping to ask for some assistance in what might be occurring? I’ve tried the live USB, post-install after a reboot and removal of the drive, and post-install after updating (pacman -Syu). I’ve seen posts about optimus-manager, but they seem to go to the archive forums which I’ve not been able to access, and so I’m uncertain if doing something with that considering the laptop having both Nvidia and Intel here would be the cause, or if there may be something else worth looking into. I’ve also tried upping the kernel to 6.08 to see if that would be helpful, but I run into issues that probably warrant a second topic.
I’ve attached the inxi output as mentioned, and hopefully did so correctly; if there’s any more information that may be needed, please do let me know and I would be happy to provide it! Thank you for any and all help!
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=2b694a57-15ad-4a12-bcc0-0ff306893bbf rw quiet
cryptdevice=UUID=cf016a5a-13c1-4a47-8f1c-147832ac2913:luks-cf016a5a-13c1-4a47-8f1c-147832ac2913
root=/dev/mapper/luks-cf016a5a-13c1-4a47-8f1c-147832ac2913
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX507ZM_FX507ZM
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX507ZM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: FX507ZM.310 date: 01/26/2022
ID-1: BAT1 charge: 91.1 Wh (100.0%) condition: 91.1/90.2 Wh (100.9%)
volts: 17.3 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
RAM: total: 15.29 GiB used: 2.47 GiB (16.1%)
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 494 high: 674 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 502 2: 543 3: 446 4: 432
5: 443 6: 461 7: 528 8: 600 9: 544 10: 588 11: 457 12: 428 13: 510 14: 433
15: 400 16: 400 17: 525 18: 484 19: 674 20: 488 bogomips: 107560
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-7:3 chip-ID: 322e:202c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x153c built: 2021 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 3-9:4 v: kernel
alternate: snd_sof_pci_intel_tgl chip-ID: 0b05:6203 bus-ID: 0000:00:1f.3
class-ID: 0300 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-3: ASUSTek C-Media Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 0000:00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
IF: eno2 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0026 class-ID: e001
Device-1: luks-cf016a5a-13c1-4a47-8f1c-147832ac2913 maj-min: 254:0
type: LUKS dm: dm-0 size: 953.57 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 953.57 GiB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 11.93 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ1T0HBLB-00B00
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: FXM7301Q temp: 40.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 11.93 GiB (1.3%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-cf016a5a-13c1-4a47-8f1c-147832ac2913 label: N/A
uuid: 2b694a57-15ad-4a12-bcc0-0ff306893bbf
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 2FD9-A140
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-7:3 info: Sonix USB2.0 HD UVC WebCam type: Video
Device-3: 3-9:4 info: ASUSTek C-Media Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0b05:6203 class-ID: 0300
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 374 Uptime: 8m wakeups: 441 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1210 libs: 316 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
