Graphical artifacts after waking form sleep mode
Hi! Sometimes when i turn on my computer/laptop from sleep mode and use it for a little time i see something like that, and one thing that help’s me is logout
How can i fix that?
provide system info:
inxi -Faz
mhwd -l && mhwd -li
find /etc/X11/ -name "*.conf"
  Kernel: 6.0.2-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/vmlinuz-6.0-x86_64
    root=UUID=37b7abe2-84d5-4141-a346-2978869a62c9 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=fbdf9da8-dd4f-4cab-a51c-95878d0b3b1f:luks-fbdf9da8-dd4f-4cab-a51c-95878d0b3b1f
    root=/dev/mapper/luks-fbdf9da8-dd4f-4cab-a51c-95878d0b3b1f
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505GE_FX505GE v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: FX505GE v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FX505GE.307 date: 05/25/2020
  ID-1: BAT0 charge: 35.6 Wh (101.4%) condition: 35.1/48.1 Wh (73.0%)
    volts: 12.3 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
    serial: <filter> status: not charging cycles: 41
  Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1061 high: 2300 min/max: 800/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 901 2: 885 3: 804 4: 900
    5: 900 6: 900 7: 901 8: 2300 bogomips: 36812
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: ASUSTeK
    driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-10) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c8c
    class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-11:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP-1-1 model: Najing CEC Panda 0x002d
    built: 2018 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
  OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
    520.56.06 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
    driver: sof-audio-pci-intel-cnl
    alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:0fb9 class-ID: 0403
  Sound API: ALSA v: k6.0.2-2-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.58 running: yes
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 1.14 TiB used: 874.32 GiB (74.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPNUW-256G-1002 size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
    rev: 20110000 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1A01
    scheme: GPT
  ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 46.91 GiB (46.9%)
    fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-fbdf9da8-dd4f-4cab-a51c-95878d0b3b1f
  ID-2: /boot raw-size: 600 MiB size: 573.7 MiB (95.62%) used: 202.7 MiB
    (35.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 324 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-4: /home raw-size: 100 GiB size: 100 GiB (100.00%) used: 46.91 GiB
    (46.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
  ID-5: /var/log raw-size: 100 GiB size: 100 GiB (100.00%) used: 46.91 GiB
  System Temperatures: cpu: 61.0 C pch: 59.0 C mobo: N/A gpu: nvidia
    temp: 59 C
  Fan Speeds (RPM): cpu: 0
  Processes: 356 Uptime: 4h 29m wakeups: 26 Memory: 23.33 GiB used: 7.72 GiB
  (33.1%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1487 pm: pacman pkgs: 1478
  libs: 358 tools: pamac,yay pm: flatpak pkgs: 9 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1c8c) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2021.11.04               false            PCI
video-hybrid-intel-nvidia-470xx-prime            2021.11.04               false            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.26               false            PCI
          video-nvidia            2021.11.04               false            PCI
    video-nvidia-470xx            2021.11.04               false            PCI
    video-nvidia-390xx            2021.11.26               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
> Installed PCI configs:
/etc/X11/mhwd.d/nvidia.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/10-optimus-manager.conf
i see you have installed optimus… do you have also installed the plasma optimus tray gui?
yeap, optimus-qt
i meant the package optimus-manager-plasma its the qt version but made for plasma with additional options…
also is optimus manager installed from official repos?
pamac search -i optimus-manager
yes, it is
ok so uninstall the qt version and replace it with the plasma one:
pamac remove optimus-manager-qt
pamac install optimus-manager-plasma
and then open it and take a screenshot of the nvidia tab. there are some settings that could help, but im no longer using it so dont remember exactly …
done
good, so now open this file:
kate /etc/environment
and put there this line:
QT_LOGGING_RULES='*=false'
it will disable the qt/kwin logs, and made the logs more readable.
reboot and put your computer to sleep and when the glitches happened again provide logs:
journalctl -b0 -p4 --no-pager
also did these glitches happen on other kernels?
Oct 21 19:03:22 laptop kernel: x86/cpu: SGX disabled by BIOS.
Oct 21 19:03:22 laptop kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 21 19:03:22 laptop kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Oct 21 19:03:22 laptop kernel:  #5 #6 #7
Oct 21 19:03:22 laptop kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 21 19:03:22 laptop kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Oct 21 19:03:22 laptop kernel: vboxdrv: loading out-of-tree module taints kernel.
Oct 21 19:03:22 laptop kernel: VBoxNetAdp: Successfully started.
Oct 21 19:03:22 laptop kernel: VBoxNetFlt: Successfully started.
Oct 21 19:03:22 laptop systemd-cryptsetup[418]: Key file /etc/luks-keys/DataSecretKey is world-readable. This is not a good idea!
Oct 21 19:03:22 laptop systemd-cryptsetup[418]: /etc/luks-keys/DataSecretKey has 0644 mode that is too permissive, please adjust the ownership and access mode.
Oct 21 19:03:22 laptop kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Oct 21 19:03:22 laptop kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Oct 21 19:03:22 laptop kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
Oct 21 19:03:22 laptop systemd-journald[349]: File /var/log/journal/9b20d0ada78049adb22137e45c7f2860/system.journal corrupted or uncleanly shut down, renaming and replacing.
Oct 21 19:03:22 laptop kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
Oct 21 19:03:22 laptop kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
Oct 21 19:03:23 laptop kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
Oct 21 19:03:23 laptop kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -61
Oct 21 19:03:23 laptop kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -61
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Oct 21 19:03:24 laptop kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
Oct 21 19:03:24 laptop kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
Oct 21 19:03:24 laptop kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
Oct 21 19:03:25 laptop kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Oct 21 19:03:28 laptop kernel: kauditd_printk_skb: 3 callbacks suppressed
Oct 21 19:03:39 laptop kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 21 19:03:39 laptop systemd[1327]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 21 19:03:39 laptop bluetoothd[1327]: Failed to set mode: Failed (0x03)
Oct 21 19:03:40 laptop kernel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
Oct 21 19:03:40 laptop kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 21 19:03:40 laptop kernel: Disabling lock debugging due to kernel taint
Oct 21 19:03:41 laptop kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  520.56.06  Thu Oct  6 21:38:55 UTC 2022
Oct 21 19:03:41 laptop kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Oct 21 19:03:44 laptop kernel: kauditd_printk_skb: 19 callbacks suppressed
Oct 21 19:03:45 laptop xdg-desktop-portal-kde[1554]: qt.core.logging: Ignoring malformed logging rule: '*=false\n'
Oct 21 19:03:45 laptop xdg-desktop-portal-kde[1554]: qt.qpa.xcb: could not connect to display
Oct 21 19:03:45 laptop xdg-desktop-portal-kde[1554]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                     Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Oct 21 19:03:45 laptop systemd-coredump[1559]: Process 1554 (xdg-desktop-por) of user 967 dumped core.
