Hi, my gpu is crashing each time I try to play guild wars 2, the game boots up normal and then it just crashes after 5 minutes, with other games my gpu is an biostar rx560, works normally but after some hours it crashes
I moved from windows to manjaro beliving that it was an issue with the drivers tehre, sadly no luck. I do have 3 error logs
here my system info and below it the crash logs
Kernel: 6.9.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=31e79a47-7939-4b02-aa22-ba5d901298ba rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: MSI model: H81M-E33 (MS-7817) v: 1.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: 6.8 date: 07/17/2018
System RAM: total: 10 GiB available: 9.66 GiB used: 5.16 GiB (53.5%)
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed:
spec: 1600 MT/s actual: 1333 MT/s volts: curr: 2 min: 1.35 max: 2
width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT102464BD160B.C16 serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: curr: 2 min: 2 max: 2 width (bits): data: 64
total: 64 manufacturer: Samsung part-no: M378B5773CH0-CH9 serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i3-4160 bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3600 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28813
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 35.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 506x570mm (19.92x22.44")
s-diag: 762mm (30.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom model: AOC 2270W
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
chroma: red: x: 0.635 y: 0.349 green: x: 0.322 y: 0.631 blue: x: 0.153
y: 0.047 white: x: 0.314 y: 0.329 size: 477x268mm (18.78x10.55")
diag: 547mm (21.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 832x624, 800x600,
640x480, 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: top model: AAA built: 2016
res: 1920x1080 dpi: 85 gamma: 1.2 chroma: red: x: 0.635 y: 0.349 green:
x: 0.290 y: 0.588 blue: x: 0.141 y: 0.078 white: x: 0.314 y: 0.329
size: 575x323mm (22.64x12.72") modes: 1366x768, 1920x1080, 1280x768,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 560 Series (radeonsi
polaris11 LLVM 18.1.8 DRM 3.57 6.9.12-1-MANJARO) device-ID: 1002:67ef
memory: 3.91 GiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 560 Series (RADV POLARIS11) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:67ef surfaces: xcb,xlib
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aae0
class-ID: 0403
API: ALSA v: k6.9.12-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.7 TiB used: 747.92 GiB (43.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Leven model: JAJS600M128C
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS727550A9E364
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A0E0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A750 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU630 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD
serial: <filter> fw-rev: 024B scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 28.49 GiB (24.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 31e79a47-7939-4b02-aa22-ba5d901298ba
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2248-0B9C
ID-3: /home/<filter>/Rhystelle raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 489.82 GiB (52.6%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: Rhystelle uuid: F63EF3CB3EF38343
ID-4: /mnt/SDDgames raw-size: 223.57 GiB size: 219 GiB (97.96%)
used: 122.35 GiB (55.9%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: N/A
uuid: 104bd674-f936-4806-a824-7817081f57f3
ID-5: /mnt/Windows10 raw-size: 465.11 GiB size: 465.11 GiB (100.00%)
used: 107.25 GiB (23.1%) fs: ntfs dev: /dev/sdb3 maj-min: 8:19
label: Windows10 uuid: 0EDE18B1DE1892D7
ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 9E16-1B26
ID-2: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb4 maj-min: 8:20 size: 546 MiB fs: ntfs label: N/A
uuid: 58B06580B065658A
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-1:2 info: Corsair K60 RGB PRO SE Mechanical Gaming Keyboard
type: keyboard,HID,mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
chip-ID: 1b1c:1b8d class-ID: 0301 serial: <filter>
Device-2: 3-9:4 info: USB OPTICAL MOUSE type: mouse,keyboard
chip-ID: 4e53:5407 class-ID: 0301
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1355 libs: 445 tools: pamac pm: flatpak pkgs: 0
1: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
2: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
3: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
CPU top: 5 of 223
1: cpu: 25.0% command: firefox pid: 114415 mem: 76.0 MiB (0.7%)
2: cpu: 20.6% command: firefox pid: 116655 mem: 236.7 MiB (2.3%)
3: cpu: 20.6% command: firefox pid: 118074 mem: 225.7 MiB (2.2%)
4: cpu: 19.8% command: firefox pid: 114085 mem: 747.0 MiB (7.5%)
5: cpu: 16.6% command: firefox pid: 118001 mem: 318.1 MiB (3.2%)
Memory top: 5 of 223
1: mem: 774.2 MiB (7.8%) command: baloo_file_extractor pid: 113583
cpu: 4.3%
2: mem: 747.0 MiB (7.5%) command: firefox pid: 114085 cpu: 19.8%
3: mem: 515.8 MiB (5.2%) command: telegram-desktop pid: 113514 cpu: 0.6%
4: mem: 506.1 MiB (5.1%) command: firefox pid: 114371 cpu: 7.7%
5: mem: 457.2 MiB (4.6%) command: plasmashell pid: 113000 cpu: 0.9%
Processes: 223 Power: uptime: 1d 10h 30m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 3.84 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.32
running-in: konsole inxi: 3.3.35
- First crash, while I was on the main mentu of guild wars 2 my pc slowed down to 0.30fps, I was able to press ctrl + alt + f3
1st log
Aug 15 15:30:25 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 15:30:25 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 15:30:25 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 15:30:25 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 15:30:25 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 15:30:25 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 15:30:25 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 15:30:25 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 15:30:25 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 15:30:25 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 15:30:25 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 15:30:25 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 15:30:25 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 15:30:25 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 15:30:25 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 15:30:26 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 15:32:12 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 15:32:12 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 15:32:12 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 15:32:12 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 15:32:12 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 