Picture 1:
Picture 2:
Picture 3:
I have used Gradience to change theme for Gnome apps. It changed the accent color in the gtk3 and gtk4 apps.
But it failed to change the gnome-shell accent color. I have tried with the User-theme extension both enabled or disabled.
I am using the latest Manjaro-Gnome stable.
I wish to know if there is any way to change the gnome-shell-accent color.
Is there any solution at the moment?
There is a feature request issue opened for the shell theme and probably the implementation is in the works
It seems there is no workaround for this currently.
system
Closed
4
