Apparently trying to use mangohud to show some details about how much I’m using the resources in my computer ( CPU usage, HDD usage, etc) but I get everything right except the GPU usage which is always 0. I tried running radeontop and everything is right. It seems that if I run
cat /sys/class/drm/card0/device/gpu_busy_percent
i get
cat: /sys/class/drm/card0/device/gpu_busy_percent: Invalid argument
that would mean there is a bug with the driver which s the most probabile.
I don’t know why this happens or if it is a GPU driver problem or the GPU itself which is a Vega 8 from a r3 2200g. running the default driver amdgpu
How about cat /sys/kernel/debug/dri/0/amdgpu_pm_info
that command required to be executed as root so this is the result:
Clock Gating Flags Mask: 0x30fe954f
Graphics Medium Grain Clock Gating: On
Graphics Medium Grain memory Light Sleep: On
Graphics Coarse Grain Clock Gating: On
Graphics Coarse Grain memory Light Sleep: On
Graphics Coarse Grain Tree Shader Clock Gating: Off
Graphics Coarse Grain Tree Shader Light Sleep: Off
Graphics Command Processor Light Sleep: On
Graphics Run List Controller Light Sleep: Off
Graphics 3D Coarse Grain Clock Gating: On
Graphics 3D Coarse Grain memory Light Sleep: On
Memory Controller Light Sleep: On
Memory Controller Medium Grain Clock Gating: Off
System Direct Memory Access Light Sleep: On
System Direct Memory Access Medium Grain Clock Gating: Off
Bus Interface Medium Grain Clock Gating: On
Bus Interface Light Sleep: On
Unified Video Decoder Medium Grain Clock Gating: Off
Video Compression Engine Medium Grain Clock Gating: Off
Host Data Path Light Sleep: On
Host Data Path Medium Grain Clock Gating: Off
Digital Right Management Medium Grain Clock Gating: On
Digital Right Management Light Sleep: On
Rom Medium Grain Clock Gating: On
Data Fabric Medium Grain Clock Gating: On
Address Translation Hub Medium Grain Clock Gating: On
Address Translation Hub Light Sleep: On
GFX Clocks and Power:
1333 MHz (MCLK)
400 MHz (SCLK)
700 MHz (PSTATE_SCLK)
933 MHz (PSTATE_MCLK)
GPU Temperature: 28 C
VCN: Disabled
(EDIT: backticks doesnt work for somereasons)
There you go then. Problem solved.
i get
It’s not problem with the driver, this is outdated command you found on Internet and tried to use which doesn’t work. The one I give you above works perfectly.
Ask “mangohud” developers to fix it then, problem with their software.
Your GPU is perfectly fine, you just didn’t knew how to ask it for stats and details until now.
@cryptocurious Thanks! That command is what i found that mangohud uses to get the GPU busyness. I will open an issue on Mangohud’s repo about this.