                                               Module linux-vdso.so.1 with build-id 00e2007671a5413021c42f09be4e4883a8d0356c
                                               Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
                                               Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
                                               Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
                                               Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
                                               Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
                                               Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
                                               Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
                                               Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
                                               Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
                                               Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
                                               Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
                                               Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
                                               Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
                                               Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
                                               Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
                                               Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
                                               Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
                                               Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
                                               Module libQt5XcbQpa.so.5 with build-id 22a26a78db099a7a86274c88f67252ec78b8cc41
                                               Module libqxcb.so with build-id 1fdbc58e0182862fe58a8b652b794def082a3ca0
                                               Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
                                               Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
                                               Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
                                               Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
                                               Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
                                               Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
                                               Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
                                               Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
                                               Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
                                               Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
                                               Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
                                               Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
                                               Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
                                               Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
                                               Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
                                               Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
                                               Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
                                               Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
                                               Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
                                               Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
                                               Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
                                               Module libexpat.so.1 with build-id 52f685635e8711c1164d20a1ef8acd3840312094
                                               Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
                                               Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
                                               Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
                                               Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
                                               Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
                                               Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
                                               Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
                                               Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
                                               Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
                                               Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
                                               Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
                                               Module liblzma.so.5 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
                                               Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
                                               Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
                                               Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
                                               Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
                                               Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
                                               Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
                                               Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
                                               Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
                                               Module libudev.so.1 with build-id 8c459883f08a1890f2f1daa9f6eeaae357e9e790
                                               Module libKF5GlobalAccel.so.5 with build-id dfc766d1818cc24b9e82d7dc6977bff57162e616
                                               Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
                                               Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
                                               Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
                                               Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
                                               Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
                                               Module libltdl.so.7 with build-id 6a619e7b85ea9702e595881863bc9e599565e8a0
                                               Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
                                               Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
                                               Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
                                               Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
                                               Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
                                               Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
                                               Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
                                               Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
                                               Module libsystemd.so.0 with build-id ef3e323faf54271c824851913c119a7767c6bff1
                                               Module libdbus-1.so.3 with build-id 6dece245a58f1549ed98431e1242f487e8ebf9a2
                                               Module libKF5DBusAddons.so.5 with build-id 5eb888d8927faddb8d56c8ff6a693e2cce655e5c
                                               Module ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
                                               Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
                                               Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
                                               Module libKF5AuthCore.so.5 with build-id da9ff08c6e52c1ef73cfb30a8c37201731c688fc
                                               Module libKF5Crash.so.5 with build-id 5ab2ca0fc5fa2dea833bb39525117bf40b85d137
                                               Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
                                               Module libharfbuzz.so.0 with build-id 0083e085bcb9cb3869e5cb05fbcd9736c41434ab
                                               Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
                                               Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
                                               Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
                                               Module libQt5QmlModels.so.5 with build-id 75ac4ba2a588a639d18be70e47f2b106930ac1a5
                                               Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
                                               Module libKF5Archive.so.5 with build-id 819ae3371588dfb743e88c23a417bcbcc2a94694
                                               Module libQt5Svg.so.5 with build-id 7db0284946e4871e7f9effc797f1dee6b7cb1be6
                                               Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
                                               Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
                                               Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
                                               Module libQt5Xml.so.5 with build-id f67bcabb5df91d3dd74fb54fd53421bcd089b9f4
                                               Module libKF5Codecs.so.5 with build-id bf96c60657188e783178682f28ba9db0ea507aa2
                                               Module libKF5WidgetsAddons.so.5 with build-id f0abc3bee1fad21ec45b3188ce079b852e2fee80
                                               Module libKF5GuiAddons.so.5 with build-id d02d92f5bdc155cea56f6c8a709ad60fa56b9317
                                               Module libKF5ConfigWidgets.so.5 with build-id 60a779885da8389a2d94e258c09a9877b10c4b23
                                               Module libQt5Network.so.5 with build-id 4ef4fd4a75511783248e62c378fe446cfa4ccc91
                                               Module libKF5Completion.so.5 with build-id 0b50881b27f40a463706296b458b6f68c99f672d
                                               Module libKF5JobWidgets.so.5 with build-id 58ac1e987656afcbecf92a8400a13f4dbd458a92
                                               Module libKF5KIOGui.so.5 with build-id 15fb3141a045d1d4c63535c25cebe7332ee72efe
                                               Module libKF5Solid.so.5 with build-id e74245c3a71b508d6d27dd5c30fef851c784d4ae
                                               Module libKF5XmlGui.so.5 with build-id 12dbceba1d2c8b4024175f04c32c7ce59921c767
                                               Module libKF5Bookmarks.so.5 with build-id 6008e6c2825cba8cea47c90aa66622d0c7006a57
                                               Module libffi.so.8 with build-id fb5dba105458f179a9153659f3ccd8e1056a2f35
                                               Module libQt5WaylandClient.so.5 with build-id 032f7f11d4e8511b03ff65222f387e69913adfbf
                                               Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
                                               Module libXtst.so.6 with build-id eaf941ac9100f7854ebc0d512979d2fc6e87d461
                                               Module libQt5X11Extras.so.5 with build-id 78547956b3be2e12eece7fa5e9fa9f161b022c50
                                               Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
                                               Module libQt5TextToSpeech.so.5 with build-id 593099f8617753c871f48e5951f368c3a863e1cf
                                               Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
                                               Module libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
                                               Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
                                               Module libQt5Core.so.5 with build-id 10f403c84cef570e5302c7b1f0d8db34f8293f71
                                               Module libQt5DBus.so.5 with build-id 80839ec0184277ea0382ce3fdc7f84eaebb4dff9
                                               Module libKF5CoreAddons.so.5 with build-id 0c1e61a987dcc5a413145ce6f4b3e9130d478885
                                               Module libKF5I18n.so.5 with build-id 8b01b131521ee05f8dd1cdc649e8989a403f89e2
                                               Module libKF5ConfigCore.so.5 with build-id 3a7aadabb9f7166cacb72f765b328e10c66fbfa8
                                               Module libKF5Service.so.5 with build-id 9aa3259c2748aaa0c6bb8ad3a2d2a5c2a12264d5
                                               Module libKF5KIOCore.so.5 with build-id 259587c6684343e9bd0ea1b998e84d57033cad09
                                               Module libQt5Qml.so.5 with build-id 22231cfcf29a284259109c7862fb6e72406b131a
                                               Module libQt5Gui.so.5 with build-id c3306c1f059a4d83b3ece5ca28ce2a147fc154e3
                                               Module libQt5Quick.so.5 with build-id 7943b27c49d44215357f6219398a7b376dcf4cbd
                                               Module libQt5Widgets.so.5 with build-id 7948b4cf67a2e204665689ba69adedcb6ec9f7e7
                                               Module libKF5ConfigGui.so.5 with build-id 7ceed534598952ecd8bf33ad51b7d0b6db177d07
                                               Module libKF5ItemViews.so.5 with build-id 056d51112983ee6da4ebeab5da319f58b3543f3f
                                               Module libQt5PrintSupport.so.5 with build-id c2adb3cc1c1891fbd2099b4285dc59e045edfe1c
                                               Module libKF5IconThemes.so.5 with build-id 4df7a5f6480a88fd05d6643cdf07638b2c76d4cc
                                               Module libKF5WindowSystem.so.5 with build-id afc9a1c136b0d640c853e1f451c15bcda90d0575
                                               Module libKF5KIOWidgets.so.5 with build-id 7c732f0ef6ac9a794468dd6562bcb4fe50bc60fe
                                               Module libKF5KIOFileWidgets.so.5 with build-id 65786d4c4e326b7284b114c610ddbaf28610c974
                                               Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
                                               Module libKF5WaylandClient.so.5 with build-id 3bc9e53fdd7340d5d77aa731c529189626b61533
                                               Module libKF5Notifications.so.5 with build-id b80091b385d6d74d1492928b2c465a0bc6822772
                                               Module xdg-desktop-portal-kde with build-id 27e57ac12655c1d88c4f219fb1d0fa5d2f87403c
                                               Stack trace of thread 1554:
                                               #0  0x00007ff1d657364c n/a (libc.so.6 + 0x8864c)
                                               #1  0x00007ff1d6523958 raise (libc.so.6 + 0x38958)
                                               #2  0x00007ff1d650d53d abort (libc.so.6 + 0x2253d)
                                               #3  0x00007ff1d69a8ede _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fede)
                                               #4  0x00007ff1d773baa5 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13caa5)
                                               #5  0x00007ff1d773c109 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13d109)
                                               #6  0x00007ff1d6b9b1ab _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2921ab)
                                               #7  0x00007ff1d773c1b9 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13d1b9)
                                               #8  0x00007ff1d8318e0e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175e0e)
                                               #9  0x000055793da6d0c6 n/a (xdg-desktop-portal-kde + 0x1e0c6)
                                               #10 0x00007ff1d650e290 n/a (libc.so.6 + 0x23290)
                                               #11 0x00007ff1d650e34a __libc_start_main (libc.so.6 + 0x2334a)
                                               #12 0x000055793da6e535 n/a (xdg-desktop-portal-kde + 0x1f535)
                                               Stack trace of thread 1556:
                                               #0  0x00007ff1d65e60bf __poll (libc.so.6 + 0xfb0bf)
                                               #1  0x00007ff1d4eaee2f n/a (libglib-2.0.so.0 + 0xabe2f)
                                               #2  0x00007ff1d4e570d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                               #3  0x00007ff1d6be050c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
                                               #4  0x00007ff1d6b8e32c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
                                               #5  0x00007ff1d69f049f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
                                               #6  0x00007ff1d6e4dcba n/a (libQt5DBus.so.5 + 0x23cba)
                                               #7  0x00007ff1d69ed2ba n/a (libQt5Core.so.5 + 0xe42ba)
                                               #8  0x00007ff1d65718fd n/a (libc.so.6 + 0x868fd)
                                               #9  0x00007ff1d65f3a60 n/a (libc.so.6 + 0x108a60)
Oct 21 19:03:45 laptop systemd[1519]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=dumped, status=6/ABRT
Oct 21 19:03:45 laptop systemd[1519]: plasma-xdg-desktop-portal-kde.service: Failed with result 'core-dump'.
