Graphical and network issues after fresh install, weird game freezes
Hi, this is my first post here and my observations overlap between gnome freezing, networking shenanigans and game (Monster Hunter Wilds) freezes. If this post is not correctly placed here please tell me or move it.
I installed manjaro (minimal) on my machine on sunday and since then i observed these issues:
Gnome:
  • Sometimes gnome becomes unresponsive. The Super key does nothing, tabbing through applications does nothing and i cannot move or close windows.
  • Especially when having a game open gnome becomes very laggy. When the game freezes almost always causes a gnome freeze as well, which is why i think the issues are connected.
  • Most of the time, the wifi connects only after 30 sec or so. Other times it is connected instantly. We never had this issue with this dongle or the wifi on any other device.
  • Rarely, the NetworkManager seems to die out of nowhere. I only notice by the wifi being gone and the network tab in the settings telling me that the service is unavailable.
  • Sometimes the connection is dropped and reconnected after ~30 sec.
Gaming:
I want to play Monster Hunter Wilds using Steam+Proton. I tried both Proton Experimental as well as Bleeding Edge. The result is the same. In general the game runs quite smoothly based on my hardware performance, but there is one issue that makes it unplayable:
Sometimes randomly and in specific missions in particular the game freezes
completely when doing a certain fight for one to three minutes. I can still hear music, but the game is unresponsive. In btop I can see that the gpu and cpu are not under more load than they are otherwise during the mission, vram is not maxed out and the temperatures are around 70°C, which should be perfectly fine. After the freeze, one or two cores of the cpu max out at 100% for a few seconds, then the load on cpu and gpu drops to the same it would have without the game.
I tried a lot of different settings constellations, different proton versions, reinstalled the nvidia drivers and all kinds of ingame changes i can make. nothing made a difference.
I believe on the install of manjaro something went wrong, maybe some driver was installed incorrectly. I used manjaro on this exact machine before already, but after moving i wanted to have a fresh install, since i didn’t use the windows partition anymore. The only difference was, that this time the install of the full version did not work, it stopped at “Configuring Hardware” at 78% indefinitely. The minimal version worked smoothly.
Here is my inxi -zv8:
Output
  Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=ba7d35b5-a2fe-4c71-8557-0ca1a639ed92 rw quiet splash
    udev.log_priority=3
  Desktop: GNOME v: 47.4 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7B78 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: X470 GAMING PRO CARBON (MS-7B78) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: 2.40 date: 11/06/2018
  System RAM: total: 32 GiB available: 31.29 GiB used: 3.68 GiB (11.8%)
  Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: spec: 2133 MT/s actual: 1067 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMK32GX4M2B3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 1+
    level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
    model-id: 8 stepping: 2 microcode: 0x800820D
    smt: enabled cache: L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB
    desc: 8x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2200 min/max: 2200/3700 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 118418
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: Micro-Star MSI
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: none off: DP-3,HDMI-A-1 empty: DP-1,DP-2,Unknown-2 bus-ID: 1c:00.0
    chip-ID: 10de:1e87 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
    compositor: gnome-shell driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch note: X driver n/a, try sudo/root
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
  Monitor-1: DP-4 pos: primary,right res: N/A size: 531x299mm (20.91x11.77")
    modes: N/A
  Monitor-2: HDMI-0 pos: left res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 102 size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
    memory: 7.81 GiB
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 1c:00.1
    chip-ID: 10de:10f8 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 1e:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Shure X2u Adapter driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
    chip-ID: 14ed:29b6 class-ID: 0300
  API: ALSA v: k6.12.12-2-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
  Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 18:00.0
  IF: enp24s0 state: down mac: <filter>