15:32:12 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 15:32:12 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 15:32:12 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 15:32:12 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 15:32:12 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 15:32:12 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 15:32:12 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 15:32:12 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 15:32:12 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 15:32:12 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 15:33:40 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 15:33:40 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 15:33:40 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 15:33:40 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 15:33:40 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 15:33:40 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 15:33:40 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 15:33:40 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 15:33:40 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 15:33:40 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 15:33:40 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 15:33:40 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 15:33:40 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 15:33:40 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 15:33:40 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 15:33:41 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 15:37:07 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 15:37:07 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 15:37:07 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 15:37:07 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 15:37:07 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 15:37:07 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 15:37:07 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 15:37:07 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 15:37:07 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 15:37:07 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 15:37:07 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 15:37:07 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 15:37:07 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 15:37:07 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 15:37:07 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 15:37:08 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 15:42:20 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 15:42:20 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 15:42:20 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 15:42:20 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 15:42:20 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 15:42:20 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 15:42:20 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 15:42:20 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 15:42:20 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 15:42:20 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 15:42:20 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 15:42:20 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 15:42:20 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 15:42:20 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 15:42:20 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 15:42:21 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 15:44:29 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 15:44:29 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 15:44:29 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 15:44:29 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 15:44:29 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 15:44:29 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 15:44:29 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 15:44:29 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 15:44:29 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 15:44:29 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 15:44:29 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 15:44:29 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 15:44:29 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 15:44:29 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 15:44:29 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 15:44:30 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 16:06:34 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 16:06:34 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 16:06:34 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 16:06:34 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 16:06:34 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 16:06:34 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 16:06:34 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 16:06:34 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 16:06:34 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 16:06:34 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 16:06:34 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 16:06:34 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 16:06:34 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 16:06:34 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 16:06:34 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 16:06:35 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU fault detected: 147 0x01820802
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: for process steamwebhelper pid 12610 thread steamwebhe:cs0 pid 12612
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_ADDR 0x0011E830
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_STATUS 0x05008002
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM fault (0x02, vmid 2, pasid 32790) at page 1173552, write from 'TC2' (0x54433200) (8)
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU fault detected: 147 0x03824402
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_ADDR 0x0011E870
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_STATUS 0x05044002
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM fault (0x02, vmid 2, pasid 32790) at page 1173616, write from 'TC1' (0x54433100) (68)
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU fault detected: 147 0x05824402
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_ADDR 0x0011E8B0
Aug 15 16:11:23 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM fault (0x02, vmid 2, pasid 32790) at page 1173680, write from 'TC1' (0x54433100) (68)
Aug 15 16:14:08 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Disabling VM faults because of PRT request!