Oct 21 19:03:45 laptop systemd[1519]: Failed to start Xdg Desktop Portal For KDE.
Oct 21 19:03:52 laptop kernel: kauditd_printk_skb: 17 callbacks suppressed
Oct 21 19:03:52 laptop NetworkManager[1337]: <warn>  [1666368232.4206] device (wlo1): no secrets: No agents were available for this request.
Oct 21 19:03:52 laptop NetworkManager[1337]: <warn>  [1666368232.4211] device (wlo1): Activation: failed for connection 'amnesia'
Oct 21 19:03:52 laptop systemd-xdg-autostart-generator[1597]: /home/amnesia/.config/autostart/org.kde.latte-dock.desktop:106: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Oct 21 19:03:52 laptop systemd-journald[349]: File /var/log/journal/9b20d0ada78049adb22137e45c7f2860/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Oct 21 19:03:53 laptop systemd-xdg-autostart-generator[1630]: /home/amnesia/.config/autostart/org.kde.latte-dock.desktop:106: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Oct 21 19:03:53 laptop pipewire[1739]: mod.rt: Can't find xdg-portal: (null)
Oct 21 19:03:53 laptop pipewire[1739]: mod.rt: found session bus but no portal
Oct 21 19:03:53 laptop pipewire-media-session[1745]: mod.rt: Can't find xdg-portal: (null)
Oct 21 19:03:53 laptop pipewire-media-session[1745]: mod.rt: found session bus but no portal
Oct 21 19:03:56 laptop pulseaudio[2015]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 21 19:04:02 laptop xdg-desktop-por[1532]: Failed to create settings proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 21 19:04:02 laptop xdg-desktop-por[1532]: No skeleton to export
Oct 21 19:04:02 laptop xdg-desktop-por[1532]: Error while sending AddMatch() message: The connection is closed
Oct 21 19:04:02 laptop xdg-desktop-por[1532]: Failed to create file chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 21 19:04:02 laptop xdg-desktop-por[1532]: Failed to create app chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 21 19:04:02 laptop systemd[1519]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 21 19:04:02 laptop systemd[1519]: xdg-permission-store.service: Failed with result 'exit-code'.
Oct 21 19:04:02 laptop kernel: kauditd_printk_skb: 17 callbacks suppressed
Oct 21 19:05:55 laptop deja-dup[2343]: Theme parser error: gtk-dark.css:5268:48-49: Expected a valid selector
Oct 21 19:05:55 laptop deja-dup[2343]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
Oct 21 19:08:19 laptop kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Oct 21 19:12:26 laptop pamac-manager[35104]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Oct 21 19:15:50 laptop kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Oct 21 19:16:13 laptop yad_new[47775]: gtk_main_quit: assertion 'main_loops != NULL' failed
Oct 21 19:16:44 laptop kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Oct 21 19:21:33 laptop systemd-coredump[60153]: Process 1834 (latte-dock) of user 1000 dumped core.
                                                Module org.kde.desktop.so with build-id e56ea5e9a408bc2d34eba8da511b80875256cfcd
                                                Module libplasmashellprivateplugin.so with build-id 1344345447a5a797cb87d423c47b6c17c33bc45f
                                                Module libkwindowsystem.so with build-id de3f2c1e2d8cbeea4773ad9346f51afdfc0eed9f
                                                Module liblattecontainmentplugin.so with build-id fb2410ad1f8e75e5ab0c9895c113447a2ad7a692
                                                Module libsqlite3.so.0 with build-id 782ea1abbeebfd86f7d34c1c4fd1c23d14a8cefd
                                                Module libqsqlite.so with build-id c33f9b1af8bb408f035b3697bd89d24cf6a14023
                                                Module libqqc2desktopstyleplugin.so with build-id efe2d3caf6be71c0259a0855e1da5013b9fdb3bd
                                                Module libkconfigplugin.so with build-id 9707c3bb5247346c9e234fd5bed1196fc6b2eae3
                                                Module libqtquickcontrols2plugin.so with build-id d977ec4fc318ca05a84a9fc7db1faad6ca4732d1
                                                Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
                                                Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
                                                Module libnghttp2.so.14 with build-id 2b3da1b8c8fef25bf3aa4dbfea446a7ac94e41f9
                                                Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
                                                Module libyaml-0.so.2 with build-id 94fd2b16e4c311e4c8b041061dfdb9ca8f508e29
                                                Module libxml2.so.2 with build-id 49868de417eee9052facae410a866ebfbd5cceb8
                                                Module libxmlb.so.2 with build-id 272439d071eeb589576992d93c91897ad955d064
                                                Module libcurl.so.4 with build-id 93344344927f7c4bc68cba8e664b3744a7d69df7
                                                Module libappstream.so.4 with build-id 486291eaf797405047a693efbcc2ea76e888c7c6
                                                Module libKF5ThreadWeaver.so.5 with build-id ce600f80b5774d9ddfd5b81cb8a9d287e447c16a
                                                Module libKF5PeopleBackend.so.5 with build-id fa760316acfd5794617e7c0a0221f0b4eae10e54
                                                Module libKF5People.so.5 with build-id e437236aaaaef30d1503e33ecfee5c900d6eeef9
                                                Module libAppStreamQt.so.2 with build-id 88cde09de8689e3aab04f558b0391c713852038a
                                                Module libkworkspace5.so.5 with build-id ba98d89a0e28bbff946f857bb19cd940f8caf65c
                                                Module libKF5Runner.so.5 with build-id 7d179d512b6676eb69e3aac0f14063d9741bdc62
                                                Module libKF5PeopleWidgets.so.5 with build-id b642502ced9585313dad24cedb5d6480334bbfc2
                                                Module libkickerplugin.so with build-id 6821cf2edeac6ec25cd4a6859a123453382c3174
                                                Module libtrashplugin.so with build-id 70700d6f97f38e95cef7379ef053811654cdeb92
                                                Module libkcoreaddonsplugin.so with build-id cd9e1426d744712b217d14a202f9e103ffdcaadf
                                                Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
                                                Module libFLAC.so.12 with build-id 33c73690d24bc47897a89c69fa78e39e0953d835
                                                Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
                                                Module libasyncns.so.0 with build-id 3ed7e52f247b08f1dff19aef6a253ee4c5c785c0
                                                Module libsndfile.so.1 with build-id 923361ca7a51d29651ef1e282559cbff70e31cde
                                                Module libgmodule-2.0.so.0 with build-id 95ec7a190858206b2eaba22e06b126e4a4449200
                                                Module libpulsecommon-16.1.so with build-id 17e5c781f557e60fbc789cb631816a4a29230f4a
                                                Module libgobject-2.0.so.0 with build-id afb0315fefdf602be0615bd5c97f35a7ac1d6bbe
                                                Module libgio-2.0.so.0 with build-id 804d947f8cb14bbbbf97e8bf2f93fd17b744e719
                                                Module libpulse.so.0 with build-id 0c1618cb1e11cc14128914e45965433374cbd10e
                                                Module libpulse-mainloop-glib.so.0 with build-id 557c18bd5f54743e924a5b8e77bbc1b55a31e219
                                                Module libplasma-volume-declarative.so with build-id ba8c7f06805ae7d303cee39148a12e3461633122
                                                Module plasma_engine_mpris2.so with build-id 13434e751277b74024f7c8050fbe877383004449
                                                Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
                                                Module libkquickcontrolsaddonsplugin.so with build-id 5e1a32f471dd1b74990141f16a71e120f6a86164
                                                Module libplasmaextracomponentsplugin.so with build-id af98ac3a2982655ab70882c0ac380e6b9c73ac97
                                                Module libqtquicktemplates2plugin.so with build-id f4b00f294df9f8e45a2abca8a6b4423d74bed3c0
                                                Module libdraganddropplugin.so with build-id 0a6178fffd33a50805db6012cca8fda3a6577fde
                                                Module libKF5Kirigami2.so.5 with build-id f9efac380f9ee7d1aa0ad25b5f3615d3f898e88b
                                                Module libKirigamiPlugin.so with build-id 933eabe5fe90b9a87e6795723a8f35ae4675bf9a
                                                Module libmodelsplugin.so with build-id dec3b95ffe86af6c5cc585e512e2a453d4d95a66
                                                Module libwindowplugin.so with build-id 607f45b39ea2369baf25afdd70fba816c6fc25e1
                                                Module libqmlplugin.so with build-id 4371bda1120bcd66729c3679993a799165b62b01