  Device-2: TP-Link Archer T3U [Realtek RTL8812BU] driver: rtw_8822bu
    type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-6:2
    chip-ID: 2357:012d class-ID: 0000 serial: <filter>
  IF: wlp3s0f0u6 state: up mac: <filter>
  Local Storage: total: 1.14 TiB used: 95.97 GiB (8.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 36.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2KW256G8
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 002C scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 95.97 GiB (10.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: ba7d35b5-a2fe-4c71-8557-0ca1a639ed92
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: B9B1-446E
  ID-1: /dev/sda1 maj-min: 8:1 size: 238.47 GiB fs: ntfs label: Media
    uuid: 0CD4CCAFD4CC9BF8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 1-4:2 info: CHERRY Wireless Device type: keyboard,mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 046a:0115 class-ID: 0300
  Device-2: 1-13:4 info: Corsair Gaming HARPOON RGB Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 1b1c:1b3c class-ID: 0300
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Device-1: 2-6:2 info: TP-Link Archer T3U [Realtek RTL8812BU] type: Network
    driver: rtw_8822bu interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 504mA chip-ID: 2357:012d class-ID: 0000
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Shure X2u Adapter type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Device-2: 5-2:3 info: Microsoft Xbox One Elite Controller
    type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0
    chip-ID: 045e:02e3 class-ID: ff00 serial: <filter>
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 43.2 C mobo: N/A gpu: nvidia temp: 58 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: 891 pm: pacman pkgs: 884 libs: 293 tools: gnome-software,pamac
    pm: flatpak pkgs: 7
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    3: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 358
  1: cpu: 8.8% command: firefox pid: 1973 mem: 733.1 MiB (2.2%)
  2: cpu: 4.2% command: firefox pid: 2341 mem: 341.1 MiB (1.0%)
  3: cpu: 3.5% command: signal-desktop pid: 4186 mem: 367.9 MiB (1.1%)
  4: cpu: 1.8% command: gnome-shell pid: 1340 mem: 363.6 MiB (1.1%)
  5: cpu: 1.2% command: thunderbird pid: 2939 mem: 700.9 MiB (2.1%)
  Memory top: 5 of 358
  1: mem: 733.1 MiB (2.2%) command: firefox pid: 1973 cpu: 8.8%
  2: mem: 700.9 MiB (2.1%) command: thunderbird pid: 2939 cpu: 1.2%
  3: mem: 367.9 MiB (1.1%) command: signal-desktop pid: 4186 cpu: 3.5%
  4: mem: 363.6 MiB (1.1%) command: gnome-shell pid: 1340 cpu: 1.8%
  5: mem: 341.1 MiB (1.0%) command: firefox pid: 2341 cpu: 4.2%
  Processes: 358 Power: uptime: 59m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: gsd-power,upowerd
  Compilers: N/A Shell: Bash v: 5.2.37 running-in: gnome-terminal
    inxi: 3.3.37
Here my mhwd -li:
> Installed PCI configs:
          video-nvidia            2024.05.03               false            PCI
Here my kernel version:
   * linux612
This is my manjaro version:
ManjaroLinux 25.0.0 Zetar
I don’t really know how to debug this further and hope for your support. Thank you in advance!
This may indicate hardware / file system problems
Have you already tried different kernels?
Like 6.6(LTS) or 6.13
:footprints:
After moving the pc was shut off for ~6months and when i attempted to reboot there were some ram issues. apparently the ram frequency settings were different, and resetting those to the correct frequencies fixed the issues i had there. Maybe that has something to do with it?
I will try a different kernel after lunch, thanks for the quick response.
Okay, i now tried kernel version 6.6, and i ran into the exact same issue. This time even before going on this one mission, simply in the lobby.
Again, game freeze, short cpu rush, then calm again. During the CPU rush gnome was unresponsive again. This time i actually made screenshots of the btop output.
The moment of the crash:
393475202341797908/1346519206773919889/moment-of-crash.png?ex=67c87b3c&is=67c729bc&hm=aa3e2f01b72e80b55c91255bee15300d854b9e7ce80531cc79dcad07dcf16653&=&format=webp&quality=lossless&width=605&height=678
Then, when the gnome ui became somewhat usable again there is always this “terminate called without an active exception” and “Aborted (core dumped)” on the top:
393475202341797908/1346519207176699944/crash-of-btop.png?ex=67c87b3c&is=67c729bc&hm=1cdc93992fe2a061220da157b1e6b91ab4b1737c9e50d41d6677c8c4a38b8c7e&=&format=webp&quality=lossless&width=605&height=678
(I’m not allowed to embed images or links, so i uploaded them to discord. Just append the link snippet with media. discordapp. net/attachments/)
Oh, now that I read it again, did you mean I should try installing the full version of manjaro with a different kernel?
