#################### inxi -Fxzc0 ########################
System: Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: GNOME 3.36.6
Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery: ID-1: BAT0 charge: 57.9 Wh condition: 57.9/60.0 Wh (96%) model: Celxpert L19C4PC0
status: Full
CPU: Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen rev: 1 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92666
Speed: 1397 MHz min/max: 1400/2900 MHz Core speeds (MHz): 1: 1397 2: 1398 3: 1397
4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1374 11: 1401 12: 1488 13: 1573
14: 1644 15: 1399 16: 1397
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
v: 455.28 bus ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 05:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:2
Display: x11 server: X.org 1.20.9 driver: amdgpu,nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.1-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus ID: 05:00.5
Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 05:00.6
Sound Server: ALSA v: k5.9.1-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 251.74 GiB (52.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
Partition: ID-1: / size: 459.79 GiB used: 249.77 GiB (54.3%) fs: ext4 dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 1.97 GiB (22.4%) dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 59.5 C mobo: N/A gpu: amdgpu temp: 46 C
Info: Processes: 386 Uptime: 3h 29m Memory: 7.22 GiB used: 2.10 GiB (29.2%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1347 Client: shell wrapper v: 5.0.18-release
inxi: 3.1.05
I installed Grand Theft Auto V on Steam and ran it with Proton 5.13-1, however I’m only getting around 30fps. After a while of playing the game’s CPU usage goes up to 300% and the game drops to 1fps.
I tried using Proton 5.0-9. On my first attempt it wouldn’t run saying that it couldn’t find the launcher. I reinstalled the game and tried running it on Proton 5.0-9 again but it just wouldn’t open. So far it seems to just work with Proton 5.13-1.
Every graphic settings is in it’s lowest setting or turned off and I’m still getting abysmal performance. Any ideas on how to fix this?