                                                Module liblattetasksplugin.so with build-id 03a23f7147eea5c47355f9099ec82e8e99321cac
                                                Module libkactivitiesextensionplugin.so with build-id 8739d55baa51d62a82d9df77b94b03ab9ca400fe
                                                Module libKF5Screen.so.7 with build-id 400349ac3ee5ae05518dc587c9874208270a70b7
                                                Module libKSysGuardFormatter.so.1 with build-id 3013c7771da4f3273587f242082af6d6a347db82
                                                Module libnotificationmanager.so.1 with build-id 805c31e8ca1006a6ee506fcfd7c7b52abaf249fe
                                                Module libprocesscore.so.9 with build-id 178876639754305afe892d25f8bb22fdeeaebce5
                                                Module libKF5ActivitiesStats.so.1 with build-id 24cd8cd9f6fc4afd1849b65193400a2a07130e2d
                                                Module libtaskmanagerplugin.so with build-id 858b76a870645cc5b3c3865ff3357e034cb036df
                                                Module libspa-journal.so with build-id 0cf833b639a0ec4378aaea11ea036ba4709293ed
                                                Module libspa-support.so with build-id d2b27eeae6dbf1ec5c661fd66b957b2eb2fa2c1b
                                                Module libKF5ItemModels.so.5 with build-id 14c3455b8da0fb9e34b9d894542e7f8d59c9469a
                                                Module libpipewire-0.3.so.0 with build-id 8ea05083e795c4a79a41203a6725d9dd02b362d7
                                                Module libtaskmanager.so.6 with build-id de883aec13bf9ea7ddd19a03f709f3efefcacc45
                                                Module libtaskmanagerplugin.so with build-id b4daa098d0b27cd8bf5004b41d51c91e099897dc
                                                Module libqtgraphicaleffectsprivate.so with build-id b9b4e3f07305ece9648cfb6278a42d0cc0b721b3
                                                Module liblattecoreplugin.so with build-id b2c469f41bf0ceba95e09e0173603d698341a813
                                                Module libplasmacomponentsplugin.so with build-id d799fc5a62a95fe4a0cab8f72335549a7171d557
                                                Module libqtgraphicaleffectsplugin.so with build-id bc1cd386d3d00d57f51f7d6d62490907693fe240
                                                Module libOpenGL.so.0 with build-id 3df533822644f44fa89abdb75b9f89220dfdee56
                                                Module libEGL.so.1 with build-id 14389538015bb4a3a44e794e2466e31bf0834209
                                                Module libxcb-composite.so.0 with build-id e8b69e2806d928f66445390cc50ab33a0b98bef0
                                                Module libxcb-damage.so.0 with build-id d18fa3897f9041bfe25380abd9834332896cda81
                                                Module libcorebindingsplugin.so with build-id 762e1ddf975babaa76d2c215332713c73a96a45b
                                                Module libqquicklayoutsplugin.so with build-id 7a4113b6a11813d6e9be13985841de8c6824d775
                                                Module libwebp.so.7 with build-id 96dd01a02a3b0b4dae0d744fc3200fd36f1c2148
                                                Module libwebpdemux.so.2 with build-id 181ecf1a79aa805a45cce672f3f229570eca9f26
                                                Module libwebpmux.so.3 with build-id c987ad73c6cbbfcdb4d632ead20256769852066e
                                                Module libqwebp.so with build-id 725d6aeee464966be97e71ea125da887497e73f8
                                                Module libqwbmp.so with build-id ebaf2ce77c046c0c2de405a8efd3a7367ba6fb5f
                                                Module libtiff.so.5 with build-id 62a8aefb339c3cbe35d1089c66c527a7b090804c
                                                Module libqtiff.so with build-id b50913cb57fa44a1e2e0a1971ffa13b8d137107e
                                                Module libqsvg.so with build-id e00dd7ced56a175eef4e4c63fab3faec7191d143
                                                Module libQt5Pdf.so.5 with build-id 9e7756832b910a26e1efc7ccbf05e53f774a724f
                                                Module libqpdf.so with build-id 3dae34811999e0e7cfaff259afab2809dc58145c
                                                Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
                                                Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
                                                Module libqmng.so with build-id 8647deb2c743c3649f8b86158cb9ea4412460cd3
                                                Module libqjpeg.so with build-id 084e64bc3e811ec381bcc51a86105cdb624997e9
                                                Module libjasper.so.6 with build-id 920c93104c2081399a4d6334e239cc0fa14bc4b2
                                                Module libqjp2.so with build-id fa28f346f69d77d5377a79e206842165a6ea4880
                                                Module libqico.so with build-id a43ca21df2fe1bc4fa39b49493a9bd7ec71db2c8
                                                Module libqicns.so with build-id 9abf6684280e69a83a486248849775d27dddcaba
                                                Module libqgif.so with build-id a6e54e41d1e766e702d2e4d4b8ce54e94291daf3
                                                Module kimg_xcf.so with build-id 46a2723cfc17fddc989a17cf3adc7d42fd37423b
                                                Module kimg_tga.so with build-id da4b86dd2980d1bacd87077663c27b89b27873ae
                                                Module kimg_rgb.so with build-id 35adb39271df451086aa00a4e02a73964cff8796
                                                Module kimg_ras.so with build-id 44ce42831cec16849b928b011f6e8623d4f07f73
                                                Module kimg_psd.so with build-id 8c4f48ac9e39a91248b101f696f9855de9650eac
                                                Module kimg_pic.so with build-id 9a7d149a09545e09662dd00ae22a430dd1103ca6
                                                Module kimg_pcx.so with build-id 8f2ba0c160aeeeb28e50aba9bb53c5dde62cb46e
                                                Module kimg_ora.so with build-id 645da447933a7dbca105b7d1618dd1363c06fc62
                                                Module kimg_kra.so with build-id befb4752c903b016d624c5ccd351982bd28eb212
                                                Module libhwy.so.1 with build-id 1500ad7398608f25d35c4ed10fc8742ae2792e41
                                                Module libjxl_threads.so.0.7 with build-id 472e614ec054abb8721443c68d6305bb77fb0358
                                                Module libjxl.so.0.7 with build-id 8e7e257490e21529a24c2984c7340c9fa9535e27
                                                Module kimg_jxl.so with build-id af02345f6e0bfb58dfbb470965db0d38498c0870
                                                Module libmvec.so.1 with build-id 87830691ff1275668548231fddf8ff8eaa937fd6
                                                Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
                                                Module libde265.so.0 with build-id 459cf009e847aef8f1589ad39b1573351b6a3b22
                                                Module libheif.so.1 with build-id 038e0a8d11ceb6bd37b4f2b8930f268b9cf7adfe
                                                Module kimg_heif.so with build-id 9a7bc4756ddd0beb096b654e7a36bb39d80542d8
                                                Module kimg_hdr.so with build-id 39df4b2f47dc6a5c2b9b9a9892296c65ee0a737e
                                                Module libIlmThread-3_1.so.30 with build-id fb61aaa8abdf748eb68984c0ef25b0ae85a6565f
                                                Module libIex-3_1.so.30 with build-id 5e8a8f33fa7d4b83185155f19d4604501a86cf62
                                                Module libImath-3_1.so.29 with build-id e896fb1a525652197371e499d81b83e6c5a3d0a5
                                                Module libOpenEXR-3_1.so.30 with build-id 875e7df47bd5ce2de8806bb9fa046061fa43a8ef
                                                Module kimg_exr.so with build-id 6bdff78ca89447c86ef99db4b5e4346cd555288a
                                                Module kimg_eps.so with build-id 26456d588fff80d9c3ee52625ffc0dc4aa756eca
                                                Module libjpeg.so.8 with build-id 46dfd8b2cbe8a10d13cd3182a7b490d0959534f9
                                                Module libyuv.so with build-id 60a987609f24d8125baf7f8f2a3b288eb465d87e
                                                Module libaom.so.3 with build-id eacc2c29204604b1ebf7a40325dcaab738ce0bd1
                                                Module libSvtAv1Enc.so.1 with build-id 17c44f1a31c27a1bbe420223d8ff973d2ab58d92
                                                Module librav1e.so.0 with build-id 71e3a64e4f1fd0bda7ec80b255af3de4ea403ac1
                                                Module libdav1d.so.6 with build-id a93560a23a7f1def734a3cf54f09eadd7c3c46e9
                                                Module libavif.so.14 with build-id 7c7c60390f804291a41ed3e75cd75121eda0ed35
                                                Module kimg_avif.so with build-id 29944e9024b74693f2a2da861c76c2788613a1cb
                                                Module kimg_ani.so with build-id 57a4994daee09949a980be2134dfcf0ba5e5fca1
                                                Module libqtquickcontrolsplugin.so with build-id 338504ba25557f012bfe7a10c04856c83a7446fa
                                                Module libQt5QmlWorkerScript.so.5 with build-id 38e5b4ffdd879132bcd64d5859e8649e72b1e9dc
                                                Module libqtquick2plugin.so with build-id 550d613539501220da472cd367f7c65c834abe2d
                                                Module plasma_containmentactions_lattecontextmenu.so with build-id 9f84548139aa795580ea183a85dc6a01793720ff
                                                Module plasma_appletscript_declarative.so with build-id 695ae091c9ccc9fb56a54f2c55aab9eb161abf09
                                                Module plasma_applet.so with build-id 6abcd0da0626ff811e4939461b7b4f3c37162473
                                                Module plasma_shell.so with build-id b6cd1994c23f1b0bad38a335cf0ae9d8367f0e16
                                                Module libxcb-res.so.0 with build-id cd3dbd6dd9e412a002d1be5ae0ec0d85650542ba
                                                Module KF5WindowSystemX11Plugin.so with build-id e5f03e6614ee21483e6b85e9ddb76f5877d2e424
                                                Module libdrm.so.2 with build-id 5b59e55b50556f6d541e4d73fd6a2dcfb1983894
                                                Module librt.so.1 with build-id ce8e0934f83057f038b5a06eb70082bef142d2f0
                                                Module libnvidia-glcore.so.520.56.06 with build-id b5e8446f41653b373f33acb52a71eba82b133d52
                                                Module libnvidia-tls.so.520.56.06 with build-id 923c587d22039c45235d942668af2db11204a200
                                                Module libnvidia-glsi.so.520.56.06 with build-id 3a9139abd662306e3c750492e0c0fa98d3348b8c
                                                Module libGLX_nvidia.so.0 with build-id 2a8c63baf3f20fe2cc3b56a199a54cac93594c4b
                                                Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
                                                Module libqxcb-glx-integration.so with build-id a9ee30eef2f19532b08a6e6572737e0a6ecec96d
                                                Module libKF5Style.so.5 with build-id 8677d379bf495281814040f8a89c0ccf75bd1f52
                                                Module liblightlycommon5.so.5 with build-id 82447bae55c6f52465ff4c3078b0b0b794803873
                                                Module lightly.so with build-id e5f3d5f771b3c6ffb12acad90b769a0cd79a7ef0
                                                Module libcomposeplatforminputcontextplugin.so with build-id b7d75f89aa42cbf4504bce73360cd2bb3fe2535c
                                                Module libQt5QuickTemplates2.so.5 with build-id ef1e40831d52b364bb22c93e3155f3fb579f1fb4
                                                Module libQt5QuickControls2.so.5 with build-id cb27d61b09aa45ce43aeef8e025765452a153dc0
                                                Module KDEPlasmaPlatformTheme.so with build-id 39932ddde210fd6947031a315e15cd64e763bed3
                                                Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
                                                Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
                                                Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
                                                Module libQt5Sql.so.5 with build-id 612004f5350b4b351ff572542b62824ff96a23cb
                                                Module libKF5Syndication.so.5 with build-id 3289654c36259e322a21086936048ddc4c97833d
                                                Module libKF5Attica.so.5 with build-id 824df743b010c633397018c4228aa25c513b97e3
                                                Module libKF5Package.so.5 with build-id b0f7fb2b0d03a86f868d5fe56abced61aa2749fd
                                                Module libKF5Declarative.so.5 with build-id 9e13f296a0012730d05e4908f68bb4b8afd5c862
                                                Module libKF5Plasma.so.5 with build-id 49e4c8ebbcbde8ebd63e268fe5893e87883f15a4
                                                Module libKF5QuickAddons.so.5 with build-id ada0aa651021253db3a0f708f1a14398af511aa1
                                                Module libKF5NewStuffCore.so.5 with build-id b02f3668ae1bdf1f3e5f7a31b0b4f5d943885da9
                                                Module libKF5PlasmaQuick.so.5 with build-id ee54c58de6a6d392212e23fd68ac2e0e93f57859
                                                Module libKF5NewStuff.so.5 with build-id fb05479449a292cdd96c955b362dae91e92f93c3
                                                Module libKF5Activities.so.5 with build-id 9ccf7dcbfe2ceb561a239b4ff730b0b6ac8ceea5
                                                Module latte-dock with build-id 4c821e71ac76e3405de373b1c458b61d1c4e473c
                                                Stack trace of thread 2073:
                                                #0  0x00007f752a5a364c n/a (libc.so.6 + 0x8864c)
                                                #1  0x00007f752a553958 raise (libc.so.6 + 0x38958)
                                                #2  0x00007f752c2523a4 _ZN6KCrash19defaultCrashHandlerEi (libKF5Crash.so.5 + 0x73a4)
                                                #3  0x00007f752a553a00 n/a (libc.so.6 + 0x38a00)
                                                #4  0x00007f752c9db444 _ZN10QSGTexture12setFilteringENS_9FilteringE (libQt5Quick.so.5 + 0x18a444)
                                                #5  0x00007f752ca0b2d0 _ZN30QSGOpaqueTextureMaterialShader11updateStateERKN17QSGMaterialShader11RenderStateEP11QSGMaterialS5_ (libQt5Quick.so.5 + 0x1ba2d0)
                                                #6  0x00007f752c9f434e _ZN16QSGBatchRenderer8Renderer17renderMergedBatchEPKNS_5BatchE (libQt5Quick.so.5 + 0x1a334e)
                                                #7  0x00007f752c9f7b7e _ZN16QSGBatchRenderer8Renderer13renderBatchesEv (libQt5Quick.so.5 + 0x1a6b7e)
                                                #8  0x00007f752c9fc5d1 _ZN16QSGBatchRenderer8Renderer6renderEv (libQt5Quick.so.5 + 0x1ab5d1)
                                                #9  0x00007f752c9e4085 _ZN11QSGRenderer11renderSceneERK11QSGBindable (libQt5Quick.so.5 + 0x193085)
                                                #10 0x00007f752ca4c75c _ZN14QSGOpenGLLayer4grabEv (libQt5Quick.so.5 + 0x1fb75c)
                                                #11 0x00007f752ca4352e _ZN14QSGOpenGLLayer13updateTextureEv (libQt5Quick.so.5 + 0x1f252e)
                                                #12 0x00007f752cb9aaf7 _ZNK32QQuickOpenGLShaderEffectMaterial14updateTexturesEv (libQt5Quick.so.5 + 0x349af7)
                                                #13 0x00007f752c9e4789 _ZN11QSGRenderer10preprocessEv (libQt5Quick.so.5 + 0x193789)
                                                #14 0x00007f752c9e404c _ZN11QSGRenderer11renderSceneERK11QSGBindable (libQt5Quick.so.5 + 0x19304c)
                                                #15 0x00007f752c9e4524 _ZN11QSGRenderer11renderSceneEj (libQt5Quick.so.5 + 0x193524)
                                                #16 0x00007f752ca3d935 _ZN23QSGDefaultRenderContext15renderNextFrameEP11QSGRendererj (libQt5Quick.so.5 + 0x1ec935)
                                                #17 0x00007f752ca97e51 _ZN19QQuickWindowPrivate16renderSceneGraphERK5QSizeS2_ (libQt5Quick.so.5 + 0x246e51)
                                                #18 0x00007f752ca47f06 n/a (libQt5Quick.so.5 + 0x1f6f06)
                                                #19 0x00007f752ca4ce14 n/a (libQt5Quick.so.5 + 0x1fbe14)
                                                #20 0x00007f752ab052ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #21 0x00007f752a5a18fd n/a (libc.so.6 + 0x868fd)
                                                #22 0x00007f752a623a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 50362:
                                                #0  0x00007f752a59e4b6 n/a (libc.so.6 + 0x834b6)
                                                #1  0x00007f752a5a0fd4 pthread_cond_timedwait (libc.so.6 + 0x85fd4)
                                                #2  0x00007f752ab0c6d4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb6d4)
                                                #3  0x00007f752ab09537 n/a (libQt5Core.so.5 + 0xe8537)
                                                #4  0x00007f752ab052ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #5  0x00007f752a5a18fd n/a (libc.so.6 + 0x868fd)
                                                #6  0x00007f752a623a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 2068:
                                                #1  0x00007f752a5a0cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