I’ll try 6.13 next.
I also noticed that there are a few warnings in the log when switching kernels.
6.6:
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> WARNING: consolefont: no font found in configuration
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
6.13:
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
maybe the missing firmware warnings are a hint?
full 6.6:
Summary
The following packages will be installed:
linux66
linux66-nvidia
Starting
resolving dependencies...
Packages (2) linux66-6.6.75-2  linux66-nvidia-550.144.03-4
Total Download Size:   184,11 MiB
Total Installed Size:  189,05 MiB
:: Retrieving packages...
linux66-6.6.75-2-x86_64 downloading...
 linux66-nvidia-550.144.03-4-x86_64 downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing linux66...
Optional dependencies for linux66
    wireless-regdb: to set the correct wireless channels of your country [installed]
installing linux66-nvidia...
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.75-2-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [microcode]
-> Running build hook: [kms]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
(4/5) Updating Kernel initcpios for Nvidia-DRM...
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Done ...
full 6.13:
Summary
linux613
linux613-nvidia
Starting
Packages (2) linux613-6.13.1-2  linux613-nvidia-550.144.03-2
Total Download Size:   193,38 MiB
Total Installed Size:  198,56 MiB
linux613-6.13.1-2-x86_64 downloading...
 linux613-nvidia-550.144.03-2-x86_64 downloading...
checking keyring...
installing linux613...
Optional dependencies for linux613
    linux-firmware: firmware images needed for some devices [installed]
installing linux613-nvidia...
==> Building image from preset: /etc/mkinitcpio.d/linux613.preset: 'default'
-> -k /boot/vmlinuz-6.13-x86_64 -g /boot/initramfs-6.13-x86_64.img
==> Starting build: '6.13.1-2-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.13-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux613.preset: 'fallback'
-> -k /boot/vmlinuz-6.13-x86_64 -g /boot/initramfs-6.13-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.13-x86_64-fallback.img'
Found linux image: /boot/vmlinuz-6.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.13-x86_64.img
Found initrd fallback image: /boot/initramfs-6.13-x86_64-fallback.img
done
Done ...
Using 6.13 the game even crashed on start up and on a second attempt it crashed when trying to load the save file.
Just to make sure it is not an issue of the game but rather the os install or my hardware i wanted to install a different game, which also uses proton.
Whilst doing that:
  • when opening signal to text someone it crashed with some weird electron error / stacktrace. I forgot to copy it.
  • when opening signal again, it worked
  • steam crashed during the install of the second game, but apparently just the ui, since is still see some steam processes running.
  • actually, it crashed twice
  • this time a killall command worked, but i also had instances where even a killall -9 firefox would not kill it.
This all reminds me a lot of the time when one of my ram sticks was faulty.
I think that might be it. Via grub i started a memtest86+ run and after 9 minutes the first error occured.
Does that mean the ram stick is faulty or could that also be a bios issue?
Okay, there is definitively something wrong with my ram. test 6 found one error and test 8 found 19 more directly one after another, which even lead to a crash of memtest86+ itself.
I will test the sticks individually again and check with a replacement / way lower frequencies on the sticks.
Since this is an issue with my hardware and not manjaro the thread can be closed, i think. although it would be helpful to others maybe if i post tomorrow or the day after if that was actually the fix or if there have been other issues. thanks for the help.
These warnings can be ignored, but if you want to be rid of them for good, then install the package mkinitcpio-firmware from the AUR. :point_down:
pamac build mkinitcpio-firmware && sudo mkinitcpio && sudo update-grub
memtest86+ never reports a false positive — on the contrary, it may actually miss a memory error — so if it does report an error, then one of the memory sticks is indeed faulty.
Agreed. :wink:
