Graphic performance issues after system update
Hello,
after exclusively working and gaming on Manjaro stable for a couple of months without problems I seem to have graphic issues since the last update. Some games like Valheim became unplayable due to extremely low fps, never had issues before. I already tried lowest settings, updating the game, running the Windows version via Proton with no success.
A suspicion is that my dedicated video card is not used but instead the internal Intel card, although I had my dual setup working fine before with using prime-run for starting games.
inxi --admin --verbosity=7 --filter --width gives me:
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=c9895b2f-35bf-4898-ac1d-a990b0d20117 rw quiet splash apparmor=1
  Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Laptop System: Dell product: XPS 15 9570 v: N/A
  Mobo: Dell model: 02MJVY v: A00 serial: <superuser required> UEFI: Dell
    v: 1.20.0 date: 06/07/2021
  ID-1: BAT0 charge: 87.7 Wh (100.0%) condition: 87.7/97.0 Wh (90.4%)
    volts: 13.1 min: 11.4 model: LGC-LGC3.67 DELL T453X type: Li-ion
    serial: <filter> status: Full
  RAM: total: 15.28 GiB used: 4.3 GiB (28.1%)
  RAM Report:
  Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52815
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
    hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
    driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
    driver: N/A alternate: nouveau bus-ID: 01:00.0 chip-ID: 10de:1c8c
    class-ID: 0302
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-12:7 chip-ID: 0c45:671d class-ID: 0e02
  Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
    display-ID: 0 resolution: <missing: xdpyinfo>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.4
    direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
    v: kernel bus-ID: 3b:00.0 chip-ID: 168c:003e class-ID: 0280
  IF: wlp59s0 state: up mac: <filter>
  IF-ID-1: br-dbb1cdd07d5c state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: ztyxarqcai state: unknown speed: 10 Mbps duplex: full
    mac: <filter>
  IP v6: <filter> scope: link
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
    v: 0.8 bus-ID: 1-4:3 chip-ID: 0cf3:e300 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Device-1: luks-608baaca-e893-4f26-84dd-7f0901c02428 maj-min: 254:0
    type: LUKS dm: dm-0 size: 352.22 GiB
  Components:
  p-1: nvme0n1p4 maj-min: 259:4 size: 352.22 GiB
  Local Storage: total: 476.94 GiB used: 357.45 GiB (74.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB
    lanes: 4 type: SSD serial: <filter> rev: 80003E00 temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 107.42 GiB size: 105.18 GiB (97.91%)
    used: 68.8 GiB (65.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: c9895b2f-35bf-4898-ac1d-a990b0d20117
  ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
    label: NO_LABEL uuid: 4788-DE83
  ID-3: /home raw-size: 352.22 GiB size: 345.62 GiB (98.13%)
    used: 288.65 GiB (83.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-608baaca-e893-4f26-84dd-7f0901c02428 label: N/A
    uuid: 073e6b08-4ce4-4cb7-93f9-4f6e46aaea16
  ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16.8 GiB fs: ext4 label: swap
    uuid: 7556d7f2-8763-4d21-b66f-14e93215d2fd
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Hub-2: 1-2:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2811 class-ID: 0900
  Device-1: 1-2.2:4 info: Mad Catz Mad Catz R.A.T.7 Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 0738:1708 class-ID: 0301
  Hub-3: 1-2.3:6 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 1-2.3.4:9 info: Brother Industries HL-5250DN Printer
    type: Printer driver: usblp interfaces: 1 rev: 2.0 speed: 480 Mb/s
    power: 2mA chip-ID: 04f9:002b class-ID: 0701 serial: <filter>
  Device-2: 1-2.4:8 info: Corsair Vengeance K70R keyboard type: Keyboard,HID
    driver: corsair,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 1b1c:1b09 class-ID: 0300
  Device-3: 1-4:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 0cf3:e300 class-ID: e001
  Device-4: 1-7:5 info: Shenzhen Goodix Fingerprint Reader
    type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
    serial: <filter>
  Device-5: 1-12:7 info: Microdia Integrated_Webcam_HD type: Video
  Hub-4: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
  Hub-5: 2-2:2 info: VIA Labs Hub ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 2109:8110 class-ID: 0900
  Hub-6: 2-2.3:3 info: VIA Labs Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 53.0 C pch: 66.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2531 fan-2: 2496
  Processes: 323 Uptime: 2h 33m wakeups: 5 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1586
  pacman: 1570 lib: 426 flatpak: 16 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.12
mhwd -li gives me:
Installed PCI configs:
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
           video-linux            2018.05.04                true            PCI
I appreciate any help, thanks in advance.
Hello,
Two things i notice here:
That is an EOL kernel. Switch to a supported one.
You have to remove the video-linux. I do not think is helping …
Thank you for your fast reply.
I updated and booted into kernel 5.16.2-1-MANJARO x86_64. Also I removed video-linux from mwhd. Now games seem to not even start anymore. Any other ideas?
  Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
  RAM: total: 15.27 GiB used: 4.58 GiB (30.0%)
  RAM Report:
  Speed (MHz): avg: 3713 high: 3972 min/max: 800/4100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3972 2: 3763 3: 3687
    4: 3897 5: 3755 6: 3639 7: 3687 8: 3667 9: 3609 10: 3617 11: 3640 12: 3624
    bogomips: 52815
  Type: l1tf
    class-ID: 0302
    direct render: Yes
  Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: no
  Components:
  Local Storage: total: 476.94 GiB used: 357.67 GiB (75.0%)
    lanes: 4 type: SSD serial: <filter> rev: 80003E00 temp: 38.9 C scheme: GPT
    used: 69.03 GiB (65.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 288.64 GiB (83.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    serial: <filter>
What do you get when you run
prime-run glxgears
and
prime-run glxinfo | grep OpenGL
Some errors if you run your game from terminal ?