Aug 15 17:52:09 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 17:52:09 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 17:52:09 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 17:52:09 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 17:52:09 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 17:52:09 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 17:52:09 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 17:52:09 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 17:52:09 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 17:52:09 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 17:52:09 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 17:52:09 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 17:52:09 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 17:52:09 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 17:52:09 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 17:52:10 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 19:13:59 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 19:13:59 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 19:13:59 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 19:13:59 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 19:13:59 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 19:13:59 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 19:13:59 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 19:13:59 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 19:13:59 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 19:13:59 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 19:13:59 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 19:13:59 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 19:13:59 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 19:13:59 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 19:13:59 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 19:14:00 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 13:22:04 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 13:22:04 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 13:22:04 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 13:22:04 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 13:22:04 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 13:22:04 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 13:22:04 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 13:22:04 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 13:22:04 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 13:22:04 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 13:22:04 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 13:22:04 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 13:22:04 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 13:22:04 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 13:22:04 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 13:22:05 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 15 18:13:52 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 15 18:13:52 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 15 18:13:52 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 15 18:13:52 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 15 18:13:52 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 15 18:13:52 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 15 18:13:52 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 15 18:13:52 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 15 18:13:52 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 15 18:13:52 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 15 18:13:52 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 15 18:13:52 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 15 18:13:52 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 15 18:13:52 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 15 18:13:52 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 15 18:13:53 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 16 01:27:48 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Disabling VM faults because of PRT request!
Aug 16 01:57:56 rotip309 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=1662612, emitted seq=1662614
Aug 16 01:57:56 rotip309 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Gw2-64.exe pid 18625 thread dxvk-submit pid 18824
Aug 16 01:57:56 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset begin!
Aug 16 01:57:56 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_0.2.1.0 test failed (-110)
Aug 16 01:57:56 rotip309 kernel: [drm:gfx_v8_0_hw_fini [amdgpu]] *ERROR* KCQ disable failed
Aug 16 01:57:56 rotip309 kernel: amdgpu: cp is busy, skip halt cp
Aug 16 01:57:57 rotip309 kernel: amdgpu: rlc is busy, skip halt rlc
Aug 16 01:57:57 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: BACO reset
Aug 16 01:57:57 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset succeeded, trying to resume
Aug 16 01:57:57 rotip309 kernel: [drm:amdgpu_dm_atomic_check [amdgpu]] *ERROR* [CRTC:56:crtc-0] hw_done or flip_done timed out
Aug 16 01:57:58 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.1 test failed (-110)
Aug 16 01:57:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: recover vram bo from shadow start
Aug 16 01:57:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: recover vram bo from shadow done
Aug 16 01:57:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset(2) succeeded!
Aug 16 01:57:58 rotip309 kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Aug 16 01:57:58 rotip309 steam[13045]: radv/amdgpu: The CS has been cancelled because the context is lost. This context is innocent.
#16 0x0000796bee429529 n/a (amdgpu_drv.so + 0x18529)
#17 0x0000796bee424b31 n/a (amdgpu_drv.so + 0x13b31)
Aug 16 02:12:06 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 16 02:12:06 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 16 02:12:06 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 16 02:12:06 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 16 02:12:06 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 16 02:12:06 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 16 02:12:06 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 16 02:12:06 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 16 02:12:06 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 16 02:12:06 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 16 02:12:06 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 16 02:12:06 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 16 02:12:06 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 16 02:12:06 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 16 02:12:06 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 16 02:12:07 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 16 02:14:12 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Disabling VM faults because of PRT request!
Aug 16 02:14:12 rotip309 lutris[2209]: 2024-08-16 02:14:12,008: AMD Radeon RX 560 Series (1002:67ef 1002:0b04 amdgpu) Driver 24.1.5
Aug 16 12:24:33 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: PCI CONFIG reset
Aug 16 12:24:33 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.1 test failed (-110)
Aug 16 12:24:33 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.2 test failed (-110)
Aug 16 14:35:05 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 16 14:35:05 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 16 14:35:05 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 16 14:35:05 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 16 14:35:05 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 16 14:35:05 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 16 14:35:05 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 16 14:35:05 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 16 14:35:05 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 16 14:35:05 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 16 14:35:05 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 16 14:35:05 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 16 14:35:05 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 16 14:35:05 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 16 14:35:05 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 16 14:35:06 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 16 18:22:44 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Disabling VM faults because of PRT request!