                                                #2  0x00007f752ab0c744 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb744)
                                                #3  0x00007f752ca4d203 n/a (libQt5Quick.so.5 + 0x1fc203)
                                                Stack trace of thread 1982:
                                                #0  0x00007f752a6160bf __poll (libc.so.6 + 0xfb0bf)
                                                #1  0x00007f7529011e2f n/a (libglib-2.0.so.0 + 0xabe2f)
                                                #2  0x00007f7528fba0d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                                #3  0x00007f752acf850c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
                                                #4  0x00007f752aca632c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
                                                #5  0x00007f752ab0849f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
                                                #6  0x00007f752c70c300 n/a (libQt5Qml.so.5 + 0x2c0300)
                                                #7  0x00007f752ab052ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #8  0x00007f752a5a18fd n/a (libc.so.6 + 0x868fd)
                                                #9  0x00007f752a623a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 2001:
                                                Stack trace of thread 2031:
                                                #0  0x00007f752a618a11 pselect (libc.so.6 + 0xfda11)
                                                #1  0x00007f75264e8524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
                                                #2  0x00007f75264e98a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
                                                #3  0x00007f752a5a18fd n/a (libc.so.6 + 0x868fd)
                                                #4  0x00007f752a623a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 50364:
                                                Stack trace of thread 50361:
                                                Stack trace of thread 2354:
                                                Stack trace of thread 35025:
                                                Stack trace of thread 1834:
                                                #3  0x00007f752ca52340 n/a (libQt5Quick.so.5 + 0x201340)
                                                #4  0x00007f752caa23b9 _ZN12QQuickWindow5eventEP6QEvent (libQt5Quick.so.5 + 0x2513b9)
                                                #5  0x00007f752b9aeb1c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b1c)
                                                #6  0x00007f752acadb88 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cb88)
                                                #7  0x00007f752b1a6588 _ZN15QPlatformWindow11windowEventEP6QEvent (libQt5Gui.so.5 + 0x133588)
                                                #8  0x00007f752b9b3001 _ZN12QApplication6notifyEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x17d001)
                                                #9  0x00007f752acadb88 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cb88)
                                                #10 0x00007f752acf7d53 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6d53)
                                                #11 0x00007f752acf834a n/a (libQt5Core.so.5 + 0x2d734a)
                                                #12 0x00007f7528fbb81b g_main_context_dispatch (libglib-2.0.so.0 + 0x5581b)
                                                #13 0x00007f7529011ec9 n/a (libglib-2.0.so.0 + 0xabec9)
                                                #14 0x00007f7528fba0d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                                #15 0x00007f752acf850c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
                                                #16 0x00007f752aca632c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
                                                #17 0x00007f752acb0e59 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fe59)
                                                #18 0x0000560f1e4ccfbe n/a (latte-dock + 0x46fbe)
                                                #19 0x00007f752a53e290 n/a (libc.so.6 + 0x23290)
                                                #20 0x00007f752a53e34a __libc_start_main (libc.so.6 + 0x2334a)
                                                #21 0x0000560f1e4d48c5 n/a (latte-dock + 0x4e8c5)
                                                Stack trace of thread 50363:
                                                Stack trace of thread 50359:
                                                Stack trace of thread 50365:
                                                Stack trace of thread 1892:
                                                #1  0x00007f752cf3e20b n/a (libxcb.so.1 + 0xd20b)
                                                #2  0x00007f752cf3fccd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
                                                #3  0x00007f7525b70042 n/a (libQt5XcbQpa.so.5 + 0x62042)
                                                Stack trace of thread 1882:
                                                #6  0x00007f752af67cba n/a (libQt5DBus.so.5 + 0x23cba)
                                                Stack trace of thread 57385:
                                                Stack trace of thread 50360:
                                                Stack trace of thread 2070:
                                                #1  0x00007f751de92017 n/a (libnvidia-glcore.so.520.56.06 + 0x1492017)
                                                #2  0x00007f751de8f90a n/a (libnvidia-glcore.so.520.56.06 + 0x148f90a)
Oct 21 19:21:33 laptop systemd[1591]: app-org.kde.latte\x2ddock@autostart.service: Main process exited, code=dumped, status=11/SEGV
Oct 21 19:36:44 laptop kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Oct 21 19:37:33 laptop kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Oct 21 19:37:58 laptop kernel: ntfs3: Unknown parameter 'windows_names'
Oct 21 19:39:49 laptop kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Oct 21 21:02:25 laptop kernel: done.
Oct 21 21:02:28 laptop systemd-coredump[89954]: Process 1690 (plasmashell) of user 1000 dumped core.
                                                Module libnss_resolve.so.2 with build-id f43d6750ae14b48f533ad27b6d225b08d931c94d
                                                Module libnss_mdns4_minimal.so.2 with build-id a6fde528b667185a18aca5be61727fb369423647
                                                Module libnss_mymachines.so.2 with build-id 8f3a07ab4f83af1e75c1b0e769eb1edb49a06e6a
                                                Module libnss_systemd.so.2 with build-id 7742b911aa659b14561dade58e27806632303093
                                                Module kio_file.so with build-id abb5096511fc773804b7be10ae6d603212df9733
                                                Module KF5IdleTimeXcbPlugin0.so with build-id 22f751906f9843ecc08d28b76619d7421c863a35
                                                Module libKF5IdleTime.so.5 with build-id 2fdc73a6faa5835d4446bf0f979e49a75bbdb680
                                                Module plasma_engine_powermanagement.so with build-id 541430643546357d417e9ed5b0ffd35b5da2176f
                                                Module libbluetoothplugin.so with build-id 64ca571e341de3f4670d52a4e6370ae19a630c16
                                                Module libKF5BluezQt.so.6 with build-id c45192330b418b3b17277bde43c90b22954b501b
                                                Module libbluezqtextensionplugin.so with build-id 659a1f194f5c9d095ee37d355106171691b9e755
                                                Module libplc4.so with build-id ae18d68f01288868c93380064a1517522f3a844f
                                                Module libplds4.so with build-id 26c6c93ab7e9b7022734be96a91d0959b4c84fe5
                                                Module libnssutil3.so with build-id c8cd9a21ff69a279996b72edb84ecce486d69115
                                                Module libnspr4.so with build-id 7810f60fbe92aa8395979eb46f16f4dac61e6a93
                                                Module libnss3.so with build-id da49468b4b8a69c37de11aba959d1f9088ce8ffc
                                                Module libsmime3.so with build-id 728e791498d969203036d9e8b8885412e6f26bcd
                                                Module libnm.so.0 with build-id 78293f911d8bd1c0177f8b95b9935dc93dea02cb
                                                Module libKF5Wallet.so.5 with build-id 86af5a3c1c2b15b99366393b86322b743ab1a787
                                                Module libKF5NetworkManagerQt.so.6 with build-id b5f13dee66efa4eb78c9f47a9bbf651b19cc0063
                                                Module libKF5ModemManagerQt.so.6 with build-id 838b783fac826fdfa37571198e317e34bebe0196
                                                Module libplasmanm_editor.so with build-id 505bb45057bd7189967fc29e7fe8a6698774f16d
                                                Module libplasmanm_internal.so with build-id 3edc24a8cec566a7e60b2dda8a8ccd0d04b471f4
                                                Module libplasmanm_qmlplugins.so with build-id 7b5dbf63fc730b4131b3e63f41cb376e314cd803
                                                Module libnotificationmanagerplugin.so with build-id 9d8bda21d26529ca209f413f826ab09bcce542bf
                                                Module libnightcolorcontrolplugin.so with build-id d4b5f74e0cb92fee6bbb90da6321840e2f14ac0d
                                                Module libkeyboardlayoutplugin.so with build-id aaa31d24df82e8b43d2761236bdc7d3ca03a22d6
                                                Module libqtlabsplatformplugin.so with build-id 0c18b639deab28a2258b791f61dbd5065550d206
                                                Module plasma_engine_keystate.so with build-id f6eb55e7eec14a7569dc2b2edd166a531564c57b
                                                Module plasma_engine_devicenotifications.so with build-id f8efc70e4938b469bb8aac33be67955bf1fb8578
                                                Module plasma_engine_soliddevice.so with build-id bcd402fc788891c41e9b2c1da02e5db9029a6b8e
                                                Module plasma_engine_hotplug.so with build-id 655e844b7c3bccaf47fced1a62d3ccbb42a2b3e2
                                                Module libqmlfolderlistmodelplugin.so with build-id 6675d966e1a1d17664b41197508a919ccbef7124
                                                Module libdialogsprivateplugin.so with build-id 480a8aed6d477af0943cbbc1a099c1751b9e13ef
                                                Module libqca-qt5.so.2 with build-id d012438853aebbe1efa1e7d737e51d95073483d6
                                                Module libkdeconnectcore.so.22 with build-id 973713447f3031a9b9b202ee37c51e8852ce391d
                                                Module libkdeconnectinterfaces.so.22 with build-id 8d4d9d7d54c574eb917282b5042973886040718f
                                                Module libkdeconnectdeclarativeplugin.so with build-id 32ed379720e1a52fee3b67aae371ca5fcdbaf69b
                                                Module libFormatterPlugin.so with build-id deb5b1c0e6e5916bda4a100cab5372fe5d768286
                                                Module libQuickChartsControls.so with build-id 915c7fce55eada83e5dc659e6127521b95a0d2ad
                                                Module libKF5NotifyConfig.so.5 with build-id 779228913db725b9d9f1fe926670958e88536be0
                                                Module plasma_engine_notifications.so with build-id 917e14066d90bc704f529a92d1befa9ac723c4f2
                                                Module libdialogplugin.so with build-id 8f6c002093522aea8dfd41554f52056b0b1d1a8b
                                                Module libqmlsettingsplugin.so with build-id 50639c5b62ae96c5f64dedf6ae77843719b20980
                                                Module libQuickCharts.so with build-id 72cb9d191ef7f325721391e655a7435a6fa34687
                                                Module libFacesPlugin.so with build-id d19fac0b84d4c650d09da38aa61d14a1434acbfc
                                                Module libSensorsPlugin.so with build-id 58804a64224a6ea45509749820295cb60de2cbfb
                                                Module libqnmbearer.so with build-id 0c29cf6c8a0607c7b7719027d97c5f740122535e
                                                Module libqgenericbearer.so with build-id fef9f802c69aed91cbefa3a52f5a6167ed3b7e58
                                                Module libqconnmanbearer.so with build-id 88c018d6ed9944cd8c965f5232aaf177e5b7aa9e
                                                Module libQt5XmlPatterns.so.5 with build-id fcc7114b8e9c1edb1b7aeff73b9605a3a503db78
                                                Module libqmlxmllistmodelplugin.so with build-id bd0ef9e17e1fa1e79b26be637729f8877dd26367
                                                Module holidaysevents.so with build-id 0d5e63788f4516349be9c57d116339561c3d07ce
                                                Module libKF5Holidays.so.5 with build-id 126f2ac53c07a1aa66c8e88109dab77e1cc81de6
                                                Module astronomicalevents.so with build-id 3e8a2b2da4dc19a3d9c71ca4f5c1ebfbcded904a
                                                Module plasma_engine_time.so with build-id d8c43dd8fb8a7ea9de2a2cc0796165d03d6e9269
                                                Module libKF5CalendarEvents.so.5 with build-id 7e35c559257309cd88e5d1a641c5a55cc7701ba3
                                                Module libcalendarplugin.so with build-id 956c5dfc50847e3cbaac0a84ae0dac762a57ffec
                                                Module libdigitalclockplugin.so with build-id 563c08fcf8f66b9706c4cad6a4b77e0a1b22ad44
                                                Module libpagerplugin.so with build-id 46e1f7b97bd2e9d4e25b37052c528dceebadc8c5
                                                Module libcontainmentlayoutmanagerplugin.so with build-id c743f898291568f26b3ab34086cfb857a4702458
                                                Module libfolderplugin.so with build-id fac55d7415f3cb2791e069e41da6dc518b2a2c3b
                                                Module libdesktopplugin.so with build-id b81b61adaa0ff3c93a590bd57c618fb3e725c0ce
                                                Module wallpaper_images.so with build-id b4e0cc3c51072ba288f7fd19a6c7f78268d32dcd
                                                Module libplasma_wallpaper_imageplugin.so with build-id 77ecbdedb8d83f3c40cb1135b589fc03dc01c625
                                                Module plasma_wallpaper.so with build-id 8828ef24f0a99548bfa328ed396e6de4a99c592a
                                                Module libactivityswitcherextensionplugin.so with build-id d77139fdfe761861408134b18b1168b5224db58e
                                                Module org.kde.plasma.notifications.so with build-id e82be72b0d87d74a79dc7573559212913be4151a
                                                Module org.kde.plasma.private.systemtray.so with build-id 65f2f0d97548600a50f29f40b0b415b7064d7062
                                                Module sensorface_packagestructure.so with build-id d87a99b3f7cbcea61cd359d4da4c0748aa2cef48
                                                Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
                                                Module libKSysGuardSystemStats.so.1 with build-id 102aae30b0e4dcde5d9284822b3a942d5999aa4f
                                                Module libKF5ConfigQml.so.5 with build-id 6d8eddb7cf7044f54791feec6aa24ac798f4366d
                                                Module libKSysGuardSensors.so.1 with build-id 3f0cfcd54a0c3793d4fad93c884043a2c91b12b2
                                                Module libKSysGuardSensorFaces.so.1 with build-id ec1e74a66d9bd67fc3ecafbe9e4831e20367142c
                                                Module org.kde.plasma.systemmonitor.so with build-id a6d6db3077c2de8052986600672b500998c08e91
                                                Module org.kde.plasma.systemtray.so with build-id d18c3382ea75445fbf431daab21a0ce02fa6a33c
                                                Module plasma_containmentactions_switchdesktop.so with build-id 1ffb3dfc411b68ac8620dab85f04f4591db2bee2
                                                Module plasma_containmentactions_contextmenu.so with build-id 38f3745c6ac48e0dd5a7b88deb7b83a9762fa64c
                                                Module plasma_containmentactions_paste.so with build-id d57864676fc1dae95ddf4cb8a5e5d9bdffdb5f45
                                                Module plasma_layouttemplate.so with build-id 931b81d9190b1686142e8c91284d8763a53dce83
                                                Module plasma_lookandfeel.so with build-id 1b8b07abb863fec08810a82148cafbc6ce5657d6
                                                Module libKUserFeedbackCore.so.1 with build-id 0b308e5c23a0c67e2d93d630f27b832e86582597
                                                Module plasmashell with build-id 0fb43d984570abe22c55bff3dfb959fd76be8ed5
                                                Stack trace of thread 1690:
                                                #0  0x00007fc141ae44b6 n/a (libc.so.6 + 0x834b6)
                                                #1  0x00007fc141ae6cd0 pthread_cond_wait (libc.so.6 + 0x85cd0)
                                                #2  0x00007fc14400b95e n/a (libxcb.so.1 + 0xd95e)
                                                #3  0x00007fc14400c8d6 xcb_wait_for_reply (libxcb.so.1 + 0xe8d6)
                                                #4  0x00007fc13ce392cc _ZN14QXcbConnection27xi2HandleDeviceChangedEventEPv (libQt5XcbQpa.so.5 + 0x702cc)
                                                #5  0x00007fc13ce051dd _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt5XcbQpa.so.5 + 0x3c1dd)
                                                #6  0x00007fc13ce093a0 _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5XcbQpa.so.5 + 0x403a0)
                                                #7  0x00007fc13ce2d6b8 n/a (libQt5XcbQpa.so.5 + 0x646b8)
