yep knew that! was trying to see if I could get it to change to the intel card
And I am simply repeating what bedna wrote…its not an original comment
Yes, they go between the ", same in grub.
The question is, does your computer use the nonfree nvidia drivers?
inxi -Ga
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: none
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Intel
driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-5 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: AOC Q27G2G4
serial: 25776 built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Looks good.
But as reference, this is my display output of the same command, and I use my amd igpu unless my nvidia egpu is invoked, ie, only prime-run shows nvidia on my system (I explained how you can experiment with the ports earlier in the thread). Wayland has nothing to do with this so you don’t get confused about that. I’m not using it, it’s just installed.
Your Display:
My Display:
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
glxinfo | grep "OpenGL renderer"
OpenGL renderer string: AMD Radeon Graphics (raphael_mendocino, LLVM 15.0.7, DRM 3.52, 6.4.10-1-MANJARO)
prime-run glxinfo | grep "OpenGL renderer"
OpenGL renderer string: NVIDIA GeForce RTX 3090/PCIe/SSE2
Your computer should work just fine, the only thing now is you run everything on your nvidia.
If playing around with the ports doesn’t work you have 2 options:
Edit
I WILL (sometime in the future) try to figure reverse-prime out. One thing I haven’t tried yet and will is change the “primary video output” (not sure all BIOS:es have that setting though) in my BIOS to my internal gpu (it is set to the nvidia as of this moment) and move my cable back to my nvidia.
That might “trick” the system to reverse it “back” to the nvidia allowing me full functionality. Just as a tip of what you can try if you dive into this.
I will play around with swapping out the monitor to the mini display port and see what that does…And I will have another look at reverse-prime , now I have at least NVIDIA graphics
Thanks again for your help, AND patience!!
Cool…although I think I may have found a reason why this is not working. I just assumed all the nVidia modern cards had optimus/prime - but from what I have found at the nVidia site the RTX series is not compatible.
Going back to the Intel listing for the ports…I think I need a USB-C to hdmi cable…I THINK the USB-C output is Intel GPU exclusively…so I could simply use the monitor input changer to swap to either.
Prime, yes, you installed that driver (I assume this is the driver (hybrid prime) you are looking for since you want to use both gpu:s). Optimus, no.
Don’t try to install those gpu switch programs.
Not sure what you mean by “input changer”.
But what you state above is one of the reasons I suggested you look for settings in your BIOS that lets you change such things, but it might not be available.
Sorry, on the monitor is a button that allows you to select what input…its an AOC monitor with 2 HDMI and 1 DP port
Nope, not available.
ahhh, ok gotcha - optimus and prime are different - and I won’t be installing the switching apps, from what I’ve read they could be more trouble that advantage!