- Second crash, I booted guild wars 2 and played a bit, after 10 mins my system frooze, could hear my game but I then got booted to the lockscreen
2nd log
Aug 16 18:46:52 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 16 18:46:52 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 16 18:46:52 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 16 18:46:52 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 16 18:46:52 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 16 18:46:52 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 16 18:46:52 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 16 18:46:52 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 16 18:46:52 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 16 18:46:52 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 16 18:46:52 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 16 18:46:52 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 16 18:46:52 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 16 18:46:52 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 16 18:46:52 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 16 18:46:53 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 16 18:48:29 rotip309 plasmashell[814]: Arrived mimeData QList(QUrl("file:///home/rotip309/amdgpu.txt")) QList("text/uri-list", "text/plain", "application/x-kde4-urilist", "application/vnd.portal.filetransfer", "application/x-kde-source-id") at 332 , 315
Aug 16 19:10:29 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Disabling VM faults because of PRT request!
Aug 16 19:12:51 rotip309 kernel: amdgpu_ttm_tt_populate+0x7c/0xc0 [amdgpu 2eb406331eb7ad0f48818cf4c999af092da42042]
Aug 16 19:12:51 rotip309 kernel: amdgpu_bo_create+0x1ee/0x4e0 [amdgpu 2eb406331eb7ad0f48818cf4c999af092da42042]
Aug 16 19:12:51 rotip309 kernel: ? __pfx_amdgpu_bo_user_destroy+0x10/0x10 [amdgpu 2eb406331eb7ad0f48818cf4c999af092da42042]
Aug 16 19:12:51 rotip309 kernel: amdgpu_bo_create_user+0x3e/0x70 [amdgpu 2eb406331eb7ad0f48818cf4c999af092da42042]
Aug 16 19:12:51 rotip309 kernel: amdgpu_gem_create_ioctl+0x173/0x3c0 [amdgpu 2eb406331eb7ad0f48818cf4c999af092da42042]
Aug 16 19:12:51 rotip309 kernel: ? __pfx_amdgpu_gem_create_ioctl+0x10/0x10 [amdgpu 2eb406331eb7ad0f48818cf4c999af092da42042]
Aug 16 19:12:51 rotip309 kernel: amdgpu_drm_ioctl+0x4e/0x90 [amdgpu 2eb406331eb7ad0f48818cf4c999af092da42042]
- Third crash, This one is recent I was installing telegram while I was watching some youtube videos
3rd log
Aug 19 03:48:10 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 19 03:48:10 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 19 03:48:10 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 19 03:48:10 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 19 03:48:10 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 19 03:48:10 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 19 03:48:10 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 19 03:48:10 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 19 03:48:10 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 19 03:48:10 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 19 03:48:10 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 19 03:48:10 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 19 03:48:10 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 19 03:48:10 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 19 03:48:10 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 19 03:48:10 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU fault detected: 147 0x00020802
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: for process ksmserver-logou pid 4564 thread ksmserver-:cs0 pid 4567
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_ADDR 0x00000C00
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_STATUS 0x05008002
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM fault (0x02, vmid 2, pasid 32771) at page 3072, write from 'TC2' (0x54433200) (8)
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU fault detected: 147 0x00024402
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_STATUS 0x05044002
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM fault (0x02, vmid 2, pasid 32771) at page 3072, write from 'TC1' (0x54433100) (68)
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU fault detected: 147 0x00004802
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM_CONTEXT1_PROTECTION_FAULT_STATUS 0x04048002
Aug 19 04:14:58 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VM fault (0x02, vmid 2, pasid 32771) at page 3072, read from 'TC0' (0x54433000) (72)
Aug 19 04:15:08 rotip309 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=611265, emitted seq=611268
Aug 19 04:15:08 rotip309 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process ksmserver-logou pid 4564 thread ksmserver-:cs0 pid 4567
Aug 19 04:15:08 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset begin!
Aug 19 04:15:08 rotip309 kernel: amdgpu: cp is busy, skip halt cp
Aug 19 04:15:08 rotip309 kernel: amdgpu: rlc is busy, skip halt rlc
Aug 19 04:15:08 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: BACO reset
Aug 19 04:15:09 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset succeeded, trying to resume
Aug 19 04:15:09 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.1 test failed (-110)
Aug 19 04:15:09 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.4 test failed (-110)
Aug 19 04:15:09 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.5 test failed (-110)
Aug 19 04:15:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: recover vram bo from shadow start
Aug 19 04:15:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: recover vram bo from shadow done
Aug 19 04:15:10 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset(2) succeeded!
