I have the nitro 5e an151-42r5ed it is only using the integrated graphics and not the radeon gpu. can any one help me
inxi -Fxz
hwinfo --gfxcard
mhwd -li
inxi -Fxz
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: GNOME 3.36.6 Distro: Manjaro Linux
Type: Laptop System: Acer product: Nitro AN515-42 v: V1.13
serial: <filter>
Mobo: RR model: Freed_RRS v: V1.13 serial: <filter> UEFI: Insyde v: 1.13
date: 02/11/2019
ID-1: BAT1 charge: 33.3 Wh condition: 46.1/48.9 Wh (94%)
model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x0095 status: Discharging
Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen L2 cache: 2048 KiB
bogomips: 31949
Speed: 1401 MHz max: 1600 MHz Core speeds (MHz): 1: 1440 2: 1380 3: 1368
4: 1367 5: 1369 6: 1368 7: 1462 8: 1368
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus ID: 01:00.0
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus ID: 04:00.0
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus ID: 3-1:2
Display: x11 server: X.org 1.20.9 driver: modesetting
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 04:00.1
Device-2: AMD Family 17h HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 04:00.6
Sound Server: ALSA v: k5.8.11-1-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
bus ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 2000 bus ID: 03:00.0
Local Storage: total: 465.76 GiB used: 101.20 GiB (21.7%)
ID-1: /dev/sda vendor: Western Digital model: WDBNCE5000PNC
ID-1: / size: 457.16 GiB used: 101.20 GiB (22.1%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 40.8 C mobo: N/A
GPU: device: amdgpu temp: 34 C device: amdgpu temp: 51 C
Processes: 387 Uptime: 2h 15m Memory: 14.62 GiB used: 3.97 GiB (27.1%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1156 Shell: Bash v: 5.0.18
inxi: 3.1.05
hwinfo --gfxcard
15: PCI 100.0: 0380 Display controller
[Created at pci.386]
Unique ID: VCu0.xer7styqgzA
Parent ID: mnDB.fA+tdbAkMSD
SysFS ID: /devices/pci0000:00/0000:00:01.1/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "ATI Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X]"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x67ef "Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X]"
SubVendor: pci 0x1025 "Acer Incorporated [ALI]"
SubDevice: pci 0x125d
Revision: 0xc0
Driver: "amdgpu"
Driver Modules: "amdgpu"
Memory Range: 0xd0000000-0xdfffffff (ro,non-prefetchable)
Memory Range: 0xe0000000-0xe01fffff (ro,non-prefetchable)
I/O Ports: 0x3000-0x30ff (rw)
Memory Range: 0xe0a00000-0xe0a3ffff (rw,non-prefetchable)
Memory Range: 0xe0a40000-0xe0a5ffff (ro,non-prefetchable,disabled)
IRQ: 64 (294 events)
Module Alias: "pci:v00001002d000067EFsv00001025sd0000125Dbc03sc80i00"
Driver Info #0:
Driver Status: amdgpu is active
Driver Activation Cmd: "modprobe amdgpu"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #25 (PCI bridge)
30: PCI 400.0: 0300 VGA compatible controller (VGA)
Unique ID: YmUS.gFHUot854JB
Parent ID: JZZT.A_VqgZKlSp2
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:04:00.0
SysFS BusID: 0000:04:00.0
Model: "ATI Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]"
Device: pci 0x15dd "Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]"
SubDevice: pci 0x125c
Revision: 0xc4
Driver: "amdgpu"
Memory Range: 0xb0000000-0xbfffffff (ro,non-prefetchable)
Memory Range: 0xc0000000-0xc01fffff (ro,non-prefetchable)
I/O Ports: 0x1000-0x10ff (rw)
Memory Range: 0xe0800000-0xe087ffff (rw,non-prefetchable)
IRQ: 44 (no events)
Module Alias: "pci:v00001002d000015DDsv00001025sd0000125Cbc03sc00i00"
Driver Info #0:
Attached to: #20 (PCI bridge)
Primary display adapter: #30
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Try to create a custom conf file in /etc/X11/xorg.conf.d/
You would need 3 entries similar those 2 in Arch Wiki:
https://wiki.archlinux.org/index.php/Xorg#More_than_one_graphics_card
what do I put cuz their is only 1 instead of two
lspci | grep -e VGA -e 3D
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4)
I looked at the wrong place, the 3rd device in Graphics is not a graphics card. Your both graphics cards devices are run by he best driver “amdgpu”. There is no need to change anything.
If you wanted to enter an ID for the GPU it would be the bus ID from inxi bus ID: 01:00.0 and 04:00.0 or SysFS BusID: 0000:01:00.0 and 0000:04:00.0 tranlated into Xorg format.
Section "Device"
Identifier "Device1"
Driver "amdgpu"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "Device2"
Driver "amdgpu"
BusID "PCI:4:0:0"
EndSection
I think the desrete GPU will be used automaticall if the load is high enough.
You can however experiment with the xorg.conf and comment out the integrated GPU, leave discrete GPU uncommented, reboot and see if see any difference.
i added it but gdm will not load till I removed the conf file
i am playing skyrim on the lowest setting and steming 480 at 15 frames game freezes and in the center starting to get hot. my gpu should be able to do more then that with out freazing. and the fans dont fulling tun on.