Thanks again, here are my outputs in that order:
prime-run glxgears
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  150 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Value in failed request:  0x0
  Serial number of failed request:  26
  Current serial number in output stream:  27
  Minor opcode of failed request:  24 (X_GLXCreateNewContext)
  Serial number of failed request:  50
  Current serial number in output stream:  51
(steam:6657): Gtk-WARNING **: 00:31:34.936: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Adwaita-maia-compact-dark/gtk-2.0/main.rc:733: error: unexpected identifier 'direction', expected character '}'
(steam:6657): Gtk-WARNING **: 00:31:34.937: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Adwaita-maia-compact-dark/gtk-2.0/hacks.rc:28: error: invalid string constant "normal_entry", expected valid string constant
Installing breakpad exception handler for appid(steam)/version(1642451672)
steamwebhelper.sh[6696]: Runtime for steamwebhelper: defaulting to /home/emberwit/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
CAppInfoCacheReadFromDiskThread took 170 milliseconds to initialize
Proceed to auto login
Opted-in Controller Mask for AppId 0: 0
(steam:6657): Gtk-WARNING **: 00:31:35.995: gtk_disable_setlocale() must be called before gtk_init()
Local Device Found
  type: 1b1c 1b09
  path: sdl://0
  serial_number:  - 0
  Manufacturer:
  Product:      Corsair K70R Gaming Keyboard
  Release:      111
  Interface:    -1
Vulkan missing requested extension 'VK_KHR_surface'.
Vulkan missing requested extension 'VK_KHR_xlib_surface'.
BInit - Unable to initialize Vulkan!
Local Device Found
  type: 1b1c 1b09
  path: sdl://0
  serial_number:  - 0
  Manufacturer:
  Release:      111
  Interface:    -1
roaming config store loaded successfully - 57701 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 31ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/emberwit/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 4.48 seconds
(steam:6657): LIBDBUSMENU-GLIB-WARNING **: 00:31:38.055: Trying to remove a child that doesn't believe we're it's parent.
(steam:6657): LIBDBUSMENU-GLIB-WARNING **: 00:31:38.056: Trying to remove a child that doesn't believe we're it's parent.
BRefreshApplicationsInLibrary 1: 3ms
BRefreshApplicationsInLibrary 1: 1ms
BuildCompleteAppOverviewChange: 986
RegisterForAppOverview 1: 49ms
RegisterForAppOverview 2: 50ms
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 892970, ActionID 1] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 892970, ActionID 1] : LaunchApp continues with user response "0"
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to SynchronizingControllerConfig with ""
Opted-in Controller Mask for AppId 892970: 0
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 892970, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 892970, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0prime-run gamemoderun /home/emberwit/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=892970 -- '/home/emberwit/.local/share/Steam/steamapps/common/Valheim/valheim.x86_64'\0
Game process added : AppID 892970 "prime-run gamemoderun /home/emberwit/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=892970 -- '/home/emberwit/.local/share/Steam/steamapps/common/Valheim/valheim.x86_64'", ProcID 7044, IP 0.0.0.0:0
chdir /home/emberwit/.local/share/Steam/steamapps/common/Valheim
ERROR: ld.so: object '/home/emberwit/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 892970, ActionID 1] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object 'libgamemodeauto.so.0' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
ERROR: ld.so: object '/home/emberwit/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Found path: /home/emberwit/.local/share/Steam/steamapps/common/Valheim/valheim.x86_64
Game process removed: AppID 892970 "prime-run gamemoderun /home/emberwit/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=892970 -- '/home/emberwit/.local/share/Steam/steamapps/common/Valheim/valheim.x86_64'", ProcID 7044
Uploaded AppInterfaceStats to Steam
No cached sticky mapping in ActivateActionSet.Installing breakpad exception handler for appid(steam)/version(1642451672)
This seems to have been an issue for ages due to nvidia and apparently v-sync enabled, but … maybe best to go over this wiki and double check if you have it as suggested there https://wiki.archlinux.org/title/Dell_XPS_15_9570
Sounds weirdly similar to my experience with Garuda KDE, right now. But, I’m on a desktop with only Nvidia graphics. I haven’t done much troubleshooting with it other than trying switching between 495.46 and 510.XX drivers and updating packages. I thought it was a BIOS update, but I get perfect performance in Valheim and general UI responsiveness with Manjaro XFCE so I’ve just been staying in that for now, until I want to troubleshoot my Garuda installation.
Edit: Well, I guess after reinstalling all packages for my Garuda installation and some package updates and the noautodefrag fstab fix the issue seems to have resolved itself… not sure what specifically was the issue. Sorry.
After a BIOS update (not sure if that did anything) and reinstallation of the graphic drivers using mhwd things seem to be working again. For mhwd to install the proper drivers I also needed to remove the unsupported kernel version 5.13, otherwise it failed to find the correct driver despite I was running a different kernel.
Thanks for your help and in case I can provide any useful outputs just let me know.