#16 0x00007277c517d529 n/a (amdgpu_drv.so + 0x18529)
#17 0x00007277c5178b31 n/a (amdgpu_drv.so + 0x13b31)
#6 0x00007277c516e931 n/a (amdgpu_drv.so + 0x9931)
Aug 19 04:15:35 rotip309 kernel: [drm] amdgpu kernel modesetting enabled.
Aug 19 04:15:35 rotip309 kernel: amdgpu: Virtual CRAT table created for CPU
Aug 19 04:15:35 rotip309 kernel: amdgpu: Topology: Add CPU node
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: No more image in the PCI ROM
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
Aug 19 04:15:35 rotip309 kernel: amdgpu: ATOM BIOS: xxx-xxx-xxx
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: vgaarb: deactivate vga console
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
Aug 19 04:15:35 rotip309 kernel: [drm] amdgpu: 4096M of VRAM memory ready
Aug 19 04:15:35 rotip309 kernel: [drm] amdgpu: 4944M of GTT memory ready.
Aug 19 04:15:35 rotip309 kernel: amdgpu: hwmgr_sw_init smu backed is polaris10_smu
Aug 19 04:15:35 rotip309 kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Aug 19 04:15:35 rotip309 kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Aug 19 04:15:35 rotip309 kernel: amdgpu: Virtual CRAT table created for GPU
Aug 19 04:15:35 rotip309 kernel: amdgpu: Topology: Add dGPU node [0x67ef:0x1002]
Aug 19 04:15:35 rotip309 kernel: kfd kfd: amdgpu: added device 1002:67ef
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: SE 2, SH per SE 1, CU per SH 8, active_cu_number 14
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
Aug 19 04:15:35 rotip309 kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
Aug 19 04:15:35 rotip309 kernel: fbcon: amdgpudrmfb (fb0) is primary device
Aug 19 04:15:35 rotip309 kernel: amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Aug 19 04:15:36 rotip309 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Aug 19 13:26:05 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: PCI CONFIG reset
Aug 19 13:26:05 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.1 test failed (-110)
Aug 19 17:41:07 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: PCI CONFIG reset
Aug 19 17:41:07 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.1 test failed (-110)
Aug 19 17:41:07 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.4 test failed (-110)
Aug 19 17:41:07 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.6 test failed (-110)
Aug 20 13:48:21 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: PCI CONFIG reset
Aug 20 13:48:21 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.1 test failed (-110)
Aug 20 13:48:21 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.4 test failed (-110)
Aug 20 13:48:21 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.6 test failed (-110)
Aug 20 14:18:16 rotip309 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=10077939, emitted seq=10077941
Aug 20 14:18:16 rotip309 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process firefox pid 73430 thread firefox:cs0 pid 73487
Aug 20 14:18:16 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset begin!
Aug 20 14:18:16 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_0.2.1.0 test failed (-110)
Aug 20 14:18:16 rotip309 kernel: [drm:gfx_v8_0_hw_fini [amdgpu]] *ERROR* KCQ disable failed
Aug 20 14:18:16 rotip309 kernel: amdgpu: cp is busy, skip halt cp
Aug 20 14:18:16 rotip309 kernel: amdgpu: rlc is busy, skip halt rlc
Aug 20 14:18:16 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: BACO reset
Aug 20 14:18:17 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset succeeded, trying to resume
Aug 20 14:18:17 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.1 test failed (-110)
Aug 20 14:18:17 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.4 test failed (-110)
Aug 20 14:18:18 rotip309 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.0.6 test failed (-110)
Aug 20 14:18:18 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: recover vram bo from shadow start
Aug 20 14:18:18 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: recover vram bo from shadow done
Aug 20 14:18:18 rotip309 kernel: amdgpu 0000:01:00.0: amdgpu: GPU reset(2) succeeded!
Aug 20 14:18:18 rotip309 kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
#15 0x000071fd82352529 n/a (amdgpu_drv.so + 0x18529)
#16 0x000071fd8234db31 n/a (amdgpu_drv.so + 0x13b31)