                                                #8  0x00007fc1403d881b g_main_context_dispatch (libglib-2.0.so.0 + 0x5581b)
                                                #9  0x00007fc14042eec9 n/a (libglib-2.0.so.0 + 0xabec9)
                                                #10 0x00007fc1403d70d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                                #11 0x00007fc14215650c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
                                                #12 0x00007fc14210432c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
                                                #13 0x00007fc14210ee59 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fe59)
                                                #14 0x00005579d87f5123 n/a (plasmashell + 0x23123)
                                                #15 0x00007fc141a84290 n/a (libc.so.6 + 0x23290)
                                                #16 0x00007fc141a8434a __libc_start_main (libc.so.6 + 0x2334a)
                                                #17 0x00005579d87f54d5 n/a (plasmashell + 0x234d5)
                                                Stack trace of thread 1921:
                                                #0  0x00007fc141b5c0bf __poll (libc.so.6 + 0xfb0bf)
                                                #1  0x00007fc14042ee2f n/a (libglib-2.0.so.0 + 0xabe2f)
                                                #2  0x00007fc1403d70d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                                #3  0x00007fc14215650c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
                                                #4  0x00007fc14210432c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
                                                #5  0x00007fc141f6649f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
                                                #6  0x00007fc14391acaf n/a (libQt5Quick.so.5 + 0x154caf)
                                                #7  0x00007fc141f632ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #8  0x00007fc141ae78fd n/a (libc.so.6 + 0x868fd)
                                                #9  0x00007fc141b69a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 1702:
                                                #1  0x00007fc14400b20b n/a (libxcb.so.1 + 0xd20b)
                                                #2  0x00007fc14400cccd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
                                                #3  0x00007fc13ce2b042 n/a (libQt5XcbQpa.so.5 + 0x62042)
                                                #4  0x00007fc141f632ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #5  0x00007fc141ae78fd n/a (libc.so.6 + 0x868fd)
                                                #6  0x00007fc141b69a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 1981:
                                                #6  0x00007fc141f632ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #7  0x00007fc141ae78fd n/a (libc.so.6 + 0x868fd)
                                                #8  0x00007fc141b69a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 29513:
                                                #2  0x00007fc141f6a744 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb744)
                                                #3  0x00007fc1439c2203 n/a (libQt5Quick.so.5 + 0x1fc203)
                                                Stack trace of thread 35384:
                                                Stack trace of thread 78077:
                                                Stack trace of thread 9959:
                                                Stack trace of thread 1969:
                                                #1  0x00007fc12e692017 n/a (libnvidia-glcore.so.520.56.06 + 0x1492017)
                                                #2  0x00007fc12e68f90a n/a (libnvidia-glcore.so.520.56.06 + 0x148f90a)
                                                #3  0x00007fc141ae78fd n/a (libc.so.6 + 0x868fd)
                                                #4  0x00007fc141b69a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 2030:
                                                #3  0x00007fc14400c937 xcb_wait_for_reply64 (libxcb.so.1 + 0xe937)
                                                #4  0x00007fc14124ec4d _XReply (libX11.so.6 + 0x47c4d)
                                                #5  0x00007fc1356adc7a n/a (libGLX_nvidia.so.0 + 0xadc7a)
                                                #6  0x00007fc13568a26b n/a (libGLX_nvidia.so.0 + 0x8a26b)
                                                #7  0x00007fc12e765768 n/a (libnvidia-glcore.so.520.56.06 + 0x1565768)
                                                #8  0x00007fc12e74d495 n/a (libnvidia-glcore.so.520.56.06 + 0x154d495)
                                                #9  0x00007fc12e750917 n/a (libnvidia-glcore.so.520.56.06 + 0x1550917)
                                                #10 0x00007fc12e75119b n/a (libnvidia-glcore.so.520.56.06 + 0x155119b)
                                                #11 0x00007fc12e6f3ab6 n/a (libnvidia-glcore.so.520.56.06 + 0x14f3ab6)
                                                #12 0x00007fc12e6f5f31 n/a (libnvidia-glcore.so.520.56.06 + 0x14f5f31)
                                                #13 0x00007fc12e6f7d3a n/a (libnvidia-glcore.so.520.56.06 + 0x14f7d3a)
                                                #14 0x00007fc12e6f852e n/a (libnvidia-glcore.so.520.56.06 + 0x14f852e)
                                                #15 0x00007fc12e6b2e58 n/a (libnvidia-glcore.so.520.56.06 + 0x14b2e58)
                                                #16 0x00007fc12e350cde n/a (libnvidia-glcore.so.520.56.06 + 0x1150cde)
                                                #17 0x00007fc14396cb49 _ZN16QSGBatchRenderer8Renderer13renderBatchesEv (libQt5Quick.so.5 + 0x1a6b49)
                                                #18 0x00007fc1439715d1 _ZN16QSGBatchRenderer8Renderer6renderEv (libQt5Quick.so.5 + 0x1ab5d1)
                                                #19 0x00007fc143959085 _ZN11QSGRenderer11renderSceneERK11QSGBindable (libQt5Quick.so.5 + 0x193085)
                                                #20 0x00007fc143959524 _ZN11QSGRenderer11renderSceneEj (libQt5Quick.so.5 + 0x193524)
                                                #21 0x00007fc1439b2935 _ZN23QSGDefaultRenderContext15renderNextFrameEP11QSGRendererj (libQt5Quick.so.5 + 0x1ec935)
                                                #22 0x00007fc143a0ce51 _ZN19QQuickWindowPrivate16renderSceneGraphERK5QSizeS2_ (libQt5Quick.so.5 + 0x246e51)
                                                #23 0x00007fc1439bcf06 n/a (libQt5Quick.so.5 + 0x1f6f06)
                                                #24 0x00007fc1439c1e14 n/a (libQt5Quick.so.5 + 0x1fbe14)
                                                #25 0x00007fc141f632ba n/a (libQt5Core.so.5 + 0xe42ba)
                                                #26 0x00007fc141ae78fd n/a (libc.so.6 + 0x868fd)
                                                #27 0x00007fc141b69a60 n/a (libc.so.6 + 0x108a60)
                                                Stack trace of thread 1980:
                                                #6  0x00007fc114d3712e n/a (libqmlxmllistmodelplugin.so + 0xd12e)
                                                Stack trace of thread 1701:
                                                #6  0x00007fc142a33cba n/a (libQt5DBus.so.5 + 0x23cba)
                                                Stack trace of thread 1947:
                                                Stack trace of thread 89313:
                                                Stack trace of thread 1769:
                                                #6  0x00007fc1435dd300 n/a (libQt5Qml.so.5 + 0x2c0300)
                                                Stack trace of thread 2009:
                                                #0  0x00007fc141b5ea11 pselect (libc.so.6 + 0xfda11)
                                                #1  0x00007fc13f7f7524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
                                                #2  0x00007fc13f7f88a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
                                                Stack trace of thread 35401:
                                                Stack trace of thread 35403:
Oct 21 21:02:28 laptop systemd[1591]: plasma-plasmashell.service: Main process exited, code=dumped, status=6/ABRT
Oct 21 21:02:31 laptop kernel: kauditd_printk_skb: 7 callbacks suppressed
Oct 21 21:03:08 laptop systemd[1591]: plasma-plasmashell.service: State 'final-sigterm' timed out. Killing.
Oct 21 21:03:08 laptop systemd[1591]: plasma-plasmashell.service: Failed with result 'core-dump'.
you have there dumped core of latte dock and afterwards dumped core of plasmashell… latted dock is no longer maintained, so create a new test user from system settings, log out, log in with the test user and test the sleep, to see if its related to latte dock or its a system wide issue
Hello,
I am on a desktop machine and I am also facing the exact same issue. I don’t use optimus or switchable graphics. I have an Nvidia 1080Ti and also running KDE. I was wondering if anyone made any progress with this issue.
